Hi All.
We picked up a summer project. It's an early 2004 V10 Touareg that the PO was just completely overwhelmed with and just wanted the car gone. I'ts led a rough life and for the past year or so was a resident at the local towing yard.
Interior footwells were soaked from the well known plugged front cowl drains being plugged. That has now been addressed and all is dry.
When we got it, the engine ran and the transmission was unlocked so it could be put in the service bay.
I did an initial scan on it before any work was performed and it is messed up although it seems no communication from the ABS module is a common theme in many of the modules.
I've pulled apart the left side carpet to access the main wiring bundle and resoldered the different factory spliced wires that are known to get wet and corroded.
I've unplugged re plugged in the ABS module, checked all the fuses, and charged up both batteries. Now, the engine runs but the transmission is locked.
I see the KESSY errors and have a plan to pull that and get the MOFSETs and resistors replaced.
Beyond the KESSY fixes, I'm not sure where to start with the repairs at this point. The engine runs but the transmission is locked in park.
I've posted the current scan below and welcome any suggestions.
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGGH77L64D060732 Mileage: 217170km-134943miles
Part No SW: 070 997 016 R HW: 028 101 172 9
Component: V10 5,0L EDCG000AGMª2813
Revision: 5KO3 Serial number: VWZ3Z0D7152879
Coding: 0060575
Shop #: WSC 02326 444 54085
VCID: 2952138183392102AA-50E6
18057 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller
RPM: 630 /min
Torque: 110.6 Nm
Speed: 3.6 km/h
Voltage: 13.98 V
Bin. Bits: 00001111
Torque: 308.1 Nm
17911 - Load Signal from Alternator Term. DF
P1503 - 000 - Implausible Signal
RPM: 588 /min
Torque: 102.7 Nm
Speed: 3.6 km/h
Voltage: 13.98 V
Bin. Bits: 00001111
(no units): 1.0
18253 - Please check DTC Memory of Steering Electronics (J527)
P1845 - 000 - - Intermittent
RPM: 693 /min
Torque: 94.8 Nm
Voltage: 11.86 V
Bin. Bits: 00001111
Bin. Bits: 00001111
Readiness: 1 1 1 0 1
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 BB
Component: AL 600 6Q 0467
Coding: 0004153
Shop #: WSC 31414 000 00000
VCID: 6FE63D997D5D0F3234-50E6
Address 05: Acc/Start Auth. Labels: None
Part No SW: 7L0 909 137 C HW: 7L0 909 137 C
Component: 2G Kessy 6850
Revision: 00H22072 Serial number: VWZ3Z0D7152879
Coding: 0147688
Shop #: WSC 02651 444 83466
VCID: 336EF1E951F56BD210-50E6
Component: ELV XXXX
6 Faults Found:
Fault Frequency: 14
Reset counter: 2
Time: 04:18:26
00955 - Key 1
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 0
Reset counter: 241
Date: 2064.00.00
Time: 00:00:14
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Fault Frequency: 0
Reset counter: 244
Date: 2064.00.00
Time: 00:00:14
00183 - Interior Access/Start Authorization Antenna 1 (R138)
Fault Frequency: 0
Reset counter: 43
Date: 2064.00.00
Time: 00:00:14
Fault Frequency: 14
Reset counter: 38
Date: 2064.00.00
Time: 00:00:14
Fault Status: 01101101
Fault Frequency: 0
Reset counter: 2
Date: 2064.00.00
Time: 00:00:14
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
VCID: 77F605F9050D47F2EC-50E6
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0021030
VCID: 356ACFF15F8175E23E-50E6
01596 - Motor for Outside/Recirculated Air Flap (V154)
00229 - Refrigerant Pressure
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 L
Component: 2702
Coding: 0086494
Shop #: WSC 02326 444 57416
VCID: 458ABF310F61E562AE-50C8
Subsystem 1 - Part No: 7L6 937 049 L
Component: 2702
No Faults Found
Address 11: Engine II Labels: None
Component: V10 5,0L EDCG000AGSª2813
Coding: 0060575
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00008441
Coding: 0012341
VCID: 234E01A9E115FB52E0-50E6
Subsystem 1 - Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
Date: 2063.15.31
Time: 31:60:00
Date: 2063.15.31
Time: 31:60:00
00532 - Supply Voltage B+
Reset counter: 39
Date: 2063.15.31
Time: 31:60:00
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000032
VCID: 4084AE251043C04A9D-50E6
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 980 P
Component: KOMBIINSTRUMENT RB4 2935
Coding: 0007231
Shop #: WSC 02326 444 83476
01335 - Drivers Seat/Mirror Position Control Module (J543)
Address 18: Aux. Heat Labels: 7L6-819-008.clb
Part No: 7L6 819 008 B
Component: Standheizung E1MAC 0235
Coding: 0000030
00664 - Fuel gauge
01126 - Engine Speed Signal
01408 - Under-Voltage Shut-Off (fixed Value)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 02326 444 53518
VCID: 70E43EE5606310CA2D-50E6
6 Faults Found:
01302 - Control Module for Telematic (J499)
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 040C623544DB1C6AF9-50E6
00926 - Terminal 30
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F06EDD92D3D7FB2A4-50E6
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
VCID: 66C858BD52A7CE7A47-5120
00492 - Body Pitch Angle from Level Control Module
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 H
Component: LUFTFDR.-CDC- 3C3P1 3099
Coding: 0015521
Shop #: WSC 02326 444 58767
VCID: 3874C6C54893888A25-5102
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
Coding: 0000003
VCID: 67D655B955ADD7727C-50E6
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 C
Component: B0 HSG 0102
Coding: 0000085
Shop #: WSC 26030 444 85857
VCID: 3C7CDAD57CABA4AAC1-4AB4
Subsystem 1 - Part No: 7L0 959 933 C
Subsystem 2 - Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Subsystem 3 - Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Subsystem 4 - Part No: 7L0 959 703 B
Subsystem 5 - Part No: 7L0 959 704 B
No Faults Found
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
VCID: 3776C5F9458D87F22C-50E6
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 G HW: 7L0 907 383 G
Component: ANHAENGERELEKTRONIK 8854
VCID: 3874C6C54893888A25-50E6
16347 - Control Module - EEPROM Error
014 - Defective
02579 - Trailer; Left Brake Lamps (M65)
02580 - Trailer; Right Brake Lamps (M66)
Address 6E: Ctrl Head Roof Labels: None
Part No: 7L6 919 044 L
Component: DACHDISPLAY 0538
Revision: 00800538 Serial number: 2009268.07
VCID: 4084AE251043C04A9D-50C8
Address 75: Telematics Labels: 3D0-035-617.lbl
Part No SW: 3D0 035 617 B HW: 3D0 035 617 B
Component: Telematik NAR1 0104
Coding: 0076510
Shop #: WSC 02326 444 00852
VCID: 1F460D59CD7DDFB2C4-50E6
01304 - Radio
Address 76: Park Assist Labels: None
Part No: 7L0 919 283 E
Component: 0E Einparkhilfe 0907
End-------------------------(Elapsed Time: 10:02)--------------------------
