Results 1 to 2 of 2
Thread: audi AVK 3.0 V6 rpm
    May 2018
    audi AVK 3.0 V6 rpm
    This might not be a VCDS question but can I use it to get the RPM pulses per revolution
    Measuring RPM as interpreted by the ECU yes as the actual pulses with VCDS no & that would be done with meter or scope and at G28 sensor G40 x2 or an estimated rotation at alternator gives a pulse for RPM if seeking to rob for some purpose.
    Sometimes the tacho itself shares the 60-2 teeth wheel too for G28 and WD would determine that quick if you RTFB.
  3. Likes Uwe liked this post
