As i'm not yet verified I'm writing in this section. I have changed clutch switch, also parking brake module, I calibrated all sensors in ABS module, but the problem is still here, I get:
00650 - Clutch Pedal Switch (F36)
Also yellow brake light is turned on on instrument cluster. Do you maybe know what the problem could be?
Thank you for your help.
Removed. Data from a clone/pirate copy of VCDS is not welcome here.
