Results 1 to 10 of 12
Thread: 07 Q7 idle and throttle up feels like traction control
    Jun 2018
    Carmel, IN, USA
    Hello All,
    Q7 shows EPC and 'fishtail' on dash, feels like traction control at idle. The engine won't die at idle, but idles very roughly around 400rpm.....feels like half the engine is disabled. 10-15% throttle after releasing brake needs 1-2 seconds to clean up and run and runs reasonable well, but not cleanly above 20% throttle. This all came on all at once.
    Monday,27,May,2019,21:16:31:28853
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4505.4
    VIN: WA1BV74L97D054434   License Plate:
    Mileage: 290390km-180439mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 28 34 36 37 3C 42 46
              47 4F 52 55 56 61 62 65 67 6C 6D 6F 72 76 77
    VIN: WA1BV74L97D054434   Mileage: 290390km-180439miles
    05-Acc/Start Auth. -- Status: Malfunction 1010
    0E-Media Player 1 -- Status: Malfunction 0010
    67-Voice Control -- Status: Malfunction 0010
    Address 01: Engine        Labels:. 079-907-560-BAR.clb
       Part No SW: 4L0 910 560 C    HW: 4L0 907 560 A
       Component: 4.2l V8/4V          0060
       Revision: 71H21---    Serial number:
       Coding: 01210009190F0560
       Shop #: WSC 03089 444 84152
       VCID: 2809040C6EF41017F6D-807C
    18 Faults Found:
    001112 - Evap System Purge Control Valve (N80)
                   P0458 - 002 - Short to Ground - MIL ON
                        Fault Status: 11100010
                        Mileage: 288046 km
                        Date: 2019.02.14
                        Time: 20:40:33
                        RPM: 1677 /min
                        Load: 37.6 %
                        Temperature: 35.0C
                        Temperature: 35.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 11.176 V
    005173 - Secondary Air Pump Relay (J299)
                   P1435 - 002 - Short to Ground - MIL ON
                        Mileage: 288046 km
                        Date: 2019.02.14
                        Time: 20:40:33
                        RPM: 1677 /min
                        Load: 37.6 %
                        Temperature: 35.0C
                        Temperature: 35.0C
                        Voltage: 11.303 V
    000258 - Mass Air Flow Sensor (G70)
                   P0102 - 002 - Signal too Low - MIL ON
                        Mileage: 288046 km
                        Date: 2019.02.14
                        Time: 20:40:33
                        RPM: 1702 /min
                        Load: 23.1 %
                        Temperature: 35.0C
                        Temperature: 35.0C
                        Voltage: 11.303 V
    000268 - Mass Air Flow Sensor (G246)
                   P010C - 002 - Signal too Low - MIL ON
                        Mileage: 288046 km
                        Date: 2019.02.14
                        Time: 20:40:33
                        RPM: 1702 /min
                        Load: 23.1 %
                        Temperature: 35.0C
                        Temperature: 35.0C
                        Voltage: 11.303 V
    008852 - Fuel Pressure Regulator Valve (N276)
                   P2294 - 004 - Open Circuit - Intermittent - MIL ON
                        Fault Status: 10100100
                        Fault Frequency: 9
                        Mileage: 290240 km
                        Date: 2009.01.28
                        Time: 00:00:39
                        RPM: 1468 /min
                        Load: 43.5 %
                        Temperature: 35.0C
                        Temperature: 35.0C
                        Voltage: 11.176 V
    004763 - Fuel Pressure Regulator Valve; Bank 2 (N276)
                   P129B - 004 - Open Circuit - Intermittent - MIL ON
                        Fault Frequency: 7
                        Mileage: 290240 km
                        Date: 2009.01.28
                        Time: 00:00:39
                        RPM: 1468 /min
                        Load: 43.5 %
                        Temperature: 35.0C
                        Temperature: 35.0C
                        Voltage: 11.176 V
    008196 - Intake Manifold Flap; Bank 1
                   P2004 - 004 - Stuck Open
                        Mileage: 290240 km
                        Date: 2009.01.28
                        Time: 00:00:42
                        RPM: 1275 /min
                        Load: 25.5 %
                        Temperature: 35.0C
                        Temperature: 34.0C
                        Voltage: 12.827 V
    009217 - EVAP Leak Detection Pump Control Circuit
                   P2401 - 002 - Short to GND - MIL ON
                        Mileage: 290240 km
                        Date: 2009.01.28
                        Time: 00:00:49
                        RPM: 826 /min
                        Load: 29.8 %
                        Temperature: 34.0C
                        Temperature: 33.0C
                        Voltage: 13.335 V
    008197 - Intake Manifold Flap; Bank 2
                   P2005 - 004 - Stuck Open
                        Mileage: 290240 km
                        Date: 2009.01.28
                        Time: 00:08:26
                        RPM: 831 /min
                        Load: 32.5 %
                        Temperature: 27.0C
                        Temperature: 27.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 13.335 V
                   P2004 - 002 - Stuck Open - MIL ON
                        Mileage: 290240 km
                        Date: 2009.01.28
                        Time: 00:17:03
                        RPM: 639 /min
                        Load: 49.4 %
                        Speed: 1.0 km/h
                        Temperature: 68.0C
                        Temperature: 33.0C
                        Voltage: 13.081 V
                   P2005 - 002 - Stuck Open - MIL ON
                        Mileage: 290240 km
                        Date: 2009.01.28
                        Time: 00:17:03
                        RPM: 639 /min
                        Load: 49.4 %
                        Speed: 1.0 km/h
                        Temperature: 68.0C
                        Temperature: 33.0C
                        Voltage: 13.081 V
                   P0300 - 001 -  - Intermittent
                        Fault Status: 00100001
                        Mileage: 290302 km
                        Date: 2009.02.03
                        Time: 19:22:08
                        RPM: 2167 /min
                        Load: 32.1 %
                        Speed: 99.0 km/h
                        Temperature: 96.0C
                        Temperature: 15.0C
                        Voltage: 13.589 V
    000772 - Cylinder 4
                   P0304 - 001 - Misfire Detected - Intermittent
                        Mileage: 290302 km
                        Date: 2009.02.03
                        Time: 19:22:08
                        RPM: 2167 /min
                        Load: 32.1 %
                        Speed: 99.0 km/h
                        Temperature: 96.0C
                        Temperature: 15.0C
                        Voltage: 13.589 V
                   P0087 - 002 - Too Low
                        Fault Status: 01100010
                        Mileage: 290330 km
                        Date: 2009.02.03
                        Time: 20:17:22
                        RPM: 703 /min
                        Load: 61.2 %
                        Speed: 2.0 km/h
                        Temperature: 88.0C
                        Temperature: 53.0C
                        Voltage: 13.462 V
    000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
                   P0031 - 002 - Short to Ground - Intermittent
                        Mileage: 290375 km
                        Date: 2009.02.08
                        Time: 05:41:37
                        RPM: 737 /min
                        Load: 43.5 %
                        Temperature: 93.0C
                        Temperature: 65.0C
                        Voltage: 13.462 V
    000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
                   P0051 - 002 - Short to Ground - Intermittent
                        Mileage: 290375 km
                        Date: 2009.02.08
                        Time: 05:41:37
                        RPM: 737 /min
                        Load: 43.5 %
                        Temperature: 93.0C
                        Temperature: 65.0C
                        Voltage: 13.462 V
    000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
                   P0057 - 002 - Short to Ground
                        Mileage: 290375 km
                        Date: 2009.02.08
                        Time: 05:42:08
                        RPM: 1761 /min
                        Load: 62.3 %
                        Speed: 30.0 km/h
                        Temperature: 90.0C
                        Temperature: 54.0C
                        Voltage: 13.843 V
    000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                   P0037 - 002 - Short to Ground
                        Mileage: 290375 km
                        Date: 2009.02.08
                        Time: 05:42:18
                        RPM: 1245 /min
                        Load: 25.1 %
                        Speed: 28.0 km/h
                        Temperature: 90.0C
                        Temperature: 57.0C
                        Voltage: 13.970 V
    Readiness: 0010 1101
       Part No SW: 09D 927 750 FH    HW: 09D 927 750 FH
       Component: AL 750 6A           0959
       Revision: 00H52000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
       VCID: 79AF1148C5DE599FD93-802C
                013 - Check DTC Memory
                        Fault Frequency: 7
                        Reset counter: 0
                        Date: 2006.05.10
                        Time: 12:00:02
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
       Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
       Component: ESP ALLRAD MK25E1   0130
       Revision: 00H21001
       Coding: 0021553
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 15:01:32
                        Count: 12545
                        Count: 8211
                        Count: 40192
                000 -  -  - Intermittent
                        Reset counter: 160
                        Mileage: 289808 km
                        Date: 2009.01.28
                        Time: 03:01:33
                        Count: 192
                        Count: 13057
                        Count: 297
                        Count: 41216
                        Reset counter: 120
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:36:30
                        Count: 14593
                        Count: 128
                        Count: 33792
                        Fault Status: 01101101
                        Reset counter: 76
                        Mileage: 288035 km
                        Date: 2019.02.14
                        Time: 19:20:57
                        Count: 12289
                        Count: 8196
                        Count: 42752
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
       Component: FBSAUDIC6 ELV   H05 0130
       Revision: 00H05000    Serial number: 10603401789549
       Coding: 0000143
       Shop #: WSC 03213 444 84058
       VCID: 25170D3819E60D7FCDB-8070
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 KSG   H28 0080
    20 Faults Found:
    00190 - Driver's Door Handle Touch Sensor (G415)
                007 - Short to Ground
                        Fault Status: 01100111
                        Fault Frequency: 16
                        Reset counter: 120
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Fault Status: 01110111
                        Reset counter: 242
                        Mileage: 280518 km
                        Date: 2018.11.30
                        Time: 15:42:26
                        Reset counter: 218
                        Mileage: 256955 km
                        Date: 2018.06.13
                        Time: 18:26:30
    00191 - Passenger's Door Handle Touch Sensor (G416)
                        Reset counter: 218
                        Mileage: 256955 km
                        Date: 2018.06.13
                        Time: 18:26:30
                        Fault Status: 00111011
                        Reset counter: 110
                        Mileage: 268128 km
                        Date: 2018.08.09
                        Time: 16:25:04
    00166 - Access/Start Authorization Switch (E415)
                        Fault Status: 00111010
                        Reset counter: 154
                        Mileage: 275785 km
                        Date: 2018.09.11
                        Time: 14:13:59
    00532 - Supply Voltage B+
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:25:34
                        Fault Frequency: 16
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:24:37
                        Reset counter: 157
    00288 - Steering Column Lock Actuator (N360)
                        Reset counter: 157
                        Fault Frequency: 19
                        Reset counter: 157
                        Fault Frequency: 19
                        Reset counter: 157
                015 - Cannot Be Tested at this Time - Intermittent - MIL ON
                        Fault Status: 10101111
                        Fault Priority: 15
                        Fault Frequency: 255
                        Reset counter: 157
                        Fault Frequency: 19
                        Reset counter: 157
                        Fault Frequency: 19
                        Reset counter: 157
                        Fault Frequency: 18
                        Reset counter: 157
                        Fault Frequency: 18
                        Reset counter: 157
                        Fault Status: 01111011
                        Reset counter: 243
                        Mileage: 280940 km
                        Date: 2018.12.09
                        Time: 19:31:26
    02241 - Engine Control Module; Immobilizer Data not Adapted
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:53:07
    00230 - Transmission Park Selector Switch (F305)
                        Fault Status: 00101010
                        Reset counter: 160
                        Mileage: 290353 km
                        Date: 2009.02.08
                        Time: 03:31:31
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L0 910 731     HW: 4E0 035 729 A
       Component: Interfacebox    H43 2740
       Revision: 00000000    Serial number: 354J 067509089
       Coding: 0002003
       VCID: 65974D385966CD7F0DB-8030
       Component: E0380 BedienteilH01 0060
       Subsystem 2 - Serial number: 00000001977162
       Subsystem 3 - Serial number: 0131.01.120000000100010766
       Subsystem 4 - Serial number: 010766
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 130
                        Mileage: 288841 km
                        Date: 2019.02.19
                        Time: 19:30:42
                        Reset counter: 160
                        Time Indication: 15
       Part No SW: 4L0 910 043     HW: 4L0 820 043 F
       Revision: 00---010    Serial number: 00000030006418
       Coding: 0786472
       VCID: 619F59284D4EA15FF13-8034
    6 Faults Found:
    00710 - Defroster Flap Positioning Motor (V107)
                003 - Mechanical Failure
                        Fault Status: 01100011
                        Reset counter: 120
                        Mileage: 256955 km
                        Date: 2018.06.13
                        Time: 18:04:14
                        Voltage: 11.70 V
                        Temperature: 33.0C
                        (no units): 63.0
                        (no units): 193.0
                        Temperature: 43.0C
                        Fault Status: 01101010
                        Fault Frequency: 110
                        Reset counter: 120
                        Mileage: 286374 km
                        Date: 2019.01.31
                        Time: 08:11:30
                        Temperature: 9.0C
                        Reset counter: 129
                        Mileage: 288682 km
                        Date: 2019.02.19
                        Time: 06:29:35
                        Temperature: 36.0C
                        Temperature: 11.0C
                        Temperature: 13.0C
                        RPM: 1720 /min
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 11.0C
    00456 - Control Module for Access and Start Control (J518)
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 15:01:36
                        Bin. Bits:    01000
                        Fault Frequency: 15
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:36:32
                        Voltage: 9.50 V
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:45:21
                        Voltage: 6.90 V
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Coding: 0113123
       VCID: 3039EC6C562458D72ED-8064
       Component: Wischer AU716   H12 0080
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                        Reset counter: 120
                        Mileage: 262136 km
                        Date: 2019.01.30
                        Time: 21:44:00
                        Reset counter: 157
                        Mileage: 262136 km
                        Date: 2009.03.25
                        Time: 14:33:00
                        Fault Frequency: 13
                        Reset counter: 120
                        Mileage: 262136 km
                        Date: 2019.01.15
                        Time: 16:32:00
                        Fault Frequency: 14
                        Reset counter: 160
                        Mileage: 262136 km
                        Date: 2009.03.11
                        Time: 13:40:00
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 262136 km
                        Date: 2009.03.11
                        Time: 13:40:00
       Part No SW: 4L0 910 111 A    HW: 4L0 035 111
       Component: CD-Changer      H41 0100
       Revision: 00000000    Serial number: AUZ5ZBF3048527
       VCID: 1E6522D43CB0DEA78C1-804A
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:26:56
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 D    HW: 4E0 035 593
       Component: SDAR SIRIUS     H04 0670
       Revision: 00000000    Serial number: AUZ4Z7F5032162
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:25:03
                        Voltage: 8.40 V
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:25:03
                        Voltage: 8.40 V
       Component: 73 AIRBAG AUDI8RH39 0210
       Revision: 03H39000    Serial number: 0038QD03AMA9
       Coding: 0014131
       VCID: 2B03FB007F023B0F1BF-807E
       Subsystem 1 - Part No: 4L0 910 339
       Component: BF-Gewichtsens. H02 0020
       Subsystem 2 - Serial number: 6332QSME127A22335
       Subsystem 3 - Serial number: 6342QSME130B0B1BE
       Subsystem 4 - Serial number: 6352QSME126B4275F
       Subsystem 5 - Serial number: 6362QSME127B2945J
       Subsystem 6 - Serial number: 63734SME1514206BV
       Subsystem 7 - Serial number: 63834SME15162D47+
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
       Revision: 00H03000    Serial number: 90026062490112
       Coding: 0012242
       VCID: 270B073063EA1F6FFF7-8072
       Component: E0221           H07 0090
                        Fault Frequency: 12
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:26:12
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:27:09
                        Reset counter: 159
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:33:59
    Address 17: Instruments        Labels:. 4L0-920-xxx-17.clb
       Part No SW: 4L0 920 983 M    HW: 4L0 920 983 M
       Component: KOMBIINSTR.         0900
       Revision: 00200000    Serial number: AYF01HN1A
       Coding: 3697283
       Shop #: WSC 03213 444 04841
       VCID: 3C21C85C8A6CACB7825-8068
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:44:21
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D0691580E2
       Coding: F5F7FE7F347A02
       Shop #: WSC 03089 444 54655
       VCID: 6C81381CBA8CFC37525-8038
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:26:22
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:33:59
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:46:30
       Part No SW: 4L0 910 158     HW: 4L0 919 158 D
       Revision: 00---007    Serial number: 00000000075462
       Coding: 0000006
       VCID: 6889440CAE74D01736D-803C
                        Reset counter: 218
                        Mileage: 256955 km
                        Date: 2018.06.13
                        Time: 18:04:20
    00003 - Control Module
                        Fault Status: 00100011
                        Mileage: 275778 km
                        Date: 2018.09.11
                        Time: 13:44:43
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 15:01:31
                        Bin. Bits:    00000
                        Fault Frequency: 15
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:36:32
                        Voltage: 9.50 V
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:45:21
                        Voltage: 6.90 V
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 B    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7550
       Revision: --H03001    Serial number: 15.1528-0095.2
       Coding: 0015520
       VCID: 290F010875FE291FE93-807C
                        Fault Frequency: 34
                        Reset counter: 160
                        Error Code: 13
                        Fault Frequency: 11
                        Reset counter: 160
                        Error Code: 64
    01577 - Turn-Off due to Over-Temp
                        Reset counter: 155
                        Mileage: 289901 km
                        Date: 2009.02.25
                        Time: 13:47:52
                        Error Code: 68
    01398 - Signal Conductor for Central Locking; Doors Open
                        Reset counter: 154
                        Mileage: 290008 km
                        Date: 2009.03.11
                        Time: 13:39:47
                        Error Code: 71
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:53:36
                        Error Code: 116
       Part No SW: 4F0 910 760     HW: 4L0 959 760
       Component: Sitzmemory FS   H01 0100
       Revision: 00000000    Serial number: 00000000896401
       Coding: 0082954
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 27752 km
                        Date: 2009.02.25
                        Time: 13:26:33
                        Reset counter: 157
                        Mileage: 28096 km
                        Date: 2009.03.25
                        Time: 14:34:02
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 D
       Component: MNS US          H48 1100
       Revision: 00000000    Serial number: 313GJ067503840
       VCID: 3829D44CBE54809766D-806C
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:26:22
                        Hex Value: 0x499C
                        Hex Value: 0x5741
                        Hex Value: 0x0045
    02927 - DVD Read Error
                        Fault Frequency: 13
                        Reset counter: 131
                        Mileage: 281929 km
                        Date: 2018.12.20
                        Time: 20:06:19
                        Hex Value: 0x5C6D
                        Hex Value: 0x3E3E
                        Hex Value: 0x04FF
                        Hex Value: 0x0000
       Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH06 0060
       Revision: 00H06000    Serial number: 6PZ 009 014-00
       VCID: 2C01F81C7A0C3C37125-8078
       Subsystem 1 - Part No: 4L0 910 568 A
       Component: J0770_SWA_Slave_H05 0060
       Subsystem 2 - Serial number: 6PZ 009 014-20
       Subsystem 3 - Serial number: 3F28.09.0600H0500000010009
       Subsystem 4 - Serial number: 010009
    02850 - Control Module 2 for Lane Change Assistance (J770)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 239
                        Mileage: 259168 km
                        Date: 2018.06.24
                        Time: 11:22:52
                        Reset counter: 157
                        Mileage: 16 km
                        Date: 2009.03.25
                        Time: 19:05:56
                        Fault Frequency: 14
                        Reset counter: 160
                        Mileage: 16 km
                        Date: 2009.02.18
                        Time: 18:36:58
    02857 - Supply Voltage for Lane Change Assistance Control Module 2
                        Fault Frequency: 13
                        Reset counter: 160
                        Mileage: 16 km
                        Date: 2009.02.18
                        Time: 18:37:18
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 16 km
                        Date: 2009.02.18
                        Time: 18:45:11
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00000000    Serial number: a
       Coding: 0051915
       VCID: 2F3BEF104B1A472F377-807A
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:45:22
       Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
       Component: Komfortgeraet   H05 0020
       Revision: 0020 ---    Serial number: 01021089900000
       Coding: 7632925
       VCID: 313FE9685D2E51DF213-8064
                        Fault Frequency: 37
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:34:04
    02956 - Lamp in Trunk/Hatch Lid; Left
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 120
                        Mileage: 278630 km
                        Date: 2018.09.23
                        Time: 09:15:53
                        Bin. Bits:  000 010
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:46:21
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 D    HW: 4L0 035 223 A
       Component: DSP-High AU716  H02 0110
       Revision: PROD_01     Serial number: 00000000009593
       Coding: 0000056
       Shop #: WSC 21843 002 1048576
                        Reset counter: 160
                        Mileage: 290008 km
                        Date: 2009.03.11
                        Time: 13:40:31
                        Voltage: 8.30 V
                        Reset counter: 160
                        Mileage: 290008 km
                        Date: 2009.03.11
                        Time: 13:39:41
                        Voltage: 8.30 V
    02247 - Subwoofer (R148/R157)
                        Reset counter: 156
                        Mileage: 279900 km
                        Date: 2018.10.28
                        Time: 13:35:56
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000043549
       Coding: 0012001
       VCID: 5EE562D47C309EA7CC1-800A
                        Reset counter: 157
                        Mileage: 262136 km
                        Date: 2009.03.25
                        Time: 14:33:00
                        Voltage: 11.800 V
                        Temperature: 77.0C
                        Fault Status: 00110010
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 262136 km
                        Date: 2009.02.25
                        Time: 13:27:00
                        Voltage: 7.000 V
                        Temperature: 77.0C
                        Fault Frequency: 12
                        Reset counter: 160
                        Mileage: 262136 km
                        Date: 2009.02.25
                        Time: 13:25:00
                        Voltage: 8.300 V
                        Temperature: 77.0C
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00-00000
       Coding: 0051915
                        Fault Frequency: 9
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:34:01
                        Fault Frequency: 9
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:34:01
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:45:18
       Coding: 0000022
                        Fault Frequency: 20
                        Reset counter: 40
                        Mileage: 290248 km
                        Date: 2009.03.25
                        Time: 14:53:08
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290392 km
                        Date: 2009.02.18
                        Time: 18:45:16
       Part No SW: 4E0 910 541 M    HW: 4E0 035 541 P
       Component: TUNER EU/US/RDW H42 0570
       Revision: 00000000    Serial number: 388I$067552149
       VCID: 2A0DFE0470F82207E09-807E
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:25:38
                        Fault Frequency: 187
                        Reset counter: 160
                        Mileage: 279905 km
                        Date: 2018.11.11
                        Time: 14:04:21
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000052559
       Shop #: WSC 03089 444 85777
       VCID: 6491503C525CB4771A5-8030
       Component: von VA0  0123456789
       Coding: 344630393135313035442056413030313233343536373839
    02256 - Quiescent Current
                        Reset counter: 160
                        Mileage: 235664 km
                        Date: 2018.02.19
                        Time: 03:18:49
                        Mileage: 237654 km
                        Date: 2018.02.27
                        Time: 20:36:59
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:27:30
                        Fault Frequency: 18
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:33:58
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Coding: 0051722
                        Fault Frequency: 34
                        Reset counter: 120
                        Mileage: 284413 km
                        Date: 2019.01.13
                        Time: 18:17:04
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:45:16
       Revision: 00050100    Serial number: 00000900033033
       Coding: 0062424
       VCID: 221D162408C8FA47A89-8076
                        Fault Frequency: 18
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:34:08
                        (no units): 0.0
                        Voltage: 11.90 V
                        (no units): 33.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Fault Status: 10100010
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:45:53
                        (no units): 255.0
                        Voltage: 6.80 V
                        (no units): 42.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                        Reset counter: 93
                        Mileage: 259170 km
                        Date: 2018.06.24
                        Time: 11:26:25
                        (no units): 0.0
                        Voltage: 11.60 V
                        (no units): 19.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000609040267
       Shop #: WSC 12336 024 394758
       VCID: 3431E07CA23C64F74A5-8060
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:25:34
       Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J6942CX
       Coding: 1001001
       VCID: 2411103C12DCF477DA5-8070
                        Fault Frequency: 17
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:24:42
                            Term 15 Off
                            Reverse OFF
                        Count: 3
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:25:28
                            Term 15 Off
                            Reverse OFF
                        Count: 3
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 3 - Serial number: RD06.10.06--H21001001C0290
       Subsystem 4 - Serial number: 1C0290
    00317 - Rear Lid Control Module (J605)
                        Reset counter: 159
                        Mileage: 290330 km
                        Date: 2009.02.08
                        Time: 02:41:18
                        Fault Frequency: 18
                        Reset counter: 160
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:33:59
       Revision: AAH05061    Serial number: 001005364-----
       Coding: 0003595
       VCID: 26150A3464E00667C41-8072
       Component: J_245_EE15_SKB09H10 0180
       Component: J_394_EE15_SKB09H10 0180
       Component: J_392_EE15_SKB09H10 0180
                        Fault Frequency: 11
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:25:13
    02961 - Lamp in Bumper; Rear Right
                        Reset counter: 114
                        Mileage: 279918 km
                        Date: 2018.11.13
                        Time: 06:37:47
                        Bin. Bits:  000 001
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:33:59
    02907 - Control Module for Roof Shade (J394)
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 19:15:51
    02906 - Control Module for Sliding Roof; Rear (J392)
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 20:24:23
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Coding: 0051722
                        Fault Frequency: 40
                        Reset counter: 120
                        Mileage: 290397 km
                        Date: 2009.02.08
                        Time: 15:12:52
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:45:17
       Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
       Revision: 00H09000    Serial number: 06230701511300
       Coding: 0021246
                        Fault Frequency: 9
                        Reset counter: 160
                        Mileage: 290397 km
                        Date: 2009.02.18
                        Time: 18:45:24
                        Fault Frequency: 14
                        Reset counter: 160
                        Mileage: 290008 km
                        Date: 2009.03.11
                        Time: 13:39:43
                        Fault Frequency: 18
                        Reset counter: 40
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:33:58
    00576 - Terminal 15
                        Fault Frequency: 14
                        Reset counter: 157
                        Mileage: 290241 km
                        Date: 2009.03.25
                        Time: 14:53:09
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007572868
       Coding: 0010900
                        Reset counter: 160
                        Mileage: 289899 km
                        Date: 2009.02.25
                        Time: 13:26:21
    End----------(Elapsed Time: 02:46, VBatt start/end: 12.0V/12.4V)-----------
    Clear fault codes and repost scan after car idling 1 minute.
    Consumers must be isolated for damage, blown fuse, water ingress or wiring damage.
  3. Likes Golftwincharged liked this post
    Looks like a power problem of some sort; blown fuse, failed relay, etc.
    I would start by looking for a common source of power for the actuators that show "Short to GND" faults in 01-Engine.
    Reset counter: 120
    Mileage: 290397 km
    Date: 2009.02.18
    Time: 18:36:30
    Count: 14593
    Count: 128
    Count: 33792
    Might be a good idea to charge or install fresh batteries & since lower levels are unacceptable or have been exceeded.
    Better double down on some Wet Kessy water penetration?
    Kessy scream's water ingress with 20 DTC's!
    HQ
    Fuse S13? Engine bay, left side, close to windshield.
    Jef
  7. Likes Jack@European_Parts, Uwe liked this post
    Jun 2018
    Carmel, IN, USA
    Fuse S13 was blown. Replacement fuse blew immediately on startup. Clearly we have an issue on this circuit.
    The first consumer to act up was the TPMS, then Side Assist. Where are those modules located in the vehicle?
    The battery's been disconnected for a few days now, will reconnect this evening and scan per Jack's instructions.
    Best to leave disconnected and open Kessy for inspection and post detailed photos.
  10. #8
    HQ
    https://forums.ross-tech.com/showthr...ou-put-them-in
    Rig up a test light tool like that, pop it in place of the S13 fuse. If you have a short to ground, it will light up pretty bright.
    Fuse S13 powers several items:
    • N112
    • N320
    • N290
    • N402
    • N80
    Unplug all those items, the test light should not light up bright (pop fuses). If it does, you've got a wire shorted to ground, start a careful visual inspection.
    Cool, only took 3 hours to post this....
    Jef
  11. Likes Jack@European_Parts, Uwe liked this post
  12. #9
    Jun 2018
    Carmel, IN, USA
    Jeff,
    Here's one for ya....I have not one but two brake bulb test lights that I've been using for 30+ years. Ha! Mine have alligator clips on them, I'll just clip them to crimp-on spade terminals and follow your instructions. GMTA indeed!
    Best,
    Rob
  13. Likes Jack@European_Parts, Uwe liked this post
  14. #10
    Rob,
    That makes you an old timer too because I still have mine.
