Resolved Instrument Cluster Fault Code 1048578 - No Basic Setting
Resolved
darkmatter
C?ID=224357
Repeated scans of my UK 2012 Audi Q3 2.0 TDi shows the following fault. I've tried clearing the fault code but it always immediately reappears. Does anyone know how to resolve this, or can tell me which aspect of 'Instruments' the fault code 1048578 refers to. Thanks, Andrew.
Address 17: Instruments Labels: 8X0-920-xxx-17.clb
Control Module Part Number: 8U0 920 990 A HW: 8U0 920 990 A
Component and/or Version: KOMBI_COLOUR H14 0030
Software Coding: 42CF00
Work Shop Code: WSC 00049 770 00153
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04391 (AU21)
VCID: 3B5BD896B287FDF97A9-806E
B2010 00 [009] - -
Reset counter: 67
Mileage: 22510 km
Date: 2014.10.16
Time: 08:57:40
CocoPops
C?ID=65608
Hi Andrew,
Normal score here is to post a full AutoScan.
I have the same Kombi Display in my Q3, I'll post my AutoScan here when I run it over the weekend for you.
darkmatter
C?ID=224357
As suggested by CocoPops, here is my full scan...
Tuesday,09,December,2014,15:31:38:57949
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
Dealer/Shop Name: ACT
VIN: WAUZZZ8U2CR020790   License Plate: A4 ACT
Mileage: 25040km-15559mi   Repair Order:
Chassis Type: 8U (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 56 5F
          62 69 72
VIN: WAUZZZ8U2CR020790   Mileage: 25040km-15559miles
Address 01: Engine (J623-CFGC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 PH    HW: 03L 906 018 ES
   Component: R4 2,0L EDC   H26 1793
   Revision: 41H26---    Serial number:
   Coding: 00250012043701080000
   Shop #: WSC 00049 770 00153
   ASAM Dataset: EV_ECM20TDI01103L906018PH 003002
   ROD: EV_ECM20TDI01103L906018EQ.rod
   VCID: 7F23EC86E61F21D9161-802A
Address 02: Auto Trans
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AM    HW: 5N0 614 109 AM
   Component: J104   C6 450M V49E 0005
   Revision: --H07---    Serial number: 00000005071467
   Coding: 0052365
   VCID: 76CD09A201256091457-8023
   Part No SW: 8U0 820 043 C    HW: 8U0 820 043 C
   Component: E87  Klimavoll      0040
   Revision: 00H03000    Serial number: 8U0820043C
   VCID: 3147FABEA8CB07A9D05-8064
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Part No SW: 8X0 907 063 K    HW: 8X0 907 063 K
   Component: BCM PQ35  M   110 0667
   Revision: AC110667
   Coding: 0E000A2CA805F1C0201841C02100094C53FF84AA216F912AE40887A400C5
   Shop #: WSC 40423 001 1048576
   VCID: 44A9A36AC77982010B3-8011
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119
   Component: WWS316 111031  H35 0071
   Coding: 0047F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Component: G397_RLFS  H06 0001
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
Address 10: Park/Steer Assist (J446)       Labels: 8X0-919-475.clb
   Part No SW: 8X0 919 475 K    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0040
   Revision: 11001001    Serial number: 55901126301937
   Coding: 090305
   ASAM Dataset: EV_EPHVA18AU21X0000 002005
   ROD: EV_EPHVA18AU21X0000.rod
   VCID: 4EBD814211357851AD7-801B
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8U0 959 655     HW: 8U0 959 655
   Component: AirbagVW-AU10 H05 0410
   Serial number: 003DUR00GU7/
   Coding: 30393132313030303030554A305238553053
   Shop #: WSC 00049 770 00119
   ASAM Dataset: EV_AirbaAU10SMEAU316 001005
   ROD: EV_AirbaAU10SMEAU316.rod
   VCID: 0429636A8FF942014B3-8051
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME1D050B16ZZZX
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME2C040B16ZZZO
   Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3516KSME12030B16ZZZD
   Serial number: 3526KSME48160B16ZZZR
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME40483814ZZZY
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 521 D    HW: 5K0 953 569 B
   Revision: FF010016    Serial number: 20111122300483
   Coding: 1894204000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D5FD68EAC93F3C944D-8068
   Component: E221 - MFL  H08 0009
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 990 A    HW: 8U0 920 990 A
   Component: KOMBI_COLOUR  H14 0030
   Coding: 42CF00
          B2010 00 [009] -  -
                    Reset counter: 67
                    Mileage: 22510 km
                    Date: 2014.10.16
                    Time: 08:57:40
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   Part No SW: 8U0 907 468 A    HW: 8U0 907 468 A
   Component: GAT 4CAN 1L M H10 0044
   Revision: 1P040023    Serial number: 2341P11B090174
   Coding: FBCF0A5A000100610353
   VCID: 40A1AF7AD3619E212FB-8015
   Component: J367-BDM  H07 0180
Address 22: AWD        Labels: Redir Fail!
   Part No SW: 0BS 907 554 D    HW: 0BS 907 554 D
   Component: Haldex 4Motion      4017
   Coding: 0000005
   VCID: 47B3B466364FA919EE1-8012
   Component: IMMO          H14 0030
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04108
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Coding: 011E06205C01000000
   VCID: 4F839C461E3F7159A61-801A
   Part No: 5N0 909 144 N
   Component: EPS_ZFLS Kl. 293    3301
   Revision: 00H22000
   VCID: 3C59DB8A7F89FAC1733-8069
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   Coding: 011E06205E01000000
   VCID: 4EBD814219357851AD7-801B
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000401235
   Coding: 0025166
   VCID: 354FCEAE5CA32B898CD-8060
Address 55: Headlight Range
   Part No SW: 4G0 035 061 E    HW: 4G0 035 061
   Component: Radio U DAB   H52 0099
   Revision: AB001007    Serial number: 109F 0B7523387
   Coding: 010105020100000002
   VCID: 1F630C060E5F81D9761-804A
   Part No SW: 8U0 035 666 A    HW: 8U0 035 666
   Component: H-BN-EU       H42 0468
   Revision: --------    Serial number: 008K$0B7514808
   Coding: 0E010106000AC1E90100233600000001E00000020000000000
   VCID: 3851C79A8BB1D6E197B-806D
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 8U0 919 604     HW: 8U0 919 604
   Component: DU High AU316  H41 0018
   Subsystem 3 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Part No SW: 8X0 959 795 A    HW: 8X0 959 795 A
   Component: TSG HL        H06 0409
   Coding: 010E06200001000000
   VCID: 4DBF864E14334349D4D-8018
Address 69: Trailer (J345)       Labels: 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Towbar module H09 0120
   Serial number: ÀÁ006789000000
   Coding: 0109080000000000
   VCID: 73CB30B6D25775B9629-8026
   Component: TSG HR        H06 0409
End-------------------------(Elapsed Time: 02:56)--------------------------
AIB Wolfgang
Hi Andrew,
the first problem to solve is >Address 02: Auto Trans Cannot be reached.
And maybe second, the Bit 7 in Byte 1, coding of Instruments 17 for shift suggestion. At my knowlwdge just for mechanical gearbox.
Wolfgang
Agreed Wolfgang ..............I would also check the report of the TRANS on the rest of the CAN in engine etc... in VCDS advanced measuring values looking for discrepancies.
darkmatter
C?ID=224357
Wolfgang and Jack, thank you for your reply.
I have run a couple more scans, and Address 02 Auto Trans was contacted OK and shows no faults, however this time Address 15 Air Bags could not be reached. I think that this is due to a glitch with VCDS, perhaps a timing issue not giving enough time for the control module to be contacted?
The faults with address 17 Instruments remains.
I did contact someone else who had reported the same problem and he was told by Audi that the No Basic Settings fault is caused by the Audi garage resetting the service interval via the display panel (rather than using VCDS/Vagcom) which does not correctly reset everything - This of course could be a red herring.
When I went through the output tests for the Intruments I got no output at all from the following: Hot light, Low fuel level indicator light, Windscreen washer fluid level low indicator lamp.
Thinking that there may be a wiring fault I looked at the wiring diagram in my ElsaWin manual and could not find any reference at all for the Hot light and Low fuel level indicator lights. I could only find a G33 Windscreen washer fluid level sensor which appears to be connected to wiring common the F34 Brake Fluid level, F66 Coolant shortage indicator switch, G17 Ambient temperature sensor.
Friday,12,December,2014,15:07:59:57949
Mileage: 25190km-15652mi   Repair Order:
          62 69 72
VIN: WAUZZZ8U2CR020790   Mileage: 25190km-15652miles
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 011 K    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H05 1725
   Revision: 00H05V01
   ROD: EV_TCMDQ500021_AU21.rod
   VCID: 2A75EDD24D1D747111F-807F
   Component: J104   C6 450M V4A3 0005
   Coding: 0052365
   Revision: AC110667
   Coding: 0047F7
   Coding: 02006E
   Coding: 090305
Address 15: Airbags
   Coding: 1894204000
   Coding: 42CF00
          B2010 00 [009] -  -
                    Reset counter: 160
                    Mileage: 25105 km
                    Date: 2014.12.11
                    Time: 11:18:13
   Coding: 0000005
   Coding: 000002
   Revision: 00H22000
   Coding: 0025166
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Part No SW: 8X0 907 357 B    HW: 8X0 907 357 A
   Component: ****LWR12**** H02 0021
   Serial number: 111118-0004-072
   Coding: 1157A61010002300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 41A7AA7ED06B9729205-8014
End-------------------------(Elapsed Time: 02:42)--------------------------
I suspect that too. Would you mind sharing details regarding the computer you're running on? Make, Model, CPU, RAM, version of Windows, etc?
Hmm, maybe run an Adaptation Channel map of your Instrument Cluster to let us see what values it has for all the Service Interval stuff?
darkmatter
C?ID=224357
Hi Uwe, thanks for replying.
I'm using a Lenovo Thinkpad T400, CPU Intel Core2 Duo P8700 2.53GHz, RAM 4 GB, Windows 7 Professional 64 bit Service Pack 1 with all Windows Updates current.
I'll have a go at running an Adaption Channel map of the Instrument Cluster and will report back.
Hmm, seems entirely OK and doesn't have USB 3.0 ports to worry about either. What "nannyware" do you have running on it?
darkmatter
C?ID=224357
AVG Free A/V. IBM Security Trusteer Rapport. AdBlock plus. Windows Firewall. Those are the obvious ones I'm aware of - hope I'm not opening my machine up to hackers by revealing that. I'm always very careful of which websites I visit, do not click on links in unsolicited emails etc., and do an A/V scan on any downloads.
Unlike Norton or McAffee, AVG doesn't have a history of causing issues with programs like VCDS that need to do real-time.
Adblock plus and Windows firewall shouldn't be a problem either.
I didn't realize IBM had acquired Trusteer Rapport. I've always refused to install Trusteer Rapport despite my bank nagging me every time I log in. Sorry, but I will NOT authorize ANYONE to take copies of whatever files they want from my computer. There have also been plenty of complaints that it makes PCs slow.
Please try the MSCONFIG trick. Run MSCONFIG. Click the Startup tab, then the [Disable All] button. Click the Services tab, put a tick mark in the "Hide all Microsoft services" at the lower left, then click the [Disable All] button. Click [OK]. Let your PC reboot when prompted. Let us know if that makes any difference.
darkmatter
C?ID=224357
I thought I could work out how to do this, but now I'm not so sure. I opened the Instruments controller, then clicked Adaption, at that point I expected to see something which would allow me to create an Adaption Channel map but all I could do was select a single Channel which I did and then I clicked Add to log and saved the log, see below.
I don't think that is quite what you were suggesting though. Would I have to select each channel in turn and add to map?
I also don't understand why the log is dated Monday 8th December 2014 as I have save other autoscan logs since then.
Thanks.
Monday,08,December,2014,15:07:46:57949
          62 69 72
Address 01: Engine
   Component: J104   C6 450M V49D 0005
   Coding: 0052365
   Revision: AC110667
   Coding: 0047F7
   Coding: 02006E
Address 15: Airbags
   Coding: 1894204000
   Coding: 0000005
   Coding: 000002
   Coding: 011E06201E01000000
   Revision: 00H22000
   Coding: 0025166
End-------------------------(Elapsed Time: 02:22)--------------------------
Tuesday,09,December,2014,15:27:35:57949
UDS Adaptation Channel: Staging
Stored value active
Saturday,13,December,2014,15:04:38:57949
UDS Adaptation Channel: Activating and deactivating all development messages
Stored value not active
From the first screen:
[Applications]
[Controller Channel Map]
Controller Address = 17
Login or security access code: leave blank
Function: Adaptation
Output: CSV file
[Go]
darkmatter
C?ID=224357
Thanks Uwe, looks easy now that you've explained! I'll try it tomorrow.
darkmatter
C?ID=224357
Here is my adaption channel map in csv format....
;SW:8U0-920-990-A   HW:8U0-920-990-A ---  Instruments
;Component:KOMBI_COLOUR  H14 0030, Coding:42CF00
;EV_Kombi_UDS_VDD_AU10,A04391,EV_Kombi_UDS_VDD_AU10.rod
;Sunday,14,December,2014,20:18:53:57949
;VCDS Version: Release 14.10.0 (x64)  Data version: 20141022
;VCID: 3B5BD896B287FDF97A9-806E
Activating and deactivating all development messages,not active
Automatic door locking,Display
Day,14
Day counter,1088 d
Deactivate seat belt warning,No
Display correction of consumptions and operating range,100 %
Display correction of fuel gauge,0.0 °
Display format,not active
Distance,25190 km
Driving profiled for range remaining,6.6
(1)-ESI: Coding of Service Interval Extension (SIE)-Oil level,Oil level evaluation
(2)-ESI: Coding of Service Interval Extension (SIE)-Oil pressure,dynamic oil pressure
(3)-ESI: Coding of Service Interval Extension (SIE)-Oil quality,good oil quality
(4)-ESI: Coding of Service Interval Extension (SIE)-TOG,Oil level thermal sensor connected to instrument cluster
ESI: distance driven from inspection,10200 km
ESI: maximum value km-driving distance/inspection,30600 km
ESI: maximum value of time between inspections,730 d
ESI: minimum value km-driving distance/inspection,14500 km
ESI: minimum value of time between inspections,730 d
ESI: oil quality,good oil quality
ESI: Resetting ESI,no warning
ESI: soot entry,11400 km
ESI: thermal load,6000 km
ESI: time from inspection,215 d
Expanded display of traffic sign detection,On
FIX: Distance covered since last mileage-dependent inspection,10200 km
Fix: Max. distance until next mileage-related inspection,30500 km
FIX: Maximum time until next time-dependent inspection,305 d
FIX: Time since last time-dependent inspection,215 d
Hour,20 H
Indicator light for start-stop operation,On
Language version,English
Language version in instrument panel insert control module,English
Minute,19 min
Month,12
Seat belt warning,Version 4
(1)-Service-key settings-p_write_delay_time,40 s
(2)-Service-key settings-p_write_delay_speed,20 km/h
(3)-Service-key settings-p_write_distance,20 km
(4)-Service-key settings-p_forcewrite_qual_time,10 s
(5)-Service-key settings-p_main_switch_keyless,On
(6)-Service-key settings-p_main_switch_basis,On
SIA: maximum value of distance to service,14500 km
SIA: maximum value of time to service,365 d
Source for synchronization of time,GPS
Speed threshold of dynamic oil pressure warning,kein Offset
(1)-Speed warning-,active
(2)-Speed warning-Unit,Miles per hour
(3)-Speed warning-Speed,80
Staging,active
Synchronization duration radio clock,0 min
(1)-Units adjusted-Temperature,°C
(2)-Units adjusted-Distance,miles
(3)-Units adjusted-Speed,Miles per hour
(4)-Units adjusted-Pressure,bar
(5)-Units adjusted-Volume,gallons (UK)
(6)-Units adjusted-Time,24h
(7)-Units adjusted-Date,dd_mm_yy
(8)-Units adjusted-Consumption,Miles per gallon (UK)
Upshift display in center panel,not active
Year,2014
Service_Key_Clear_All_Counters,Yes
OK, I don't see anything obvious there. That doesn't mean I'm not missing something though.
AIB Wolfgang
Moin,
maybe I'm too many tolate but I think, the reason for this basic setting issue is based here:
Please change the values max driving distance to 30000,
Please change the values min driving distance to 15000 km.
and minimum value of time between inspections to 365 d
GOOD LUCK:)
darkmatter
C?ID=224357
Wolfgang,
When I switch my engine off a message is displayed between the rev counter and speedo telling me how many miles and days until the next service.
Today I noticed that it says:
Miles to next service: 11,100
Days to next service: 29
That can't be right. I believe my car to be on a long life service schedule (approx 20,000 miles or 2 years) so I'd expect the display to say something like 11,100 miles and 360 days. I wonder if this suppports your theory that I should change the values as you suggested.
AIB Wolfgang
Hello
these are the difficulties to set the right values of SIA:D
Your car was built in 2012! VIN: WAUZZZ8U2C..... no it's 2015 >> 3Years! and that is what the counter in "17" reminds .
Day counter,1088 d.
Just he want's to do the Changing of Brake Fluid, remaining time 29 days.
Please talk to guy, who played with these values, that's really "try and error" :cool:
sorry
Dana
Western PA, USA
