Results 1 to 10 of 10
Thread: AUDI TT 8N 2001 (non bose) - TELEPHONE
    Feb 2018
    GR
    Hi
    I have an Audi TT 8N (non Bose) but with handsfree preparation, not the bluetooth one but the wired one.. (yeah that one with the old cradle for Nokia/Motorola etc....).
    The problem is that every time i just connect the Nokia phone (without being on a call) , radio mutes and not responding when i press buttons etc and i cannot even a call no sound.... and i only see "TELEFON" on headunit and DIS on clusters.
    I think it should work as follows... keep it connected and when receives a call, then mutes the radio and hear from speakers (which one should it be i don't know..)
    I also notice that on coding there is not reference regarding Telephone setting apart from Bose system which i don't have :/
    Any help please?
    http://wiki.ross-tech.com/wiki/index...ation_I#Coding
    HQ
    Jef
  3. Likes Boki Ar liked this post
    Feb 2018
    GR
    Wednesday,27,March,2019,00:11:36:60191
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
    VCDS Version 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
    VIN: TRUZZZ8NZ11045966   License Plate: EYA9900
    Mileage: 181540km-112803mi   Repair Order:
    Chassis Type: 8N (8N - Audi TT (1999 > 2007))
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    VIN: TRUZZZ8NZ11045966   Mileage: 181540km-112803miles
    Address 01: Engine        Labels: 06A-906-032-BAM.lbl
       Part No: 8N0 906 018 H
       Component: 1.8L R4/5VT     G   0004
       Coding: 10710
       VCID: 3635DB65F159CC47741-513D
       TRUZZZ8NZ11045966     AUZ5Z0A4212029
    Readiness: 0110 0101
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
       Part No: 8N0 907 379 E
       Component: ESP     20    CAN  V005
       Coding: 18446
       Shop #: WSC 01236
       VCID: 3E25C345D9690407AC1-4B01
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043 A
       Component: TT-KLIMAVOLLAUTOMAT D03
       Coding: 00040
       Shop #: WSC 01236
       VCID: 2809051D2BEDAAB7F6D-2581
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 2008
       Coding: 10102
       Shop #: WSC 01236
       VCID: 77AB1661B6D3F54FAF7-513D
    Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
       Part No: 8N1 920 880 H
       Component: KOMBI+WEGFAHRS. M73 D56
       Coding: 05044
       Shop #: WSC 01020
       VCID: 3A2DCF55C5412827909-4B01
                49-00 - No Communications
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 B
       Component: HALDEX LSC  ECC     0006
       VCID: 1F1B1EC17EA36D0F877-4B01
    No Faults Found
    Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
       Part No: 8N8 962 267
       Component: Zentralverrieg.,DWA D05
       Coding: 06730
       Shop #: WSC 01236
       VCID: 7EA5034599E9C407EC1-4F0D
       Part No: 8N8 951 177 A
       Component: Innenraumueberw.    D09
       Coding: 00001
       VCID: 3D27C449D46F1F1FB5B-5119
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00010
       Shop #: WSC 01236
       VCID: 65974C291C7F77DF0DB-5161
    01539 - Headlights Not Adjusted
                35-00 -  -
                35-00 -  -
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 186 D
       Component:  Radio             0001
       Coding: 00007
       Shop #: WSC 00040
       VCID: 211F183948D75BFFB13-4B01
    End----------(Elapsed Time: 02:44, VBatt start/end: 13.3V/13.1V)-----------
  5. Likes Boki Ar liked this post
    Feb 2018
    GR
    any help please?
    Those old radios are a POS, the buttons wear cosmetically and mechanically/electronically and replacements with new BT settings are far better with nice filters & advisable ultimately because cheaper!
    Clean install like this and folding mechanism.
    https://www.youtube.com/watch?v=973ZdEWPkrg
    Feb 2018
    GR
    i think i would not be able to press the alert button if something urgent
    i've thought about this solution but not my cup of tea, thank you vm
    HQ
    With the radio, MVB group 004.4 shows the telephone mute status. My guess is the phone cradle is messed up and when you dock a phone, to goes to mute when it shouldn't.
    <Toggle Jack mode = ON>
    <Toggle Jack mode = OFF>
    I suspect Jack is on the right path in that you have a hardware failure.
    Jef
  10. Likes PetrolDave liked this post
  11. #8
    Yeah me too until the RNS and OEM radios just became too much trouble for cost when seeing the bling bling for peanuts + additional functions, I had to see if it was bullshit!
    I installed a 7 inch touch screen with WIFI & NAV + BT + DVD player I never watch other than to see that it worked when I installed it about a year ago and even the other day I smiled when my wiper fluid was deliberately used up because I wanted to install fresh when I got home and the dam info screen popped up with a diagnostic screen telling me I had an MMI I didn't even realize now in an ALH Jetta.
    .....no drilling holes and SAT + antenna read right inside dash & multi-function on CAN talks to everything.
    I would say it shouldn't be dismissed!
  12. #9
    Feb 2018
    GR
    Thanks.
    Sorry, confused, does the MVB group 004.4 show the telephone mute status or the intake air temperature?
  13. #10
    Quote Originally Posted by napostolidis View Post
    Thanks.
    You need to select the radio (address 56) and then look at MVB 004.4
  14. Likes Uwe, Jack@European_Parts liked this post
