Results 1 to 10 of 13
Thread: 2015 Volkswagen Golf GTI - engine rpm max 3000rpm
    Verified VCDS User obdserwis-pl's Avatar
    May 2019
    Poland
    I have problem with cutoff engine rpms to 3000.
    After short ride, gauges shows 'Engine max 3000rpm' and EPC light turn on
    After ignition off, and turn on again problem sometimes losts.
    This is Golf GTI 2.0 TSI engine
    Thursday,30,May,2019,16:29:22:02777
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
    VIN: 3VW4T7AUXFM061894   License Plate:
    Mileage: 150998km-93825mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 47 52 5F 75 A9
    VIN: 3VW4T7AUXFM061894   Mileage: 150998km-93825miles
    A9-Struct. Borne Sound -- Status: Malfunction 0010
    Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0105
       Revision: --H13---
       Coding: 091D00124424002F1000
       Shop #: WSC 46809 001 1048576
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001007
       ROD: EV_ECM20TFS0205G0906259A_VW37.rod
       VCID: 2C1408C64701EE2A51-8078
    15255 - Secondary Air Injection System Valve (N112)
              P0413 00 [096] - Open Circuit
                        Mileage: 150998 km
                        Date: 2019.02.20
                        Time: 22:57:37
                        Engine speed: 1041.25 /min
                        Normed load value: 17.3 %
                        Coolant temperature: 28 °C
                        Intake air temperature: 23 °C
                        Voltage terminal 30: 14.042 V
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 32 s
                        MAP_MES_SAE: 51 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 16.015625 %
                        FUP_H_SAE: 5890.0 kPa
    15188 - Oil Pressure Switch
              P164B 00 [044] - Malfunction
                        Mileage: 150997 km
                        Date: 2019.02.15
                        Time: 06:07:07
                        Engine speed: 799.50 /min
                        Normed load value: 10.2 %
                        Coolant temperature: 107 °C
                        Intake air temperature: 65 °C
                        Voltage terminal 30: 13.984 V
                        STATE_LS_SAE[1]: OL_INTR
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 36 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
                        FAC_TPS_1_SAE: 13.671875 %
                        FUP_H_SAE: 4970.0 kPa
    Readiness: 1010 0101
       Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4511
       Revision: 03253104    Serial number: TFK01411040813
       Shop #: WSC 00066 790 00202
       ROD: EV_TCMDQ250021.rod
       VCID: 291AF1D248F3FB02AA-807C
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 53184000002376
       Coding: 01FA6BA13426096D007F020981C72980D62C9000408194B400430050C005
       VCID: 47DE576AFEA72D725C-8012
       Revision: 00021000    Serial number: 0349864043
       Coding: 030C0C
       Shop #: WSC 01383 790 50316
       VCID: 3A383E9EBD55409AD3-806E
    65813 - Supply voltage
                        Fault Frequency: 48
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2018.09.02
                        Time: 17:09:49
       Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
       Revision: 00001K01
       Coding: 00020014200100000005004012111400
       VCID: 42C8467ED585085A8B-8016
    328198 - Position Sensor for Right Temperature Flap Motor
              B1095 11 [008] - Short to Ground
                        Reset counter: 248
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:19:33
                        Voltage terminal 30: 13.8 V
                        Outside air temperature: 5.0 °C
                        Interior temperature: 20.3 °C
                        Right temperature flap: actual value: 197
                        Right temperature flap: actual value: 82.0 %
                        Right temperature flap: specified value: 196
    262914 - Refrigerant Pressure
              B10AB F0 [008] - Too Low
                        Reset counter: 1
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 13:27:53
                        Outside air temperature: 16.0 °C
                        Engine speed: 0 /min
                        Temperature after evaporator: 15.0 °C
                        System run time-Terminal 15 on: 6 s
    1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
              B10F0 00 [008] -  -
                        Reset counter: 4
                        Mileage: 150997 km
                        Date: 2019.02.15
                        Time: 05:58:25
                        Voltage terminal 30: 13.3 V
                        Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
    1048836 - Blower Output Reduction due to Energy Management
              B10CE 00 [008] -  -
                        Reset counter: 3
                        Mileage: 150964 km
                        Date: 2019.02.13
                        Time: 00:01:47
                        Voltage terminal 30: 12.4 V
                        CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 0
              B10CD 00 [008] -  -
                        Fault Frequency: 7
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2018.09.11
                        Time: 00:09:02
                        Voltage terminal 30: 10.6 V
       Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86580412140847
       Coding: 00111846404182E969E44000001407201800000000000000000000000000
       Shop #: WSC 00066 790 00228
       ROD: EV_BCMBOSCH_014.rod
       VCID: 4AD86E5EEDB5D01A43-801E
       Component: WWS    141129  043 0581
       Serial number:         150105060939
       Component: RLHS  037 0059
       Serial number: S3Y14M12D09H08M33S03
       Coding: 00A8DD
       Sun Roof:
       Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS73.404  H02 0003
       Serial number: 0000FST000062X500000
       Coding: 181801
    13 Faults Found:
    131330 - Supply voltage
              [VersorgungsspannungSpannung zu niedrig]
                        Reset counter: 40
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:19:05
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:14:42
    6666 - Bulb for Low Beam Headlamp Left
              B1217 15 [009] - Open or Short to Plus
                        Fault Frequency: 62
                        Reset counter: 220
                        Mileage: 139582 km
                        Date: 2018.04.09
                        Time: 10:42:28
    5130 - Bulb for Front Left Turn Signal
              B11E8 15 [008] - Open or Short to Plus
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 00:00:14
    5386 - Bulb for Front Right Turn Signal
              B11EA 15 [008] - Open or Short to Plus
                        Reset counter: 253
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 00:00:14
    17162 - Bulb for Left DRL and Parking Lamp
              B12EA 15 [008] - Open or Short to Plus
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 00:00:39
    17418 - Bulb for Right DRL and Parking Lamp
              B12EB 15 [008] - Open or Short to Plus
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 00:00:39
    17674 - Bulb for Front Left Side Marker Lamp
              B12BA 15 [009] - Open or Short to Plus
                        Reset counter: 22
                        Mileage: 138991 km
                        Date: 2018.04.05
                        Time: 02:15:48
    17927 - Bulb for Front Right Side Marker Lamp
              B12BB 11 [008] - Short to Ground
                        Reset counter: 245
                        Mileage: 150938 km
                        Date: 2018.09.11
                        Time: 00:08:07
    17930 - Bulb for Front Right Side Marker Lamp
              B12BB 15 [008] - Open or Short to Plus
                        Reset counter: 252
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 00:10:10
    939524 - No Communications with Humidity Sensor
              U10F5 00 [008] - -
              [Geber für Luftfeuchtigkeitkeine Kommunikation]
                        Reset counter: 241
                        Mileage: 150820 km
                        Date: 2018.07.17
                        Time: 10:10:52
    722449 - Control Module for Power Sunroof
              B13C6 F0 [008] - Function Aborted
                        Reset counter: 2
                        Mileage: 150964 km
                        Date: 2019.02.12
                        Time: 00:00:00
                        Reset counter: 6
                        Mileage: 150964 km
                        Date: 2019.01.16
                        Time: 01:54:44
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM01EG7G
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 51EA793200E3E3C202-8004
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J14000232ZF0+
       Coding: 303131
       Subsystem 2 - Part No SW: -----------    HW: 480 002 410 14
       Serial number: 35700000000EA941711J
       Subsystem 3 - Part No SW: -----------    HW: 480 002 410 14
       Serial number: 35800000000418947118
       Subsystem 4 - Part No SW: -----------    HW: 480 402 210 14
       Serial number: 3510002A91811BA2301P
       Subsystem 5 - Part No SW: -----------    HW: 480 402 210 14
       Serial number: 3520002A518166A5B16$
       Subsystem 6 - Part No SW: -----------    HW: 480 401 910 14
       Serial number: 3550002B518166B5736%
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 910 14
       Serial number: 3560002B718166B1C1B6
    9483008 - Seat Occupied Recognition
              B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                        Fault Frequency: 39
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2018.07.18
                        Time: 03:36:05
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
              [Bladder Mat: functional restriction because of low voltage]
                        Reset counter: 2
                        Mileage: 150964 km
                        Date: 2019.02.14
                        Time: 21:03:18
       Revision: FF032032    Serial number: 20141103500490
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 044480668F11C66AF9-8050
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung -unterer Grenzwert unterschritten>]
                        Reset counter: 2
                        Mileage: 150964 km
                        Date: 2019.02.12
                        Time: 00:00:05
                        Ubat 30 Voltage: 6.00 V
                        Ignition State: OFF
                        Terminal 15: 5.20 V
    136194 - Supply voltage
              [Versorgungsspannung -unterer Grenzwert unterschritten>]
                        Reset counter: 2
                        Mileage: 150964 km
                        Date: 2019.02.12
                        Time: 00:00:05
                        Ignition State: OFF
                        Terminal 15: 5.20 V
       Part No SW: 5G1 920 856     HW: 5G1 920 856
       Component: KOMBI         342 4270
       Coding: 0BAD091A2180CF0502086A001000000000000000
       VCID: 6B96CBDA828F291218-803E
    13635840 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
                        Reset counter: 40
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:17:51
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 05121410000139
       Coding: 0101000820085900EF0002281C0F00000001050000000000000000000000
       ROD: EV_GatewConti_011_VW37.rod
       VCID: 71AAD9B2A0A3C3C222-8024
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 27140002607290054435
       Coding: 280000
    1282 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten]
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:17:08
                        Supply voltage: Terminal 30: 8.4 V
                        Terminal 15: On
    8782090 - Cruise Control Switch
              B1154 96 [008] - Component internal failure
                        Reset counter: 231
                        Mileage: 144961 km
                        Date: 2018.06.04
                        Time: 16:54:02
                        Supply voltage: Terminal 30: 13.5 V
                        Terminal 15: On
       Revision: 00000000    Serial number: 14000318772004
       Coding: 5D00000000000000
       Shop #: WSC 00066 790 07027
       ROD: EV_ELVMarquMQB.rod
       VCID: 342410A69F31B6EA09-8060
              [Under voltage (continued)]
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:23:05
                        ELV State: 04
                        Information Clamps: 77 60
                        CoCo State: A0 01
                        WFS State: 17 06
                        Vehicle speed: 0.00 km/h
                        Voltage: 47
                        AD-Value H-bridge: 23
                        Clamp15 flip flop: SSTx: button contacts: 06
                        CAN signals: 00
              U1400 00 [008] - -
              [Under voltage (temporary)]
                        Fault Frequency: 7
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:15:01
                        ELV State: 04
                        CoCo State: A0 01
                        WFS State: 17 06
                        Voltage: 4C
                        AD-Value H-bridge: 25
                        CAN signals: 00
    1048844 - Ignition Starter Switch
              B11D7 29 [008] - Signal Implausible
                        Fault Frequency: 15
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2018.09.11
                        Time: 00:01:23
                        ELV State: 02
                        Information Clamps: 00 08
                        CoCo State: E0 01
                        WFS State: 00 06
                        Vehicle speed: 655.34 km/h
                        Voltage: 6D
                        AD-Value H-bridge: 34
                        Clamp15 flip flop: SSTx: button contacts: 09
                        CAN signals: 05
    13637378 - Databus
              [Errorvalue ESP_Wegimpulse]
                        Reset counter: 242
                        Mileage: 150938 km
                        Date: 2018.07.18
                        Time: 03:35:48
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 1F 06
                        Vehicle speed: 121.37 km/h
                        Voltage: 77
                        AD-Value H-bridge: 3A
                        CAN signals: 04
       Serial number: 031214060503S9
       Coding: 003E13200000040000000000
       VCID: 40CC4C76DB891A4A9D-8014
       Serial number: 00000000000000424978
       Coding: 011000
    6 Faults Found:
    65548 - Supply voltage
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:18:59
    65604 - Door Warning Lamp
              B1326 01 [009] - Electrical Failure
                        Fault Frequency: 211
                        Reset counter: 207
                        Mileage: 139044 km
                        Date: 2018.04.05
                        Time: 14:36:14
    589827 - Window Regulator; Rear Driver Side
              B131F 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 220
                        Mileage: 150950 km
                        Date: 2019.01.12
                        Time: 01:42:49
    589829 - Window Regulator; Rear Driver side
              B131F F5 [008] - Supply Voltage too Low
                        Fault Frequency: 20
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:21:30
    589830 - Window Regulator; Rear Driver side
              B131F F4 [008] - Supply Voltage too High
                        Reset counter: 2
                        Mileage: 150964 km
                        Date: 2019.02.13
                        Time: 00:01:24
    589839 - Window Regulator Motor; Front Driver Side
              B1321 02 [008] - Signal Failure
                        Reset counter: 2
                        Mileage: 150964 km
                        Date: 2019.02.12
                        Time: 00:14:46
       Coding: 8102
       VCID: 373E27AA8E475DF22C-8062
    Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
       Part No SW: 5G0 035 456     HW: 5G0 035 456
       Component: MIB_lite_amp  H40 0060
       Serial number: VWZ8Z1EC401V8B8
       Coding: 22000000AAAAAA0000
       ASAM Dataset: EV_AMPMst11CALPI 001006
       ROD: EV_AMPMst11CALPI.rod
       VCID: 6386A3FA6A5F6152A0-8036
    0565 - Loudspeaker 1 in Double-Subwoofer
              B130C 13 [008] - Open Circuit
                        Reset counter: 245
                        Mileage: 150938 km
                        Date: 2018.09.11
                        Time: 00:02:14
    0570 - Loudspeaker 2 in Double-Subwoofer
              B130D 13 [008] - Open Circuit
                        Reset counter: 245
                        Mileage: 150938 km
                        Date: 2018.09.11
                        Time: 00:02:14
    15360256 - Component Protection
              U1101 00 [008] - Active
              [Anti-theft protection - component protection active (0xEA6100)]
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:43:58
       Serial number: 281114060500CK
       VCID: 3FCE4F8AA67765B2E4-806A
       Serial number: 00000000000000363754
       Coding: 091000
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:18:43
    589843 - Window Regulator; Front Passenger Side
              B1320 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 213
                        Mileage: 150950 km
                        Date: 2019.01.12
                        Time: 01:42:49
    589845 - Window Regulator; Front Passenger side
              B1320 F5 [008] - Supply Voltage too Low
                        Fault Frequency: 19
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:21:06
    589846 - Window Regulator; Front Passenger side
              B1320 F4 [008] - Supply Voltage too High
                        Reset counter: 2
                        Mileage: 150964 km
                        Date: 2019.02.13
                        Time: 00:01:24
       Part No SW: 5G0 035 876     HW: 5G0 035 876
       Component: MU-S-NS-US    014 0645
       Serial number: V7B01911143974
       Coding: 027300010000000021110002001800001F0203340100010546
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 699AB1D288733B026A-803C
       Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
       Component: ABT_Std_Nav  H60 0030
       Serial number: VWZ8Z9PS600DGL
       Subsystem 2 - Part No SW: 5G0 919 866 S    HW: -----------
       Component:  NAR 2015  --- 0022
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Function restriction due to insufficient voltage - lower limit value not reached]
                        Fault Frequency: 51
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:17:57
                        Voltage terminal 30: 8.3 V
    6669 - Optical Data Bus for Digital Sound System
              U10CC 00 [008] - Intermittent Disruption
              [Optical data bus: sporadic open circuit in sound]
                        Reset counter: 4
                        Mileage: 150979 km
                        Date: 2019.02.15
                        Time: 05:30:59
                        Temperature of MOST transceiver-max.value: -50 °C
                        Temperature of MOST transceiver-min.value: -19 °C
                        Temperature of MOST transceiver-Current: 41 °C
    7219 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 2
                        Mileage: 150964 km
                        Date: 2019.02.13
                        Time: 00:38:15
                        Voltage terminal 30: 11.5 V
       Component: OCULowMQBUS   007 0564
       Coding: 02730002C2823A017F1E06000000
       Shop #: WSC 00066 790 00122
       ROD: EV_OCULowMQB.rod
       VCID: 43C6437ACA9F015280-8016
              [supply voltage lower limit exceeded]
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:11:06
              U1400 00 [008] - -
              [restriction due to undervoltage]
                        Reset counter: 2
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:06:07
       Serial number: 140925202932
    0002 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten--> Versorgungsspannung Spannung dauerhaft zu niedrig]
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:13:44
    0004 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung--> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
                        Reset counter: 250
                        Mileage: 150938 km
                        Date: 2019.01.11
                        Time: 01:13:44
    End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.3V)-----------
    Probably oil PSI related and TV harness should be checked if damaged as per TSB's
  3. Likes Uwe liked this post
    Dallas (McKinney) ,TX ,USA
    Or Lower O-Rings never been chnage at oil filter, and car loosing oil pressure . This is most stupid filter kit VW ever made , that not supply 2 lower O-rings. You have to buy complete rod which is almost $10.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  5. Likes Jack@European_Parts, Uwe, jyoung8607 liked this post
  6. #4
    I agree Marin........INDEED!
    Quote Originally Posted by Jetta ,97 View Post
    Jetta/Jack: I had to take a look because I have never changed these O-rings (I hadn't thought it necessary). Notwithstanding the note in the manual (see the diagram below) - the O-rings look like they can be easily separated from the rod (and simply replaced from bits in my O-ring box). Is there anything special about these O-rings and how often do you recommend changing them?
    Jan 2019
    Canada
    You have a code for oil pressure switch so car is in limp mode. Either something wrong with press switch or you have low oil pess. I would start with checking the switch as the code says switch malfunction
  9. Likes Jack@European_Parts liked this post
  10. #7
    Don,
    Don't you think when the filter is changed I change the rod with oring set?
    This is why it's good to change oil more frequently, bifurcate turbo from sump and use regular oil for engine, huh?
  11. #8
    Jack: you replace the rod and the o rings EVERY filter change - wow? I guess that's the difference between us (well......... that and opposable thumbs - I don't have them)!!
  12. Likes Jack@European_Parts liked this post
  13. #9
    Apr 2018
    ITALY
    of course O-rings are replaced at every filter change. here in Europe all you need is to buy a MANN filter, new O-rings come together in the box.
  14. Likes golfi_vend, Jack@European_Parts liked this post
  15. #10
    Tartu, Estonia
    Even though MANN being kinda OE stuff, it still doesn't come with lower o-rings included.
    https://www.drive2.com/l/499046338688712740/
    OE code for EA888 3.gen should be 06L115678Q.
    The world is my oyster...
  16. Likes Jack@European_Parts, Uwe, Jetta ,97 liked this post
