Results 1 to 10 of 13
Thread: 2004 Audi A4 cluster adaptation
    Jan 2019
    Canada
    Is it possible to adapt new cluster for this car with vcds? I don't see procedure in the wiki.
    Tried as immo3 cluster but that does not work.
    It is RB4 cluster
    Wednesday,29,May,2019,16:54:04:38330
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUAC48H24K014230   License Plate:
    Mileage: 10km-6mi   Repair Order:
    Chassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
              67 69 75 76 77
    VIN: WAUAC48H24K014230   Mileage: 10km-6miles
    Address 01: Engine        Labels: 06B-909-518-AMB.lbl
       Part No SW: 8E0 909 518 AK    HW: 8E0 909 018 A
       Component: 1.8L R4/5VT     G   0006
       Coding: 0016584
       Shop #: WSC 93030 999 83980
       VCID: 79F93B8D334CE8829A-5140
    18010 - Power Supply Terminal 30
    18107 - Powertrain Data Bus
                P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
    18043 - Powertrain Data Bus
                P1635 - 008 - Missing Message from A/C Controller - Intermittent
    18058 - Powertrain Data Bus
                P1650 - 004 - Missing Message from Instrument Cluster - Intermittent
    Readiness: 0110 0101
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 8E0 910 155 F    HW: 01J 927 156 JK
       Component: V30 01J 1.8l5VT USA 3220
       Revision: 00000007    Serial number: 00000001210603
       Coding: 0001001
       Shop #: WSC 93030 999 72925
       VCID: 285F2EC99866A10AB5-5122
    18270 - Powertrain Data Bus
                P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
       Part No: 8E0 614 517
       Component: ABS/ESP front       3429
       Coding: 04279
       Shop #: WSC 00001
       VCID: 65C167FDFFF47C624E-5122
       Part No: 8E0 820 043 AD
       Component:   A4 Klimaautomat   1323
       Coding: 00100
       Shop #: WSC 00672
       VCID: 63C579E5F1C00252A0-5122
    00532 - Supply Voltage B+
                53-10 - Supply Voltage Too Low - Intermittent
                49-00 - No Communications
       Part No: 8E0 907 279 F
       Component: int. Lastmodul  KAN 0517
       Coding: 01014
       Shop #: WSC 00672
       VCID: 3561F7BD0FD4CCE23E-4AE8
    8 Faults Found:
                57-00 - Electric Circuit Failure
    01501 - Bulb for Blinkers; Rear Left (M6)
                79-10 - Please Check Fault Codes - Intermittent
    Address 15: Airbags        Labels: 8H0-959-655-84.lbl
       Part No: 8H0 959 655 B
       Component: Airbag 8.4EC        2015
       Coding: 0010105
       Shop #: WSC 00672 785 00200
       VCID: 3979FB8D73CC2882DA-5122
       Part No: 8E0 953 549 N
       Component: Lenksáulenmodul     0611
       Coding: 01041
       Shop #: WSC 00672
       VCID: 3E73E8913AE20FBAEF-4AE8
       Part No: 8H0 920 900 C
       Component: KOMBI+WEGFAHRS. RB4 D17
       Coding: 02301
       VCID: 275D2DF5C578AE72BC-5122
       WAUAC48H34K009019     AUZ6Z0C0259440
    01176 - Key
                65-10 - Unauthorized - Intermittent
    01304 - Radio
       Part No: 8H0 959 433 C
       Component: Komfortgerát T7B    1412
       Coding: 11788
       Shop #: WSC 00672
       VCID: 3467CAB904AED5EA09-4AE8
       Subsystem 1 - Part No: Steuerger
       Component: t Fahr. antwortet nicht
       Subsystem 2 - Part No: 8H1959802
       Component: Tőrsteuer.BF BRM 0001
       Subsystem 3 - Part No: 8H0959801A
       Component: Tőrsteuer.HL BRM 0001
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0001
    11 Faults Found:
                35-00 -  -
                35-00 -  -
                35-00 -  -
                35-00 -  -
    00892 - Switch for Trunk Closing Cylinder (F248)
    00934 - Electric Window Motor; Rear Left (V26)
                62-10 - No or Incorrect Adjustment - Intermittent
                37-00 - Faulty
                37-00 - Faulty
       Part No: 4Z7 907 357
       Coding: 00070
       Shop #: WSC 00672
       VCID: 04075A79148EA56AF9-4B1A
    End-------------------------(Elapsed Time: 05:49)--------------------------
    That is not a new cluster it is a used cluster & with a different identity.
    I could help you with a data transfer, provided you supply the needed controllers, all keys and proof of purchase with ownership credentials.
    WAUAC48H24K014230
    Emission standard 0GN Emission standard ULEV 1
    Vehicle Identification No. WAUAC48H24K014230
    Model Audi A4 Cabrio. 1,8
    AA4C
    Date of production 26.11.2003
    Model year 2004
    Sales type 8H752H
    Engine Code AMB
    Transmission Code GHX
    8H0 920 900 EX 920-000 instrument cluster 260KM/H "CDN"+
    PR-9Q2
    Vehicle Identification No. WAUAC48H34K009019
    AA4C
    Date of production 11.09.2003
    Model year 2004
    Sales type 8H752H
    Engine Code AMB
    PR-9Q2
    It is an Immo-3 cluster.
    Are you certain both PINs are correct?
    Is the key in the ignition matched to the old cluster and ECU?
    It is a very common issue for incorrect pirated Chinese tools to corrupt the ability to do an 050 in RB type cluster due to protection Electronic Counter Measures by "ECM" in cluster for tampering.
  5. Likes Uwe liked this post
    Jan 2019
    Canada
    WAUAC48H24K014230
    AA4C
    Model year 2004
    Sales type 8H752H
    Engine Code AMB
    PR-9Q2
    AA4C
    Model year 2004
    Sales type 8H752H
    Engine Code AMB
    PR-9Q2
    Used but virginised so for purposes of programming it's like brand new.
    If original cluster was available i wouldn't be here, transferring data is easy
    Jan 2019
    Canada
    So it should program just like any other immo3 cluster? Just wasn't sure about that part because every time I did one of these original cluster was available to just transfer immo data from it.
    Anything is possible but codes should be correct, read them with couple different tools to confirm.
    Car is theft recovery from an auction and a lot of parts were missing along with the key, so it's a new blank key. Could that be a problem? But I'm pretty sure with immo3 that shouldn't matter as long the pins are correct
    Quote Originally Posted by rrador View Post
    Yes, it sounds like that's the problem. With Immo-3 you can match one thing (key, cluster, or ECU) if the other two are already match, but you don't have that at the moment. I'm not sure what the solution is here.
  9. Likes Jetta ,97 liked this post
  10. #8
    I am OP , very common mistakes are made, send it to me for data transfer.
  11. #9
    Dallas (McKinney) ,TX ,USA
    Manual Transfer only , which can not be done only with VCDS. But even if he has original key , used cluster at this car can not be adopted with VCDS, unless you set it to Factory 04 or 01 mode , even if you have both Pins.
    ( Jack Please do not comment on this ,Please , I like to respect UWE form last discussion)
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  12. #10
    No Marin, the forum doesn't work like that.
    Again if the proper security clearance is had and input, with a successful login, you can indeed set this in adaption in VCDS & to the "desired immobilizer status"! or if the cluster is in a new mode status as the OP stated or as OP aforementioned a new blank key transponder can be married and then an 050 can take place or manual data transfer can save used transponders or if you know what you are doing you can default the ID48 transponders with OEM tools or some aftermarket tools.
    Now if the EEPROM is off from improper tools used, that must be fixed manually too!
    OP says it's virgin......
    OP says new blank key!
    OP please post adaption data or immobilizer status in advanced measuring blocks......
