Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 2014 Caddy Van (Highline) retrofit MFSW
    United States
    Thanks guys. Since this 8X0 module is clearly functional in a VW I'll update the 8X0-953-569.clb file so it includes options only found in 5K0-953-569.clb at this time.
  2. Likes Uwe liked this post
  3. #12
    Tartu, Estonia
    Please also add cruise via mfsw and acc via mfsw to 5k0-953-569.clb label file.
    The world is my oyster...
  4. Likes Dana liked this post
  5. #13
    United States
    Hi Magnus,
    Now that you mention it, I left this line commented out (meaning it won't show in the lbl based LCH) of 8X0-953-569:
    ;LC,02,4~7,80,Cruise Control controlled via Adaptive Cruise Control (ACC)
    If you are confident that this 8X0 series module supports that coding config I'll add it!
    Next, 5K0-953-569.lbl also has that ACC config commented out so I can edit that file as well if you believe that's best. Edit, 5K0-953-569 looks like this now:
    https://photos.app.goo.gl/mYtfePydSuDZHMsYA
  6. Likes Uwe liked this post
  7. #14
    Tartu, Estonia
    I'm not aware of byte 80 being used for ACC, but if this is so, then okay. Is there any scans where this can be observed?
    But there are some things I want to discuss. Like the 3c0-953-569.clb and then 5k0-953-569.clb. I get that the label file is chosen per Software Part number, but there is plausibility error. All 3c0 SW controllers are HW 5k0.... . This SW 3c0... is then superseeded to separate details like stalks and SWCM. If we replace SWCM alone, it always superseedes to such where SW and HW are identical.
    Example:
       Part No SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
       Revision: --X01---    Serial number: 20151016301545
       Coding: 299AA50001
       Shop #: WSC 01286 386 08256
       VCID: 895ACFDD2895C90201-80DC
       Serial number: 50000000000000492358
       Coding: E30000
    This is from a 2013 RoW Passat B7. It had previously 3c0... SWCM. As You can see, 5k0... label file is chosen.
    Now then there is the same HW, but factory SWCM.
       Part No SW: 3C9 953 501 CN    HW: 5K0 953 569 AS
       Revision: FF010042    Serial number: 20131203100144
       Coding: 399AA50001
       Shop #: WSC 00015 115 00001
       VCID: 77BEE0E3CE9852F0FA-8022
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0032
       Serial number: 0017284
       Coding: 830000
    Here is 3c0 label file chosen.
    Wouldn't be big deal, but 5K0 doesn't have the info about ACC via stalk:
    LC,02,4~7,A0,Cruise Control controlled with Adaptive Cruise Control (ACC).
    For 5k0 label file I also have a suggestion:
    LC,02,4~7,C0,Cruise Control controlled via Multi-Function-Steering-Wheel (MFSW) with ACC
    This can be seen here, it's a 2018 Caddy with Adaptive Cruise Control.
       Part No SW: 5K0 953 521 GE    HW: 5K0 953 569 BF
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20180528200168
       Coding: 1082C60008
       Shop #: WSC 35110 790 50316
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 75A2EAEBD49420E7B2-8020
       Subsystem 1 - Part No SW: 2K0 959 442 A    HW: 2K0 959 442 A  Labels: 3C8-959-537.CLB
       Serial number: 1341821014401916BC1B
       Coding: 2C0000
    I have full scans from all mentioned cars if needed to confirm.
  8. Likes Uwe, kamold, rhinopower, Dana liked this post
  9. #15
    Nov 2016
    I'm with golfi_vend on this. When i retrofitted the golf 7 style wheel on my passat, half the options were missing on the label file 3c0-953-569.clb when the hardware is 5k0. I resorted to using a custom label file so i could actually code the module correctly, in a manner it supported
  10. Likes golfi_vend, Dana, Uwe liked this post
  11. #16
    United States
    Thanks for the feedback. I don't believe the new label files will make it to the next VCDS version but we should have all 3 updated early next week.
    Edit. I wanted to report back.
    1) After further research I could not locate an example of ;LC,02,4~7,80,Cruise Control controlled via Adaptive Cruise Control (ACC). Because I added it due to this thread, but believe it is incorrect, I removed it (; commented it out) from the 5K0-953-569 label. That is included in the ROD file Experimental coding chart so it isn't entirely hidden from all users and we may find a use for it one day.
    2) I added both of these to 5K0-953-569, 8X0-953-569 and 3C0-953-569:
    LC,02,4~7,A0,Cruise Control controlled via Adaptive Cruise Control (ACC)
    That may not be necessary for 8X0-953-569 but I made all 3 the same in this area. If we receive reports that one or both of those selections aren't supported with an 8X0 module we can simply remove them in the future.
    3) I added the following to 3C0-953-569:
    LC,04,3,Multi-Function-Steering-Wheel (MFSW) for MQB-Platform installed
    That should cover rhinopower's MK7 style wheel with 3C0 module moving forward.
  12. Likes Uwe liked this post
