VW Caddy MK60 Long Coding Deleted
m3nt4l
C?ID=348982
VW Caddy MK60EC1 Long Coding Deleted
Good Morning,
I have a VW CAddy 2013 and the Long Coding has been deleted from the module.
Is anyone able to provide me with the correct coding?
Sunday,02,June,2019,09:26:29:08713
VCDS Version: 19.6.0.2  HEX-NET CB: 0.4505.4
VIN: WV1ZZZ2KZDX101147   License Plate: FY13 AHK
Mileage: 94870km-58949mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZDX101147   Mileage: 94870km-58949miles
Address 01: Engine (J623-CAYE)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PA    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 4258
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114010030500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PA 003006
   ROD: EV_ECM16TDI02103L906023PA.rod
   VCID: 74A422F7DF9926EF85-8020
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Shop #: WSC 35110 377 00145
   VCID: 7CB40AD7FFC96EAFCD-8028
                    Reset counter: 77
                    Date: 2013.10.23
                    Time: 01:03:24
                    Count: 7
                    Count: 2
                    Count: 20992
                    Count: 195
                    Count: 42496
                    Reset counter: 80
                    Mileage: 94833 km
                    Date: 2013.10.23
                    Time: 01:01:58
                    Count: 3
                    Count: 2
                    Count: 20992
                    Count: 320
                    Count: 42496
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 0068
   Revision: BB021001
   Coding: 411A583A8025182A088000829000006403017288524F0160648000000040
   VCID: 42C8B42FDDADD85FC7-8016
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 29011  26  0512
   Coding: 009795
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag02A H07 0013
   Revision: --------    Serial number: 003HL00G1FPC
   Coding: 000000000000000000000000000000003241
   VCID: 3522DFF394637FE772-8060
   Part No SW: 5K0 953 507 AR    HW: 5K0 953 549 C
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90422MAV0003B
   Coding: 1080060000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 004C7E279B210A4F91-8054
   Part No SW: 2K0 920 965 G    HW: 2K0 920 965 G
   Component: KOMBI         H06 0705
   Coding: 480001
   VCID: 3326E1EB9A1761D75C-8066
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 080213F1001884
   Coding: 357401
   VCID: 74A422F7D79926EF85-8020
   Component: IMMO          H06 0705
   VCID: 6A983C8F8D5DE01F2F-803E
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 03 0174
   Coding: 0000000
   VCID: 76A018FF01E534FFBB-8022
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 140    3305
   Revision: 00H22000
   VCID: 373ED5FB466F8DF760-8062
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75A21FF31CE33FE7B2-8020
   Part No SW: 5K0 035 156 A    HW: 5K0 035 156 A
   Component: Radio         553 0555
   Revision: R0553007    Serial number: VWZ5Z1N0816178
   Coding: 0500020001
   VCID: 25020FB32CC30F67C2-8070
End----------(Elapsed Time: 01:01, VBatt start/end: 14.0V/14.0V)-----------
Address 03,1K0 907 379 BK,recoded (Long Coding),from,00000000000000000000000000000000000000,to,433C200D092A0303C21204E49022C081300000,(35110/377/00145),
                Address 01: Engine
Control Module Part Number: 03L 906 023 PA
  Component and/or Version: 1,6l R4 CR td H43 4258
           Software Coding: 00114010030500080000
            Work Shop Code: WSC 35110
Advanced Identification/FAZIT
     Identification: SJ8-FST
     Revision: --H43---
     Date: 06.02.13
     Manufacturer number: 0014
     Test stand number: 0476
Flash Status
     Programming Attempts(application): 0/0/0
     Successful Attempts(application): 0/0/0
     Programming Status: 00000000
     Flash Date: 00.00.00
Misc.
     Hardware number: 03L 907 425 C
     Workshop System Name: J623
     ASAM Dataset Revision: 003006
Car Info
     Chassis Number: WV1ZZZ2KZDX101147
     Engine code: CAYE
VCDS Info:
       Labels: 03L-906-023-CAY.clb
       Readiness: No script available
                Address 25: Immobilizer
Control Module Part Number: 5K0 953 234
  Component and/or Version: IMMO          H06 0705
           Software Coding: 000000
            Work Shop Code: WSC 00000
     Identification: VDD-024
     Date: 11.02.13
     Manufacturer number: 1901
     Test stand number: 0123
Flash Status
Software
     OSEK-OS: 03.14.00
     HiSpd Net: 01.12.01
Misc.
     Hardware number: 5K0 953 234
     Workshop System Name: J334
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A03709
Car Info
Immobilizer
     Transponder ID (Current val.): B0A69B0F
     Transponder ID 1: B0A69B0F
     Transponder ID 2: B0A4B470
     Transponder ID 3: 04D3E529
VCDS Info:
       Labels: 5K0-920-xxx-25.clb
Please tell us how the coding got wiped. What parts have been changed, or what work was done to this vehicle that caused it?
Please post Advanced ID data from 01-Engine and 25-Immobilizer.
m3nt4l
C?ID=348982
advanced ID's should be at the bottom of the autoscan.
The instrument cluster was disconnected and connected again causing the loss of the abs coding. Really weird!
golfi_vend
Tartu, Estonia
C?ID=195131
Please try:
433C200D092203FBC20C04E89020C081A00000
