Results 1 to 10 of 15
Thread: Audi A3 8P TDI: 005 - No or Incorrect Basic Setting / Adaptation
    Nov 2018
    Can't seem to clear this fault code. I looked through the wiki and looked at channels 42, 43, 44, 45 and 49. I updated the some channels to 160 for USA but the rest looked OK according to the pop-up help on VCDS. I then ran a SRI, turn the key off and on. The code is still there. I try to clear it, but then the same code pops up with the newer time stamp.
    Since I am in the USA and it's a diesel, I have no idea what the proper values should be.
    Any help would be greatly appreciated.
    Thanks.
    Alex
    Wednesday,22,May,2019,10:50:10:37015
    VCDS Version: 18.9.1.0 (x64)
    VCDS Release 18.9.1:  SRI Reset
    Control Module Part Number: 8P0 920 983 L       Labels:  8P0-920-xxx-17-MY8.clb
    Component:KOMBIINSTR. VDO H03 0360, Coding:0272288
    Channel  	Description                                       	Unit      	Current val.  	New val.
    02       	Service Reminder Status                           	          	0             	---
    40       	Distance since Service                            	km x100   	0             	---
    41       	Time since Service                                	Days      	0             	---
    42       	Minimum Distance to Service                       	km x100   	160           	---
    43       	Maximum Distance to Service                       	km x100   	160           	---
    44       	Maximum Time to Service                           	Days      	365           	---
    45       	Oil Quality                                       	          	1             	---
    47       	Soot Quantity                                     	km x100   	0             	---
    48       	Thermal Load                                      	km x100   	0             	---
    49       	Minimum Time to Service                           	Days      	365           	---
    50       	Basic Distance Value for Oil Change               	km x100   	160           	---
    51       	Basic Time Value for Oil Change                   	Days      	365           	---
    52       	Basic Distance Value for Inspection               	km x100   	160           	---
    53       	Distance since Inspection                         	km x100   	0             	---
    54       	Basic Time Value for Inspection                   	Days      	365           	---
    55       	Time since Inspection                             	Days      	0             	---
    56       	Day Counter                                       	Days      	1970          	---
    Wednesday,22,May,2019,10:16:32:37015
    VIN: .License Plate:
    Mileage: 55650km-34579mi   Repair Order:
    Chassis Type: FM-AU35 (7N0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
              72 77
    VIN: Mileage: 55650km-34579miles
    Address 01: Engine (CBE)       Labels: None
       Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H15---    Serial number: AUX7Z0L6FNP05N
       Coding: 0050078
       Shop #: WSC 46531 003 1048576
       VCID: 2C5CF9E78F9BA02A51-8078
       Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 9430
       Revision: 05551213    Serial number: 00001207062401
       Shop #: WSC 06314 000 00000
       VCID: 142C410737EB18EA69-8040
       Revision: 00H31001
       Coding: 1150400F49240001881202E9921F0042BF0C00
       VCID: 7DFA04A3E461F9A2B6-8028
       Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
       Component: KlimavollautomatH09 0180
       Revision: 000112      Serial number: 8P0820043BN
       VCID: 79F210B33049C5829A-802C
    Address 09: Cent. Elect.
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7M0619511
       Coding: 0000100
       VCID: 3668DB8F41D7EAFA37-8062
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
       Component: Airbag AU1042 H10 0250
       Revision: --------    Serial number: 003FC001UFZP
       Coding: 303142393041303030374A55304C38503053
       ROD: EV_Airba10AURB4.rod
       VCID: 50A48D170B73A4CA0D-8004
       Subsystem 1 - Part No SW: 8P0 959 339 E    HW: 8P0 959 339 E
       Component: BF-Gewichtss.  H04 0040
       Serial number: 5850000R12628018GL
       Serial number: 3572DRB40000EC1861B$
       Serial number: 3582DRB40000EB4D11E2
       Serial number: 35128RB400006C8FAFDB
       Serial number: 35228RB400006C90DE2W
       Serial number: 35547RB400006C9654BX
       Serial number: 35647RB400006C9410DQ
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Component: J0527           H38 0070
       Coding: 0014142
       VCID: 4688AB4F31377A7AA7-8012
       Component: E0221           H02 0100
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 983 L    HW: 8P0 920 983 L
       Component: KOMBIINSTR. VDO H03 0360
       Revision: D0H03004    Serial number: 2246L004001599
       Coding: 0272288
       Shop #: WSC 04153 002 104857
       VCID: 438EB25B02054F5280-8016
    00003 - Control Module
                        Fault Status: 01100101
                        Mileage: 55654 km
                        Date: 2019.05.22
                        Time: 10:12:22
       Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
       Component: J533  Gateway H42 1632
       Revision:   H42       Serial number: 250612F2002357
       Coding: 352102
       VCID: 3F86BEABAEED2BB2E4-806A
       Revision: D0H03004    Serial number: AUX7Z0L6FNP05N
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0001213
       VCID: 4992A073202995024A-801C
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 232    3305
       Revision: 00H22000
       VCID: 3776D68B46DD13F22C-8062
    Address 46: Central Conv.
       Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
       Component: AB2 SUBWOOFERBOXH07 0180
       Revision: 00006       Serial number: 92158230715599
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0001213
       VCID: 4A909F7F252F9E1A43-801E
       Component: ****LWR12**** H02 0012
       Serial number: 120718-0002-103
       Coding: 1163951010020000
       ROD: EV_HeadlRegulBasic.rod
       VCID: 4280B75FD51F465A8B-8016
       Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
       Component: R Concert2+     H06 0293
       Revision: 00H06000    Serial number: AUZ1Z3M3148073
       Coding: 0750112
       VCID: 73EE229B1225BFD2D0-8026
    Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0001176
       Shop #: WSC 06314 000 1012544
       VCID: 4280B75F1D1F465A8B-8016
    Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0001176
       Part No SW: 8P1 862 336 A    HW: 8P1 862 336
       Component: FSE_256x BT     H44 0660
       Revision: 00000000    Serial number: 00000005173676
       Coding: 0001277
    End-------------------------(Elapsed Time: 02:27)--------------------------
    So whats the back story here?
    Nov 2018
    It was bought from VW/Audi after they fixed the diesel emissions 2 weeks ago by the dealer and I bought it yesterday.
    So take to dealer isn't it under extended warranty or flat out purchase warranty?
    Doesn't the MIL reside in a non working or non operational or ADP of cluster for related AECD's and require a clear understanding when in fault?
    Nov 2018
    The VW/Audi extended warranty only covers engine/emissions components. Plus, there is a $50 deductible. I suspect the instrument panel is not part of the engine/emissions component and it's long past the bumper-to-bumper warranty.
    Engine light was not on. I'm not sure what you mean by the rest of the sentence.
    Again doesn't or isn't the MIL residing in the instrument cluster & effectively an AECD itself?
  7. #7
    Nov 2018
    There is no MIL. Code only comes up during Autoscan.
  8. #8
    Way to get in the " Holly P " spirit of the Canon EPA & CARB regulations, I guess ignore it huh?
  9. #9
    Quote Originally Posted by findalex View Post
    Your values look OK to me.
    Try "Change to fixed Intervals (Rest of World)" from the "Operation" pull-down and see if that helps. You must click [Perform SRI] after you do that for the changes to actually be written. You can flip it back to "Change to fixed Intervals (USA)" if it doesn't help.
  10. #10
    Consideration should be made before messing with SRI that is for another Emissions tier, no?
    Since those adaptions are related to an AECD or monitoring to comport with recommended maintenance are they not under useful life warranty if in deficiency or DTC for adaptation?
