- Feb 3, 2014
- 65
- 15
- Nottingham, UK
- C?ID=205609
Please can someone help. I have a problem that keeps popping up on the dash, something about the left turning is not working on my left headlight.
Saturday,25,May,2019,00:01:55:23584
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4
VIN: WAUZZZ4G6DN074425 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3B 3C 42 44 46
52 53 55 56 5F 62 69 6D 72 85 8B 8E 8F 90 A9 C0
VIN: WAUZZZ4G6DN074425 Mileage: 196404km-122039miles
Address 01: Engine (J623-CGQB) Labels: Redir Fail!
Part No SW: 4G0 907 589 C HW: 4G0 907 589
Component: 3.0BTD EDC17 H24 0001
Revision: 57H24---
Coding: 322A403225760B020000
Shop #: WSC 00189 210 96593
ASAM Dataset: EV_ECM30BTD0114G0907589C 001001
ROD: EV_ECM30BTD_AU57.rod
VCID: 34311DF11EBEADA74A5-8060
7140 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Part No SW: 4G0 927 158 AA HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H16 1003
Revision: --H16---
ASAM Dataset: EV_TCMAL551211 002018
VCID: 6D87C8953D143C6F45B-8038
Part No SW: 4G0 907 379 J HW: 4G0 907 379 J
Component: ESP PREMIUM H09 0361
Coding: 49A7C70592E5E3A0FB00
VCID: 382929C102D649C766D-806C
Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
Component: BCM2 2.0 H32 0421
Coding: 01B93046000000000000
Shop #: WSC 02391 785 00200
VCID: 77ABEAFD4FC886BFAF7-8022
Serial number: 2312000210208011
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0076
Serial number: 12101200041184
Coding: 3622007825
ASAM Dataset: EV_AirCondiComfoUDS 002036
VCID: 629DABA9F4CA7317E89-8036
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 BCM1 2.0 H12 01300130
Revision: 20012002 Serial number: 00000001459586
Coding: 0200201050B49FE2C98100C380001908CF9DE7082F080201000008406100
VCID: 6E85CF993092C7777C1-803A
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120822 H36 0080
Serial number: 120920000515
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 20664589
Coding: 02006D
Subsystem 3 - Part No: 4G0 941 531 E
Component: E1 - LDS
Subsystem 4 - Part No: 4H0 907 658
Component: AQ_Hum_Sensor
No Faults Found
Revision: 11001001 Serial number: 61061229001247
Coding: 89EB0C
VCID: 71BFD4E5212CD88F613-8024
Part No SW: 4G0 907 561 A HW: 4G0 907 561
Component: ACC3 H17 0400
Coding: 7F04010202
VCID: 2809F981D276D947F6D-807C
10240 - Sensor for Automatic Distance Control
[FAULT_BLR_BLK8_31]
Reset counter: 170
Mileage: 193964 km
Date: 2019.03.30
Time: 14:27:33
Control Module temperature: 26 °C
Voltage terminal 15: 14.547 V
Velocity_vehicle_reference: 30.68 m/s
Longitudinal_acceleration_vehicle_reference: -0.08 m/s²
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00AHY9M
Coding: 30323436313330303539554A305234473053
VCID: 363527F908C2BFB7741-8062
Serial number: 3575HRB405B1IMPK9H3
Serial number: 3585HRB405F1HPAM49HX
Serial number: 3515JRB401E4UN9OP8SQ
Serial number: 3525JRB401C4UN9ON23Z
Serial number: 3554VRB400K4UNK8A1TK
Serial number: 3564VRB400G4UNK86P4C
Revision: -------- Serial number: 90372LJB0019X
Coding: 0000FD
VCID: 372B2AFD0F4846BF6F7-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Serial number: 24 08 2012 C0106888
Part No SW: 4G9 920 950 H HW: 4G9 920 950 H
Component: TDieGb AccNv H78 0515
Revision: 28131207 Serial number: 658220812596054
Coding: 338620081F512600010600
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 353720F515C4B4AF7DB-8060
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000721063
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001018
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790377423
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1208100000000000035A
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0076
Serial number: 16101200040546
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
0026 - Motor for Rear Left Upper Body Vent
B10D3 21 [008] - Signal Amplitude Too Low
Reset counter: 206
Mileage: 196404 km
Date: 2019.05.24
Time: 21:50:45
Voltage terminal 30: 14.48 V
Outside air temperature: 18.5 °C
Left Rear Upper Body Vent Motor-Act.val.: 9849
Left Rear Upper Body Vent Motor-Specified value: 9849
Left Rear Upper Body Vent Motor-Stop open: 11411
Left Rear Upper Body Vent Motor-Stop closed: 10000
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [008] - Signal Amplitude Too High
Fault Frequency: 10
Reset counter: 206
Mileage: 195913 km
Date: 2019.04.17
Time: 12:17:18
Voltage terminal 30: 13.77 V
Outside air temperature: 19.0 °C
Right Rear Upper Body Vent Motor-Act.val.: 11701
Right Rear Upper Body Vent Motor-Specified value: 11701
Right Rear Upper Body Vent Motor-Stop open: 11416
Right Rear Upper Body Vent Motor-Stop closed: 10000
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Coding: 008003
ROD: EV_AirSuspe_VW51.rod
VCID: 2E050F99F09287773C1-807A
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000040573590
Coding: 0078130000006001000001010101102030303232203232
Shop #: WSC 02311 785 00200
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA8201K9NE
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Part No SW: 4G0 907 566 E HW: 4G0 907 566
Component: J769 SWA MasterH02 0020
Revision: 00H02000 Serial number: 6PZ 010 287-04
Coding: 0011104
VCID: 313F14E5ED2C988F213-8064
Subsystem 1 - Part No: 4G0 907 568 E
Component: J770 SWA Slave H02 0020
Subsystem 2 - Serial number: 6PZ 010 287-24
Subsystem 3 - Serial number: 5F11.10.1200H02000AMS14422ÿ
Subsystem 4 - Serial number: S14422ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0506
Coding: 011F16005E01628002080013
VCID: 45D7503545A4242FEDB-8010
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0002931404
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D1BE9E4AAA397589-8066
Revision: 00002001 Serial number: 0184206701
Coding: 013B062220B93080832009042C01040F0000000000000000000000000000
Component: TSG BF H03 0506
Coding: 011F16005E01628002080002
VCID: 46D5573978A22F37E41-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000502100
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B03068DC380F25F1BF-807E
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
Component: ....AFS13.... H01 0020
Serial number: 121011-0004-013
Coding: 11226F33F918EB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
H02 0010
Coding: 1D0000
H02 0010
Coding: 1D0000
572171 - Stationary Cornering Lamp Left
C1083 13 [008] - Open Circuit
Fault Frequency: 36
Reset counter: 206
Mileage: 194202 km
Date: 2019.04.02
Time: 17:58:40
Part No SW: 4G0 035 061 J HW: 4G0 035 061
Component: Radio U DAB H60 0123
Revision: AB001007 Serial number: 109J/0C7582343
Coding: 010103020100000001
VCID: 2411EDB1AEDE3D27DA5-8070
Part No SW: 4G0 035 670 F HW: 4G0 035 670 H
Component: H-BNT-EU H50 0637
Revision: -------- Serial number: 190JZ0C7523127
Coding: 080101050003F9ED7D90EB3E00000003000001000200000000
VCID: 2615F7B9D8E2CF37C41-8072
Subsystem 1 - Part No: 8R0 060 884 AR
Component: ECE 2013 1505
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC9402P8W8
Subsystem 3 - Part No SW: 4G2 919 612 Q HW: 4G2 919 612 Q
Serial number: 90349LJB000N3
Component: CD-Database 4949
Component: TSG HL H03 0506
Coding: 010F14004001628002080002
VCID: 49CF5C0569BCC04F093-801C
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H09 0100
Revision: 5G001001 Serial number: 00000174171115
Coding: 0109080000000000
VCID: 71BFD4E521ACD88F613-8024
Part No SW: 4G9 959 107 B HW: 4G9 959 107 A
Component: HDSG-Modul H03 0143
Revision: 14003001 Serial number: 272200267
Coding: 097205C011
ROD: EV_HDSGAu571.rod
Component: TSG HR H03 0506
Part No SW: 4G0 907 217 A HW: 4H0 907 217 A
Component: DPC-SG H25 0038
Coding: EE060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 2615F7B9D862CF37C41-8072
0001 - Front Heater for Lane-Holding Assist
C1101 15 [008] - Open or Short to Plus
Fault Frequency: 77
Reset counter: 206
Mileage: 192840 km
Date: 2019.03.21
Time: 12:49:59
Outside air temperature: -41.5 °C
Voltage terminal 15: 12.5 V
Control Module temperature: 32.0 °C
Part No SW: 4G0 907 541 A HW: 4G0 907 541
Coding: 7F04010202
Part No SW: 4G0 907 107 D HW: 4H0 907 107
Component: BV-SG H31 0038
Serial number: 005000052009127
Coding: 04C23A1C1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 270BFABDDF68D63FFF7-8072
Component: RGS-VL H13 0080
Coding: 0066E608031F0376070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F14E5E1AC988F213-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0005
Serial number: 120919201954
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 4G0 907 160 B HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0004
Serial number: 120820200082
VCID: 2411EDB1AE5E3D27DA5-8070
End----------(Elapsed Time: 03:28, VBatt start/end: 12.2V/12.1V)-----------
