ACC retrofit on a Skoda Superb pre-equiped with Front Assist - Need help coding
RMS Autotechnik
France
C?ID=363349
Hello everyone,
I'm new on this forum so please bear with me if I do mistakes- and I'm french so sorry in advace for my language.
My name is Remy and I am working on VAG cars doing coding and retrofits for 6 years now.
I have one of my client that wanted to retrofit a working ACC on his 2018 Skoda Superb (3V) MQB chassis. He already has the front assist camera that I think also work for ACC - you can confirm on the AutoScan below.
We replaced the steering wheel level to have the ACC commands under the indicator lever - ref 5Q0 953 502 AL
I think I succefully codded modules 19, 01, 17, 5F. But I have trouble coding ABS (03) et the ACC itself (13). Auto-Scan showing errors comunicate with the commands.
I can't see any information in long coding of the ABS (03) and don't know if I need to code somehting in the module (13).
In the car the limiter is working, when we change mode to ACC with the lever a message show that we re in ACC mode but nothing happens.
I'm looking for someone that allready did this retrofit on his MQB or already have an ACC + front assist in his cars with same module and can share his auto-scan.
I have Hex-Net with latest update of VCDS.
Thank you very much for your help- this is my last chance to have this working
Wednesday,29,May,2019,16:58:59:02963
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4504.4
VIN: TMBLE7NPXJ7568956   License Plate: DUREUIL2905
Mileage: 15995km-9938mi   Repair Order:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44
          47 4B 52 5F 69 6C 6D 75 A5 BB BC CA
VIN: TMBLE7NPXJ7568956   Mileage: 15995km-9938miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0C1D00122476050B3004
   Shop #: WSC 33361 790 00156
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
   ROD: EV_ECM20TFS0203G0906259B.rod
   VCID: AB168F76C20E2312D8-80FE
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
                    Mileage: 15995 km
                    Date: 2019.05.29
                    Time: 16:55:26
                    Coolant temperature: 90 °C
                    Intake air temperature: 50 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 11.855 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 91.0 °C
                    Time since engine start: 0.0 s
                    T_ES: 7 min
                    Cruise control switch actuation-Main switch hardware: operated
                    Cruise control switch actuation-Main switch CAN: operated
                    ECU_STATE: ENG_STOP
Readiness: 1110 0001
   Part No SW: 0D9 300 018 C    HW: 02E 927 770 AS
   Component: DQ250-6A MQB  H54 5201
   Revision: 06454104    Serial number: TFK01711160972
   ROD: EV_TCMDQ250021.rod
   VCID: 9C745CAA97A0D4AAA1-80C8
   Part No SW: 5Q0 614 517 CT    HW: 5Q0 614 517 AG
   Component: ESC           H62 0653
   Revision: 00000000    Serial number: 60298000000181
   Coding: 1E076B9C542623744780070540C96978D62AC4E2E0029675304150F8C2A9420B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
   VCID: 854219CE042A35626E-80D0
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0468735040
   Coding: 032C0C070F
   VCID: BE30B622217CA6BA6F-80EA
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0023
   Serial number: Y0006RAR14946
   Coding: 0010000000000500018280808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   VCID: BD32B12E2C7ABDA276-80E8
   Part No SW: 3V0 907 044 CP    HW: 3V0 907 044 CP
   Component: AC Automat    H34 4402
   Revision: 20K10000    Serial number: 00000B00819930
   Coding: 1201000400041001100510410010112A
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X_SK37.rod
   VCID: 844404CA0F100C6A79-80D0
   Subsystem 2 - Part No SW: 3V0 907 049 E    HW: 3V0 907 049 E
   Component: E265KlimaHeck  H02 0101
   Serial number:       06051501850797
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001802501642
   ROD: EV_BCMBOSCH_018.rod
   VCID: 895A15FE283251020A-80DC
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 131217  032 0121
   Serial number: 00000001712110304981
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: TBY18M01D30H04M42S16
   Coding: 0688DF
   Subsystem 3 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0851813
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0855859
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0855726
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0855862
   Serial number: 000308418018026
   Coding: 0471155151
   VCID: CBD6EFF662CE0312F8-809E
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Coding: 320067C951FFC728949C8045
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: B522A90E144A65E2BE-80E0
1116 - Databus
          U1122 00 [009] - Implausible Message
          [FAULT_TSK_CODING_IN_PLAUS_PHASE_FAIL]
                    Reset counter: 91
                    Mileage: 15995 km
                    Date: 2019.05.29
                    Time: 16:55:25
                    Control Module temperature: 44 °C
                    Voltage terminal 15: 11.7 V
   Serial number: 12011841350098
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: B83CA03A0358988AA5-80EC
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Serial number: 003VVR3UVRNY
   Coding: 98CCC0C0000000005C5400CF004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 875E13C63E2627721C-80D2
   Subsystem 1 - Part No SW: -----------    HW: 480 002 701 18
   Serial number: 35700000000A01592B2C
   Subsystem 2 - Part No SW: -----------    HW: 480 002 701 18
   Serial number: 35800000000516492B2D
   Subsystem 3 - Part No SW: -----------    HW: 480 402 201 18
   Serial number: 3510001B5287908564D2
   Subsystem 4 - Part No SW: -----------    HW: 480 402 201 18
   Serial number: 3520001B328C22E372F6
   Subsystem 5 - Part No SW: -----------    HW: 480 402 401 18
   Serial number: 35500019B28C22E474AD
   Part No SW: 5Q0 953 521 ER    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20180120500258
   Coding: 6414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 86401EC2392C3E7A67-80D2
   Part No SW: 3V0 920 710 B    HW: 3V0 920 710 B
   Component: KOMBI         301 0310
   Coding: 07A5081AFF840008018B7B0B5001000800000000
   Shop #: WSC 73430 031 00156
   VCID: AE108662F11C563AFF-80FA
   Component: GW MQB High   518 5323
   Serial number: 25011810522042
   Coding: 030100347F085900FB00024A9C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00160
   ROD: EV_GatewNF_VW37.rod
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000A2777270118
   Serial number: 1903416404
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00004.12.17
   Coding: 0301
   VCID: CCD4ECEA67C0042AF1-8098
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 18000007905005
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: B32697161A3E7BD290-80E6
   Serial number: Y0006RAR15242
   Component: HRE_Master    H12 0080
   Serial number: 0467976171
   Coding: 02012103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0467061099
   Coding: 020121
   Serial number: 0000301477865
   Coding: 001D8920DE00040000001100
   VCID: C7DED3C67EA6E772DC-8092
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 817003 00
   Coding: 0100001100400110
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_SK37.rod
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1HJE03S1RL
   Coding: 0384020000AA002FAA0000000000
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: D9FA05BED81261827A-808C
   Serial number: 23011810800468
   Coding: 000000020100067206007F01000000000000000000000000000000000000
   VCID: F2A8521225A432DA5B-80A6
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: Leimo links  H02 0013
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329
   Component: Leimo rechts  H02 0013
   Serial number: 0000296581546
   Coding: 001D0320DE00040000001100
   VCID: C6C0DEC279ACFE7A27-8092
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 565 035 021 B    HW: 565 035 021
   Component: MU-H-LND-EU   H54 1240
   Serial number: A853A0JS024253
   Coding: 03840201000000004111120200880A102F0103E401208500DE
   VCID: 8D5221EE5C5A4D2226-80D8
   Subsystem 1 - Part No SW: 3V0 919 606 D    HW: 3V0 919 606 D
   Component: ABT_High-2  H50 9130
   Serial number: SKZ6ZHV0243169
   Subsystem 2 - Part No SW: V03 959 801 JR    HW: -----------
   Component: ECE 2019  --- 0175
   Component: Gracenote2  --- 1017
          U1111 00 [009] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 91
                    Mileage: 15995 km
                    Date: 2019.05.29
                    Time: 16:55:29
                    Voltage terminal 30: 12.0 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 907 383 M    HW: 5Q0 907 383 M
   Component: Anhaenger     H27 0260
   Revision: 8B001004    Serial number: 0465907261
   Coding: 0100000202000000
   VCID: C1CACDDE5082D94212-8094
   Coding: 04840201A3002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
   VCID: B93AA53E385281825A-80EC
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31753788500000
   Coding: 0D88
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------
   Coding: 03840201EA423A0D3B1C9E020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW41.rod
   VCID: BC34BC2A3760B4AA41-80E8
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 1272
   Serial number: 08011841P10737
   Coding: 0204080200000401002623558150A90094000E100040
   VCID: 885C10FA3338280A15-80DC
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       012 0032
   Serial number: 0000299458214
   Coding: 001C81208000040000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   VCID: C9DAD5FE68B21102CA-809C
   Component: TSG HBFS      012 0032
   Serial number: 0000299457827
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   Coding: 408040648202
End----(Elapsed Time: 02:09, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
golfi_vend
Tartu, Estonia
C?ID=195131
Without enabling/hacking FeC codes You will not get this working even with correct coding.
As for ABS coding:
LC,24,1~4,14,ACC And Front Assist Installed (8T5/8T7)
LC,24,1~4,16,ACC And Front Assist Installed (8T3/8T8)
LC,24,1~4,18,ACC And Front Assist Installed with Stop&Go (8T3/8T8)
RMS Autotechnik
France
C?ID=363349
As for ABS coding:
Hi, Thanks for your help.
I tried to code ABS modul with 14 16 and 18 like you said and does not work. Still the same errors
Can you please tell me more about this FEC code ? Is it something we can't find or code with VCDS ? only with VAS ?
Thank you
golfi_vend
Tartu, Estonia
C?ID=195131
There are other bits needed to consider in this byte, not just ACC related.
About FeC. It would be too complicated to explain, so I'll just paste this text that involves MIB, but the swap/fec part stays the same. With exeption, that You can't buy acc fec.
. I haven't seen a lot of information posted about this topic, so I thought I'd share what I know.
MIB-1 and MIB-2 units utilize a feature activation mechanism called SWaP (Software as Product). By entering an FeC (Feature enablement code), VW techs can provision your vehicle's infotainment system with new features.
You've likely seen threads regarding Performance Monitor being enabled on random vehicles. Or, folks in the UK didn't purchase App-Connect (carplay/android auto), and are trying to get it activated after purchase. Fact is, these features can only be enabled by having a legitimate FeC code and PIN. These are registered to the vehicle using ODIS with an online connection to VWAG. That implies there's an association that happens on VW's servers that ties that registration code to your vehicle's VIN.
How do you view the FeC codes provisioned for your vehicle? Hold down the Menu button for several seconds, and you'll get a menu option that let's you view them.
What else does the FeC / SWaP code registration imply? Based on my experience:
- If you pick up a used infotainment system, component protection will kick in. But the infotainment device will still have the FeC codes in there, and the functions that were provisioned for the original vehicle/VIN will work.
- When you get the dealer to remove component protection (which is pretty quick & easy), the device will see the VIN has changed, and the FeC codes will show up as "Invalid" as the status. When the VW tech runs through the ODIS guided fault finder, ODIS will pull all of the FeC codes applicable to your VIN, and enable them for you on the new infotainment device.
- On a 2015 vehicle, there is no App-Connect feature provisioned (Since this is a 2016/MIB2 feature only). So this feature won't work. You can however, purchase the same part number that UK folks are purchasing: 5g0054830a Bring this to a dealer, have them use ODIS to activate it along with your retrofitted MIB-II unit.
- On a 2015 vehicle, the FeC code for Navigation & Traffic is different than that of a 2016+. So the fact is, you'll never be able to activate this.
- Regarding Performance Monitor, there currently isn't a purchase-able activation code available to my knowledge. No idea how VW will be enabling 2016 vehicles to get the feature either.
There is an alternative however. You can get a "hacked" unit from APG out in Poland. An Australian & UK company sells hacked units also. Whether you want to go this route is up to you.
downtime
C?ID=280813
And one addition, you can’t buy hacked ACC either like with MIB unit.
And as your car already has 3Q0 radar, the round faced 5Q0 non-fec radar won’t work either.
AINils
Germany (AIB)
C?ID=56975
But hacking these radar with part nr 3qf, 5q0 and 2q0 isn´t a big deal
