Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 2010 Phaeton - Big Electrical Issues - VCDS not clearing faults
    VAG batteries & on a routine, seem to not last past 2 years and or unless they are put on maintainers due to sleep mode failing to be achieved, no?
  2. #12
    It's on again, off again. I've had some original (i.e. came with the car when new) batteries last 6-8 years, but I've also seen some fail at 2 years.
  3. #13
    Well sure but does this count, when the statistics show themselves at a 2 year lease auction & where almost every battery is dead or requiring a jump start by the "lane starter" & of over 500 cars per show?
  4. #14
    May 2019
    England
    Hi Guys, thank you so much for your support and I had to get an Auto Electrician to sort out the issue as it was past my ability. He said that the gear lever was not communicating with the steering column and needed re-mapping. The car is working now and lessons learned are;
    If it's working, don't go looking for issues
    Don't play around with fuses
    Below a scan just done and to say thanks again for your help;
    Friday,07,June,2019,14:05:28:01891
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ3DZA8000590   License Plate:
    Chassis Type: 3D (6N0)
    Scan: 01 02 03 05 07 08 09 15 16 17 18 19 34 37 38 42 46 47 52 56
              62 68 71 72 76 77
    VIN: WVWZZZ3DZA8000590   Mileage: 169290km-105191miles
    68-Wiper Electr. -- Status: OK 0000
    71-Battery Charger -- Status: OK 0000
    Address 01: Engine (CEX)       Labels: None
       Part No SW: 3D0 907 401 G    HW: 3D0 907 401 D
       Component: 3.0TDI EDC17G000AG  0030
       Revision: --H01---    Serial number: VWX3Z0I1861025
       Coding: 0406002C191F0160
       Shop #: WSC 01065 000 00000
       VCID: 234FC021E1D29B52E0-5106
       Part No SW: 09L 927 760 R    HW: GS1 911 4
       Component: AG6 09L 3,0 TDI RdW 3606
       Revision: --H04---    Serial number:        4522722
       VCID: 468979B532A08E7AA7-5124
    Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
       Part No: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H35 0047
       Coding: 0008356
       VCID: 6BDFE8014982931218-5140
       Part No SW: 3D0 909 139 D    HW: 3D0 909 139 D
       Component:    Kessy            6850
       Revision: 00H22072    Serial number: VWX3Z0I1861025
       Coding: 0004328
       VCID: 2A512D0581F84A1AA3-807E
    Address 07: Control Head        Labels: 3D0-907-048.clb
       Part No SW: 3D0 907 048     HW: 3D0 907 048
       Component: J127 KBT vorn       0031
       Revision: ABH64001    Serial number: VWZ6Z7M0243072
       VCID: 63CF8021A652DB52A0-8036
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 L
       Component: Climatronic D1      2035
       VCID: 2757D43192EA7772BC-8072
    Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
       Part No SW: 3D0 937 049 N    HW: 3D0 937 049 N
       Component: J519                6900
       Revision: -4005---    Serial number: --------------
       Coding: 60810000AB211DC20100000000000000
       VCID: 356B0E79584615E23E-8060
       Part No: 3D0 909 601 E
       Component: 0H Airbag 8.4E+ H12 0935
       Coding: 0012360
       VCID: 254BDE39E8E665628E-8070
       Part No: 7L6 953 549 K
       Component: J527                3601
       Coding: 0000011
       VCID: 479774B132AA97725C-8012
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No SW: 3D0 920 983 C    HW: 3D0 920 983 C
       Component: J285 KOMBI-INST.    0616
       Revision: KPH06V01
       Coding: 0039401
       Shop #: WSC 00670 067 57207
       VCID: 2953D20980FE4102AA-807C
    Address 18: Aux. Heat        Labels: None
       Part No: 3D0 815 005 AP
       Component: J737__Standheizung  4405
       Revision: 00084000    Serial number: 09020869A00000
       VCID: 6BDFE8014A82931218-803E
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 3D0 920 983 C
       Component: J533  GW-K-CAN TP20 0616
       Coding: 5FF2F3AC3B011003
       VCID: 70E5FF6D63A470CA2D-8024
    Address 34: Level Control        Labels: 3D0-907-553-V2.clb
       Part No: 3D0 907 553 C
       Component: LUFTFDR.-CDC- 3C3V0 1122
       Coding: 0005521
    Address 37: Navigation (J0506)       Labels:. 3D0-035-680.clb
       Part No SW: 3D0 035 680     HW: 3D0 035 680
       Component: RNS-MID       H64 0210
       Revision: AB001001    Serial number: VWZ6Z7M0243072
       Coding: 020100000000002200
       Shop #: WSC 00670 210 45725
       VCID: 5DBBB6D94436EDA296-8008
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 E
       Component: Dachmodul           0802
       Coding: 0004157
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 M
       Component: 4Z HSG              8132
       Coding: 0000040
       Shop #: WSC 56073 001 1048576
       VCID: 3A711D457658FA9AD3-4AEA
       Subsystem 1 - Part No: 3D2 959 701 H
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 3D2 959 702 H
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 3D0 959 703 G
       Subsystem 4 - Part No: 3D0 959 704 G
       Subsystem 5 - Part No: 3D0 909 610 E
       Component: 3O HDSG             2530
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No SW: 3D0 035 465 C    HW: 3D0 035 465 C
       Component: 08K Audioverst.     0120
       Revision: 00005000    Serial number: 00000000216602
       VCID: 2143CA29F8CE8942F2-8074
    Address 56: Radio (J0506)       Labels:. 3D0-035-680.clb
    Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
       Part No: 3D2 955 120 B
       Component: Front Wiper         3501
       Coding: 0013685
       Shop #: WSC 01065 000 376832
       VCID: 2143CA29FCCE8942F2-8074
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
       VCID: 244DC33DE3DC9C6A99-8070
    Address 76: Park Assist        Labels: None
       Part No: 3D0 919 283 E
       Component: 10 Einparkhilfe     1107
       VCID: 2C5D2B1D8B0C542A51-8078
    Address 77: Telephone        Labels: None
       Part No SW: 3D0 035 385 A    HW: 3D0 035 385 A
       Component: J412                8605
       Revision: 00016000    Serial number: 0000B7A085377
       Coding: 0020141
       VCID: 2045CF2DF3C4804AFD-8074
    End-------------------------(Elapsed Time: 03:53)--------------------------
  5. Likes Uwe, Dana liked this post
  6. #15
    Quote Originally Posted by Mr_Rossi View Post
    Somehow I think your auto-electrician is using different terminology than we do.
