2013 Audi A6 MMI Failure
Airplanedoc
C?ID=168996
The MMI in my 2013 Audi A6 stopped working. Occasionally it will pop up and display initializing. After about 30 sec. the display would shutdown and stow itself. I did a full auto scan (below) and could not identify the issue. I took it to the dealer who stated it was the 5F module. They ordered a new module and were still unable to repair the communication issues. (BTW, The cost of the new module is now on them). It appears they are throwing parts at the issue without validating the failure. I would like to know if anyone has seen this failure and any suggestions for repair.
Monday,13,May,2019,14:07:38:49096
VCDS Version: 18.9.1.0 (x64)
VIN: WAUGGAFC7DN133216   License Plate:
Mileage: 76676km-47644mi   Repair Order: mmi inop
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 47 52 53
          55 56 5F 62 6C 72 8F 90
VIN: WAUGGAFC7DN133216   Mileage: 76676km-47644miles
17-Instruments -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
5F-Information Electr. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CTUA)       Labels: None
   Part No SW: 4G0 907 551 D    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0006
   Revision: --H07---
   Coding: 0A2A0032052601060000
   ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
   ROD: EV_ECM30TFS0214G0907551D.rod
   VCID: 2A5BC3414D40E11AA3-807E
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   VCID: 2D51C85D7CAEF62246-8078
   Coding: 44A78F0122E5F1805B00
   VCID: 3663E73189F8B5FA37-8062
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H33 0433
   Coding: 0DA82046000000000000
   VCID: 7BF53605FA5AA89288-802E
   Serial number: 2313000035190007
   Part No SW: 4G0 820 043 AH    HW: 4G0 820 043 AH
   Component: KLIMA 2 ZONEN H11 0086
   Serial number: 15031300111160
   Coding: 6681201849
   ASAM Dataset: EV_AirCondiBasisUDS 002044
   VCID: 65C1707D64DE0E624E-8030
   Revision: 11012002    Serial number: 00000001530779
   Coding: 06002091063C9FE08100088380003908CF9CD208A6090221000004406000
   VCID: 6FED1255BE22C43234-803A
   Component: WWS57X 130313  H36 0080
   Serial number:         130315051505
   Coding: 0045F7
   Serial number: 21114010
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 13 03 2013  00000726
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R5ADK02
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Serial number: 11088C96000000000001
   Revision: 11001001    Serial number: 61061308000406
   Coding: A8C305
   VCID: 71E9142DA016D2C222-8024
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002VB2R
   Coding: 303234373131303030314A55304C34473053
   VCID: 3365DE259A8AA0D210-8066
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y130000RYBM0M
   Serial number: 3575HRB405D1TEI4BON6
   Serial number: 3585HRB401450EP26PA0
   Serial number: 3515JRB401I50FFI8PRZ
   Serial number: 3525JRB401I50FSMIPD6
   Serial number: 3554VRB401450DLOOHA.
   Serial number: 3564VRB400I50F3CJ9LL
   Revision: --------    Serial number: 90372MCF0010F
   Coding: 000414
   VCID: 387FE9098BEC438A25-806C
   Subsystem 1 - Part No SW: 4G0 951 528 F    HW: 4G0 951 528 F
   Component: E221 - MFL  H09 0010
   Serial number: 17 01 2013  33334009
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460208    Serial number: 658200313596019
   Coding: 0BE609040B41D705020000
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K.rod
   VCID: 377DEA358EF24CF22C-8062
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000869016
   Coding: 00CD073000
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 3032420203
   Voltage stabilizer:
   Serial number: 1301200000000000018B
0267 - Optical data bus
          U1049 00 [009] - Open circuit
                    Reset counter: 18
                    Mileage: 76621 km
                    Date: 2019.05.13
                    Time: 09:11:27
                    Voltage terminal 30: 13.2 V
                    Voltage terminal 15: 13.3 V
                    Control Module temperature: 31 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Revision: AA000000    Serial number: 00000054758321
   VCID: 77FD2A35C6728CF2EC-8022
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8202YKHY
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 010 287-03
   VCID: 306FD129A39C9BCA6D-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H03 0050
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F19.03.1300H03000AMS16039ÿ
   Subsystem 4 - Serial number: S16039ÿ
   Coding: 011F17005E00628002000012
   VCID: 479D9AF5F6123C725C-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0008322587
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 326BDB216590A9DA1B-8066
   Revision: 00002001    Serial number: 0302599166
   Coding: 0106023A00FA408580B0080402050E070000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000136955
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO20954497
   Coding: 101F00
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Fault Frequency: 7
                    Reset counter: 54
                    Mileage: 73539 km
                    Date: 2019.03.27
                    Time: 05:44:03
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 53
                    Mileage: 74088 km
                    Date: 2019.04.04
                    Time: 09:37:32
Address 47: Sound System
   Coding: 011F17005E00628002000002
   VCID: 468397F1F118257AA7-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000632198
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B55C64542BAF81258-807E
   Serial number: 130320-0002-067
   Coding: 1221A6101002A500
   ROD: EV_HeadlRegulBasic.rod
Address 56: Radio
   VCID: 49999CCDE006CA024A-801C
   Revision: --H06---    Serial number: 525 PA8J33G11N
   Coding: 1080004
   VCID: 264337719158C57A87-8072
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 3169D42D609692C262-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End-------------------------(Elapsed Time: 05:05)--------------------------
Airplanedoc
C?ID=168996
The dealer finally found the Radio module was not transmitting through the optical system. They bypassed it with a jumper and the MMI system came back to life. I believe I will invest in a set of optical jumpers in the event of future communication system failures. I will post more when I actually get my car back. BTW, they put me in a 2019 A6 while they have my car (No charge). :thumbs:
It should have taken them no more than 15 minutes to figure that out!
Nice. But in may ways, I like the older one better. 8-speed trans vs. 7; super-charged vs. turbo, and conventional controls vs. the new one's touch-screen nonsense. The new one also has the added complexity of 48V mild-hybrid electrical system (and attendant cooling system), along with an obnoxious start/stop system, all to gain 2 MPG in the city, and nothing on the highway?
Airplanedoc
C?ID=168996
Agreed, The auto-engine stop is a pain. Additionally, I believe my 2013 handles better. I prefer performance over all the glass gadgets installed. :cool:
