Electronic Steering Column Lock Passat replace
FARADAY
Poland
C?ID=224237
Can I Replace Electronic Steering Column Lock using VCDS?
golfi_vend
Tartu, Estonia
C?ID=195131
If you have SKC for your car.
/BTW Uwe, could SKC added to acronyms?/
Keithuk
Stoke on Trent, England
C?ID=122432
If VCDS could access the Secret Key Code (SKC) it would double in value.
golfi_vend
Tartu, Estonia
C?ID=195131
It would be good, but i imagine the legal difficulties and also technical. The SKC must be extracted from somewhere, then there is this encryption thing that i guess is a property of some company(VW SIEMENS VDO BOSCH). Then the thing of where the skc could come, ECU or Cluster. Or even from KESSY module?
I think its just too much of work and easier would be buying such tools or, buying service.
Spacewalker
Poland
C?ID=159607
VCDS can access security code always, but not always controler accept it due to limit access
I wasn't picking on your spelling. I generally don't do that, especially when I know someone isn't a native English speaker. I think what you mean is "VCDS can USE the SKC" rather than ACCESS it.
Dana
Western PA, USA
FARADAY,
You would need the PIN / SKC but what type of vehicle are you looking to replace the ESCL on? For instance, if this is a VW Crafter or 3C Passat / CC we have a procedure to offer you .. providing you can get the PIN extracted.
Spacewalker
Poland
C?ID=159607
From my point of view VCDS can:
USE SKC
ACCESS SKC
but can not
RETRIEVE it from memory
this is what I was mean
I suppose in my mind (and I suspect in the mind of most more native English speakers) the meaning of the word "access" is closer to "retrieve" than to "use", at least in this context.
Note: I could be wrong. English is not my FIRST language either, however, it has been my primary language for more than 40 years now. ;-)
FARADAY
Poland
C?ID=224237
This is 3C Passat, dealer offer new ESCL but they say need to replace ESL too. I can retrieve PIN/SKC.
Dana
Western PA, USA
