Hi everyone,
My name is Erik from the Netherlands and a real VCDS enthusiast.
We've installed a genuine VAG trailer hitch with OEM module and code it. Unfortunately it still doesn't work.
- Installed the 69 Trailer in Installation list 19 CAN Gateway
- Ticked "Anhaengersteuergerat" in 09 Cent. Electr.
- Activated stabilisation trailer in 03 ABS Brakes
After installing I can reach the 69 trailer module, no fault codes show up and the values of all lights switch from OFF to ON, when I tap the brake, turn lights etc.
Only no output to trailer lights!
Am I missing or forgot to ticked / activate something?
Below the list after we've disconnect the battery as last option.
I know the faults will dissapear after a test drive.
Saturday,25,May,2019,18:44:50:22007
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8V9EA044949 License Plate: AUDIA3-5
Mileage: 135284km-84061mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F 69 BB BC
VIN: WAUZZZ8V9EA044949 Mileage: 135284km-84061miles
Address 01: Engine (J623-CXSA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 DE HW: 04E 907 309 A
Component: 1.4l R4 TSI H08 5672
Revision: WAH08---
Coding: 02190012242401082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM14TFS01104E906016DE 002002
ROD: EV_ECM14TFS01104E906016DE_AU37.rod
VCID: 68894614F2F6843736D-803C
17158 - Databus
U1123 00 [039] - Received Error Message
Mileage: 135284 km
Date: 2019.05.25
Time: 00:00:40
Coolant temperature: 92 °C
Intake air temperature: 54 °C
Voltage terminal 30: 12.062 V
Mass flow through throttle valve: 0.0 kg/h
U0428 00 [039] - -
Mileage: 135284 km
Date: 2019.05.25
Time: 00:00:39
Voltage terminal 30: 12.086 V
selected gear-Bits 0-7: 0
Readiness: 1110 0001
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 62043000000187
Coding: 12F16AA224242A700180060441CC294856245480608294F2022100788508
ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
VCID: 7BA3095893603FAFCBF-802E
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 91
Mileage: 135284 km
Date: 2019.05.25
Time: 00:00:40
Reset counter: 91
Mileage: 135284 km
Date: 2019.05.25
Time: 00:00:50
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000001203143
Coding: 03000004000000011000000000001100
Shop #: WSC 00083 002 1048576
VCID: 323DE47C04AA3EE7589-8066
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: FE390EB6000000000001
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011319900705
Coding: 04020A42C2C120DD43844004001C07A80008000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77AB1568AF481BCFAF7-8022
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130713 041 0580
Serial number: 130718233323
Coding: 0A47F7
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Component: E1 - LDS MQB H05 0032
Serial number: 11 05 2013 00000470
Subsystem 3 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20441502
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R02L5C8
Coding: 98CCC0000C0000005C5400CA004800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4BC3999883404F2F3BF-801E
Subsystem 1 - Part No SW: ----------- HW: 480 002 507 13
Serial number: 35767000000C4B4C2D00
Subsystem 2 - Part No SW: ----------- HW: 480 002 507 13
Serial number: 3586700000034B4C2D0Z
Subsystem 3 - Part No SW: ----------- HW: 480 402 507 13
Serial number: 3516502B11074482F2B2
Subsystem 4 - Part No SW: ----------- HW: 480 402 507 13
Serial number: 3526502AF10744809195
Subsystem 5 - Part No SW: ----------- HW: 480 402 906 13
Serial number: 3556502B1106FA4292EF
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 307 13
Component: PedP_Sensor_D 001 6149
Serial number: 22865029D106FA43D07K
Subsystem 7 - Part No SW: ----------- HW: 480 401 307 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502C3107DB5120D8
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 401 307 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C3107DB53310Y
Part No SW: 8V0 953 521 B HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 24071308490696
Coding: A418
ROD: EV_SMLSKLOMQB_012_AU37.rod
VCID: 392FD350D9DCCDBF993-806C
Part No SW: 8V0 920 870 G HW: 8V0 920 870 G
Component: KOMBI H03 2211
Coding: 07A509002B8000080D00EA00000000
VCID: 3FDBBD48C7F8E38FA77-806A
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000794624
Coding: 030100042B0864005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 3B23C958D3E0FFAF8BF-806E
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 19 07 2013 D0273403
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004050444572
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 15071304080197
Coding: 00108F204000040000001002
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 M
Component: EPS_MQB_ZFLS 127 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D27C740CDF4F19FB5B-8068
16135 - Steering Angle Sensor
B1168 F2 [009] - Not Initialized
Reset counter: 0
Time: 00:00:00
Motor status: 00
Supply voltage: 12.50 V
Temperature: 44.0 °C
KFC: 3F
KFA: 00 07
Environmental conditions: 5F
uAdSensI_U5VFiltered_xdu16: 5.08797 V
uioUdNotFilt_xdu16: 12.44 V
uAdSensI_SwitchedKl30_xdu16: 12.44 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 14
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 14071304080187
Coding: 001087204C00040000001002
VCID: 3E25C04CC0F2EA87AC1-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Coding: 0198000001000000
VCID: 75B71F60B54469DFBDB-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 864 A HW: 8V0 035 864
Component: MU-S-N-ER 040 0370
Serial number: A3F02607131359
Coding: 01730301FF00000021110001000A00002F0004440100010006
ASAM Dataset: EV_MUStd4CPASE 002018
ROD: EV_MUStd4CPASE_VW37.rod
Subsystem 1 - Part No SW: 8V0 919 866 A HW: -----------
Component: ECE 2013 --- 0021
Subsystem 2 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H48 0013
Serial number: AUZ8Z9DG601QY3
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000005071300010156
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 HW: 5Q0 907 383
Component: Anhaenger H11 0030
Revision: 6A001003 Serial number: 00000195009332
Coding: 0101000200000000
ASAM Dataset: EV_TrailFunctDemouHella 001001
ROD: EV_TrailFunctDemouHella.rod
VCID: 74B12264BE3E70D78A5-8020
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 04071301101240
Coding: 000087204000040000001002
VCID: 41DFBBB0B10C957FD13-8014
Component: TSG HBFS 010 0006
Serial number: 04071303111248
End----------(Elapsed Time: 01:21, VBatt start/end: 12.4V/12.3V)-----------
