Results 1 to 5 of 5
Thread: Golf MK6 no high beam
    May 2019
    Norway
    Hi
    I have an 2010 vw golf, my high beam suddenly stopped working.
    When i pull the lever the high beam turns on.
    My front and rear fog lights altso stopped working.
    Checked fuses
    new lightswitch
    Tried to change the BCM
    Tried a known working steering module.
    Tried an known working lever
    Checked wiring.
    I can activate the lights with vcds, but will not work with the swith
    Have anybody had an simmular problem
    If you post a full unedited VCDS Auto-Scan we will be able to see what fault codes are present, which will help suggest possible solutions.
  3. Likes Uwe liked this post
    May 2019
    Norway
    ho
    here is the scan
    Monday,03,June,2019,07:32:31:11492
    VIN: WVWZZZ1KZAM650622   License Plate:
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
    VIN: WVWZZZ1KZAM650622   Mileage: 170700km-106068miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 DQ    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 5915
       Coding: 00114036032401080000
       Shop #: WSC 00066 000 00087
       ASAM Dataset: EV_ECM16TDI02103L906023DQ 001007
       ROD: EV_ECM16TDI_001_VW36.rod
       VCID: 78A9E9AA52518587A6D-802C
    9867 - Coolant Pump 2
              P261A 00 [037] - Open circuit
                        Mileage: 170705 km
                        Date: 2019.06.03
                        Time: 16:30:25
                        Coolant temperature: 17 °C
                        Intake air temperature: 17 °C
                        Voltage terminal 30: 11.407 V
                        Environmental conditions-TCO_2_MES: 16 °C
                        Environmental conditions-Battery voltage: 11.4 V
    Readiness: 1010 0000
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       Coding: 113B200D092700FA881104E6901B0051350000
       VCID: 7AADF3A26CDD9797D09-802E
                        Fault Status: 00101100
                        Reset counter: 18
                        Mileage: 170705 km
                        Date: 2013.10.20
                        Time: 05:54:01
                        Count: 29184
                        Count: 105
                        Count: 42752
                        Count: 256
                        Count: 254
       Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
       Revision: 00003001
       Coding: 0000000003
       Shop #: WSC 00066 000 00193
       VCID: 7EA5FFB27075BBB7EC1-802A
              U1111 00 [008] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.22
                        Time: 03:05:18
    13701392 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Bremsensteuergerät - kein Signal/Kommunikation]
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.22
                        Time: 03:05:19
    13701936 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.28
                        Time: 23:24:22
    9481748 - High Pressure Sensor
              B10AE 14 [008] - Open or Short to Ground
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.22
                        Time: 03:05:17
       Part No SW: 5K0 937 086 C    HW: 5K0 937 086 C
       Component: BCM PQ35 M    011 0028
       Revision: BC011001
       Coding: 00180E3A982D02C040080080540081E403710088637D856264C007000001
       Shop #: WSC 00920 218 178581
       VCID: 34311D9A0E39A1E74A5-8060
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 19120  21  0512
       Coding: 009795
       Component: RLS 101209 05  54  0402
       Coding: 0330AD
       Part No SW: 1K9 919 475     HW: 1K9 919 475
       Component: PARKHILFE 8K  H07 0001
       Revision: --------    Serial number: 90340923400152
       Coding: 100002
       VCID: 78A9E9AA52D18587A6D-802C
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRA150LG
       Coding: 00003137
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B2336A623E76E9F8BF-806E
       Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME0B0D534DZZZ%
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME3007534DZZZT
       Serial number: 3511HSME6C1B121EZZZT
       Serial number: 3521HSME081D121EZZZM
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Coding: 0000532
       VCID: 78A9E9AA5ED18587A6D-802C
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
       Part No SW: 5K0 920 870 G    HW: 5K0 920 870 G
       Component: KOMBI         H03 0305
       Coding: 170F00
       Shop #: WSC 00066 000 00148
       VCID: 313F148EF1AB94CF213-8064
    12718592 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.28
                        Time: 00:08:44
       Part No SW: 1K0 907 530 AF    HW: 1K0 907 951
       Component: J533  Gateway   H17 0231
       Revision:   H17       Serial number: 1321J09B060369
       Coding: E9A07F06000202042002
       VCID: 6B83C6E61F873E1F5BF-803E
       Component: IMMO          H03 0305
       VCID: 6A8DC3E21CFD2717209-803E
       Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
       Component: TUER-SG FT    002 0307
       Revision: 12101005    Serial number: 0000167773
       Coding: 0210B6
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: 2809F9EAC271D507F6D-807C
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000004567149
       Coding: 000090
    67592 - Entry Lamp in Exterior Mirror
              B11F9 01 [009] - Electrical Failure
                        Fault Frequency: 28
                        Reset counter: 18
                        Mileage: 170705 km
                        Date: 2019.05.26
                        Time: 02:09:32
    68107 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN AirBag]
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.22
                        Time: 03:05:13
    68108 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN MSG]
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.22
                        Time: 03:05:18
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: 313F148EFD2B94CF213-8064
       Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
       Component: TUER-SG BT    002 0307
       Revision: 14101005    Serial number: 0000180827
       Coding: 0211B6
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW36.rod
       VCID: 290FFCEED97BEC0FE93-807C
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000004483500
       Coding: 000090
              U1111 00 [008] - -
              [Front CAN AirBag]
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.22
                        Time: 03:05:13
              U1111 00 [008] - -
              [Front CAN MSG]
                        Reset counter: 58
                        Mileage: 170705 km
                        Date: 2019.05.22
                        Time: 03:05:18
       Part No SW: 1K0 035 186 AB    HW: 1K0 035 186 AB
       Component: Radio RCD310  013 0036
       Revision: 00000000    Serial number: VWZ1Z2I6556918
       Coding: 0500040004
       VCID: 6695B7D208650377041-8032
       Part No SW: 1K0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H17 0231
       Revision: --------    Serial number: 1321J09B060369
       Coding: 030B085A
       VCID: 6889B9EA0271150736D-803C
       Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790745272
    End----(Elapsed Time: 01:13, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
    May 2019
    Norway
    Anybody, any idea?
    Jul 2014
    Tallinn, Estonia
    For the high beams not working, you can try to check whether module 16 registers the forward (towards the dash) push of the stalk by checking the measuring blocks for lever actuation. If the actuation is registered, then perhaps there is something wrong with the BCM as other exterior lights are also affected.
  7. Likes Uwe liked this post
