Results 1 to 10 of 15
Thread: Tweaking my miles per gallon display
    Apr 2019
    NO ASS no cert no worries
    Well it’s been almost 3000 miles and at least seven tanks of gas, and it is hit or miss on whether or not I get a fairly accurate reading on my miles per gallon. It is usually running about 2 miles per gallon high on the overall per tank value vs hand calc. How can I adjust this down even 1 mile per gallon and maybe it could learn the rest? Any help is appreciated.
    Edit, I am of course referring to the “since refuel” screen.
    I will try to help you with this once you put a link to an Auto-Scan from your car in your forum signature. It has become too tedious for me to have to go through your posting history and try to find a scan, so I can look up exactly how your car is equipped so I can see what we know about it.
    Apr 2019
    If I only knew how to do that. If there’s an easy way to explain, please do.
    Apr 2019
    Quote Originally Posted by kawzx7 View Post
    In the upper right-hand corner of pretty much any page (while you're logged in), clock on Settings.
    That will take you to a page with a vertical menu on the left hand side.
    In the My Settings section, you'll find Edit Signature.
    That will get you an edit box where you can use BB Code to create a signature that will appear at the bottom of every one of your posts.
    In your Instrument Cluster, there should be an Adaptation channel called:
    IDE00499 -- Display correction of consumptions and operating range (%)
    I would guess it's currently set to 100%. Try changing it.
    In older cars, these sorts of channels would sometimes only take changes in 5% increments, so don't be surprised if it won't take smaller changes. But if you're 2 MPG off, 5% should get you pretty close.
  7. #7
    Apr 2019
    Do they accept negative values? Or do you mean set to 95%?
    Edit: set to 95%. We shall see!
  8. #8
    Why would they? You can't have negative fuel consumption, right?
    TBH, I'm not sure whether 95% or 105% is the direction you want to go.
  9. #9
    Dec 2016
    DE
    Raising the value above 100% heightens the displayed/calculated consumption. So if the car uses more fuel than displayed in the DIS/HMI and you want to fix that, that is the way to go. Likewise a value below 100% reduces the displayed consumption.
  10. Likes kawzx7, Uwe, Berisford, Dana liked this post
  11. #10
    Apr 2019
    Looking like 105%. 95% yielded a 6 mpg discrepancy. 105% should put it right on the money.
  12. Likes Uwe liked this post
