Results 1 to 4 of 4
Thread: The request to Clear Codes was not acknowledged by the control module
    Jan 2018
    I just bought a "new" car (Passat GTE) and have hard time trying to clear codes. With some control modules I get error message stating "the request to Clear Codes was not acknowledged by the control module". I would like to clear the codes of Tire Pressure Warning and Remote key 2 Current Too Low. Could you please help?
    Saturday,25,May,2019,20:30:47:50709
    VIN: WVWZZZ3CZHEXXXXXX   License Plate: PASSAT1
    Mileage: 69159km-42973mi   Repair Order:
    Chassis Type: 3C-VW48 (5QE)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 23 2B 42 44 47 51 52
              55 5F 69 6C 6D 75 8C A5 A9 BB BC C6 CA
    VIN: WVWZZZ3CZHEXXXXXX   Mileage: 69159km-42973miles
    C6-Batt. Chrg. -- Status: Malfunction 0010
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CUKC)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AH    HW: 04E 907 309 F
       Component: R4 1.4l TFS   H22 3379
       Revision: X3H22---
       Coding: 011D001A647405083000
       Shop #: WSC 40090 222 00000
       ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
       ROD: EV_ECM14TFS_006_VW48.rod
       VCID: 669441DEF8EBAC67041-8032
    10341 - Please Check Fault Codes in Transmission Control Module
              U1026 00 [032] - -
              [Transmission control moduleRead out DTC]
                        Mileage: 68508 km
                        Date: 2019.03.29
                        Time: 12:10:51
                        Coolant temperature: 19 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 14.780 V
                        Unlearning counter according OBD: 30
                        Outside air temperature: 21 °C
                        Absolute intake pressure: 101 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 39.00 l
                        E-machine torque actual value: 1.7 Nm
                        Operating mode control expanded electrical driving: Correct result
                        Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 1
                        High-volt. battery: charge state: abs. value: 27.44 %
    25358 - Fuel Tank Door
              P04B6 00 [096] - Stuck Closed
       Part No SW: 0DD 300 045 T    HW: 0DD 927 770 B
       Component: GSG DQ400E    H31 1601
       Revision: 00031033    Serial number: TFK01606240021
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021_VW48.rod
       VCID: 3828DFA6E2DFEA9766D-806C
    31031 - Transmission Friction Element / Clutch A
              P07A3 00 [040] - Stuck On
                        Mileage: 68719 km
                        Date: 2019.04.24
                        Time: 14:23:46
                        Engine speed: 7.00 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 61 km/h
                        Control Module temperature: 65 °C
                        CURRENT pressure: -9.5 bar
                        selected gear: GANG_5
                        Driving position: N
                        Accelerator position: 0.4 %
                        DTC memory status: 24320
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
       Component: ESC           H62 0855
       Revision: 00000000    Serial number: 62136000001459
       Coding: 0FEC408F382623704777060441C849F0021CC4E260829271B8A1F078C20202
       Shop #: WSC 00015 115 08193
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
       ROD: EV_Brake1UDSContiMK100OMG_003_VW48.rod
       VCID: 7CA003B6966706B7C25-8028
    16401 - Tire Pressure Warning
              C102D 00 [044] -  -
                        Mileage: 69013 km
                        Date: 2019.05.22
                        Time: 11:29:17
       Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
       Component: VWKESSYMQB    036 0811
       Revision: 00036000    Serial number: 0415655086
       Coding: 0F2020070F
       Shop #: WSC 05311 115 00307
       VCID: 3C20C3B6D6E7C6B7825-8068
       Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
       Component: GEB.F.Heckoef  H17 0812
       Serial number: ;8057838
    222732 - Sensor 2 for Rear Lid/Hatch Opening
              B1338 01 [137] - Electrical Failure
                        Reset counter: 227
                        Mileage: 69072 km
                        Date: 2019.05.23
                        Time: 21:40:51
                        ZAT_pressed: OFF
                        Enabling immobilizer: Condition not met
                        Control Module Voltage: 14.709 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Coding information: coded
                        Driver door: Open
                        Front Passenger Door: Open
                        Left rear door: Open
                        Right rear door: Open
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 5GE 907 044 AL    HW: 5GE 907 044 AL
       Component: Climatronic   H04 1502
       Revision: 00001K07
       Coding: 1202102420011101091550000010182A
       ROD: EV_ACClimaBHBVW37X_006_VW48.rod
       VCID: 0654615ED8AB4C67A41-8052
       Subsystem 3 - Part No SW: 3Q0 963 231 D    HW: 3Q0 963 231 D
       Component: J848 HV-PTC  200 0204
       Serial number: -00103.5T.5B20340198
    H02
       Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
       Component: BCM PQ37BOSCH 032 0222
       Revision: --------    Serial number: 865806081600ZT
       ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
       ROD: EV_BCMBOSCH_017.rod
       VCID: 015E7242F1856B5F913-8054
       Component: WWS    160715  042 0607
       Serial number:         160727045901
       Component: RLHS  042 0105
       Serial number: S4Y16M08D30H12M30S50
       Coding: 00A8DD
       Light switch:
       Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
       Serial number: 26 06 2016  10000501
       Serial number: 000000000ZY1620412PJ
       Serial number: 00000000000066540852
       Ceiling Light Module:
       Subsystem 6 - Part No SW: 3G0 947 105 E    HW: 3G0 947 105 E
       Component: J528 Dachelek  H08 0008
       Serial number: 16081900010274E
       Coding: F38380
    204546 - Remote key 2
                        Reset counter: 227
                        Mileage: 69072 km
                        Date: 2019.05.23
                        Time: 21:50:35
       Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
       Component: PLA 3.0 12KH08 0161
       Serial number: 000305183616231
       Coding: 1A71161951
       Shop #: WSC 05311 115 00081
       ASAM Dataset: EV_EPHVA2CAU3700000 009017
       ROD: EV_EPHVA2CAU3700000_009_VW48.rod
       VCID: 0D465E72BDDD3F3FE5B-8058
       Component: ACC BOSCH MQB H04 0194
       Coding: 520067CB59FFC428949C8045
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3430EB96FEB70EF74A5-8060
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    010 0870
       Serial number: 003MFR02E6DG
       Coding: 88CCC000002000005C5400CF004800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 50F887066A6F52D74ED-8004
       Belt Pretensioner left:
       Component: BeltPretRevFL  106 1032
       Serial number: 3G1857705G0221Q00352
       Coding: 80000D
       Belt Pretensioner right:
       Component: BeltPretRevFR  106 1032
       Serial number: 3G1857706G0230Q01015
       Coding: 80000D
       Subsystem 3 - Part No SW: -----------    HW: 480 002 608 16
       Serial number: 3570000000009A956D1P
       Subsystem 4 - Part No SW: -----------    HW: 480 002 608 16
       Serial number: 35800000000DCC60ED11
       Subsystem 5 - Part No SW: -----------    HW: 480 401 608 16
       Serial number: 3510002AF218C2A5A2AC
       Subsystem 6 - Part No SW: -----------    HW: 480 401 608 16
       Serial number: 35200029F215E1E25374
       Subsystem 7 - Part No SW: -----------    HW: 480 401 608 16
       Serial number: 3550002A9218C2A4C2CD
       Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160812500571
       Coding: 0410
       Shop #: WSC 00015 115 00001
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 7BA200AA9369018FCBF-802E
       Part No SW: 3G0 920 795 B    HW: 3G0 920 795 B
       Component: KOMBI         404 2153
       Coding: 07240B182FC4000801886B113201002000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009052
       VCID: 2C00F3F626875637125-8078
       Part No SW: 5Q0 963 272 H    HW: 5Q0 963 272 H
       Component: STH-MQB       008 0075
       Coding: 13C1
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       VCID: 3B22C0AAD3E9C18F8BF-806E
       Component: R64 D208L  004 0401
       Serial number: 00000000000000096477
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 F    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3265
       Revision: --------    Serial number: 30081610521959
       Coding: 020300172EF21000FB00527E5C1D00000001070100010000000300000000
       ASAM Dataset: EV_GatewEVConti 013020
       ROD: EV_GatewEVConti_013_VW48.rod
       VCID: 49CEAA628935631F093-801C
       Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
       Serial number: 29160001579790026323
       Coding: 2DFFFF
       Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
       Serial number: 6058001104
       Analog clock:
       Subsystem 3 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Component: Analoguhr  209 2002
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
       Component: EBKV          H14 0200
       Serial number:   085430010743
       Coding: 05720100431900020002060500
       Shop #: WSC 05311 115 00320
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
       ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861100816122543
       Serial number: 16000188130001
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BE2282C1257BDF613-8024
       Serial number: 200816EHA06456
       Coding: 003F1E208000028000001000
       VCID: 43D2B84AAB19B94FC3F-8016
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0001005429
       Coding: 01010010005101
       Shop #: WSC 00015 115 00307
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       VCID: 3D26CEB2CDFDCFBFB5B-8068
    Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
       Part No SW: 3Q0 035 465     HW: 3Q0 035 465
       Component: MIB2_amp_P_VW H60 0440
       Revision: 00000001    Serial number: VWZ8Z1GJD009G55
       Coding: 1284020001AA0A20AA0000000000
       ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
       ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
       VCID: 6B8230EAE309910F5BF-803E
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 3G0 907 080 E    HW: 3G0 907 080 C
       Component: LE Gen 3.3H09 0072
       Revision: 00H09000
       Coding: C0020000000000000000
       Shop #: WSC 34982 002 1048576
       ASAM Dataset: EV_DMCM08530113G0907080E 001017
       ROD: EV_DMCM08530113G0907080E.rod
       VCID: 270A0CDA3F61756FFF7-8072
    31801 - No Communication with Battery Energy Control Module
              U0111 00 [032] - -
                        Fault Frequency: 112
       Serial number: 170616EFH07884
       Coding: 003F10208000028000001000
       VCID: 42DCBD4EB403B047C89-8016
       Component: AFS-ECU       H01 0120
       Coding: 039A00004F210200
       Shop #: WSC 05311 000 08193
       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
       VCID: 3FDAB4BAC7F1DDAFA77-806A
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 043 D    HW: 3G0 035 043
       Component: MU-H-N-EU     H51 0814
       Serial number: A683H0GB041053
       Coding: 028402010000000051110002000808001F0209E4012000009F
       VCID: 1D662E326D3DAFBF95B-8048
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL039VS
       Subsystem 2 - Part No SW: V03 959 806 FL    HW: -----------
       Component: ECE 2019  --- 0175
       Component: Gracenote2---  --- 1013
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0204
       Revision: 8A001003    Serial number: 0411208477
       Coding: 0100000202000000
       Part No SW: 5Q0 980 568     HW: 5Q0 980 568
       Component: RVC Compact+  H06 0100
       Coding: 0184020163002017000048
       ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
       ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
       VCID: 7AAC05AE9C533887D09-802E
       Part No SW: 5Q0 959 107 C    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0260
       Revision: --------    Serial number: 30891726200000
       Coding: 02A8
       ASAM Dataset: EV_DeckLidCONTIAU736 001013
       Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
       Component: OCULowMQBEU   012 0717
       Coding: 028472011082BA0300F800000000
       ROD: EV_OCULowMQB.rod
       VCID: 44D0BB56AE17BE77FA5-8010
    Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
       Part No SW: 3Q0 915 227 P    HW: 3Q0 915 227 K
       Component: K8C           H05 0520
       Serial number: 09081616010136
       ASAM Dataset: EV_BECM09620213Q0915227P 002009
       ROD: EV_BECM09620213Q0915227P.rod
       VCID: 3E24C9BEC0FBD4A7AC1-806A
       Battery Junction Box:
       Subsystem 1 - Part No SW: 3Q0 915 227 J    HW: 3Q0 915 227 J
       Component: A2 HVSMBJBECU  H08 0410
       Serial number: 00000010081616010111
       Cell module: control module 1:
       Subsystem 2 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC1  H04 0442
       Serial number: 16519ZKK311A01041041
       Cell module: control module 2:
       Subsystem 3 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC2  H04 0442
       Serial number: 16519ZKK311A01041115
       Cell module: control module 3:
       Subsystem 4 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC3  H04 0442
       Serial number: 16520ZKK311A01040230
       Cell module: control module 4:
       Subsystem 5 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC4  H04 0442
       Serial number: 16519ZKK311A01041076
       Cell module: control module 5:
       Subsystem 6 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC5  H04 0442
       Serial number: 16521ZKK311A01040185
       Cell module: control module 6:
       Subsystem 7 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC6  H04 0442
       Serial number: 16521ZKK311A01040711
       Cell module: control module 7:
       Subsystem 8 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC7  H04 0442
       Serial number: 16521ZKK311A01040297
       Cell module: control module 8:
       Subsystem 9 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
       Component: J1068MQB CMC8  H04 0442
       Serial number: 16521ZKK311A01040408
       Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
       Component: MQB_B_MFK     H06 0220
       Serial number: 22081611P22057
       Coding: 000408020700040100222345C050A10010000E300040
       VCID: 3A2CC5AEDCD3F887909-806E
       Part No SW: 3G0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 160729200395
       VCID: 698E4AE2E9F5831F293-803C
       Serial number: 280716EGS06798
       Coding: 000E10200100028000001000
       VCID: 45D6A652A52D877FEDB-8010
       Serial number: 280716EGS0679B
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 M    HW: 5QE 915 682 M
       Component: OBC KOSTAL    H31 4006
       Revision: --------    Serial number: 0808160GT0017G
       Coding: 115068222000
       ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
       ROD: EV_OBCSinglPhaseKLOMQB11P.rod
       VCID: 57EA7C1A4F8105EF8F7-8002
    13705540 - Databus
              [Errorvalue_ ESP_21_CHK]
                        Reset counter: 16
                        Mileage: 58680 km
                        Date: 2018.12.03
                        Time: 09:58:41
       Component: SAD_STG_1     013 0005
       Coding: 208040748202
    End----------(Elapsed Time: 02:41, VBatt start/end: 13.1V/13.1V)-----------
    On some of these late-model cars, the ABS module (where your tire pressure fault is) no longer accepts a request to clear fault codes via individual module (physical) addressing. Instead they only accept requests to clear fault codes via the functional OBD-II addressing scheme. So try clearing fault codes 01-Engine and see what happens.
    However, this shouldn't be the case in the BCM (where your Remote Key fault is). If you're getting "not acknowledged" there, I'm puzzled.
    Tartu, Estonia
    Open hood for testing?
    The world is my oyster...
    That being a 2017 model, I would be quite surprised if its gateway had diagnostic firewall functionality.
    But of course it doesn't cost much to try.
