Results 1 to 9 of 9
Thread: Audi A3, 2004, databus (and power?) problem
Threaded View
    Jan 2015
    Norway
    Hi there,
    the symptoms: I was driving, and noticed that the light in the instrument cluster went black. Then it came back, went black again, and then all the dials went to 0. Came back, gone again. This happened a few times, then everything was back to normal.
    The scan is first before I deleted the codes, and the last part is after I cleared codes (its the same file). It seems like the CAN gateway has 00470 still. Any ideas ?
    Wednesday,22,May,2019,18:42:55:41099
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4502.4
    VIN: WAUZZZ8P54A165042   License Plate: BR51499
    Mileage: 200790km-124765mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 47 52 55 56 76 7D
    VIN: WAUZZZ8P54A165042   Mileage: 200790km-124765miles
    08-Auto HVAC -- Status: Malfunction 1010
    09-Cent. Elect. -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Malfunction 1010
    76-Park Assist -- Status: Malfunction 1010
    7D-Aux. Heat -- Status: Malfunction 1010
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 G    HW: 028 101 136 4
       Component: R4 2,0L EDC G000SG  9884
       Revision: 12345678    Serial number: AUX7Z0D3FN70K1
       Coding: 0000072
       Shop #: WSC 74565 000 00000
       VCID: A71EB103164D1F723C-80F2
    16785 - EGR System
                P0401 - 000 - Insufficient Flow - Intermittent
                        RPM: 1806 /min
                        Torque: 92.0 Nm
                        Speed: 46.0 km/h
                        Load: 25.1 %
                        Duty Cycle: 14.7 %
                        Bin. Bits: 00101000
                        Mass Air / Rev.: 355.0 mg/str
                        Mass Air / Rev.: 675.0 mg/str
    18107 - Powertrain Data Bus
                P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
                        RPM: 2268 /min
                        Torque: 0.0 Nm
                        Speed: 58.0 km/h
                        Load: 0.0 %
                        Voltage: 14.29 V
                        Bin. Bits: 00101000
                        Bin. Bits: 00000000
                        (no units): 0.0
    18043 - Powertrain Data Bus
                P1635 - 000 - Missing Message from A/C Controller - Intermittent
                        RPM: 2184 /min
                        Torque: 0.0 Nm
                        Speed: 56.0 km/h
                        Load: 0.0 %
                        Voltage: 14.29 V
                        Bin. Bits: 11001000
                        Bin. Bits: 00000000
                        (no units): 0.0
    Readiness: 1 1 0 0 0
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0023174
       Shop #: WSC 06435 000 00000
       VCID: BA387877F5FF929A53-80EE
       Part No SW: 8P0 820 043 E    HW: 8P0 820 043 E
       Component: KlimavollautomatH12 0150
       Revision: 015231      Serial number: 8P0820043E
       VCID: AE10442739B74E3AFF-80FA
                        Reset counter: 214
                        Mileage: 200795 km
                        Date: 2019.05.22
                        Time: 18:05:15
    00483 - Control Module for Auxiliary Air Heater
                        Reset counter: 214
                        Mileage: 200795 km
                        Date: 2019.05.22
                        Time: 18:05:22
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 A    HW: 8P0 907 279 A*
       Component: Bordnetz-SG 1.0 H30 0501
       Revision: 00030000    Serial number: 00000000690970
       Coding: 030ACA0083140400640000322800000000
       Shop #: WSC 12345 123 12345
       VCID: BB367D73FAC5AB9248-80EE
       Subsystem 1 - Part No: 8P1 955 119 C  Labels: 1TX-955-119.CLB
       Component: Wischer WWS Audi350 0180
       Coding: 16711696
       Shop #: WSC 12345
    7 Faults Found:
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
       Component: Airbag 8.4ED    H00 0140
       Coding: 0010602
       VCID: C3C605938235D35200-8096
       Part No SW: 8P0 953 549 G    HW: 8P0 953 549 G
       Component: Lenks‰ulenmodul H36 0070
       Coding: 0000042
       VCID: C2C800979D2FDA5A0B-8096
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
       Part No SW: 8P0 920 930 F    HW: 8P0 920 930 F
       Component: KOMBIINSTR. VDO H25 0140
       Revision: D09         Serial number: 2243DD09053438
       Coding: 0004003
       Shop #: WSC 80093 222 69422
       VCID: B5226B4BDCE17DE2BE-80E0
    Address 18: Aux. Heat        Labels: 1K0-815-005.clb
       Part No: 1K0 815 005 EF
       Component: Heizgeraet      H08 0040
       Revision:        A    Serial number: 09011596
       Coding: 0001011
       Shop #: WSC 38059 136 84162
       VCID: EA988837C5DFE21AE3-80BE
                        Reset counter: 214
                        Mileage: 200795 km
                        Date: 2019.05.22
                        Time: 18:05:16
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:56
       Part No SW: 1K0 907 530 D    HW: 1K0 907 951
       Component: Gateway         H08 0100
       Revision: 08          Serial number: 2500104325011F
       Coding: 7D0F1F42070100
       Shop #: WSC 06435 123 12345
       VCID: A81CB23F1B53100A35-80FC
    8 Faults Found:
                        Fault Status: 01101100
                        Fault Frequency: 11
                        Reset counter: 174
                        Mileage: 200787 km
                        Date: 2019.05.22
                        Time: 16:01:19
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:12
                        Fault Frequency: 10
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:32
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:46
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:46
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:46
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:47
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:55
       Revision: D09         Serial number: AUX7Z0D3FN70K1
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
       Part No: 8P0 959 801 A
       Component: Tuersteuerger.  H10 0010
       Coding: 0000048
       VCID: B93A677BF0F999825A-80EC
       Part No: 1K1 909 144 F
       Component: EPS_ZFLS Kl.10      1301
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 B
       Component:    KSG          H02 0040
       Coding: 188800186D288505484A016000
    00849 - S-contact at Ignition/Starter Switch (D)
       Part No SW: 8P3 035 382     HW: 8P3 035 382
       Component: AB2 SUBWOOFERBOXH25 0160
       Revision: 00003       Serial number: 10000001119925
       VCID: F0AC9A5FE30318CAAD-80A4
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
       Part No: 8P0 959 802 A
       Coding: 0000048
       Part No: 8P0 907 357 A
       Coding: 0000001
       VCID: B83C627FCBF3808AA5-80EC
    Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
       Part No SW: 8P0 035 186     HW: 8P0 035 186
       Component: concert II EU   H53 0060
       Revision:      08S    Serial number: AUZ2Z3D2056623
       Coding: 0001001
       VCID: EFAE9923FE3D0732B4-80BA
    Address 76: Park Assist        Labels: 8P0-919-283.lbl
       Part No SW: 8P0 919 283     HW: 8P0 919 283
       Component: Parkhilfe 4-Kan H06 0020
       Coding: 0000003
       VCID: F8BCA27F8B73408A65-80AC
                        Fault Status: 00101110
                        Fault Frequency: 85
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:07
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:09
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:38
                        Fault Frequency: 11
                        Reset counter: 214
                        Mileage: 200794 km
                        Date: 2019.05.22
                        Time: 18:04:29
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
                        Reset counter: 171
                        Mileage: 200620 km
                        Date: 2019.05.22
                        Time: 10:15:17
       Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
       Revision: 00700000    Serial number:
       VCID: AC144E2F0FAB3C2AD1-80F8
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.5V/12.5V)-----------
       Coding: 0000072
    Readiness: 0 0 1 1 1
       Coding: 0023174
                        Reset counter: 214
                        Mileage: 200795 km
                        Date: 2019.05.22
                        Time: 18:05:15
                        Reset counter: 214
                        Mileage: 200795 km
                        Date: 2019.05.22
                        Time: 18:05:22
       Coding: 16711696
       Shop #: WSC 12345
       Coding: 0010602
       Coding: 0000042
       Coding: 0004003
       Coding: 0001011
                        Reset counter: 174
                        Mileage: 200796 km
                        Date: 2019.05.22
                        Time: 18:46:51
       Coding: 0000048
       Coding: 0000048
       Coding: 0000001
       Coding: 0001001
       Coding: 0000003
    End----------(Elapsed Time: 01:22, VBatt start/end: 14.0V/14.2V)-----------
