Results 1 to 3 of 3
Thread: VW Golf MK5 Drivers Door Issue after Retrofitting Lights
    Feb 2019
    Good Afternoon,
    A friend has his MK5 Golf ahd decided he wanted to retrofit the under door lights. He had purchased the lights and used another coding device (OBD11) to code it. When he did this everything went opposite (drivers window switch would operate passenger window, drivers wing mirror switch would operate passenger wing mirror etc etc). he then tried to revert the changes back and then both doors stopped working switches windows etc nothing would work.
    He called me and i reverted everything back to original values (i think) and managed to get the passenger side working but nothing on the drivers side works (window switch, mirror switch, fuel tank switch, under door light).
    Here are 2 scans i did:
    Sunday,26,May,2019,13:49:29:08713
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4437.4
    VIN: WVWZZZ1KZ7W013084   License Plate: Y10OMR
    Mileage: 206510km-128319mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 76
    VIN: WVWZZZ1KZ7W013084   Mileage: 206510km-128319miles
       Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
       Revision: --H14---    Serial number: VWZ7Z0F8002822
       Coding: 0403000318070160
       Shop #: WSC 14384 344 603265
       VCID: 2D12F793B433372246-8078
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 01279 785 00200
       VCID: 73A621EB129721D2D0-8026
       Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
       Component: ClimatronicPQ35 090 0909
       Revision: 00090016    Serial number: 00000000000000
       VCID: 70AC2EE763811ACA2D-8024
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Revision: 00H37000    Serial number: 00000005783850
       Coding: E58F8F2700041500001400001400000000087F075C
       Shop #: WSC 01392 785 00200
       VCID: 2B16F98B8A27391258-807E
       Component: Wischer 170506 020  0501
       Coding: 00038805
       Shop #: WSC 01392
       Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
       Component: RLS     160506 014  1201
       Coding: 00208933
       Shop #: WSC 01392
    00924 - Relay for Headlamp Cleaning System (J39)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 109
                        Mileage: 206486 km
                        Voltage: 12.60 V
    01800 - Light Switch (E1)
                        Reset counter: 149
                        Mileage: 206518 km
                        Voltage: 13.00 V
       Component: 38 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD0HZMMG
       Coding: 0013112
       Shop #: WSC 01269 785 00200
       VCID: 3D32C7D36453A7A2F6-8068
       Subsystem 1 - Serial number: 6332MSME0E151D61C
       Subsystem 2 - Serial number: 6342MSME0B5B641DN
       Subsystem 3 - Serial number: 6352QSME0B41315FH
       Subsystem 4 - Serial number: 6362QSME0E642349K
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 634 0070
       Coding: 0000042
       Shop #: WSC 00071 210 88195
       VCID: 76A018FF01E534FAF7-8022
       Part No SW: 1K6 920 963     HW: 1K6 920 963
       Revision: V0003000    Serial number: VWZ7Z0F8002822
       Coding: 0007403
       Shop #: WSC 55799 001 1048576
       VCID: 6FAE2D9B7EBF053234-803A
       Revision:   H12       Serial number: 31001065171354
       Coding: 3D0F074007000001
       Shop #: WSC 11111 111 45725
       VCID: 2C14FA978F293E2A51-8078
                        Reset counter: 108
                        Mileage: 206500 km
                        Time: 01:40:32
                000 -  -  - Intermittent
                        Reset counter: 148
                        Mileage: 206500 km
                        Time: 01:41:04
       Component: IMMO            VDD 1610
       Part No SW: 1K0 959 701 N    HW: 1K0 959 701 N
       Component: Tuer-SG         004 0954
       Coding: 0000564
       Shop #: WSC 11111 111 45799
       VCID: 393AD3C3707B9B82DA-806C
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.074 H07 1806
       Shop #: WSC 00000 028 00001
       VCID: 3522DFF35C637FE23E-8060
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 AJ
       Coding: 19C8024E7600840D48DAC69010CC
       VCID: 78BC16C70BF1428AE5-802C
       Subsystem 2 - Part No: 1K0 951 178
       Component: Neigungssensor  001 0101
       Subsystem 3 - Part No: 1K0 951 178
       Component: Innenraumueberw.001 0101
       Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
       Coding: 0000564
       VCID: 3A38CCCF757D909AD3-806E
       Part No: 1K0 035 186 R
       Component: Radio BVX       020 0032
       Coding: 0040402
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 22 Einparkhilfe     0101
    End----------(Elapsed Time: 01:05, VBatt start/end: 12.5V/12.5V)-----------
    Sunday,26,May,2019,15:54:12:08713
       Revision: 00H11001
       Coding: 0004738
       Coding: 00038805
       Shop #: WSC 01392
       Coding: 00208933
       Shop #: WSC 01392
       Coding: 0013112
       Coding: 0000042
       Coding: 0007403
       Coding: 0000884
    00120 - Outside Warning Light/Door exit Light Driver Side
       Coding: 01C802087F2D840548DAC69010CC
       Coding: 0000884
       Coding: 0040402
    End----------(Elapsed Time: 01:04, VBatt start/end: 13.9V/13.9V)-----------
    Any help is much appreciated.
    Thanks
    VCDS Distributor NEtech's Avatar
    Try this coding for Address [42]
    0000628
    It also looks like there is problem with the Door exit light there.
  3. Likes Uwe liked this post
    Feb 2019
    I have tried that code and still nothing.
    Thanks
