Results 1 to 6 of 6
Thread: Interface not found
Hybrid View
    May 2019
    Interface not found
    Yesterday it was working just fine. Today the interface is not found. When I plug it into USB it blinks green a couple of times and that's it. VCDS doesn't see the interface. Windows shows device unrecognised (vendor/device descriptor failure). Tried with 2 different PC and 3 different cars. Any suggestions?
    Edit: I tried rebooting windows, reinstalled vcds, etc. No effect.
    Cheers,
    Rafal
    What type of interface do you have? HEX-CAN, HEX-V2, HEX-NET or something else?
    Are you running Windows 10?
    I believe he's got a HEX-V2, about two years old.
    Does VCIConfig recognize it? Have a look at this thread:
    https://forums.ross-tech.com/showthread.php?13306
    May 2019
    VCIConfig doesn't see the interface (dropdown list is empty). Windows 10 device manager tells Unknown USB Device "Device Descriptor Request Failed". I tried giving it a rest over the night but no luck.
    Then I suggest you contact the local distributor you purchased it from so he can perform a physical evaluation.
  6. #6
    May 2019
    Ok, thanks. I will contact local dealer. Hope they have some capabilities to fix things not only sell
