Results 1 to 10 of 16
Thread: 2014 Caddy Van (Highline) retrofit MFSW
    Jan 2016
    Question 2014 Caddy Van (Highline) retrofit MFSW
    Before fitting MFSW
    Wednesday,15,May,2019,11:13:35:59107
    VCDS Version: 18.9.1.0 (x64)
    Dealer/Shop Name: B Ross
    Workshop Code: 123 12345 000000
    VIN: WV1ZZZ2KZFX029472   License Plate: SL64NVR
    Mileage: 150050km-93236mi   Repair Order: may 2019
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 77
    VIN: WV1ZZZ2KZFX029472   Mileage: 150050km-93236miles
    Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 TF    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9979
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00114014032500080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM16TDI02103L906023TF 003003
       ROD: EV_ECM16TDI02103L997557M.rod
       VCID: 7DF79E27EC178DA2B6-8028
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: 433C400D09240303C20F02EB901BC081A0000020
       Shop #: WSC 35110 377 08192
       VCID: 7EF5992BE91196BAAF-802A
       Part No SW: 7N0 907 426 BT    HW: 7N0 907 426 BT
       Component: AC Manuell    H20 0607
       Revision: 00001004
       Coding: 0010004002
       ROD: EV_ACManueBHBVW36X_VW32.rod
       VCID: 071BFCCFBECBD7729C-8052
       Part No SW: 5K0 937 086 S    HW: 5K0 937 086 S
       Component: BCM PQ35 M+   122 0174
       Revision: BD122001
       Coding: 491A583E8025F16A088800829000016403017288524F8160648000000040
       VCID: 44812BC3C77D3C6AB9-8010
       Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 12060  21  0501
       Coding: 009795
       Subsystem 2 - Part No: 7N0 951 171 A
       Component: DWA-Sensor 00  002 0206
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 2K0 919 475     HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0004
       Revision: --------    Serial number: 32901419102259
       Coding: 108001
       ASAM Dataset: EV_EPHVA14VN3370000 001006
       ROD: EV_EPHVA14VN3370000.rod
       VCID: 70E9B713AB45F0CA2D-8024
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag02Q H07 0013
       Revision: --------    Serial number: 003HL00RT0DO
       Coding: 000000000000000000000000000000003251
       VCID: 3567460794A795E23E-8060
       Part No SW: 5K0 953 521 DN    HW: 5K0 953 569 AF
       Revision: FF010042    Serial number: 20140704201109
       Coding: 5080160000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7BF3903FF203839288-802E
       Part No SW: 2K0 920 976 E    HW: 2K0 920 976 E
       Component: KOMBI         H03 0905
       Coding: 480800
       VCID: 3363781F9AD38BD210-8066
       Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1653
       Revision:   H57       Serial number: 140714F1001608
       Coding: 357401
       Component: IMMO          H03 0905
       VCID: 6ADDA57B8D990A1A63-803E
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2110
       Coding: 0000560
       VCID: 48993FF33B55180A55-801C
    00912 - Window Regulator Switch; Front Left (E40)
    00913 - Window Regulator Switch; Front Right Driver (E81)
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 397F4A3770BF7182DA-806C
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000560
       VCID: 479B3CCF364B17725C-8012
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: RCD310 EU     H05 5006
       Revision: -----09S    Serial number: VWZ4Z2P1279677
       Coding: 05000200010013
       VCID: 72EDBD1BAD49C2DADB-8026
    00856 - Radio Antenna
                        Fault Status: 00100111
                        Reset counter: 224
       Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
       Component: TELEFON       H16 4217
       Revision: 1B001001    Serial number: 00007666462728
       Coding: 0A01010000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3C715323B78D44AAC1-8068
    End-------------------------(Elapsed Time: 02:41)--------------------------
    Address 42: DTCs cleared
    Address 56: DTCs cleared
       Revision: 00H46001
       Revision: 00001004
       Coding: 0010004002
       Revision: BD122001
       Coding: 009795
       Coding: 108001
       Coding: 5080160000
       Coding: 480800
       Coding: 357401
       Coding: 0000560
       Revision: 00H22000
       Coding: 0000560
    After fitting MFSW
    Friday,31,May,2019,15:12:10:59107
    VIN: WV1ZZZ2KZFX029472   License Plate: SL64NVL
    Mileage: 150400km-93454mi   Repair Order:
    VIN: WV1ZZZ2KZFX029472   Mileage: 150400km-93454miles
       Revision: 00H46001
       Revision: 00001004
       Coding: 0010004002
       Revision: BD122001
       Coding: 009795
       Coding: 108001
       Coding: 5080160000
    227355 - Windshield Wiper/Washer Switch
              B1149 13 [009] - Open Circuit
                        Fault Frequency: 6
                        Reset counter: 235
                        Mileage: 150407 km
                        Date: 2019.05.31
                        Time: 00:00:00
       Coding: 180800
       Shop #: WSC 12345 123 00000
       Coding: 357401
       Coding: 0000560
       Revision: 00H22000
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.0 V
                            PD
                        Temperature: 18.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
       Coding: 0000560
                        Reset counter: 16
    When I try to code the MFSW it tells me error 31
    Original coding =5080160000
    attempted new code 108A160000
    any ideas? I am assuming the slip ring module should be correct as it is a highline van?
    Bruceabz
  2. Likes Dana liked this post
  3. #2
    United States
    I know this thread is a week old, and you may have sorted this, but I don't think that HW# 5K0-953-569-AF module is going to support the MFSW:
    http://wiki.ross-tech.com/wiki/index...er_5K0-953-569
    I wish I had better news and thanks for posting all of the scans!
    Jan 2016
    Hi Dana, Thanks for the reply, I checked further into the slip ring and sure enough I does not support a MFSW ! Best get on eBay and get one that does.
    Cheers
    Bruceabz
  5. Likes Dana liked this post
    Jan 2016
    Hi Dana, i have fitted a replacement steering wheel module, but i am still having issues getting it to work. It now accepts coding for the MFSW, but the MFSW buttons won't work. See attached scan. any ideas welcome!
    Tuesday,18,June,2019,20:06:59:59107
    Mileage: 152590km-94815mi   Repair Order:
    VIN: WV1ZZZ2KZFX029472   Mileage: 152590km-94815miles
    6082 - Steering Column Control Module
              U0212 00 [036] - No Communications
                        Mileage: 152591 km
                        Date: 2019.06.18
                        Time: 19:48:09
                        Coolant temperature: 42 C
                        Intake air temperature: 22 C
                        Voltage terminal 30: 11.633 V
                        Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                        Control Module temperature-TECU: 38 C
    6118 - Cruise Control Switch (E45)
              P0568 00 [037] - Implausible Signal
                        Mileage: 152591 km
                        Date: 2019.06.18
                        Time: 19:47:00
                        Accelerator position: normalized-Accelerator position: 0.00 %
                        Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 10000010
       Revision: 00H46001
       Revision: 00001004
       Coding: 0010004002
       Revision: BD122001
       Coding: 009795
                000 -  -
                        Reset counter: 1
                        Mileage: 152591 km
                        Date: 2019.06.18
                        Time: 19:38:33
                            Term 15 On
                        Voltage: 11.90 V
       Coding: 108001
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 AE    HW: 5K0 953 569 BD
       Component: LENKS.MODUL   018 0230
       Revision: FF010018    Serial number: 20151021200770
       Coding: 1084204000
       ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 7F0B642FE61B9FB2A4-802A
       Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H09 0013
       Serial number: 0042747
       Coding: 820000
    229127 - Cruise Control Switch
              B1154 11 [009] - Short to Ground
                        Reset counter: 1
                        Mileage: 152591 km
                        Date: 2019.06.18
                        Time: 20:02:41
       Coding: 180800
       Coding: 357401
       Coding: 0000560
       Revision: 00H22000
                000 -  -  - MIL ON
                        Battery Volts: 11.9 V
                            PD
                        Temperature: 21.0C
                        Count: 2
                        Count: 1
                            SteerAng n.Init
       Coding: 0000560
    United States
    Hi Bruceabz,
    Although the MFSW slave is communicating - I'm concerned that 8X0 (Audi) #16 module isn't compatible with the LIN MFSW itself. You may want to try coding it to: 5082160000
    Based on the parts catalog your factory 5K0 953 569 AF module supers to 5K0 953 569 AL which is a Highline. If the installed module won't accept the factory coding of 5080160000 or 5082160000 it may be worth giving that part number a shot.
    P.S. I know we had a similar thread in forum with a replacement 8X0 SW module and VW compatibility issues so I'll report back it I can locate that one.
    Jan 2016
    Hi Dana, thanks for the info. I am away from home for a couple of days but will give the coding a try. Failing that it's back on Ebay for the correct part
    Cheers bruceabz
    Tartu, Estonia
    Per my experience it is OK to use 8X0 SWCM, but 8X0 label file doesn't have needed descriptions to code to work with VW MFSW.
    I do believe correct coding would be: 108A160000
    PS! I do think that 3c0-953-569, 5k0-953-569 and 8x0-953-569 labels files can be integrated to 1 label file.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  10. Likes Dana liked this post
  11. #8
    United States
    Thanks Magnus. I see what you mean: https://photos.app.goo.gl/TrY2f5pUvHbTeMCg9
    I'll subscribe to this thread and if the OP is successful we can update that 8X0 lbl.
  12. Likes Uwe liked this post
  13. #9
    Jan 2016
    I have the MFSW working with coding 1082260000. The only issue left is the cruise control. The CC is on the wiper stalk, but the long coding drop down doesn't give me that option. The only options are 1st no CC or 2nd CC on a separate stalk.
  14. Likes Dana liked this post
  15. #10
    Jun 2017
    CC in wiper stalk is coding 1082160000
    The experimental labels of unit 16 do clarify a lot
  16. Likes Uwe, Dana liked this post
