Results 1 to 10 of 14
Thread: 2011 VW JETTA ABS Long Coding Erased (MK60EC1)
    May 2016
    Honolulu, HI USA
    I lost ABS long coding after Immo. programming.
    2011 VW Jetta
    VIN: 3VW2K7AJ8BM390989
    Address 03: ABS Brakes(J104) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
    Revision: 00H31001
    Coding: 0000.....
    VCID: 7BF5CC50FA15A59288-802E
    This is second time ABS coding problem.
    First one was my friends job...
    But second one is my mistake. I didn't Auto-Scan.
    Please help me out...
    Thank you
    Please post an Auto-Scan even if it's with the ABS coding of all zeroes...
  3. Likes Jack@European_Parts, Uwe, lock-key liked this post
    Quote Originally Posted by lock-key View Post
    Next time you'll do a scan before immo programming, right?
    In addition to an Auto-Scan, please post Advanced ID data from 01-Engine, 17-Instruments, and 25-Immobilizer.
  5. Likes Dana liked this post
  6. #4
    Nov 2017
    Latvia
    I didn't Auto-Scan.
    So, please open \VCDS\Scans folder and search from here. Maybe you DO have a coding.
  7. Likes Jack@European_Parts, lock-key liked this post
  8. #5
    May 2016
    Honolulu, HI USA
    I use Abrites EEFROM Immobilizer program done.
    Here is Auto-Scan after lost coding.
    Saturday,25,May,2019,11:06:19:61637
    VCDS Version: 18.9.1.0
    VIN: 3VW2K7AJ8BM390989   License Plate:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 08 09 15 17 19 25 56
    VIN: 3VW2K7AJ8BM390989   Mileage: 163760km-101755miles
    Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
       Part No SW: 06G 906 055 C    HW: 06G 906 055 B
       Component: 2.0l /85 KW      01 1110
       Revision: T5H04---    Serial number:
       Coding: 0001015
       Shop #: WSC 21026 444 84597
       VCID: 2959C6188009E702AA-807C
    Readiness: 0110 0101
       Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
       Component: AQ 250 6F           1791
       Revision: 00H90000    Serial number:
       Coding: 0000840
       VCID: 7F0D38402E0DB9B2A4-802A
       Revision: 00H31001
    03306 - Coding Not Valid
                000 -  -  - Intermittent
                        Reset counter: 236
                        Mileage: 163767 km
                        Date: 2013.10.14
                        Time: 03:13:02
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 4161
                        Count: 49152
                        Reset counter: 236
                        Date: 2013.10.14
                        Time: 03:13:32
                        Count: 3
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 48896
    00150 - Plausibility Brake Booster System
                        Reset counter: 236
                        Mileage: 163767 km
                        Date: 2013.10.14
                        Time: 03:11:13
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 398
                        Count: 49408
       Part No SW: 5C0 820 047 M    HW: 5C0 820 047 M
       Component: J301  Klimaanlage   0103
       Revision: 2000908S    Serial number: 00000000390400
       VCID: 2A5B3914850FEC1AA3-807E
       Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0226
       Revision: B2066001    Serial number: 03311151110169
       Coding: 7B994B1808AB0B0000302000240884D40042502E60000000300000000000
       VCID: 2D51320874E1FB2246-8078
       Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3464
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3464
       Coding: 820000
       Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3464
       Coding: 800000
       Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3464
       Coding: 800000
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   013 0807
       Serial number: 003GTD0B4640
       Coding: 00003936
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3467276C9FCBAAEA09-8060
       Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
       Component: BF-Gewichtss.  H10 0027
       Serial number: 6940000Y1100004R4C0G
       Coding: 303148
       Serial number: 3572MSME6A7A555EZZZC
       Serial number: 3582MSME4B79505DZZZ5
       Serial number: 3516KSME31614E10ZZZJ
       Serial number: 3526KSME30474E10ZZZN
       Serial number: 3556LSME79213E0FZZZ2
       Serial number: 3566LSME48083E0FZZZ4
       Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
       Component: KOMBI         H07 0406
       Coding: 270201
       Shop #: WSC 00066 000 00144
       VCID: 2B553C1042F5F51258-807E
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 0226
       Coding: 102200
       VCID: 70EFEB7CA353D6CA2D-8024
       Component: IMMO          H07 0406
       VCID: 6ADBF9148D8F2C1A63-803E
       Part No SW: 1K0 035 164 A    HW: 1K0 035 164 A
       Component: LOW NAR       H14 0043
       Revision: -----06S    Serial number: VWZ4Z6L3142181
       Coding: 0500040001
       VCID: 204FDB3C3333264AFD-8074
    End-------------------------(Elapsed Time: 03:00)--------------------------
  9. #6
    Please post advanced ID data of engine ECU and Immobilizer.
    JPPSG!
  10. Likes lock-key liked this post
  11. #7
    OP:
    FOD check so far passes for configuration.
    Please describe brake attributes, accoutrements installed & aforementioned request for advanced ID?
    Vehicle Identification No. 3VW2K7AJ8BM390989
    Model Jetta
    JEM
    Date of production 06.06.2011
    Model year 2011
    Sales type 162VJ3
    Engine Code CBPA
    Transmission Code MAM
    Coding: 0001015
    Coding: 0000840
    Revision: 00H31001
  12. Likes lock-key liked this post
  13. #8
    May 2016
    Honolulu, HI USA
    OP:
    Model Jetta
    JEM
    Model year 2011
    Sales type 162VJ3
    Engine Code CBPA
    Coding: 0001015
    Coding: 0000840
    Revision: 00H31001
    Could you tell me.
    How to find those Advanced ID ?
    I have picture of PR Codes. The brake code was 1ZQ.
    https://qsqdtw.bn.files.1drv.com/y4p...525_103410.jpg
    I use ABS/ESP Long Code Calculator Helper show:
    00 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18
    00 00 00 00 09 25 00 03 00 0B 00 ED 90 21 00 00 00 00 00
    Thank you
  14. #9
    Nov 2017
    Latvia
    It's not hidden actually. See button under Readiness. Get that info from all modules Uwe asked in post #3.
  15. Likes Uwe, Dana liked this post
  16. #10
    May 2016
    Honolulu, HI USA
    Here is Auto-Scan
    Tuesday,28,May,2019,17:42:30:61637
    Mileage: 163760km-101755mi   Repair Order: 2011 Jetta 05-28-19
       Coding: 0001015
       Coding: 0000840
       Revision: 00H31001
                        Reset counter: 236
                        Mileage: 163767 km
                        Date: 2013.10.13
                        Time: 03:13:02
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 4161
                        Count: 49152
                        Reset counter: 236
                        Date: 2013.10.13
                        Time: 03:13:32
                        Count: 3
                        Count: 12
                        Count: 20992
                        Count: 195
                        Count: 48896
                        Reset counter: 236
                        Mileage: 163767 km
                        Date: 2013.10.13
                        Time: 03:11:13
                        Count: 3
                        Count: 12
                        Count: 29184
                        Count: 398
                        Count: 49408
       Coding: 820000
       Coding: 820000
       Coding: 800000
       Coding: 800000
       Coding: 00003936
       Coding: 303148
       Coding: 270201
       Coding: 102200
       Coding: 0500040001
    End-------------------------(Elapsed Time: 02:02)--------------------------
    Here is Advanced ID Data.
    Tuesday,28,May,2019,17:19:24:61637
    Mileage:    Repair Order: 2011 Jetta
                    Address 01: Engine
    Control Module Part Number: 06G 906 055 C
      Component and/or Version: 2.0l /85 KW      01 1110
               Software Coding: 0001015
                Work Shop Code: WSC 21026
    Advanced Identification
         Identification: ZSC-864
         Revision: T5H04---
         Date: 21.05.11
         Test stand number: 7825
         Manufacturer number: 0087
    Flash Status
         Programming Attempts: 1
         Successful Attempts: 1
         Programming Status: 00000000
         Required Conditions: 00000000
         Flash Tool Code: 84821 444 21026
         Flash Date: 14.14.14
    Software
         M14V30
    Misc.
         Hardware number: 06G 906 055 B
         Immo Challenge: 38 C3 D3 F0
    Car Info
         Chassis Number: 3VW2K7AJ8BM390989
         Engine code: CBP
    VCDS Info:
           Readiness: No script available
    Tuesday,28,May,2019,17:23:58:61637
    Mileage:    Repair Order: 2011 Jetta 17- Instrument
    Control Module Part Number: 5C6 920 950 D
      Component and/or Version: KOMBI         H07 0406
               Software Coding: 270201
                Work Shop Code: WSC 00066
    Advanced Identification/FAZIT
         Identification: ZYS-000
         Date: 31.05.11
         Manufacturer number: 4131
         Test stand number: 0866
    Flash Status
         Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
         Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
         Flash Date: 00.00.00
    Software
         OSEK-OS: 03.14.00
         HiSpd Net: 01.12.01
    Misc.
         Hardware number: 5C6 920 950 D
         Workshop System Name: J285
         Equipment/PR Code: 2D2D2D2D2D2D2D2D
         Dataset Number: -----------
         Dataset Version: ----
         End of Line Equipment Level: ------------------
         ASAM Dataset Revision: A04089
    Car Info
    VCDS Info:
           Labels: 5K0-920-xxx-17.clb-SRI1
    Tuesday,28,May,2019,17:27:00:61637
    Mileage:    Repair Order: 2011 Jetta 25-Immobilizer
                    Address 25: Immobilizer
    Control Module Part Number: 5K0 953 234
      Component and/or Version: IMMO          H07 0406
               Software Coding: 000000
                Work Shop Code: WSC 00000
         Date: 31.05.11
    Flash Status
    Software
         OSEK-OS: 03.14.00
         HiSpd Net: 01.12.01
    Misc.
         Hardware number: 5K0 953 234
         Workshop System Name: J334
         ASAM Dataset Revision: A03008
    Car Info
    Immobilizer
         Transponder ID (Current val.): 2AD8840E
         Transponder ID 1: 6C78931F
         Transponder ID 2: 6C7A511B
         Transponder ID 3: D18E83EF
         Transponder ID 4: 502168A1
         Transponder ID 5: 2AD8840E
    VCDS Info:
           Labels: 5K0-920-xxx-25.clb
  17. Likes Uwe, Dana liked this post
