Morning,
Think i posted this into the wrong forum earlier!
Having some trouble with an A4 which has had a new steering rack fitted, offside front level sensor has also been replaced.
Have these faults attached which won't clear.
Has anyone come across this before or have any suggestions on what to look at?
Thanks in advance for any help!
Friday,24,May,2019,09:21:00:19998
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8K68A012616 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 07 08 09 0E 10 14 15 16 17 19 1B 37 42 46 47 52 53
55 56 62 6C 72 77
VIN: WAUZZZ8K68A012616 Mileage: 157510km-97872miles
1B-Active Steering -- Status: Malfunction 0010
Address 01: Engine (J623-CAPA) Labels:| 059-907-401-V1.clb
Part No SW: 8K0 907 401 F HW: 8K0 907 401
Component: 3.0TDI EDC17 H01 0002
Revision: --H01---
Coding: 0104002C180F0118
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM30LTDIA5 A02002
ROD: EV_ECM30LTDIA5_A02.rod
VCID: 2E554B1971595B3A7F-807A
4698 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
Fault Frequency: 9
Mileage: 157514 km
Date: 2007.08.01
Time: 00:41:28
Coolant temperature: 89 °C
Intake air temperature: 37 °C
Voltage terminal 30: 12.080 V
Engine speed: 0.0 /min
Vehicle speed: 0.00 km/h
CCS target speed: 0.00 km/h
CCS status-Bits 0-7: 00001000
Cr Ctl st Shut Offirev-Bits 0-7: 00000000
Cr Ctl st Shut Offrev-Bits 0-7: 00000001
Cr Ctl st Shut Offrev-Bits 0-7: 00000110
Cr Ctl st Shut Offrev-Bits 0-7: 00000000
Cr C st Key 0-Bits 0-7: 00000000
4699 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
Fault Frequency: 9
Mileage: 157514 km
Date: 2007.08.01
Time: 00:41:28
Part No SW: 8K0 907 379 S HW: 8K0 907 379 S
Component: ESP8 quattro H04 0210
Coding: 1B6500
VCID: 499F1885E0F71C024A-801C
03110 - Active Steering Control Module (J792)
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 54
Mileage: 157514 km
Date: 2007.08.01
Time: 00:41:38
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x000D
Hex Value: 0x3399
Hex Value: 0x00FF
Part No SW: 8K0 907 064 C HW: 8K0 907 064 C
Component: BCM2 1.1 H70 0141
Coding: 031100
VCID: 30695561636D4DCA6D-8064
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H35 0052
Serial number: 0108000005066006
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Serial number: 0207000003271004
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 P HW: 4E0 035 729 A
Component: Interfacebox H43 5170
Revision: 00000000 Serial number: 331LT077520098
Shop #: WSC 06342 000 00000
VCID: 468513B931E9F37AA7-8012
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000035446
Subsystem 3 - Serial number: 0120.12.070000000100010111ÿ
Subsystem 4 - Serial number: 010111ÿ
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 N HW: 8T2 820 043 N
Component: KLIMA 3 ZONEN H05 0120
Revision: D1000000 Serial number: 0119.12.070147
Coding: 36040000
VCID: 3D777C55A43FB0A2F6-8068
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000070441
Coding: 260050914014AF311E01000300001D0D0F9D834800010141000000
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 070108 H05 0060
Serial number: SWFBIE 0000237
Coding: 00FD11
Component: RLS H04 0002
Serial number: 10034420
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000001412070498
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H42 0390
Revision: 00042001 Serial number: AUZ5ZBH4571158
VCID: 2B53420D8A4B2E1258-807E
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 C HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0010
Revision: 11001001 Serial number: 75230736312410
Coding: 300003
VCID: 397F6845B0178C82DA-806C
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0052
Revision: 00000000 Serial number: 11120701520001
Coding: 050181
Shop #: WSC 00694 210 91850
VCID: 70E99561A3ED0DCA2D-8024
03264 - Functionalty Shut Off
Reset counter: 94
Mileage: 157514 km
Date: 2007.08.01
Time: 00:46:02
Error Code: 9
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD12G55T
Coding: 30363434363030303030554A3052384B3053
VCID: 3C717151B725B9AAC1-8068
Serial number: 6334MSME2C21181AA
Serial number: 6344MSME2C21197EM
Serial number: 6352QSME440F4313B
Serial number: 6362QSME4A182E41M
Serial number: 63732SME3F061F7DG
Serial number: 63832SME49704311T
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90315GL5000AW
Coding: 000016
VCID: 3E757B59A939ABBAEF-806A
Component: E221 - MFL H02 0003
Part No SW: 8K0 920 980 B HW: 8K0 920 980 B
Component: KOMBIINSTR. H14 0214
Revision: 00000000 Serial number: 7BY37U4D7
Coding: 2F0409003A002600010000
VCID: 316F5065686744C262-8064
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E07C15803C
Coding: 000003
Shop #: WSC 00694 210 51188
VCID: 448109B1C7D5C16AB9-8010
Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0150
Serial number: 1700255E171207
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 A HW: 8K0 907 144 A
Component: DYNAMIKLENK. H05 0322
Revision: 50000003 Serial number: --------------
Coding: 0C0000
VCID: 2D574C15745F202246-8078
000 - - - MIL ON
Fault Status: 11100000
Count: 56
Count: 1
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 333AQ087533468
Shop #: WSC 00694 210 80997
VCID: 3B73724D7A2BBE92C8-806E
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000006764256
Coding: 011C02204001410001
VCID: 3F8B065DAE33A2B2E4-806A
Revision: 00002001 Serial number: 0108449715
Coding: 011B062200390440002001
Component: DWA-Sensor H02 0030
Component: LIN BACKUP HO H03 1301
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 54
Mileage: 157514 km
Date: 2007.08.01
Time: 00:50:35
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 G HW: 8T0 035 223 G
Component: DSP STD H08 0290
Revision: S2500000
Coding: 010101
VCID: 326D5F696D617FDA1B-8066
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000006755109
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000480585
VCID: 34615971977571EA09-8060
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8T0 907 357 A HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Shop #: WSC 06324 000 00000
VCID: 3C7171517F25B9AAC1-8068
Subsystem 1 - Part No: 8K0 941 329
Component: AFS-Modul links H01 S001
Subsystem 2 - Part No: 8K0 941 329
Component: AFS-Modul rechtsH01 S001
02988 - Left-Hand/Right-Hand Traffic Switchover Active
000 - - - MIL ON
Reset counter: 54
Mileage: 157514 km
Date: 2007.08.01
Time: 16:17:40
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 336AL087531318
VCID: 2E554B19B9595B3A7F-807A
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000006742866
Coding: 010C02204001210001
VCID: 7F0B465DEEB362B2A4-802A
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 B HW: 4L0 907 441 A
Component: J772__Rearview 0070
Revision: --H12--- Serial number: 525PA8-J7Y900P
Coding: 1023006
VCID: 377B6E7D46039AF22C-8062
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000006748617
VCID: 7EF5BB59E9B96BBAAF-802A
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005074811
Coding: 0010920
VCID: 2A5D470985B1371AA3-807E
End-------------------------(Elapsed Time: 03:39)--------------------------
