Results 1 to 9 of 9
Thread: GTI 2019 mk7.5 Facelift - "Starting Vibration Reduction" Channel in ABS (I Cant find)
    May 2019
    Porto Alegre, RS, Brazil
    Hey guys,
    Has anyone found a way do disable the "Starting Vibration Reduction" function and torque limitation in 2018+ GTI's?
    I can't find the channel, was wondering if there is a different channel name in the facelift one's.
    It's so annoying the way it holds the car performance when launching it.
    Thank you
    May 2014
    Rodrigoe: first post and first question - I'm honored to be your first responder!!
    There's a kind-of rule on this forum that I suspect stretches back to the primordial time when the concept of VCDS was nothing more than an itch in Uwe's intellect. Anyhow, the protocol (I'm sure that it's written down somewhere) asks that new questions be accompanied by posting an auto-scan of the car . It's a pretty-good rule really because it tells those who may be interested in replying what equipment is in the car (not everyone here is intimately aware of how a MY19 GTI is built for the market in Porto Alegre, RS). Give it a go - I'm sure that it will help illicit an avalanche of responses.
    PS: and if you want to be particularly helpful given the topic of your question - it would also be helpful if you posted-up a copy of the adaptation map for the ABS module @ address hex03
  3. Likes Uwe liked this post
    May 2019
    Hey Don,
    I really appreciate your kind words and instructions. Surely i will follow them from now on.
    Let me share with you and everybody else the Auto-Scan and a couple o images from the ABS adaptation map (sorry, I couldn't download a txt. or xls.):
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 20 29 2B 39 42 44 4B 52 5F
              A9 D6 D7
    VIN: 9BWAV7AU0K4000078   Mileage: 7583km-4711miles
    Address 01: Engine (J623-CXDB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 P    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 091D00322464012B1000
       Shop #: WSC 01530 935 00200
       ASAM Dataset: EV_ECM20TFS0205G0906259P 001001
       ROD: EV_ECM20TFS0205G0906259P.rod
       VCID: 3B233698B3ECCC0F8BF-806E
    Readiness: 0010 0001
       Part No SW: 0D9 300 043 F    HW: 02E 927 770 AS
       Component: DQ250-6F MQB  H54 5204
       Revision: 06454104    Serial number: TFK01807300004
       ROD: EV_TCMDQ250021.rod
       VCID: 1D67D8000D38A23F95B-8048
       Part No SW: 5Q0 614 517 DH    HW: 5Q0 614 517 AH
       Component: ESC           H62 0754
       Revision: 00000000    Serial number: 51478000000244
       Coding: 01FA6BA13420216C40770607E0CB2980D62C84026007947636415070C006430B00000012121212B835351919323200
       VCID: 7AADF39CFC563507D09-802E
       Part No SW: 3Q0 959 435 J    HW: 3Q0 959 435 J
       Component: VWKESSYMQB    037 1104
       Revision: 00037000    Serial number: 0488150015
       Coding: 132C0C0723
       ASAM Dataset: EV_KessyHellaMQBAB 004043
       VCID: 41DF4470D100A6DFD13-8014
       Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
       Revision: 00001K08
       Coding: 0002001420010001100400400010140A
       VCID: 6C81C5C486029BB7525-8038
       Part No SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
       Revision: --------    Serial number: C8640808180477
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 0A4DA35CACB62587C09-805E
       Component: WWS    180902  043 0551
       Serial number:         180910212312
       Component: RLHS  037 0059
       Serial number: S3Y16M04D25H05M32S00
       Coding: 90A8DD
       Serial number: 000000000ZY173333491
       Serial number: 00000000000030501433
       Sun Roof:
       Component: J245 PS73.404  H04 0005
       Serial number: 0000FST00261H6W00000
       Coding: 181901
       Steering Column Switch:
       Subsystem 7 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0100280820180C302755
       Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0050
       Serial number: 000308417618205
       Coding: 0271161851
       ASAM Dataset: EV_EPHVA2CAU3700000 009041
       VCID: 51FF74300160565F413-8004
    13637426 - Databus
                        Reset counter: 168
                        Mileage: 7576 km
                        Date: 2019.05.24
                        Time: 16:45:03
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Coding: 3500678149FFC428949C810520300600000000000000000004
       VCID: 44D14D64CE12B3F7FA5-8010
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                        Reset counter: 168
                        Mileage: 7576 km
                        Date: 2019.05.24
                        Time: 16:45:03
                        Control Module temperature: 44 °C
                        Voltage terminal 15: 12.1 V
    0928 - Databus
              [FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
                        Reset counter: 168
                        Mileage: 7576 km
                        Date: 2019.05.24
                        Time: 16:45:03
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 168
                        Mileage: 7576 km
                        Date: 2019.05.24
                        Time: 16:45:03
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Component: AirbagVW21    006 0336
       Serial number: 003VWM068KJC
       Coding: 98CCC000000000005C0000CF000800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 094F9C50A9B02E9FC93-805C
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34169667E04071820871
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34169668E18061830049
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 207 18
       Serial number: 357000000006A0C01135
       Subsystem 4 - Part No SW: -----------    HW: 480 000 607 18
       Serial number: 35800000000E79D8503W
       Subsystem 5 - Part No SW: -----------    HW: 480 402 208 18
       Component: SideSensor_Dr  004 6149
       Serial number: 3510001022B7DB95A5CB
       Subsystem 6 - Part No SW: -----------    HW: 480 402 208 18
       Component: SideSensor_Pr  004 6149
       Serial number: 35200012E2B78F63D6CO
       Subsystem 7 - Part No SW: -----------    HW: 480 400 208 18
       Component: FrontSensor_D  003 6149
       Serial number: 3550001AB29FD1540457
       Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
       Component: KOMBI         403 4191
       Coding: 07AD11182D80000801887F011001000080000000
       VCID: 2B0306D8438C5C8F1BF-807E
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5344
       Serial number: 21081800841132
       Coding: 030100047F085900FB00027E1C0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       VCID: 3D273880ADF8C23FB5B-8068
       Component: 1-00-03-00-04
       Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0052
       Serial number: 29180002003480038353
       Coding: 2DFFFF
       Serial number: 6926396000
    Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
       Part No SW: 3G0 857 511 AR    HW: 3G0 857 511 AG
       Component: FLA           H10 0003
       Revision: AA001001
       Coding: 0404000000000000000000
       ASAM Dataset: EV_HighBeamAssisAU33X 001017
       ROD: EV_HighBeamAssisAU33X_VW37.rod
       VCID: 78A9E994C25A2717A6D-802C
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       VCID: 47CB5A68FF2498EF1F7-8012
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H07 0021
       Serial number: 18000236268005
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 313F14B061A0365F213-8064
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS001 0289
       Serial number: YE007RHM2687B
       Coding: 001F1220D000028000001000
       Subsystem 1 - Part No SW: 5Q4 959 811     HW: 5Q4 959 811
       Serial number: 00000000000007070700
       Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 871F0000
       ROD: EV_SteerAssisMQB_015.rod
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0342
       Serial number: 13071811601606
       Coding: 000000050900214A01100F01020000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002004
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 353720A095C81A7F7DB-8060
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS001 0289
       Serial number: YE007RGD1300A
       Coding: 001F1020DC00028000001000
       VCID: 43D34E78CB1CB4CFC3F-8016
       Subsystem 1 - Part No SW: 5Q4 959 812     HW: 5Q4 959 812
       Serial number: 00000000000006355901
       Coding: 090000
       Part No SW: 3Q0 035 864 C    HW: 3Q0 035 864 C
       Component: MU-S-N-ER     851 0867
       Coding: 02731003FF00000051220001001828001F0503F401200400C7
       ROD: EV_MUStd4CDELP_VW26.rod
       Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
       Component: ABT_Std-2_Nav  H52 8130
       Serial number: VWZ6ZHV1333430
       Subsystem 2 - Part No SW: 5NA 919 866 C    HW: -----------
       Component: MRM2 2018/19  --- 1010
       Part No SW: 5GB 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0002
       Serial number: 170429200679
       VCID: 7DA7F880ED78023FF5B-8028
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392F2C90B9D0FE1F993-806C
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    Thank you again,
    Rodrigo
    May 2014
    ^^^^ very nice indeed -thanks for the response (some time in the future, you should read about the channel map process)
    hmm..... assuming that the version of VCDS software is not ignoring the relevant channels (not likely the problem, but I have had this happen in the past) -it has to be an issue with SW version on your hex03 module. Here's the admap from the ABS module with the same HW number as on your car (which is: 5Q0 614 517 AH)
    ;SW:5Q0-614-517-CH   HW:5Q0-614-517-AH ---  ABS Brakes
    ;Component:ESC           H62 0743, Coding:12F18AA2242822708B800A00A0CA2948512444D1500594731821503482A8420000000012121212B835351919323200
    ;EV_Brake1UDSContiMK100IPB,036010,EV_Brake1UDSContiMK100IPB_036_AU37.rod
    ;Wednesday,15,August,2018,10:36:06:16808
    ;VCDS Version: Release 18.2.1 (x64)  Data version: 20180518 DS287.2
    ;VCID: 79BA288CF898FA8C63-802C
    IDE00001-Production mode,not active ,3
    IDE00252-Brake system vacuum pump,5 ,1
    IDE00820-Activating and deactivating all development messages,0 ,1
    IDE01763-Dimming,not activated ,1
    IDE02332-Deactivate production mode,Deactivating ,3
    IDE03493-Driver door status,activated ,1
    IDE03659-Roller test bench mode,Manual activation: possible ,1
    IDE04456-Brake disk drying,Medium ,1
    IDE04508-Hydraulic brake booster,8 ,1
    IDE04643-Overboost in brake system,activated ,1
    IDE04645-Electromechanical parking brake,not activated ,1
    IDE04774-Vehicle and trailer stabilization,not activated ,1
    IDE04871-Dynamic starting assist,normal ,1
    IDE04939-Tire pressure monitoring display,2 ,1
    IDE04944-Brake pedal evaluation,activated ,1
    IDE04949-Engine drag torque control,activated ,1
    IDE04951-Brake booster,4 ,1
    IDE04952-Braking torque boost for distance regulation,3 ,1
    IDE05055-Hydraulic brake assistant,normal ,1
    IDE05057-Brake prefill,activated ,1
    IDE05161-Straight ahead brake stabilization,activated ,1
    IDE05263-AUTO HOLD functionality,not activated ,1
    IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
    IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
    IDE05286-Expanded electronic differential lock,Standard ,1
    IDE05337-Starting vibration reduction-,normal ,1
    IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated ,1
    IDE05711-Automatic application during engine stalling,activated ,1
    IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
    IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
    IDE06139-AUTO HOLD slippage recognition,activated ,1
    IDE06505-Electromechanical parking brake: delay level,6 ,1
    IDE07006-Tire pressure monitoring display: tire selection,1 ,1
    IDE07292-Brake pre-filling,completed successfully ,1
    IDE07565-ABS in lower speed range,activated ,1
    IDE07848-Thresholds for brake performance,activated ,1
    IDE12030-Rough road optimization,activated ,1
    MAS00122-Electronic Stability Program,not activated ,1
    MAS00970-Running manufacturer number,activated ,1
    MAS01180-AUTO HOLD functional status,Last setting ,1
    MAS01299-Offroad,0 ,1
    MAS02080-XCP calibration protocol,not activated ,1
    MAS02138-Hill-start assistant,normal ,1
    MAS02666-Seat belt buckle scan,activated ,1
    MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
    MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
    MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
    MAS11606-Electromechanical parking brake: emergency braking,activated ,1
    ENG118148-Developer_Function_1,0 ,1
    ENG130301-Developer_Function_121,not activated ,1
    ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
    ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
    ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
    ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
    ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
    ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
    ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
    ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
    ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
    ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
    ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
    ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
    ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
    ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
    ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
    ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
    ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
    ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
    ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
    ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
    ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
    ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
    ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
    ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
    Elapsed Time: 00:16
    About half-way down the channel count in my admap - you will find these:
    • IDE05337-Starting vibration reduction > normal
    • IDE05337-MAS02653-Starting vibration reduction-Torque limitation > Deactivated
    These channels are missing on your pictures.
    But then your SW version is 5Q0 614 517 DH and my admap SW version is 5Q0-614-517-CH . Strange that the later SW has this removed - but it's entirely possible and it could be the result of different hardware in the brake system - I guess
    As a very, very long-shot and to confirm that there are no gremlins at play - I wonder how RT folk would feel about trying another VCDS software version (yes, it's an almost sacrilegious suggestion, but I like to live-on-the-edge!!)
    EDIT: the "mortal-sin" in my sacrilegious suggestion has been exposed as advised subsequently (below) - Mia culpa!! Alas all that awaits me now is an eternity in a very hot place - abandon hope all ye who enter (as Mr Dante said)
    Mar 2019
    This element appears to be removed from the MY19 cars. I've looked with 18.9, 19.4 and 19.6 and it's not magically appeared at any point. Others have noted it as well with "other" dongles on the market as missing as well.
  7. Likes Uwe, DV52, smh liked this post
    Jun 2019
    One more data point - On my 2019 Alltrack with SW 5Q0 614 517 DR I couldn't find this element either. I'd really like find where to control this element as I find starting this car from a stop is really annoying, having driven manuals for the last 40 years.
    But I also noticed on the 09 central electronics module several of the element names have been changed compared to previous MY scans. I didn't check for the element ID, however, so I can't say for certain that this is only a naming change rather than changing the parameter IDs altogether.
    May 2014
    ^^^ smh: Yes there was a couple of major changes made in later BCMs on MQB platform cars to the adaptation channel ("element"?) name structure - mostly related to the Parent name in the ID (the Child names were largely unchanged). And, for the particular BCM for your car that you posted, the code-string was abandoned entirely and all of these software switches became adaptation channels .
  10. Likes Uwe liked this post
  11. #8
    Verified VCDS User tehfalcon's Avatar
    Oct 2015
    Has anything been found out about this? I’m at Stage 2 power levels now and it’s impossible to drag race with the torque limiter and vibration reduction enabled. Cuts power even with Traction and Stability off.
    2006 Audi A6 4.2 Quattro Auto ‘Prestige’ Stock
    2007 Volkswagen Rabbit 2.5 4-Door Manual ‘S’ Stage 1
    2007 Volkswagen EOS 3.2 DSG 'Highline' Stock
    2019 Volkswagen GTI 2.0T 4-Door DSG ‘SE’ Stage 2
  12. #9
    Verified VCDS User VagImports's Avatar
    Mar 2019
    Argentina
    I coulnd´t deactivate it either (GTI 7.5 2019).
    What do you think about replacing the ABS Module with one coming from a MK7 GTI? Could it be the solution?
    It´s a bit extreme, but if you use the car in track days or drag, it´s impossible to apply the power to the ground.
    VAG Imports Argentina (Juan García)
