The MMI in my 2013 Audi A6 stopped working. Occasionally it will pop up and display initializing. After about 30 sec. the display would shutdown and stow itself. I did a full auto scan (below) and could not identify the issue. I took it to the dealer who stated it was the 5F module. They ordered a new module and were still unable to repair the communication issues. (BTW, The cost of the new module is now on them). It appears they are throwing parts at the issue without validating the failure. I would like to know if anyone has seen this failure and any suggestions for repair.
Monday,13,May,2019,14:07:38:49096
VCDS Version: 18.9.1.0 (x64)
VIN: WAUGGAFC7DN133216 License Plate:
Mileage: 76676km-47644mi Repair Order: mmi inop
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 47 52 53
55 56 5F 62 6C 72 8F 90
VIN: WAUGGAFC7DN133216 Mileage: 76676km-47644miles
17-Instruments -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CTUA) Labels: None
Part No SW: 4G0 907 551 D HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0006
Revision: --H07---
Coding: 0A2A0032052601060000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
ROD: EV_ECM30TFS0214G0907551D.rod
VCID: 2A5BC3414D40E11AA3-807E
Part No SW: 4G1 927 158 A HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H16 1006
Revision: --H16---
Coding: 000002
VCID: 2D51C85D7CAEF62246-8078
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 44A78F0122E5F1805B00
VCID: 3663E73189F8B5FA37-8062
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H33 0433
Coding: 0DA82046000000000000
VCID: 7BF53605FA5AA89288-802E
Serial number: 2313000035190007
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 AH HW: 4G0 820 043 AH
Component: KLIMA 2 ZONEN H11 0086
Serial number: 15031300111160
Coding: 6681201849
ASAM Dataset: EV_AirCondiBasisUDS 002044
VCID: 65C1707D64DE0E624E-8030
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001530779
Coding: 06002091063C9FE08100088380003908CF9CD208A6090221000004406000
VCID: 6FED1255BE22C43234-803A
Component: WWS57X 130313 H36 0080
Serial number: 130315051505
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21114010
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 13 03 2013 00000726
Component: USHL4.2 H30 0030
Serial number: 0000002274555R5ADK02
Subsystem 5 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 11088C96000000000001
Revision: 11001001 Serial number: 61061308000406
Coding: A8C305
VCID: 71E9142DA016D2C222-8024
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D8002VB2R
Coding: 303234373131303030314A55304C34473053
VCID: 3365DE259A8AA0D210-8066
Component: BF-Gewichtss. H11 0046
Serial number: 6940000Y130000RYBM0M
Serial number: 3575HRB405D1TEI4BON6
Serial number: 3585HRB401450EP26PA0
Serial number: 3515JRB401I50FFI8PRZ
Serial number: 3525JRB401I50FSMIPD6
Serial number: 3554VRB401450DLOOHA.
Serial number: 3564VRB400I50F3CJ9LL
Revision: -------- Serial number: 90372MCF0010F
Coding: 000414
VCID: 387FE9098BEC438A25-806C
Subsystem 1 - Part No SW: 4G0 951 528 F HW: 4G0 951 528 F
Component: E221 - MFL H09 0010
Serial number: 17 01 2013 33334009
Part No SW: 4G8 920 983 E HW: 4G8 920 983 E
Component: TBenUsa H79 0515
Revision: 28460208 Serial number: 658200313596019
Coding: 0BE609040B41D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K.rod
VCID: 377DEA358EF24CF22C-8062
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000869016
Coding: 00CD073000
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 3032420203
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 1301200000000000018B
0267 - Optical data bus
U1049 00 [009] - Open circuit
Reset counter: 18
Mileage: 76621 km
Date: 2019.05.13
Time: 09:11:27
Voltage terminal 30: 13.2 V
Voltage terminal 15: 13.3 V
Control Module temperature: 31 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000054758321
VCID: 77FD2A35C6728CF2EC-8022
Component: SARA 6D H02 0056
Revision: -------- Serial number: EJ1BPA8202YKHY
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH03 0050
Revision: 00H03000 Serial number: 6PZ 010 287-03
Coding: 0000001
VCID: 306FD129A39C9BCA6D-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H03 0050
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F19.03.1300H03000AMS16039ÿ
Subsystem 4 - Serial number: S16039ÿ
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F17005E00628002000012
VCID: 479D9AF5F6123C725C-8012
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0008322587
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BDB216590A9DA1B-8066
Revision: 00002001 Serial number: 0302599166
Coding: 0106023A00FA408580B0080402050E070000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000136955
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO20954497
Coding: 101F00
02615 - Fuel Tank Cap; Lock
Fault Status: 00101001
Fault Frequency: 7
Reset counter: 54
Mileage: 73539 km
Date: 2019.03.27
Time: 05:44:03
02616 - Fuel Tank Cap; Unlock
Reset counter: 53
Mileage: 74088 km
Date: 2019.04.04
Time: 09:37:32
Address 47: Sound System
Component: TSG BF H03 0507
Coding: 011F17005E00628002000002
VCID: 468397F1F118257AA7-8012
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000632198
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B55C64542BAF81258-807E
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 130320-0002-067
Coding: 1221A6101002A500
ROD: EV_HeadlRegulBasic.rod
Address 56: Radio
Component: TSG HL H03 0507
VCID: 49999CCDE006CA024A-801C
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Revision: --H06--- Serial number: 525 PA8J33G11N
Coding: 1080004
VCID: 264337719158C57A87-8072
Component: TSG HR H03 0507
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3169D42D609692C262-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 05:05)--------------------------
