Results 1 to 4 of 4
Thread: Fault Codes 02895 & 02897 2013 Audi S5
    Verified VCDS User andrewgovroom's Avatar
    May 2019
    Fault Codes 02895 & 02897 for 2013 Audi S5 Please Help!
    Hi everyone! Just got my first Ross-Tech VCDS earlier this week. I bought this VCDS because i'm hoping it could help me fix fault codes 02895 & 02897. My mechanic was messing around in my headlight setting because I had a different fault code, at the time, and he some how change some settings some how. I know most people thinks it was the DRL Modules, but I replaced both of them and i'm still getting those 2 fault codes. However after playing around with my mechanics Autel for a couple hours, I believe it is not a hardware issue, it is more like software/setting issue. I concluded that the only reason why i'm getting these 2 fault codes is because when my head lights are on, the LED DRL doesn't dim and light up anymore. Keep in mind my DRL aren't defective, they work perfectly during the day. I notice I only get these fault codes only when my low beam head lights are on.
    So my question is, does anyone know if Ross-Tech VCS actually has an option to turn on the DRL dim when low beam is on? Thank you in advance for any help you could provide. I have a 2013 Audi S5.
    UPDATE 5-25-2019
    I went through all the long code bits in the central electronics, and none of them has an option to turn on DRL with Low Beam. However there was one that allows you to turn on DRL with High Beam, but that didn't do anything that I noticed..
    Here is the AutoScan Log I saved right after I finished installing and setting up the software on my laptop. Please note this Autoscan log is after I got the 2 fault codes. I do not have my original autoscan log given this is the first VCDS I ever bought. Thank you again for anyone who can help!
    Saturday,25,May,2019,16:19:49:58979
    VIN: WAUCGAFR6DA074900   License Plate:
    Chassis Type: FR-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56
              5F 6C A9
    VIN: WAUCGAFR6DA074900   Mileage: 79350km-49305miles
    Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0004
       Revision: --H07---
       Coding: 1A250034052600060000
       Shop #: WSC 49910 001 1048576
       ASAM Dataset: EV_ECM30TFS0218K5907551E 001004
       ROD: EV_ECM30TFS0218K5907551E.rod
       VCID: 3829292612DDEDF766D-806C
       Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
       Component: 0B5 30TFSINAR H01 0009
       Revision: --H01---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMDL501021 001012
       ROD: EV_TCMDL501021.rod
       VCID: 40D941C64A0DA537DED-8014
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Coding: 291D1A
       VCID: 04518DD61E157917BA5-8050
       Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
       Component: BCM2 2.0      H12 0633
       Coding: 0D804000000000000000
       VCID: 015F84C201076C3F913-8054
       Serial number: 2313000061264006
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000057786625
       Coding: 00037025002C00000000
       VCID: 45D750D255AF801FEDB-8010
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01180420130852
       Coding: 6602228000
       VCID: 392F2C222957F4FF993-806C
       Revision: 08016001    Serial number: 00000595553002
       Coding: 26000095863CBFE0210048C300003D0D0F9CD388A2090221000008004000030100000030000000
       Shop #: WSC 06342 123 12345
       VCID: 78A9E92652DD2DF7A6D-802C
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 150413  H15 0080
       Serial number: SWF13040155466
       Coding: 00FD11
       Serial number: 21200973
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000604131772
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R5LJ202
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: D358C0A6000000000001
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Fault Frequency: 11
                        Reset counter: 79
                        Mileage: 78678 km
                        Date: 2019.05.12
                        Time: 17:51:19
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Fault Frequency: 11
                        Reset counter: 79
                        Mileage: 78678 km
                        Date: 2019.05.12
                        Time: 17:51:20
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Serial number: 003KJD91N4TZ
       Coding: 303343334830303030304A55304C38543053
       VCID: 4ACD63EE7C316F67009-801E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R130000CTN4
       Serial number: 6334MSME7B4526019
       Serial number: 6344MSME79053373B
       Serial number: 6352QSME34313F4EO
       Serial number: 6362QSME2730016EB
       Serial number: 63732SME1A303652T
       Serial number: 63832SME1A301E50Y
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20130413000430
       Coding: 000036
       VCID: 51FF748291E75CBF413-8004
       Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P
       Component: KOMBIINSTR.   H35 0556
       Revision: 00200000    Serial number: UUZ25VH4E
       Coding: 8BB701008301D705020200
       Shop #: WSC 06325 123 12345
       VCID: 4BC366EA73CB766F3BF-801E
       Component: GW-BEM 4CAN-M H11 0056
       Revision: 1Y070028    Serial number: 2841Y133288178
       Coding: 80C303FF00
       VCID: 4ACD63EE7CB16F67009-801E
       Serial number: 0495750303
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H14 0100
       Serial number: 000704130001416
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F3B127AE7932A4F377-807A
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000057784899
       Coding: 001B7B25002C00000000
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0304
       Coding: 011C13224E00120102
       VCID: 56F5879EB8093B87941-8002
       Revision: 00001000    Serial number: 0010384982
       Coding: 100000010001
       Shop #: WSC 06324 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 34311D160EB509974A5-8060
       Revision: 00002001    Serial number: 0304725176
       Coding: 0106029A00FA400580B0003200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000659515
       Component: J245EE20SKB13  H05 0220
       Revision: 00005001    Serial number: 94813013373802
       VCID: 2D070872ED1F585F05B-8078
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0304
       VCID: 55F78092A50F309F9DB-8000
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 10000000199777
       ROD: EV_ParkiBrake_AU48.rod
       Part No SW: 4G0 035 082 E    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0121
       Revision: AB001007    Serial number: 156DZ0D7715082
       Coding: 020007010000000001
       Shop #: WSC 06342 000 00000
       VCID: 221DEB4EA4C19727A89-8076
       Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
       Component: H-BNT-NA      H44 0624
       Revision: --------    Serial number: 204DX0D7573264
       Coding: 140200020206A1EF45028B4E00000403140000000000000000
       VCID: 372B2A1A1F43E28F6F7-8062
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Component: DU7 High  H42 0104
       Serial number: A130DL0D2702724
       Serial number: 00000001473118
       Component: CD-Database  4949
       Revision: --H07---    Serial number: 525PA8-J31918V
       Coding: 1000008
       VCID: 382929261E5DEDF766D-806C
       Part No SW: 8K0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 130319200578
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: 72BDDB0E342147A7989-8026
    End----(Elapsed Time: 01:49, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
    -Andrew
    As always, when asking a coding/adaptation question it's much easier to answer if you include a full unedited VCDS Auto-Scan - see my signature for a How-To
  3. Likes Eric, Uwe liked this post
    May 2019
    Thank you for the advice! I'm very new to this so I will definitely do a VCDS auto-scan.
    Andrew has started a duplicate thread here, and merging them would be messy/redundant, so I'm closing this one.
    PS: For future reference and as a matter of general forum policy: We can easily move a thread to a more appropriate section one a person becomes verified, and I would much prefer to do that rather than having duplicate threads cluttering up the forum. However, it may not be immediately obvious that this should be done, so if someone things a thread should be relocated, feel free to shoot me a PM.
  6. Likes PetrolDave liked this post
