2015 Audi A5 ACC Not Available
m3nt4l
C?ID=348982
Good evening,
I have an 2015 Audi A5 and randomly the ACC stopped working and displayed “ACC: Not Available”
I scanned the car and have found a fault code in relation to the ACC. Saying “Deactivation after multiple emergency braking activations”
I have tried to clear it but it comes back straight away. Any help?
Kind regards
Monday,27,May,2019,19:10:22:08713
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
VIN: WAUZZZ8T6GA031772   License Plate: YB65 TBY
Mileage: 78300km-48653mi   Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 42 44 46 47 52 53 56 5F AC
VIN: WAUZZZ8T6GA031772   Mileage: 78300km-48653miles
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 BM    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8508
   Revision: 85H23---
   Coding: 0A254012234601080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906021BM 002008
   ROD: EV_ECM20TDI_AU48.rod
   VCID: 71AA2BE3A08B13C222-8024
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Fault Frequency: 49
                    Mileage: 77629 km
                    Date: 2019.05.10
                    Time: 15:00:23
                    Coolant temperature: 39 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 11.820 V
                    ACC target acceleration: 0.007 m/s²
                    ACC control module received status-Bits 0-7: 7
                    Active brake system error status-Bits 0-7: 1
                    Status of ACC/CCS acceleration interface-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
                    Engine status: COENG_READY
   Part No SW: 8K9 927 156 B    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H03 0004
   Revision: --H03---
   Coding: 000001
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001016
   ROD: EV_TCMDL501021.rod
   VCID: 3C34CAD7B749AEAAC1-8068
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 441DCC01
   VCID: 095A6303A01B4B028A-805C
   Part No SW: 8K0 907 064 KE    HW: 8K0 907 064 KE
   Component: BCM2 2.0      H15 0711
   Coding: 01B04040000000000000
   VCID: 7DB207D3E4D367A2B6-8028
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0815000127363005
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 3215000161488011
   Part No SW: 8K2 820 043 BB    HW: 8K2 820 043 BB
   Component: KLIMA 3 ZONEN H04 0122
   Revision: D1000000    Serial number: 01271020150963
   Coding: 342600A000
   VCID: 6A983C8F855DE01A63-803E
   Revision: 08016001    Serial number: 00001200936102
   Coding: 260000108034AFC00081400300001D0D001D438827090201000008004400030100000024000000
   VCID: 78BC16C7CBF1428AE5-802C
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 011015  H13 0080
   Serial number: SWF15100015110
   Coding: 00FD11
   Serial number: 60863968
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002110157109
   Serial number: EB8887D7000000000001
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H11 0110
   Coding: 00F2BA
   VCID: 312AEBE3680B53C262-8064
04016 - Deactivation after Multiple Emergency Braking Activations
                    Reset counter: 97
                    Mileage: 77629 km
                    Date: 2019.05.10
                    Time: 15:00:29
                    Temperature: 19.0°C
                    Voltage: 11.65 V
                    Hex Value: 0x0057
                    Lateral Accel.: 0.00 m/s^2
   Component: AirbagVW-AU10 H49 0610
   Serial number: 003KFDD23B60
   Coding: 30533933363030303030554A305238543053
   VCID: 48DCA607F391F20A55-801C
   Serial number: 6334MSME552D4B12G
   Serial number: 6344MSME4D484178N
   Serial number: 6352QSME4A571E46S
   Serial number: 6362QSME59522B6EW
   Serial number: 63732SME3E524570$
   Serial number: 63832SME6E5706689
   Revision: --------    Serial number: 90372OJM000OY
   Coding: 00003E
   VCID: 44C4B237C7B9D66AB9-8010
   Part No SW: 8T0 920 984 M    HW: 8T0 920 984 M
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 5T-31YNAG
   Coding: 33A7010007012600010000
   VCID: 49DAA303E09B0B024A-801C
   Part No SW: 8R0 907 468 AA    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0070
   Revision: 1Z130032    Serial number: 3241Z15A24017C
   Coding: 80CF07FF00
   VCID: 7EB000DFE9D57CBAAF-802A
   Serial number: 3670298203
   Serial number: 15294003244011200410
   Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
   Component: TSG FA        H10 0305
   Coding: 011002224001120102
   VCID: 57FE757B262F6DF2CC-8002
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0030284429
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3E30C0DFA155BCBAEF-806A
   Revision: 00002001    Serial number: 0382809994
   Coding: 011B068280B900008320003680000047
   Revision: 00005001    Serial number: 94813052172707
   VCID: 2D12F7937433372246-8078
   Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
   Component: TSG BF        H09 0305
   VCID: 56E0787F212554FAD7-8002
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 10000000607669
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A38CCCFBD7D909AD3-806E
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109JW0F2514252
   Coding: 010103010000000001
   VCID: 2B16F98B4A27391258-807E
   Part No SW: 8R2 035 666 K    HW: 8R2 035 666 H
   Component: H-BN-EU       H49 0946
   Revision: --------    Serial number: 515J%0FB015337
   Coding: 130101020006A9ED21808B5E00000403E40000020000000000
   VCID: 41CABB23D8ABC34292-8014
   Subsystem 1 - Part No: 8R0 060 884 DF
   Component: EUR 2016  2204
   Component: DU7 High  H42 0104
   Serial number: A130JX0F3491713
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002413434
   Component: CD-Database  6890
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152741106
   ROD: EV_RDCMA00100_008.rod
   VCID: 2F2EED9B763F453274-807A
End----------(Elapsed Time: 01:37, VBatt start/end: 12.1V/12.1V)-----------
NEtech
C?ID=56995
Reset counter: 97
Mileage: 77629 km
Date: 2019.05.10
Time: 15:00:29
Temperature: 19.0°C
Voltage: 11.65 V
Hex Value: 0x0057
The car has had 2 or more Emergency Braking Activations, withing one ignition cycle.
Check if there is something covering the radar.
Else you would need to have an calibration made, at a shop who has the equipment for that.
Maybe a bad battery ?
