Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Audi Q3 fault code 1048578 - No Basic Setting
    Repeated scans of my UK 2012 Audi Q3 2.0 TDi shows the following fault. I've tried clearing the fault code but it always immediately reappears. Does anyone know how to resolve this, or can tell me which aspect of 'Instruments' the fault code 1048578 refers to. Thanks, Andrew.
    Address 17: Instruments Labels: 8X0-920-xxx-17.clb
    Control Module Part Number: 8U0 920 990 A HW: 8U0 920 990 A
    Component and/or Version: KOMBI_COLOUR H14 0030
    Software Coding: 42CF00
    Work Shop Code: WSC 00049 770 00153
    ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04391 (AU21)
    VCID: 3B5BD896B287FDF97A9-806E
    B2010 00 [009] - -
    Reset counter: 67
    Mileage: 22510 km
    Date: 2014.10.16
    Time: 08:57:40
    Sep 2014
    Hi Andrew,
    Normal score here is to post a full AutoScan.
    I have the same Kombi Display in my Q3, I'll post my AutoScan here when I run it over the weekend for you.
  3. Likes Uwe, Jack@European_Parts liked this post
    As suggested by CocoPops, here is my full scan...
    Tuesday,09,December,2014,15:31:38:57949
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    Dealer/Shop Name: ACT
    VIN: WAUZZZ8U2CR020790   License Plate: A4 ACT
    Mileage: 25040km-15559mi   Repair Order:
    Chassis Type: 8U (8U0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 56 5F
              62 69 72
    VIN: WAUZZZ8U2CR020790   Mileage: 25040km-15559miles
    Address 01: Engine (J623-CFGC)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 PH    HW: 03L 906 018 ES
       Component: R4 2,0L EDC   H26 1793
       Revision: 41H26---    Serial number:
       Coding: 00250012043701080000
       Shop #: WSC 00049 770 00153
       ASAM Dataset: EV_ECM20TDI01103L906018PH 003002
       ROD: EV_ECM20TDI01103L906018EQ.rod
       VCID: 7F23EC86E61F21D9161-802A
    Address 02: Auto Trans
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 AM    HW: 5N0 614 109 AM
       Component: J104   C6 450M V49E 0005
       Revision: --H07---    Serial number: 00000005071467
       Coding: 0052365
       VCID: 76CD09A201256091457-8023
       Part No SW: 8U0 820 043 C    HW: 8U0 820 043 C
       Component: E87  Klimavoll      0040
       Revision: 00H03000    Serial number: 8U0820043C
       VCID: 3147FABEA8CB07A9D05-8064
    Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
       Part No SW: 8X0 907 063 K    HW: 8X0 907 063 K
       Component: BCM PQ35  M   110 0667
       Revision: AC110667
       Coding: 0E000A2CA805F1C0201841C02100094C53FF84AA216F912AE40887A400C5
       Shop #: WSC 40423 001 1048576
       VCID: 44A9A36AC77982010B3-8011
       Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119
       Component: WWS316 111031  H35 0071
       Coding: 0047F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Component: G397_RLFS  H06 0001
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177
       Component: DWA-Sensor H0  H01 0020
       Component: LIN BACKUP HO  H11 9005
    Address 10: Park/Steer Assist (J446)       Labels: 8X0-919-475.clb
       Part No SW: 8X0 919 475 K    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0040
       Revision: 11001001    Serial number: 55901126301937
       Coding: 090305
       ASAM Dataset: EV_EPHVA18AU21X0000 002005
       ROD: EV_EPHVA18AU21X0000.rod
       VCID: 4EBD814211357851AD7-801B
    Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
       Part No SW: 8U0 959 655     HW: 8U0 959 655
       Component: AirbagVW-AU10 H05 0410
       Serial number: 003DUR00GU7/
       Coding: 30393132313030303030554A305238553053
       Shop #: WSC 00049 770 00119
       ASAM Dataset: EV_AirbaAU10SMEAU316 001005
       ROD: EV_AirbaAU10SMEAU316.rod
       VCID: 0429636A8FF942014B3-8051
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME1D050B16ZZZX
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME2C040B16ZZZO
       Serial number: 3516KSME12030B16ZZZD
       Serial number: 3526KSME48160B16ZZZR
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME40483814ZZZY
    Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
       Part No SW: 8X0 953 521 D    HW: 5K0 953 569 B
       Revision: FF010016    Serial number: 20111122300483
       Coding: 1894204000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 3D5FD68EAC93F3C944D-8068
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Component: E221 - MFL  H08 0009
    Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
       Part No SW: 8U0 920 990 A    HW: 8U0 920 990 A
       Component: KOMBI_COLOUR  H14 0030
       Coding: 42CF00
              B2010 00 [009] -  -
                        Reset counter: 67
                        Mileage: 22510 km
                        Date: 2014.10.16
                        Time: 08:57:40
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
       Component: GAT 4CAN 1L M H10 0044
       Revision: 1P040023    Serial number: 2341P11B090174
       Coding: FBCF0A5A000100610353
       VCID: 40A1AF7AD3619E212FB-8015
       Component: J367-BDM  H07 0180
    Address 22: AWD        Labels: Redir Fail!
       Part No SW: 0BS 907 554 D    HW: 0BS 907 554 D
       Component: Haldex 4Motion      4017
       Coding: 0000005
       VCID: 47B3B466364FA919EE1-8012
       Component: IMMO          H14 0030
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04108
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
       Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
       Component: TSG FA        H09 0410
       Coding: 011E06205C01000000
       VCID: 4F839C461E3F7159A61-801A
       Part No: 5N0 909 144 N
       Component: EPS_ZFLS Kl. 293    3301
       Revision: 00H22000
       VCID: 3C59DB8A7F89FAC1733-8069
    Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
       Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
       Component: TSG BF        H09 0410
       Coding: 011E06205E01000000
       VCID: 4EBD814219357851AD7-801B
       Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
       Component: J540 EPB4  VW-64783 0009
       Revision:   H19       Serial number: 00000000401235
       Coding: 0025166
       VCID: 354FCEAE5CA32B898CD-8060
    Address 55: Headlight Range
       Part No SW: 4G0 035 061 E    HW: 4G0 035 061
       Component: Radio U DAB   H52 0099
       Revision: AB001007    Serial number: 109F 0B7523387
       Coding: 010105020100000002
       VCID: 1F630C060E5F81D9761-804A
       Part No SW: 8U0 035 666 A    HW: 8U0 035 666
       Component: H-BN-EU       H42 0468
       Revision: --------    Serial number: 008K$0B7514808
       Coding: 0E010106000AC1E90100233600000001E00000020000000000
       VCID: 3851C79A8BB1D6E197B-806D
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 8U0 919 604     HW: 8U0 919 604
       Component: DU High AU316  H41 0018
       Subsystem 3 - Part No: 8R0 060 961 C
       Component: CD-Database  3638
       Part No SW: 8X0 959 795 A    HW: 8X0 959 795 A
       Component: TSG HL        H06 0409
       Coding: 010E06200001000000
       VCID: 4DBF864E14334349D4D-8018
    Address 69: Trailer (J345)       Labels: 7N0-907-383.clb
       Part No SW: 7N0 907 383     HW: 7N0 907 383
       Component: Towbar module H09 0120
       Serial number: ÀÁ006789000000
       Coding: 0109080000000000
       VCID: 73CB30B6D25775B9629-8026
       Component: TSG HR        H06 0409
    End-------------------------(Elapsed Time: 02:56)--------------------------
    Last edited by Uwe; 12-11-2014 at 10:35 AM. Reason: Wrapped CODE tags around Auto-Scan
  5. Likes CocoPops liked this post
  6. #4
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hi Andrew,
    the first problem to solve is >Address 02: Auto Trans Cannot be reached.
    And maybe second, the Bit 7 in Byte 1, coding of Instruments 17 for shift suggestion. At my knowlwdge just for mechanical gearbox.
    Wolfgang
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #5
    Agreed Wolfgang ..............I would also check the report of the TRANS on the rest of the CAN in engine etc... in VCDS advanced measuring values looking for discrepancies.
  9. #6
    Wolfgang and Jack, thank you for your reply.
    I have run a couple more scans, and Address 02 Auto Trans was contacted OK and shows no faults, however this time Address 15 Air Bags could not be reached. I think that this is due to a glitch with VCDS, perhaps a timing issue not giving enough time for the control module to be contacted?
    The faults with address 17 Instruments remains.
    I did contact someone else who had reported the same problem and he was told by Audi that the No Basic Settings fault is caused by the Audi garage resetting the service interval via the display panel (rather than using VCDS/Vagcom) which does not correctly reset everything - This of course could be a red herring.
    When I went through the output tests for the Intruments I got no output at all from the following: Hot light, Low fuel level indicator light, Windscreen washer fluid level low indicator lamp.
    Thinking that there may be a wiring fault I looked at the wiring diagram in my ElsaWin manual and could not find any reference at all for the Hot light and Low fuel level indicator lights. I could only find a G33 Windscreen washer fluid level sensor which appears to be connected to wiring common the F34 Brake Fluid level, F66 Coolant shortage indicator switch, G17 Ambient temperature sensor.
    Friday,12,December,2014,15:07:59:57949
    Mileage: 25190km-15652mi   Repair Order:
              62 69 72
    VIN: WAUZZZ8U2CR020790   Mileage: 25190km-15652miles
    Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
       Part No SW: 0BH 300 011 K    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H05 1725
       Revision: 00H05V01
       ROD: EV_TCMDQ500021_AU21.rod
       VCID: 2A75EDD24D1D747111F-807F
       Component: J104   C6 450M V4A3 0005
       Coding: 0052365
       Revision: AC110667
       Coding: 0047F7
       Coding: 02006E
       Coding: 090305
    Address 15: Airbags
       Coding: 1894204000
       Coding: 42CF00
              B2010 00 [009] -  -
                        Reset counter: 160
                        Mileage: 25105 km
                        Date: 2014.12.11
                        Time: 11:18:13
       Coding: 0000005
       Coding: 000002
       Revision: 00H22000
       Coding: 0025166
    Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
       Part No SW: 8X0 907 357 B    HW: 8X0 907 357 A
       Component: ****LWR12**** H02 0021
       Serial number: 111118-0004-072
       Coding: 1157A61010002300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 41A7AA7ED06B9729205-8014
    End-------------------------(Elapsed Time: 02:42)--------------------------
  10. #7
    Quote Originally Posted by darkmatter View Post
    I suspect that too. Would you mind sharing details regarding the computer you're running on? Make, Model, CPU, RAM, version of Windows, etc?
    Hmm, maybe run an Adaptation Channel map of your Instrument Cluster to let us see what values it has for all the Service Interval stuff?
    Hi Uwe, thanks for replying.
    I'm using a Lenovo Thinkpad T400, CPU Intel Core2 Duo P8700 2.53GHz, RAM 4 GB, Windows 7 Professional 64 bit Service Pack 1 with all Windows Updates current.
    I'll have a go at running an Adaption Channel map of the Instrument Cluster and will report back.
  12. #9
    Hmm, seems entirely OK and doesn't have USB 3.0 ports to worry about either. What "nannyware" do you have running on it?
    AVG Free A/V. IBM Security Trusteer Rapport. AdBlock plus. Windows Firewall. Those are the obvious ones I'm aware of - hope I'm not opening my machine up to hackers by revealing that. I'm always very careful of which websites I visit, do not click on links in unsolicited emails etc., and do an A/V scan on any downloads.
