Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Audi Q3 fault code 1048578 - No Basic Setting
  1. #21
    My car has been to the Audi dealer who has correctly reset the service interval counter, this has cleared the fault. It looks like the previous dealer who serviced the car made a mistake.
    Here is the final control module map.
    ;SW:8U0-920-990-A   HW:8U0-920-990-A ---  Instruments,,,,
    ;Component:KOMBI_COLOUR  H14 0030, Coding:42CF00,,,
    ;EV_Kombi_UDS_VDD_AU10,A04391,EV_Kombi_UDS_VDD_AU10.rod,,
    ;Tuesday,24,February,2015,17:01:18:04481
    ;VCDS Version: Release 14.10.1 (x64)  Data version: 20150130,,,,
    ;VCID: 3B7502F6B27421F97B2-806E,,,,
    Activating and deactivating all development messages,not active ,,,
    Automatic door locking,Display ,,,
    Day,24,,,
    Day counter,1160 d,,,
    Deactivate seat belt warning,No ,,,
    Display correction of consumptions and operating range,100%,,,
    Display correction of fuel gauge,0.0 ,,,
    Display format,not active ,,,
    Distance,27960 km,,,
    Driving profiled for range remaining,6.4,,,
    (1)-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation ,,,
    (2)-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure ,,,
    (3)-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality ,,,
    (4)-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster ,,,
    ESI: distance driven from inspection,13000 km,,,
    ESI: maximum value km-driving distance/inspection,30000 km,,,
    ESI: maximum value of time between inspections,730 d,,,
    ESI: minimum value km-driving distance/inspection,15000 km,,,
    ESI: minimum value of time between inspections,730 d,,,
    ESI: oil quality,good oil quality ,,,
    ESI: Resetting ESI,no warning ,,,
    ESI: soot entry,14700 km,,,
    ESI: thermal load,7800 km,,,
    ESI: time from inspection,287 d,,,
    Expanded display of traffic sign detection,On ,,,
    FIX: Distance covered since last mileage-dependent inspection,13000 km,,,
    Fix: Max. distance until next mileage-related inspection,30500 km,,,
    FIX: Maximum time until next time-dependent inspection,730 d,,,
    FIX: Time since last time-dependent inspection,1 d,,,
    Hour,17 H,,,
    Indicator light for start-stop operation,On ,,,
    Language version,English ,,,
    Language version in instrument panel insert control module,English ,,,
    Minute,1 min,,,
    Month,2,,,
    Seat belt warning,Version 4 ,,,
    (1)-Service-key settings-p_write_delay_time,40 s,,,
    (2)-Service-key settings-p_write_delay_speed,20 km/h,,,
    (3)-Service-key settings-p_write_distance,20 km,,,
    (4)-Service-key settings-p_forcewrite_qual_time,10 s,,,
    (5)-Service-key settings-p_main_switch_keyless,On ,,,
    (6)-Service-key settings-p_main_switch_basis,On ,,,
    SIA: maximum value of distance to service,14500 km,,,
    SIA: maximum value of time to service,365 d,,,
    Source for synchronization of time,GPS ,,,
    Speed threshold of dynamic oil pressure warning,kein Offset ,,,
    (1)-Speed warning-,active ,,,
    (2)-Speed warning-Unit,Miles per hour ,,,
    (3)-Speed warning-Speed,80,,,
    Staging,not active ,,,
    Synchronization duration radio clock,0 min,,,
    (1)-Units adjusted-Temperature,C ,,,
    (2)-Units adjusted-Distance,miles ,,,
    (3)-Units adjusted-Speed,Miles per hour ,,,
    (4)-Units adjusted-Pressure,bar ,,,
    (5)-Units adjusted-Volume,gallons (UK) ,,,
    (6)-Units adjusted-Time,24h ,,,
    (7)-Units adjusted-Date,dd_mm_yy ,,,
    (8)-Units adjusted-Consumption,Miles per gallon (UK) ,,,
    Upshift display in center panel,not active ,,,
    Year,2015,,,
    Service_Key_Clear_All_Counters,Yes ,,,
  2. #22
    Sep 2014
    Interestingly, I'm now suffering from the same issue.
    Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
       Part No SW: 8U0 920 990 E    HW: 8U0 920 990 E
       Component: KOMBI_COLOUR  H01 0240
       Coding: 42CF01
       Shop #: WSC 00049 770 00118
       VCID: 3F868C35A65840B9E2-806A
              B2010 00 [009] -  -
                        Reset counter: 138
                        Mileage: 29559 km
                        Date: 2016.09.01
                        Time: 11:17:36
    Oh and guess when my car was serviced.... Yup, 1st September 2016!
  3. #23
    Quote Originally Posted by CocoPops View Post
    Who serviced it?
    Feel free to post an Adaptation map from the cluster, maybe we can figure out what it's unhappy about.
  4. #24
    Sep 2014
    Sure thing:
    ;SW:8U0-920-990-E   HW:8U0-920-990-E ---  Instruments
    ;Component:KOMBI_COLOUR  H01 0240, Coding:42CF01
    ;EV_Kombi_UDS_VDD_AU10,A04399,EV_Kombi_UDS_VDD_AU10.rod
    ;Thursday,26,January,2017,21:17:30:09724
    ;VCDS Version: Release 17.1.1 (x64)  Data version: 20170107 DS267.0
    ;VCID: 3F868C35A65840B9E2-806A
    IDE00301-Distance,34260 km
    IDE00342-ESI: Resetting ESI,no warning
    IDE00343-Language version,English
    IDE00344-Seat belt warning,Version 4
    IDE00492-MAS00900-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation
    IDE00492-MAS02010-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure
    IDE00492-MAS02012-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality
    IDE00492-MAS02013-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster
    IDE00493-Display correction of fuel gauge,0.0
    IDE00499-Display correction of consumptions and operating range,100 %
    IDE00500-Hour,21 H
    IDE00501-Minute,17 min
    IDE00502-Year,2017
    IDE00503-Month,1
    IDE00504-Day,26
    IDE00505-Speed threshold of dynamic oil pressure warning,kein Offset
    IDE00510-ESI: distance driven from inspection,4700 km
    IDE00511-ESI: time from inspection,147 d
    IDE00512-ESI: minimum value km-driving distance/inspection,14500 km
    IDE00513-ESI: maximum value km-driving distance/inspection,30600 km
    IDE00514-ESI: maximum value of time between inspections,730 d
    IDE00515-ESI: oil quality,good oil quality
    IDE00517-ESI: soot entry,6000 km
    IDE00518-ESI: thermal load,3400 km
    IDE00819-Day counter,939 d
    IDE00820-Activating and deactivating all development messages,not active
    IDE00827-ESI: minimum value of time between inspections,730 d
    IDE01087-Staging,active
    IDE01153-SIA: maximum value of distance to service,14500 km
    IDE01154-SIA: maximum value of time to service,365 d
    IDE02327-Indicator light for start-stop operation,On
    IDE02494-Automatic door locking,Display
    IDE03329-Driving profiled for range remaining,6.8
    IDE03346-IDE00301-Units adjusted-Distance,miles
    IDE03346-IDE00316-Units adjusted-Time,24h
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
    IDE03346-MAS01456-Units adjusted-Speed,Miles per hour
    IDE03346-MAS02201-Units adjusted-Temperature,C
    IDE03346-MAS03032-Units adjusted-Volume,gallons (UK)
    IDE03346-MAS03033-Units adjusted-Consumption,Miles per gallon (UK)
    IDE03346-MAS03034-Units adjusted-Pressure,bar
    IDE03348-MAS01456-Speed warning-Speed,85
    IDE03348-MAS01561-Speed warning-Unit,Miles per hour
    IDE03348-MAS03206-Speed warning-Speed warning,active
    IDE03349-FIX: Max. distance until next mileage-related inspection,31600 km
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,4700 km
    IDE03352-FIX: Time since last time-dependent inspection,147 d
    IDE03360-Upshift display in center panel,not active
    IDE03371-Synchronization duration radio clock,0 min
    IDE03372-Source for synchronization of time,GPS
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
    IDE03568-ENG102019-Service-key settings-p_main_switch_basis,On
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
    IDE03867-Deactivate seat belt warning,No
    IDE04103-Language version in instrument panel insert control module,English
    IDE04112-Display format,not active
    IDE05193-Expanded display of traffic sign detection,On
    IDE06425-Roller test bench mode: functional,not active
    IDE07221-Cylinder shut-off,No display
    MAS03555-Lap counter,On
    ENG119824-boost_pressure,On
    ENG108924-Service_Key_Clear_All_Counters,Yes
    ENG114944-Start_up_screen,No display
    ENG112416-IDE01766-velocity_detection-Distance impulses,4
    ENG112416-MAS01209-velocity_detection-Speed source,Distance impulses
    Elapsed Time: 00:18
  5. Likes Uwe liked this post
  6. #25
    Sep 2014
    Just followed Wolfgangs ma/min values from 30600 to 30000 and 14500 to 15000.
    Sorted!
    Definitely worth storing this somewhere...
    It was serviced by local Audi dealer btw (official)
  7. Likes Uwe, Eric liked this post
  8. #26
    Sep 2014
    For completeness, here is the channel map POST change:
    ;Thursday,26,January,2017,21:26:42:09724
    IDE00500-Hour,21 H
    IDE00501-Minute,26 min
    IDE00502-Year,2017
    IDE00503-Month,1
    IDE00504-Day,26
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
    IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
    Elapsed Time: 00:18
    PS Glad it's resolved, I'm headin back inside... it's reading 0.0degrees out here
  9. Likes Uwe, Eric liked this post
  10. #27
    Sorted!
    I wonder if there was a version of ODIS that had incorrect scripts in it for a while?
  11. #28
    Aug 2017
    Quote Originally Posted by AIB Wolfgang View Post
    Moin,
    maybe I'm too many tolate but I think, the reason for this basic setting issue is based here:
    Please change the values max driving distance to 30000,
    Please change the values min driving distance to 15000 km.
    and minimum value of time between inspections to 365 d
    GOOD LUCK
    Thank You! In case it helps anyone else, I came across this thread as I had the "No Basic Setting" fault code on Instruments on my 2013 Audi A3 (8V model, UK spec). This exact same fix (including the exact same original distances of 30600 and 14500) worked perfectly.
    My car didn't have the fault code when new, but had been serviced by an Audi main dealer, so I guess they introduced the troublesome distances during their service reset.
    Thanks again!
  12. Likes Jack@European_Parts, Uwe liked this post
  13. #29
    Jan 2018
    Same Issue on Audi A1 62 Plate that went into local UK Audi dealer for a service
    Thanks for sharing AIB Wolfgang
    Moin,
  14. Likes Jack@European_Parts, Uwe liked this post
