Results 1 to 10 of 15
Thread: 2010 Phaeton - Big Electrical Issues - VCDS not clearing faults
    May 2019
    England
    Not too sure what happened but, the car will not start and the VCDS will not clear the error codes. Pretty sure the ECU is working as I can hear noises when trying to start the car. Any advice gratefully accepted.
    Thanks in anticipation.
    Sunday,26,May,2019,13:43:45:01891
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWZZZ3DZA800xxxx   License Plate:
    Chassis Type: 3D (6N0)
    Scan: 01 02 03 05 07 08 09 15 16 17 18 19 34 37 38 42 46 47 52 56
              62 68 71 72 76 77
    VIN: WVWZZZ3DZA800xxxx   Mileage: 169280km-105185miles
    02-Auto Trans -- Status: Cannot be reached 1100
    68-Wiper Electr. -- Status: OK 0000
    71-Battery Charger -- Status: OK 0000
    Address 01: Engine (CEX)       Labels: None
       Part No SW: 3D0 907 401 G    HW: 3D0 907 401 D
       Component: 3.0TDI EDC17G000AG  0030
       Revision: --H01---    Serial number: VWX3Z0I1861025
       Coding: 0406002C191F0160
       Shop #: WSC 01065 000 00000
       VCID: 234FC021E1D29B52E0-50EA
    049409 - No Communication with Transmission Control Module
                   U0101 - 001 -
                        Fault Status: 01100001
                        Mileage: 169288 km
                        Date: 2019.05.25
                        Time: 19:33:59
                        Voltage: 11.17 V
                        Bin. Bits: 00000000
                        (no units): 8.0
                        Bin. Bits: 00000001
    Address 02: Auto Trans
    Address 03: ABS Brakes
       Part No SW: 3D0 909 139 D    HW: 3D0 909 139 D
       Component:    Kessy            6850
       Revision: 00H22072    Serial number: VWX3Z0I1861025
       Coding: 0004328
       VCID: 2A512D0581F84A1AA3-807E
       Subsystem 1 - Part No: 4E0 905 852 E
       Component: ELV                 2141
    Address 07: Control Head        Labels: 3D0-907-048.clb
       Part No SW: 3D0 907 048     HW: 3D0 907 048
       Component: J127 KBT vorn       0031
       Revision: ABH64001    Serial number: VWZ6Z7M0243072
       VCID: 63CF8021A652DB52A0-8036
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 L
       Component: Climatronic D1      2035
       VCID: 2757D43192EA7772BC-8072
    Address 09: Cent. Elect.
       Part No: 3D0 909 601 E
       Component: 0H Airbag 8.4E+ H12 0935
       Coding: 0012360
       VCID: 254BDE39E8E665628E-8070
       Part No: 7L6 953 549 K
       Component: J527                3601
       Coding: 0000011
       VCID: 479774B132AA97725C-8012
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No SW: 3D0 920 983 C    HW: 3D0 920 983 C
       Component: J285 KOMBI-INST.    0616
       Revision: KPH06V01
       Coding: 0039401
       Shop #: WSC 00670 067 57207
       VCID: 2953D20980FE4102AA-807C
                        Reset counter: 84
                        Mileage: 169288 km
                        Date: 2019.05.25
                        Time: 19:56:29
    Address 18: Aux. Heat        Labels: None
       Part No: 3D0 815 005 AP
       Component: J737__Standheizung  4405
       Revision: 00084000    Serial number: 09020869A00000
       VCID: 6BDFE8014A82931218-803E
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 3D0 920 983 C
       Component: J533  GW-K-CAN TP20 0616
       Coding: 5FF2F3AC3B011003
       VCID: 70E5FF6D63A470CA2D-8024
                        Reset counter: 84
                        Mileage: 169288 km
                        Date: 2019.05.25
                        Time: 19:56:29
    Address 34: Level Control
    Address 37: Navigation (J0506)       Labels:. 3D0-035-680.clb
       Part No SW: 3D0 035 680     HW: 3D0 035 680
       Component: RNS-MID       H64 0210
       Revision: AB001001    Serial number: VWZ6Z7M0243072
       Coding: 020100000000002200
       Shop #: WSC 00670 210 45725
       VCID: 5DBBB6D94436EDA296-8008
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 E
       Component: Dachmodul           0802
       Coding: 0004157
    Address 46: Central Conv.
    Address 47: Sound System
    Address 56: Radio (J0506)       Labels:. 3D0-035-680.clb
    Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
       Part No: 3D2 955 120 B
       Component: Front Wiper         3501
       Coding: 0013685
       Shop #: WSC 01065 000 376832
       VCID: 2143CA29FCCE8942F2-8074
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
       VCID: 244DC33DE3DC9C6A99-8070
    Address 76: Park Assist        Labels: None
       Part No: 3D0 919 283 E
       Component: 10 Einparkhilfe     1107
       VCID: 2C5D2B1D8B0C542A51-8078
                013 - Check DTC Memory
    Address 77: Telephone
    End-------------------------(Elapsed Time: 04:27)--------------------------
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Welcome to the forum, and welcome to Team Phaeton! We demand to be taken seriously!
    Quote Originally Posted by Mr_Rossi View Post
    Lots of things in the car are unresponsive to diagnostics, but only the transmission controller is actually offline totally. Hmm.
    Let's check the simple things first:
                        Voltage: 11.17 V
    That's very low. Check the state of BOTH batteries, and then place a charger on them if you can. You can get in a situation where the cabin electronics mostly work, but the engine just can't crank, if the left-side battery (vehicle power supply) is low and the right one (starting) is kaput. The Phaeton has a paralleling relay and some other emergency starting logic to help, but often that just hides a problem until it gets really bad. A MY2009 car with the factory batteries would be well overdue.
    Silence gives consent.
  3. Likes Eric, Jack@European_Parts, Uwe liked this post
    In addition to all aforementioned, check fuses & for water ingress!
  5. Likes Uwe liked this post
  6. #4
    Apologies for being pedantic here, but based on the VIN, this is a 2010 car (which of course doesn't preclude it having been made and even registered in 2009). But since Model Year is what's most important when it comes to diagnostics, I've fixed the thread title.
    May 2019
    England
    Have charged both batteries and have same problem - Latest scan below
    Both batteries charged all day and still a low voltage. Thanks all for your help. The car is a 59 plate.
    Voltage: 10.03 V
    Bin. Bits: 00000000
    (no units): 8.0
    Bin. Bits: 00000001
    How old are they?
    "Plate" is irrelevant.
    May 2019
    England
    How old are they?
    Both batteries about 3 years old
  10. #8
    Not old enough that they should be bad at this time, but not new enough that they're "known good". I'd pull them and load-test them individually.
  11. #9
    Cincinnati, OH
    I fell victim to one of the classic blunders! The most famous of which is "never get involved in a land war in Asia," but only slightly less well-known is this: "Always check the VIN when a Brit tells you his model-year because 80% of the time he's talking about his license plate!"
  12. Likes NZDubNurd, PetrolDave, Uwe, Zenerdiode liked this post
  13. #10
    Cincinnati, OH
    Voltage: 10.03 V
    Bin. Bits: 00000000
    (no units): 8.0
    Bin. Bits: 00000001
    It's gotten considerably worse since your last scan. That is not consistent with a healthy battery that was on a decent charger for any length of time. Do you have a multimeter? Can you check each battery directly with the car shut off? Phaetons do have some common issues, like water intrusion into the KESSY security module, but the voltage here is just too low to even go down that road yet.
  14. Likes Uwe liked this post
