Hi folks,
I have a 2012 SEAT Leon on which I have retrofitted Xenon headlights.
I know I need a 087 CECM to operate the Xenon shutters for high beam which my 086 CECM doesn't support. But it seems there are lots of different versions of the CECM with different part numbers, so I'm looking for some advice on how to find the correct part number i need to be compatible with my car.
Here is the autoscan from VCDS
I'm not concerned about the various fault codes yet, I've had the CECM unplugged so I'm reckoning that's where most of those fault codes are coming from.
I appreciate any advice that can be offered.
Wednesday,10,December,2014,19:55:58:49204
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: VSSZZZ1PZCR044720 License Plate:
Mileage: 48100km-29887mi Repair Order:
Chassis Type: 1P (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZCR044720 Mileage: 48100km-29887miles
09-Cent. Elect. -- Status: Malfunction 1010
46-Central Conv. -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CFHC) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 FJ HW: 03L 906 018 FJ
Component: R4 2,0L EDC H24 7898
Revision: 42H24--- Serial number:
Coding: 00190012042500080000
ASAM Dataset: EV_ECM20TDI01103L906018FJ 003004
ROD: EV_ECM20TDI01103L906018DP.rod
VCID: 77F7DD59CE0D70995E1-8022
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 133B4012092600FEC81202E690190082350800
Shop #: WSC 04941 000 00000
VCID: 7BFFC169FA2554F93A9-802E
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5P0 907 044 S HW: 5P0 907 044 S
Component: Climatronic H18 0804
Revision: 00001001
Coding: 0000000002
Shop #: WSC 06402 785 00200
ROD: EV_ClimaAutoBasis_SE35.rod
VCID: 40857685DB43F7212FB-8015
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 M HW: 5K0 937 086 M
Component: BCM PQ35 M 021 0064
Revision: BC021001
Coding: 46180A3EC825B0C042C80084950089CC44F90008627D8560488428000040
VCID: 3E79087DA9B781D15D7-806B
Subsystem 1 - Part No: 1P0 955 119 D
Component: Wischer 02121 26 0611
Coding: 00DB90
Subsystem 2 - Part No SW: 1P0 955 559 A HW: 1P0 955 559 A Labels: 1P0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 02542E
Subsystem 3 - Part No: 1P0 951 171
Component: Innenraumuebe 010 4971
7 Faults Found:
00927 - Terminal 30 (Right)
Fault Status: 00101011
Reset counter: 137
Term 15 Off
Voltage: 12.00 V
Reset counter: 137
Term 15 Off
Voltage: 12.00 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 94
Mileage: 47887 km
Date: 2014.12.02
Time: 05:59:46
Voltage: 14.30 V
Reset counter: 94
Mileage: 47887 km
Date: 2014.12.02
Time: 05:59:46
Voltage: 14.10 V
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:29
Term 15 Off
Voltage: 12.00 V
Fault Status: 00101010
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.04
Time: 12:50:07
Term 15 Off
Voltage: 11.90 V
Reset counter: 138
Mileage: 47973 km
Date: 2014.12.06
Time: 14:13:03
Term 15 Off
Voltage: 12.30 V
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5P0 919 475 B HW: 8P0 919 475 M
Component: PARKHILFE 4K H08 0008
Revision: -------- Serial number: 36861133004507
Coding: 100004
VCID: 3A71046DB59FADF161F-806F
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__A0E VW10 HI 1918
Revision: 23016000 Serial number: 003K0PQDQPT
Coding: 0012357
VCID: 4C9D52B52F0B2341C33-8019
Subsystem 1 - Serial number: 6332MTS622972991
Subsystem 2 - Serial number: 6342MTS622863401
Subsystem 3 - Serial number: 6351HTS6PJHIT9KR
Subsystem 4 - Serial number: 6361HTS6QCGK0AKR
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 521 BN HW: 5K0 953 569 E
Revision: FF010040 Serial number: 20120102301801
Coding: 108A140002
ROD: EV_SMLSNGVOLWS.rod
VCID: 79F3DB61F81966E9285-802C
Subsystem 1 - Part No SW: 1P0 959 538 D HW: 1P0 959 538 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0102
Coding: E20000
Part No SW: 1P0 920 953 D HW: 1P0 920 953 D
Component: KOMBI H05 0607
Coding: 110B01
Shop #: WSC 13107 102 20971
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 3163234160E96EA9D05-8064
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:30
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:32
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 061211F2000697
Coding: 350203
Fault Status: 00110100
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:32
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:32
Component: IMMO H05 0607
VCID: 6AD1F42D8DBFDD71D1F-803F
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661516730
VCID: 2953CB2140391669185-807C
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H08 5218
Revision: AB001001 Serial number: VWZ6Z7M9706178
Coding: 00000400040000A00300
VCID: 3B7F0169BAA594F97A9-806E
Subsystem 1 - Part No: 7N5 919 859
Component: EU West V9 7918
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0508
Revision: 12110009 Serial number: 0003506134
Coding: 0012B0
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 6DDBFF31BC51CA49B4D-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 E HW: 3C0 959 794 E
Component: J389__TSG-HR 007 1501
Serial number: 00000006239847
Coding: 000290
68098 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:31
68100 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:31
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 142 3305
Revision: 00H22000
Shop #: WSC 01806 210 90324
VCID: 37771D59468DB0999E1-8062
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0508
Revision: 14110009 Serial number: 0003502586
Coding: 0012B0
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 6ED9F83DB15731518D7-803B
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 E HW: 3C0 959 795 E
Component: J388__TSG-HL 007 1501
Serial number: 00000006241444
Coding: 000290
U1111 00 [008] - -
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:31
U1111 00 [008] - -
Reset counter: 137
Mileage: 47933 km
Date: 2014.12.05
Time: 08:41:31
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007661462358
Coding: 0200000000010110
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA.rod
VCID: 356B1751948142898CD-8060
End-------------------------(Elapsed Time: 03:08)--------------------------
