Audi A3 8P TDI: 005 - No or Incorrect Basic Setting / Adaptation
findalex
C?ID=95887
Can't seem to clear this fault code. I looked through the wiki and looked at channels 42, 43, 44, 45 and 49. I updated the some channels to 160 for USA but the rest looked OK according to the pop-up help on VCDS. I then ran a SRI, turn the key off and on. The code is still there. I try to clear it, but then the same code pops up with the newer time stamp.
Since I am in the USA and it's a diesel, I have no idea what the proper values should be.
Any help would be greatly appreciated.
Thanks.
Alex
Wednesday,22,May,2019,10:50:10:37015
VCDS Version: 18.9.1.0 (x64)
VCDS Release 18.9.1:  SRI Reset
Control Module Part Number: 8P0 920 983 L       Labels:  8P0-920-xxx-17-MY8.clb
Component:KOMBIINSTR. VDO H03 0360, Coding:0272288
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	0             	---
40       	Distance since Service                            	km x100   	0             	---
41       	Time since Service                                	Days      	0             	---
42       	Minimum Distance to Service                       	km x100   	160           	---
43       	Maximum Distance to Service                       	km x100   	160           	---
44       	Maximum Time to Service                           	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	km x100   	0             	---
48       	Thermal Load                                      	km x100   	0             	---
49       	Minimum Time to Service                           	Days      	365           	---
50       	Basic Distance Value for Oil Change               	km x100   	160           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	160           	---
53       	Distance since Inspection                         	km x100   	0             	---
54       	Basic Time Value for Inspection                   	Days      	365           	---
55       	Time since Inspection                             	Days      	0             	---
56       	Day Counter                                       	Days      	1970          	---
Wednesday,22,May,2019,10:16:32:37015
VIN: .License Plate:
Mileage: 55650km-34579mi   Repair Order:
Chassis Type: FM-AU35 (7N0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 47 4C 52 55 56 62
          72 77
VIN: Mileage: 55650km-34579miles
Address 01: Engine (CBE)       Labels: None
   Part No SW: 03L 997 030 A    HW: 03L 906 019 EJ
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H15---    Serial number: AUX7Z0L6FNP05N
   Coding: 0050078
   Shop #: WSC 46531 003 1048576
   VCID: 2C5CF9E78F9BA02A51-8078
   Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9430
   Revision: 05551213    Serial number: 00001207062401
   Shop #: WSC 06314 000 00000
   VCID: 142C410737EB18EA69-8040
   Revision: 00H31001
   Coding: 1150400F49240001881202E9921F0042BF0C00
   VCID: 7DFA04A3E461F9A2B6-8028
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0180
   Revision: 000112      Serial number: 8P0820043BN
   VCID: 79F210B33049C5829A-802C
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7M0619511
   Coding: 0000100
   VCID: 3668DB8F41D7EAFA37-8062
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H10 0250
   Revision: --------    Serial number: 003FC001UFZP
   Coding: 303142393041303030374A55304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 50A48D170B73A4CA0D-8004
   Subsystem 1 - Part No SW: 8P0 959 339 E    HW: 8P0 959 339 E
   Component: BF-Gewichtss.  H04 0040
   Serial number: 5850000R12628018GL
   Serial number: 3572DRB40000EC1861B$
   Serial number: 3582DRB40000EB4D11E2
   Serial number: 35128RB400006C8FAFDB
   Serial number: 35228RB400006C90DE2W
   Serial number: 35547RB400006C9654BX
   Serial number: 35647RB400006C9410DQ
   Component: J0527           H38 0070
   Coding: 0014142
   VCID: 4688AB4F31377A7AA7-8012
   Component: E0221           H02 0100
   Part No SW: 8P0 920 983 L    HW: 8P0 920 983 L
   Component: KOMBIINSTR. VDO H03 0360
   Revision: D0H03004    Serial number: 2246L004001599
   Coding: 0272288
   Shop #: WSC 04153 002 104857
   VCID: 438EB25B02054F5280-8016
00003 - Control Module
                    Fault Status: 01100101
                    Mileage: 55654 km
                    Date: 2019.05.22
                    Time: 10:12:22
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 250612F2002357
   Coding: 352102
   VCID: 3F86BEABAEED2BB2E4-806A
   Revision: D0H03004    Serial number: AUX7Z0L6FNP05N
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0001213
   VCID: 4992A073202995024A-801C
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 232    3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3776D68B46DD13F22C-8062
Address 46: Central Conv.
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158230715599
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0001213
   VCID: 4A909F7F252F9E1A43-801E
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Component: ****LWR12**** H02 0012
   Serial number: 120718-0002-103
   Coding: 1163951010020000
   ROD: EV_HeadlRegulBasic.rod
   VCID: 4280B75FD51F465A8B-8016
Address 56: Radio        Labels: 8J0-035-1xx-56.clb
   Part No SW: 8P0 035 186 AC    HW: 8P0 035 186 AC
   Component: R Concert2+     H06 0293
   Revision: 00H06000    Serial number: AUZ1Z3M3148073
   Coding: 0750112
   VCID: 73EE229B1225BFD2D0-8026
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
   VCID: 4280B75F1D1F465A8B-8016
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001176
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005173676
   Coding: 0001277
End-------------------------(Elapsed Time: 02:27)--------------------------
findalex
C?ID=95887
It was bought from VW/Audi after they fixed the diesel emissions 2 weeks ago by the dealer and I bought it yesterday.
So take to dealer isn't it under extended warranty or flat out purchase warranty?
Doesn't the MIL reside in a non working or non operational or ADP of cluster for related AECD's and require a clear understanding when in fault?
findalex
C?ID=95887
The VW/Audi extended warranty only covers engine/emissions components. Plus, there is a $50 deductible. I suspect the instrument panel is not part of the engine/emissions component and it's long past the bumper-to-bumper warranty.
Engine light was not on. I'm not sure what you mean by the rest of the sentence.
Again doesn't or isn't the MIL residing in the instrument cluster & effectively an AECD itself?
findalex
C?ID=95887
There is no MIL. Code only comes up during Autoscan.
Way to get in the " Holly P " spirit of the Canon EPA & CARB regulations, I guess ignore it huh?
Your values look OK to me.
Try "Change to fixed Intervals (Rest of World)" from the "Operation" pull-down and see if that helps. You must click [Perform SRI] after you do that for the changes to actually be written. You can flip it back to "Change to fixed Intervals (USA)" if it doesn't help.
Consideration should be made before messing with SRI that is for another Emissions tier, no?
Since those adaptions are related to an AECD or monitoring to comport with recommended maintenance are they not under useful life warranty if in deficiency or DTC for adaptation?
No, because it's nothing but a dang reminder, and that fault code indicates the cluster believes some channels are "out of sorts".
Is there anything in the EPA or DOT regulations that require reminders at all?
If the cluster is in error and the MIL resides in it than isn't that under useful life warranty?
Yes and isn't that discretion left to the self regulating manufacturer, further using good engineering judgement when writing or dissemination of a required RTFB or service book to perform required maintenance or reminders to maintain a warranty and the required useful life of an AECD and is what is typically used by an OEM if not performed as a basis to void such a warranty?
The cluster does not have a fault that is in any way emissions-related, nor would the fault prevent emissions-related faults or warnings from showing up, nor would it even prevent service reminders from being displayed, nor would this fault be visible to any generic OBD-II scan tool. So no, I don't think it's under the usefult life warranty.
Yeah but how is it any different than when the immobilizer resides in a cluster & If its part of it and the MIL resides there and it required an adaptation or any related function for that component, it is required to be under useful life warranty or disseminated functions, right?
Those adaptions are directly related to care or recommendations in the RTFB or service book no?
VW tried that same angle in beginning with immobilizer generations saying it isn't related because if car isn't running it doest produce SMOG & it was shot down resulting in things like NASTF and the IRF program.
