- Joined
- Jul 9, 2014
- Messages
- 1,819
- Reaction score
- 1,543
- Location
- Tallinn, Estonia
- VCDS Serial number
- C?ID=330192
I did a Discover Media PQ retrofit for a colleague's 2012 Passat B7 using my former Discover Media PQ unit. The standard package of this retrofit is a newer parking aid module 1K8919472C, newer highline reversing camera module 7N0907441B (and camera) and a newer CAN gateway 7N0907530BL. Everything was working fine. The radio played fine, reversing camera displayed a picture and the camera lines moved as they should but one weird thing popped up and didn't want to go away - when stationary and shifting from R to P, the PDC doesn't turn off. You have to press the appropriate button for it to turn off. When driving ahead 20km/h+, PDC turns off as it should. Any ideas on this? Perhaps this is caused by an incompatible parameterization of the PDC module? It reportedly came out of a 2015+ Sharan.
I did this retrofit in stages. First the DM itself, the PDC module and this behaviour didn't show. Second I fitted the newer camera module and CAN, then this behaviour showed.
Also, I had Traffic Sign Recognition enabled on my car but this car doesn't have the Lane Assist camera for it to work. I unticked the appropriate bits in DM coding and went over the adaptations but this fault returned after clearing. DM admap is below...
The following autoscan is somewhat out-of-date as I was able to code the PDC module so it doesn't miss the trailer and RCTA modules. Also the CAN fault in clocks isn't actual anymore.
I managed to find PDC coding after completing stage 1 (when P disengaged PDC):
Saturday,25,May,2019,11:52:21:46309
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
Dealer/Shop Name:
Workshop Code: 123 12345 098765
VIN: WVWZZZ3CZCE149555 License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 3C 42 44 46 47 4C 4F 52
53 55 5F 61 62 6C 72
VIN: WVWZZZ3CZCE149555 Mileage: 335550km-208501miles
Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 NT HW: 03L 907 309 AE
Component: R4 2,0L EDC H27 2473
Revision: 41H27--- Serial number: 00000000000000
Coding: 001D0012046401080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM20TDI01103L906018NT 003004
ROD: EV_ECM20TDI01103L906018NC.rod
VCID: 094F609449B20C1FC93-805C
Part No SW: 02E 300 057 N HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3113
Revision: 05551213 Serial number: 00001203121663
Shop #: WSC 05311 000 00000
VCID: 24111120C2D0B177DA5-8070
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AJ HW: 3AA 614 109 AJ
Component: J104 C2 450M VE84 0023
Revision: --H07--- Serial number: 00000005472483
Coding: 0122300
VCID: 75B71C6439CA78FFBDB-8020
Part No SW: 3AA 907 044 F HW: 3AA 907 044 F
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 0011004803
VCID: 3333E27C7BBE26CF53F-8066
Address 09: Cent. Elect. (J519) Labels:. User\3AA-937-087.lbl
Part No SW: 3AA 937 087 H HW: 3AA 937 087 H
Component: BCM PQ47 H+ 421 0464
Revision: BC421001
Coding: 0008000000000000001C0080740029F423D50088672D8760E480C7240041
Shop #: WSC 05311 123 08193
VCID: 3FDBBE4C4776F2AFA77-806A
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 21021 10 0603
Coding: 00B795
Component: RLS 170312 05 54 0403
Coding: 024D2A
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331626405049
Coding: 0021151011
Shop #: WSC 12345 123 98765
ASAM Dataset: EV_EPHVA18VW364GP00 001007
VCID: 372BD66C6FC6CAEF6F7-8062
13632272 - Databus
[Steuergerät für Anhängererkennung-J345 - mGate_Komf_1.GK1_Sta_Anhaen - kein Signal/keine Kommunikation]
Reset counter: 172
Mileage: 335550 km
Date: 2019.05.25
Time: 11:47:54
13639168 - Databus
[Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
Reset counter: 172
Mileage: 335550 km
Date: 2019.05.25
Time: 10:25:22
Address 13: Auto Dist. Reg Labels: 3AA-907-567.clb
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000540740
Coding: 0010000
Shop #: WSC 05311 000 08193
VCID: 3829D5506E58C59766D-806C
Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
Component: J234__11R VW10 HI 2118
Revision: 24017000 Serial number: 003LDP5MB9AX
Coding: 0012626
VCID: 4EC59388FCDC6B275C1-801A
Subsystem 1 - Serial number: 6332MTS680270602
Subsystem 2 - Serial number: 6342MTS640730592
Subsystem 3 - Serial number: 6351HTS6E2OGMAKR
Subsystem 4 - Serial number: 6361HTS6R1AHMAKR
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BM HW: 5K0 953 569 T
Revision: FF010040 Serial number: 20120322300300
Coding: 3992A50001
VCID: 75B71C64354A78FFBDB-8020
Component: E221__MFL-TK6 H06 0022
Coding: E30000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 880 C HW: 3AA 920 880 C
Component: KOMBI H03 0408
Coding: 161F01
Shop #: WSC 05311 115 08193
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
U0056 00 [008] - Performance
[Datenbus Kombi/Fahrwerk: keine Kommunikation]
Reset counter: 172
Time: 00:00:00
10486016 - Control module
B2001 00 [009] - Incorrect software version
[BAP: Steuergerät falsche Softwareversion]
Reset counter: 132
Mileage: 335550 km
Date: 2019.05.25
Time: 10:29:48
Part No SW: 7N0 907 530 BL HW: 1K0 907 951
Component: J533 Gateway H41 1682
Revision: H41 Serial number: 100112F1002116
Coding: 462006
VCID: 7BA30A5C13EE2E8FCBF-802E
Part No SW: 3AA 959 799 A HW: 3AA 959 799 A
Component: IMMO 083 0402
Revision: 00083000 Serial number: VWZCZ000000000
VCID: 46D5ABA814ACA367E41-8012
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 3AA 907 566 B HW: 4G0 907 566
Component: J769 SWA MasterH02 0040
Revision: 00H02000 Serial number: 6PZ 010 316-08
Coding: 0000172
Subsystem 1 - Part No: 3AA 907 568 B
Component: J0770_SWA_Slave_H02 0040
Subsystem 2 - Serial number: 6PZ 010 316-28
Subsystem 3 - Serial number: 5F07.03.1200H020003C730455ÿ
Subsystem 4 - Serial number: 730455ÿ
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0004585626
Coding: 0200FF
Shop #: WSC 05311 115 00000
VCID: 3537DC6475CA38FF7DB-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000002803340
Coding: 0000D8
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.311 1002
Revision: 1AH03734 Serial number: 00120720345801
Coding: 0000258
VCID: 3C21C9405A60E9B7825-8068
Address 46: Central Conv. Labels:. User\3C0-959-799-46.lbl
Component: 02 KESSY PQ47 083 0346
Coding: 0191020052C30E76340494157E004FCE705801030434B8
Component: Neigungssensor 004 0611
Subsystem 4 - Component: ViP n.mounted
Part No SW: 5K0 035 456 C HW: 5K0 035 456 C
Component: KonzernAmp 8K H07 0202
Revision: -------- Serial number: EAA086A0009398
ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
ROD: EV_AudioVerst8KanalBNO2.rod
VCID: 2A0DFF18AC746707E09-807E
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1682
Coding: 00000008
VCID: 6FBB2E0C5796422F777-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0004586703
Coding: 0200FE
ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
VCID: 3635DB6868CC33E7741-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000002805260
Coding: 0000D8
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000000064936
Coding: 0022167
VCID: 3635DB68644C33E7741-8062
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Coding: 029200000B000200
Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H04 0012
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H04 0012
Coding: 230000
Part No SW: 5C0 035 680 B HW: 5C0 035 680 B
Component: MU-S-N-ER H20 0252
Serial number: VWZAZ2R0221946
Coding: 02740401AA00000011110003000908001F0100C4002001000C
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 20191D30DA48AD57BED-8074
Subsystem 1 - Part No SW: 5NA 919 866 R HW: -----------
Component: ECE AS 19/20 --- 1115
7201 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 132
Mileage: 335550 km
Date: 2019.05.25
Time: 11:20:39
Voltage terminal 30: 11.9 V
BAP-BAP_Function_ID: 02
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1682
Coding: 030F1859
VCID: 71BF287441A254DF613-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900436783
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 012408012201000300
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 3039ED708AA81DD72ED-8064
End----------(Elapsed Time: 01:47, VBatt start/end: 12.0V/12.1V)-----------
Address 10: Park/Steer Assist Labels: 5Q0-919-294.clb
Control Module Part Number: 1K8 919 472 C HW: 5Q0 919 294 A
Component and/or Version: PARKHILFE 8K H03 0480
Software Coding: 0071155011
Work Shop Code: WSC 00020 999 00000
ASAM Dataset: EV_EPHVA18VW364GP00 001007 (VW46)
13639168 - Databus
Reset counter: 207
Mileage: 333059 km
Date: 2019.05.04
Time: 12:16:59
SW:5C0-035-680-B HW:5C0-035-680-B --- Information Electr.
Component:MU-S-N-ER H20 252 Coding:02740401AA00000011110003000908001F0100C4002001000C
EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_VW36.rod
Saturday,25,May,2019,12:05:03:46309
VCDS Version: Release 18.9.1 (x64) Data version: 20190114 DS296.0
IDE00001-Production mode,00 0 0 0,3
IDE00346-Summertime-automatic,none 0,1
IDE00758-Base volume of telephone,50 %,1
IDE00769-Number 1 for Info call,5E 7 A1 80 0 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF FF 0,23
IDE00770-Number 1 for roadside assistance,5E 7 A1 80 0 98 37 87 24 F3 FF FF FF FF FF FF FF FF FF FF FF FF FF 0,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF 0,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF 0,1
IDE00845-Wheel circ.,0 mm,2
IDE02121-CD eject button,Enabled 0,1
IDE02122-Developer mode,activated 0,1
IDE02330-Number 2 for Info call,5E 8 91 94 81 20 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF 0,23
IDE02331-Number 2 for roadside assistance,5E 6 91 94 81 60 11 21 31 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0,23
IDE02332-Deactivate production mode,0 0,3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic 0,49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 0,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 0,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 0,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 0,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 0,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 0,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 0,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 0,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 0,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 0,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 0,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 0,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 0,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 0,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 0,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 0,49
IDE02502-Confirmation of installation change,30 E7 0,2
IDE02607-Wheel pulse,0 0,2
IDE02699-Number 1 for roadside assistance,5E 2 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 2 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0,23
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF 0,4
IDE04550-Bluetooth: Sniff mode,OFF 0,1
IDE05111-Fee-based traffic information (TMC),15 0,2
IDE05113-Infotainment Recorder,activated 0,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF 0,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On 0,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF 0,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF 0,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF 0,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF 0,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF 0,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 0,4
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 0,4
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),4 0,4
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),7 0,4
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),4 0,4
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 0,4
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 0,4
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 0,4
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 0,4
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 0,4
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 0,4
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 0,4
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 0,4
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 0,4
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 0,4
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 0,4
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 0,4
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 0,4
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 0,4
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 0,4
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 0,4
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 0,4
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,7 0,4
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 0,4
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 0,4
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128 0,4
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 0,4
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 0,4
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 0,4
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 0,4
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 0,4
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 0,4
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 0,4
IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated 0,4
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated 0,4
IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated 0,4
IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated 0,4
IDE10604-Menu entries for mobile online services,activated 0,1
IDE11122-Country identification: country of sale HMI,DE 0,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked 0,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked 0,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked 0,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked 0,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked 0,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked 0,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked 0,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked 0,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked 0,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked 0,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked 0,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked 0,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked 0,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked 0,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked 0,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked 0,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked 0,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked 0,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked 0,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked 0,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked 0,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked 0,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked 0,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked 0,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked 0,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked 0,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked 0,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked 0,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked 0,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked 0,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked 0,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked 0,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked 0,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked 0,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked 0,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked 0,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked 0,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked 0,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked 0,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked 0,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked 0,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked 0,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked 0,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked 0,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked 0,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked 0,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked 0,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked 0,21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked 0,21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked 0,21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked 0,21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked 0,21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked 0,21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked 0,21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked 0,21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked 0,21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked 0,21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked 0,21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked 0,21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked 0,21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked 0,21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked 0,21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked 0,21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked 0,21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked 0,21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked 0,21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked 0,21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked 0,21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked 0,21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked 0,21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked 0,21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked 0,21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked 0,21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked 0,21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked 0,21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked 0,21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked 0,21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked 0,21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked 0,21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked 0,21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked 0,21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked 0,21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked 0,21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked 0,21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked 0,21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked 0,21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked 0,21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked 0,21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked 0,21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked 0,21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked 0,21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked 0,21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked 0,21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked 0,21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked 0,21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked 0,21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked 0,21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked 0,21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked 0,21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked 0,21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked 0,21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked 0,21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked 0,21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked 0,21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked 0,21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked 0,21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked 0,21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked 0,21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked 0,21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked 0,21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked 0,21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked 0,21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked 0,21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked 0,21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked 0,21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked 0,21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked 0,21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked 0,21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked 0,21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked 0,21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked 0,21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked 0,21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked 0,21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked 0,21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked 0,21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked 0,21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked 0,21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked 0,21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked 0,21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked 0,21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked 0,21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked 0,21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked 0,21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked 0,21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked 0,21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked 0,21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked 0,21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked 0,21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked 0,21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked 0,21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked 0,21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked 0,21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked 0,21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked 0,21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked 0,21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked 0,21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked 0,21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked 0,21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked 0,21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked 0,21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked 0,21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked 0,21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked 0,21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked 0,21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked 0,21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked 0,21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked 0,21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked 0,21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked 0,21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked 0,21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked 0,21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked 0,21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked 0,21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked 0,21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked 0,21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked 0,21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked 0,21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked 0,21
MAS00950-Audio Parameter,0 0,1
MAS00951-Bluetooth,On 0,1
MAS03782-WLAN,On 0,1
ENG117917-BAP_Debug_Mode_Release,not_released 0,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP 0,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated 0,6
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated 0,6
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated 0,6
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated 0,6
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated 0,6
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated 0,6
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated 0,6
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated 0,6
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated 0,6
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated 0,6
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated 0,6
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated 0,6
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated 0,6
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated 0,6
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated 0,6
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated 0,6
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated 0,6
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated 0,6
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated 0,6
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated 0,6
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated 0,6
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated 0,6
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated 0,6
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated 0,6
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated 0,6
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated 0,6
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated 0,6
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated 0,6
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated 0,6
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated 0,6
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated 0,6
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated 0,6
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated 0,6
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated 0,6
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated 0,6
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,not activated 0,6
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated 0,6
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated 0,6
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,not activated 0,6
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated 0,6
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated 0,6
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated 0,6
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated 0,6
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated 0,6
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated 0,6
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated 0,6
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated 0,6
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated 0,6
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated 0,6
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated 0,6
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,activated 0,6
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,activated 0,6
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,activated 0,6
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated 0,6
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,activated 0,6
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated 0,6
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated 0,6
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated 0,6
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated 0,6
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated 0,6
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated 0,6
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated 0,6
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated 0,6
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated 0,6
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated 0,6
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated 0,6
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated 0,6
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated 0,6
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated 0,6
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated 0,6
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,not activated 0,6
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated 0,6
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated 0,6
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,not activated 0,6
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated 0,6
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated 0,6
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated 0,6
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated 0,6
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated 0,6
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated 0,6
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated 0,6
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated 0,6
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated 0,6
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated 0,6
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated 0,6
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,not activated 0,6
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated 0,6
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated 0,6
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,not activated 0,6
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated 0,6
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,not activated 0,6
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated 0,6
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated 0,6
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,not activated 0,6
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated 0,6
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated 0,6
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated 0,6
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated 0,6
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated 0,6
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated 0,6
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated 0,6
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,activated 0,6
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,activated 0,6
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated 0,6
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,activated 0,6
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,not activated 0,6
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated 0,6
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated 0,6
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,not activated 0,6
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated 0,6
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated 0,6
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated 0,6
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated 0,6
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated 0,6
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated 0,6
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated 0,6
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated 0,6
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated 0,6
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated 0,6
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated 0,6
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated 0,6
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated 0,6
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated 0,6
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated 0,6
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated 0,6
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated 0,6
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated 0,6
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated 0,6
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated 0,6
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated 0,6
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated 0,6
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated 0,6
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated 0,6
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated 0,6
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated 0,6
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated 0,6
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated 0,6
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated 0,6
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated 0,6
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated 0,6
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated 0,6
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated 0,6
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated 0,6
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated 0,6
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated 0,6
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,not activated 0,6
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated 0,6
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated 0,6
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,not activated 0,6
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated 0,6
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated 0,6
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated 0,6
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated 0,6
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated 0,6
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated 0,6
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated 0,6
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated 0,6
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated 0,6
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated 0,6
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated 0,6
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated 0,6
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,activated 0,6
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,activated 0,6
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated 0,6
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,activated 0,6
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated 0,6
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated 0,6
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated 0,6
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated 0,6
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated 0,6
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated 0,6
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated 0,6
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated 0,6
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated 0,6
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated 0,6
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated 0,6
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated 0,6
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated 0,6
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated 0,6
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated 0,6
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated 0,6
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated 0,6
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated 0,6
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated 0,6
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated 0,6
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated 0,6
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated 0,6
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated 0,6
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated 0,6
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated 0,6
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated 0,6
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated 0,6
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated 0,6
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated 0,6
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated 0,6
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,not activated 0,6
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated 0,6
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated 0,6
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated 0,6
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated 0,6
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated 0,6
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated 0,6
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated 0,6
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated 0,6
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated 0,6
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated 0,6
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated 0,6
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated 0,6
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated 0,6
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated 0,6
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated 0,6
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated 0,6
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated 0,6
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated 0,6
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated 0,6
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated 0,6
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated 0,6
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated 0,6
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated 0,6
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated 0,6
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated 0,6
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated 0,6
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated 0,6
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated 0,6
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated 0,6
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,not activated 0,6
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated 0,6
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated 0,6
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,not activated 0,6
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated 0,6
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated 0,6
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated 0,6
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated 0,6
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated 0,6
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated 0,6
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated 0,6
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated 0,6
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated 0,6
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated 0,6
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated 0,6
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated 0,6
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated 0,6
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated 0,6
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated 0,6
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated 0,6
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated 0,6
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated 0,6
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated 0,6
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated 0,6
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated 0,6
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated 0,6
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated 0,6
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated 0,6
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated 0,6
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated 0,6
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated 0,6
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated 0,6
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated 0,6
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated 0,6
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated 0,6
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated 0,6
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated 0,6
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated 0,6
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated 0,6
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated 0,6
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated 0,6
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated 0,6
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated 0,6
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated 0,6
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated 0,6
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated 0,6
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated 0,6
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated 0,6
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated 0,6
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated 0,6
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,not activated 0,6
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated 0,6
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated 0,6
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,not activated 0,6
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated 0,6
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated 0,6
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated 0,6
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated 0,6
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated 0,6
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated 0,6
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated 0,6
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated 0,6
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated 0,6
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated 0,6
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated 0,6
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,not activated 0,6
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated 0,6
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated 0,6
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,not activated 0,6
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated 0,6
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated 0,6
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated 0,6
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated 0,6
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated 0,6
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated 0,6
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated 0,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended 0,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated 0,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated 0,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,activated 0,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment 0,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated 0,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated 0,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,activated 0,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Databus Infotainment 0,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated 0,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated 0,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated 0,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated 0,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated 0,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated 0,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated 0,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated 0,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,not activated 0,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,not activated 0,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated 0,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,not activated 0,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated 0,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated 0,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated 0,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus 0,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated 0,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated 0,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,not activated 0,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,not activated 0,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated 0,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated 0,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated 0,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,not activated 0,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated 0,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated 0,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated 0,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated 0,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated 0,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated 0,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated 0,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated 0,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,not activated 0,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,not activated 0,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated 0,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated 0,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated 0,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated 0,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,not activated 0,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,not activated 0,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated 0,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated 0,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,not activated 0,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,not activated 0,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated 0,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated 0,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated 0,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated 0,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated 0,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated 0,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated 0,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 0,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated 0,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated 0,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated 0,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated 0,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated 0,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated 0,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated 0,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated 0,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated 0,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated 0,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated 0,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated 0,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated 0,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated 0,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated 0,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated 0,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,not activated 0,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,not activated 0,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated 0,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated 0,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated 0,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated 0,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated 0,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated 0,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated 0,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated 0,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated 0,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus extended 0,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated 0,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal 15 0,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated 0,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated 0,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated 0,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated 0,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated 0,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated 0,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,not activated 0,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,not activated 0,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated 0,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment 0,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated 0,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated 0,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,not activated 0,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,not activated 0,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available 0,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Not available 0,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available 0,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available 0,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available 0,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment 0,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available 0,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Not available 0,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available 0,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 0,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available 0,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available 0,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available 0,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available 0,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Not available 0,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Not available 0,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 0,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,20 0,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,50 0,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 0,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,20 0,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,50 0,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,3 0,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 0,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,15 0,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,60 0,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,0 0,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,0 0,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,2 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,10 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,15 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,90 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,0 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,0 %,12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,00 0 0 0 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1 2D 1E 37 28 37 28 2D 1E 7 64 1E 4 10 3 0A 0 0 0 1 3 0,4
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0 0,2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0 0,2
ENG117919-Startup_Screen_Sticker_HMI,00 2 0,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,On 0,3
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF 0,3
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On 0,3
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF 0,3
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF 0,3
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF 0,3
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF 0,3
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF 0,3
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked 0,3
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 0,3
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On 0,3
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF 0,3
ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP 0,3
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On 0,3
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF 0,3
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF 0,3
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF 0,3
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF 0,3
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF 0,3
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated 0,3
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated 0,3
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present 0,3
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present 0,3
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF 0,3
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated 0,3
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF 0,3
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF 0,3
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF 0,3
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 0,3
ENG109862-ENG152537-Vehicle_configuration-media_control,not activated 0,3
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF 0,3
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU 0,3
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 0,3
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF 0,3
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF 0,3
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF 0,3
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF 0,3
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF 0,3
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF 0,3
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF 0,3
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated 0,3
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF 0,3
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF 0,3
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 0,3
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 0,3
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 0,3
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active 0,3
ENG109862-ENG117844-Vehicle_configuration-picture_navi,On 0,3
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated 0,3
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated 0,3
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 0,3
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF 0,3
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF 0,3
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 0,3
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF 0,3
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated 0,3
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not activated 0,3
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not activated 0,3
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not activated 0,3
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS 0,3
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated 0,3
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction 0,3
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region 0,3
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated 0,3
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present 0,3
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF 0,3
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated 0,3
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 0,3
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF 0,3
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF 0,3
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On 0,3
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF 0,3
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF 0,3
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked 0,3
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF 0,3
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF 0,3
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF 0,3
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated 0,3
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated 0,3
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated 0,3
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF 0,3
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF 0,3
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF 0,3
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On 0,3
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated 0,3
Elapsed Time: 00:33
SW:1K8-919-472-C HW:5Q0-919-294-A --- Park/Steer Assist
Component:PARKHILFE 8K H03 480 Coding:0021151011
EV_EPHVA18VW364GP00,001007,EV_EPHVA18VW364GP00_VW32.rod
Saturday,25,May,2019,11:56:38:46309
VCDS Version: Release 18.9.1 (x64) Data version: 20190114 DS296.0
VCID: 372BD66C6FC6CAEF6F7-8062
IDE00001-Production mode,Deactivating 0,3
IDE01165-Park assist activation tone,On 0,1
IDE01169-Audio reduction request,On 0,1
IDE01170-Visual display for park assist,OPS display 0,1
IDE02332-Deactivate production mode,0 0,3
IDE03782-Switch-off speed for parking assist,15 km/h,1
MAS01426-Speaker volume for rear park assist,Stage 5 0,1
MAS01427-Speaker frequency for rear park assist,Stage 4 0,1
MAS01428-Speaker volume for front park assist,Stage 4 0,1
MAS01429-Speaker frequency for front park assist,Stage 6 0,1
Elapsed Time: 00:05
