Results 1 to 8 of 8
Thread: Caddy Van 2019 Subwoofer Wiring
    Mar 2019
    Hi there, I want to connect a Kenwood subwoofer to the Discover media that came with the van. I am trying to find out which wires are the speaker wires on the back of the unit, can't find any VW wiring diagrams anywhere. The wiring on the Kenwood has the option of Yellow and Red RCA connections or you can connect directly to the speaker wire which would be more of a ball ache, connecting to the RCA leads would obviously be much easier if adapters can be bought, any help would be appreciated
    Apr 2018
    ITALY
    you can buy one hour of access on Erwin, input your VIN and get WD for your Caddy.
    you will not find RCA outputs behind the OEM unit, you'll have to tap into a speaker-level signal.
    maybe you could consider retrofitting the OEM subwoofer, it's probably doable.
    Mar 2019
    What section on Erwin would i look for this information?
    Quote Originally Posted by steved1969 View Post
    Input your VIN, then download ALL the wiring diagrams offered as pdf files.
  5. Likes Uwe liked this post
    Nov 2016
    There is no pre-out for the DM, you have to connect to speaker level out. The 8 speaker wires are very obvious when you pull the unit out and look at the quadlock
    Jul 2014
    Tallinn, Estonia
    To make it even more obvious - they're in the light brown sub-connector of the Quadlock.
    May 2014
    ^^^ here's one I made-up a little earlier - should be the same as in the Golf
  9. #8
    Mar 2019
    The pins on my van were 2367
