- Joined
- Mar 20, 2019
- Messages
- 58
- Reaction score
- 16
- Location
- South Africa
- VCDS Serial number
- C?ID=357723
hi all. my friend have a audi that starts fine when it is cold. once the vehicle has been driven for some time and it gets switched off. it refuses to restart until its cold again. when it drives it does not cut out or anything. any suggestions what the problem could be. the following fault codes goes away after delete. but once engine is switched off and on again faults codes re appear again. please advise. many thanks.
Wednesday,22,May,2019,15:42:28:62451
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8E57A164718 License Plate:
67 69 75 76 77
VIN: WAUZZZ8E57A164718 Mileage: 199060km-123690miles
Address 01: Engine Labels: 03G-906-018-BRD.clb
Part No SW: 03G 906 018 AQ HW: 03G 906 018 AQ
Component: R4 2.0l PPD1.3 G 9971
Revision: --H43--- Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Shop #: WSC 00999 444 64523
VCID: 74B028A302B410978A5-8020
001025 - EGR System
P0401 - 006 - Insufficient Flow - Intermittent - MIL ON
Fault Status: 10100001
Reset counter: 40
RPM: 2112 /min
Torque: 88.0 Nm
Speed: 58.0 km/h
84.63 %
4.68 %
Mass Air / Rev.: 381.5 mg/str
Mass Air / Rev.: 599.5 mg/str
008194 - Particulate Trap Bank 1
P2002 - 006 - Efficiency Below Threshold - Intermittent - MIL ON
Reset counter: 40
RPM: 2432 /min
Torque: 240.0 Nm
Speed: 30.0 km/h
Pressure: 0.0 mbar
Text: 0 mbar
Text: 224 C
Temperature: 18.0°C
001648 - Glow Plug Module 1; Glow Plug Circuit
P0670 - 006 - Electrical Malfunction - Intermittent - MIL ON
Fault Frequency: 173
Reset counter: 40
Torque: 0.0 Nm
0.00 %
Voltage: 12.77 V
Bin. Bits: 10110000
Temperature: 24.0°C
001668 - Glow Plug Control Module (J179)
P0684 - 007 - Implausible Signal - Intermittent
Fault Frequency: 15
Reset counter: 38
Torque: 0.0 Nm
0.00 %
Voltage: 11.87 V
Bin. Bits: 00110000
Temperature: 13.0°C
005441 - Fuel Pump Relay (J17)
P1541 - 009 - Open Circuit - Intermittent
Fault Status: 00000100
Reset counter: 38
Torque: 0.0 Nm
0.00 %
Voltage: 9.49 V
Bin. Bits: 00000001
Temperature: 17.0°C
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Coding: 0004405
Shop #: WSC 06325 000 00000
VCID: 2C00F0C39A040857125-8078
Part No: 8E0 820 043 BQ
Component: A4 Klimaautomat 3233
Coding: 00000
VCID: 71BE21B778B625BF613-513C
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 01001
Shop #: WSC 06325
VCID: 3D26CD87746E91DFB5B-4B00
30-00 - Open or Short to Plus
02071 - Local Databus
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H13 4230
Revision: 91H13423 Serial number: 0036M0G57V04
Coding: 0031612
VCID: 3B22C39F6F6A9FEF8BF-806E
Subsystem 1 - Serial number: 6332DRB4046A0831F
Subsystem 2 - Serial number: 6342DRB4047CCA9FA
Subsystem 3 - Serial number: 6352ARB401DF95F1+
Subsystem 4 - Serial number: 6362ARB401DF11E6Y
Subsystem 5 - Serial number: 63729RB401E60ACD$
Subsystem 6 - Serial number: 63829RB401E60A97V
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 02041
Shop #: WSC 06325
VCID: 41DEB1770896F53FD13-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 901 H HW: 8E0 920 901 H
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0006118
Shop #: WSC 80093 222 69422
VCID: 2A0CF6DB90E01667E09-5184
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006118
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0804
Coding: 00001
VCID: 6B8233DF5A9ACF6F5BF-50D0
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 07918
Shop #: WSC 03163
VCID: 79AE199720C66DFFD93-4B00
Subsystem 1 - Part No: 8E2959802F
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E2959801F
Component: Tõrsteuer.BF BRM 0606
Component: Tõrsteuer.HL BRM 0606
Component: Tõrsteuer.HR BRM 0606
35-00 - -
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8E0 035 186 AK HW: 8E0 035 186 AK
Component: R Concert2+ H02 0220
Revision: 00H02000 Serial number: AUZ1Z3F0294957
Coding: 0210311
VCID: 70B824B3768C2CB76ED-5160
00856 - Radio Antenna
Fault Status: 00101011
Reset counter: 4
Time Indication: 15
End----(Elapsed Time: 05:38, VBatt start/end: 12.1V/12.0V. VIgn 11.9V)-----
