Results 1 to 6 of 6
Thread: Trailer hitch retrofit, A8 4H
    Mar 2019
    I´m retrofitting electrically swiveling original trailer hitch to my 2010 A8 4.2tdi. I´m using cable loom from Kufatec.
    I managed to get the coding solved. Kufatec has nice instructions, but is lacking coding info for engine and ABS/ESP. SVM is of course the proper way to code, but I manage to get access to almost otherwise similar A8 with factory hitch installed. You can find the autoscans of both A8´s showing needed coding in engine and abs. I´ll post a comprehensive list of all coding needed to here once I can verify it with my car.
    The issues I´m struggling is with the trailer unit. Is the A8 4H so different that it won´t communicate at all other trailer units than it´s own (4H0 907 383C)? I´ve tried 4F chassis box, which I wasn´t even expecting to work, but then Q7 box too (4L0 907 383 C), which is identical to wiring/pinout and functions.
    It just wont communicate with the unit. Throwing "5729 - No Communication with Towing System Control Module (J345) U1003 00 [009]" fault. Wiring is triple checked and measured, so no issue there. CAN lines connect nicely to other units in the same branch and show proper resistance value.
    Before going to buy new 4H0 unit, any thoughts on does the A8 4H really have so different handshakes, that it won´t communicate at all if it´s not exactly original box? And if so, what is the actual change in firmware making it so? Yes, A8 4H introduced Flex Bus and a lot of other things, but it has nothing to do with the normal can bus.
    Below autoscan from two cars for coding comparison. The one with hitch has also back-up camera and jukebox, plus something different with door module coding I haven´t yet identified. My car without trailer only has some MMI coding tweaks.
    A8 4H 4.2tdi with trailer hitch
    Sunday,28,April,2019,18:26:49:01825
    VCDS Version: 18.9.1.0
    Workshop Code: 000 00555 000000
    Chassis Type: 4H-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 11 31 13 15 16 17 18 19 22 28 34
              36 3B 3C 42 46 47 48 52 53 55 56 57 5B 5F 62 69 6C 6D 6F 72
              81 84 85 88 89 8A 8B 8D 8E 8F 90
    VIN: WAUZZZ4H4BN002046   Mileage: 65961km-40986miles
    48-Seat, Rear, DS -- Status: Malfunction 0010
    5B-Seat,Rear,PS -- Status: OK 0000
    84-Night Vision -- Status: OK 0000
    8A-Multicont. Seat Rear,DS -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    8D-Multicont. Seat Rear,PS -- Status: OK 0000
    Address 01: Engine (J623-CDSB)       Labels:* Redir Fail!
       Part No SW: 4H0 907 409     HW: 4H0 907 409
       Component: 4.2TDI EDC17  H04 0010
       Revision: 34H04---
       Coding: 0106002C291F0A68
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM42TDI1114H0907409 001016
       ROD: EV_ECM42TDI1114H0907409.rod
       VCID: 69E18094887EC3026A-803C
       Part No SW: 4H1 927 158 P    HW: 0BL 927 156 E
       Component: 0BL 42 TDIRdW H08 1006
       Revision: --H08---
       Coding: 001111
       ASAM Dataset: EV_TCMALX51011 001013
       ROD: EV_TCMALX51011_001.rod
       VCID: 3D4904C4AC768FA2F6-8068
       Part No SW: 4H0 907 379 A    HW: 4H0 907 379 A
       Component: ESP PREMIUM   H08 0151
       Coding: E4EAA20027574500E700
       ASAM Dataset: EV_ESPPremi 004012
       ROD: EV_ESPPremi_004_AU64.rod
       VCID: 30572DF06B2472CA6D-8064
       Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 AB
       Component: BCM2 2.0      H23 0510
       Coding: 01873000000000000000
       Shop #: WSC 06208 000 1048576
       VCID: 6CEFF9808F8CD62A11-8038
       Serial number: 0210000104416003
       Component: MEM-BFS       H07 0115
       Revision: AA000000    Serial number: 00001010174974
       Coding: 0018B60000043201000001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 345F21E0973C4EEA09-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 D    HW: 4H0 820 043 D
       Component: Klima 4 Zonen H14 0045
       Coding: 389100BE04
       VCID: 2171D8B430CECB42F2-8074
    0130 - Motor for  Left Side Window Defrost Flap
              B10D7 21 [008] - Signal Amplitude Too Low
                        Fault Frequency: 31
                        Reset counter: 157
                        Mileage: 56288 km
                        Date: 2018.09.13
                        Time: 01:05:58
       Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
       Component: BCM1 2.0      H11 0083
       Revision: 15011002    Serial number: 00000000718951
       Coding: 0200E01050B49FE1EF810007A0001908009CE3080A000101800008402100
       VCID: 2961C09440FE0302AA-807C
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 100609  H32 0040
       Serial number:         100612133241
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 10005464
       Coding: 025523
       Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
       Component: E1 - LDS  H07 0044
       Serial number: 30 06 2010  00000044
       Subsystem 4 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0275
       Serial number: WA100296000000048314
       Coding: 020300
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: C7088235000000000001
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 C    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0160
       Revision: AA001001
       VCID: 2077DDB033C4C24AFD-8074
       Part No SW: 4H0 919 475 F    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0020
       Revision: 11001001    Serial number: 55931018102056
       Coding: 320902
       ASAM Dataset: EV_AU57XParkiAssis2 002005
       ROD: EV_AU57XParkiAssis2.rod
       VCID: 35591CE4944657E23E-8060
    Address 11: Engine II (J624)       Labels:* None
       Revision: 34H04---
       ASAM Dataset: EV_ECM42TDI2114H0907409 001016
       ROD: EV_ECM42TDI2114H0907409.rod
       Part No SW: 4H0 907 561 A    HW: 4H0 907 561
       Component: ACC3          H15 0160
       Coding: 3704010201
       ASAM Dataset: EV_AdaptCruisContrAU64X 001012
       ROD: EV_AdaptCruisContrAU64X_001.rod
       VCID: 2961C09448FE0302AA-807C
    10240 - Sensor for Automatic Distance Control
                        Reset counter: 179
                        Mileage: 56581 km
                        Date: 2019.02.02
                        Time: 09:33:13
                        Control Module temperature: 11 °C
                        Voltage terminal 15: 14.197 V
                        Velocity_vehicle_reference: 3.91 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.89 m/s²
    141056 - Function Restriction due to Faults in Other Modules
              U1113 00 [024] - -
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Reset counter: 179
                        Mileage: 58867 km
                        Date: 2019.02.22
                        Time: 15:08:57
                        Control Module temperature: 2 °C
                        Voltage terminal 15: 14.108 V
                        Velocity_vehicle_reference: 17.44 m/s
                        Longitudinal_acceleration_vehicle_reference: -2.94 m/s²
       Part No SW: 4H0 959 655 B    HW: 4H0 959 655 B
       Component: Airbag10.43   H24 0028
       Revision: --------    Serial number: 003G10014U5H
       Coding: 30314246304230303033554A304C34483053
       Serial number: 3575HRB404V6CMJO8O1F
       Serial number: 3585HRB40516CMJO7PPB
       Serial number: 3515JRB404V6DUG65H8$
       Serial number: 3525JRB405R6CSQ8H8LJ
       Serial number: 3554VRB40616RJQI4HLK
       Serial number: 3564VRB40616RJQI6HGI
       Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
       Component: Lenks.Modul   H07 0007
       Revision: --------    Serial number: 90815JFT0002J
       Coding: 0004BC
       VCID: 325327F86D2840DA1B-8066
       Subsystem 1 - Part No SW: 4H0 951 528     HW: 4H0 951 528
       Component: E221 - MFL  H04 0009
       Serial number: 31 05 2010  33010184
       Part No SW: 4H0 920 830 D    HW: 4H0 920 830 F
       Component: TDieRDWACCNV- H30 0297
       Revision: 26110011    Serial number: 658130710593025
       Coding: 13860800DF000008010000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K.rod
       VCID: 267BCBA859E02C7A87-8072
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H04 0210
       Serial number: 1100626000454
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105 A    HW: 4H0 265 105 A
       Component: Standheizung  H22 0240
       Revision: 56005006    Serial number: 20100629145316
       Coding: 5D1300
       Part No SW: 4H0 907 468 D    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0183
       Revision: --------    Serial number: 00000000026084
       Coding: 00C1037D00
       ASAM Dataset: EV_GatewUDS 001023
       ROD: EV_GatewUDS_AU57.rod
       VCID: 325327F8652840DA1B-8066
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650287580
    6664 - Control unit for battery monitoring
              U1051 00 [008] - Implausible signal
                        Reset counter: 179
                        Mileage: 65961 km
                        Date: 2019.04.28
                        Time: 18:18:13
                        Voltage terminal 30: 11.8 V
                        Voltage terminal 15: 11.7 V
                        Control Module temperature: 17 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H11 0013
       Serial number: 002106100001040
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       VCID: 2765C6AC5EEA3572BC-8072
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H14 0045
       Coding: 0100000000
       ASAM Dataset: EV_AirCondiHeck 001038
       ROD: EV_AirCondiHeck.rod
       VCID: 315128F4602E7BC262-8064
       Part No SW: 4H0 907 553 B    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H16 0095
       Coding: 008003
       ASAM Dataset: EV_AirSuspe 003017
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2B6D3A9C4202111258-807E
       Component: MEM-FS        H07 0115
       Revision: AA000000    Serial number: 00001010174948
       Coding: 0018B78000853201020001010101112131313333203333
       Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
       Component: SARA 6D red   H02 0015
       Revision: --------    Serial number: EJ1BPA370052KV0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D6934847C161F2246-8078
       Part No SW: 4H0 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH02 0100
       Revision: 00H02000    Serial number: 6PZ 010 287-00
       Coding: 0010101
       Shop #: WSC 42500 205 96338
       VCID: 6DE9F4847496DF2206-8038
       Subsystem 1 - Part No: 4H0 907 568
       Component: J770  SWA Slave H01 0100
       Subsystem 2 - Serial number: 6PZ 010 287-20
       Subsystem 3 - Serial number: 5F10.07.1000H010003CH13217˙
       Subsystem 4 - Serial number: H13217˙
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000105482517
       Coding: 011F0E205E0062C202080007
       Shop #: WSC 02312 785 00200
       VCID: 3B4D0ADCBA628192C8-806E
       Revision: 00002001    Serial number: 0132444779
       Coding: 011A062000B93580B320C7802C0100000000000000000000000000000000
       Subsystem 1 - Part No: 4H0 951 177
       Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
       Component: DACHELEKTRONI  H11 0080
       Serial number: H2010000000000002654
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0070
       Revision: CJ007000    Serial number: 00000000000240
       VCID: 1B0DEA5C1AA2E19228-804E
    Address 48: Seat, Rear, DS (J876)       Labels: None
       Part No SW: 4H0 959 860     HW: 4H0 959 860
       Component: MEM-FS-Fond   H05 0114
       Revision: AA000000    Serial number: 00001010179677
       Coding: 001892800000300D0A00392038193A2039203B3B202020
       VCID: 71D1E8F4A8AE3BC222-8024
    03795 - Switch Module for Seat Adjustment
                        Reset counter: 154
                        Mileage: 64285 km
                        Date: 2019.03.29
                        Time: 20:02:59
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0162
       Revision: --------    Serial number: 0000105622854
       VCID: 3A430FD8B558B89AD3-806E
       Part No SW: 4H0 907 801 C    HW: 4H0 907 801 A
       Component: EPB-4         H03 0009
       Revision: --------    Serial number: 00000000005768
       ASAM Dataset: EV_ParkiBrake 001015
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2867C59053F43A0AB5-807C
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357     HW: 4H4 907 357
       Component: ....AFS13.... H01 0070
       Serial number: 100702-0004-044
       Coding: 11116F33F91AEA00
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
       VCID: 6FD5EE8CB69A2D3234-803A
    H02 0006
       Coding: 1A0000
    H02 0006
       Coding: 1A0000
       Part No SW: 4H0 035 053     HW: 4H0 035 053
       Component: Radio U Basic H51 0050
       Revision: AB001007    Serial number: 438G$0A7501784
       Coding: 010003010000000001
       VCID: 5C8FA9405F2CA6AAE1-8008
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4F0 919 129 D    HW: 4F0 919 129
       Component: HybridTV-DVB  H07 0510
       Revision: R0070000    Serial number: 76301300452801
       Coding: 01010000
       VCID: 2D69348474161F2246-8078
    Address 5B: Seat,Rear,PS (J877)       Labels: None
       Component: MEM-BFS-Fond  H05 0114
       Revision: AA000000    Serial number: 00001010179634
       Coding: 001896800000300D0A00392038193A2039203B3B382020
       Part No SW: 4H0 035 670 C    HW: 4H0 035 670 C
       Component: H-BNT-EU      H41 0171
       Revision: --------    Serial number: 030GK0A7500435
       Coding: 020100000001FBEF7D14AB1E000000030000010000000000
       VCID: 247FD1A027DCDE6A99-8070
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
       Component: DU8 D4 SV NB  H46 0021
       Serial number: AUZ8ZDA260036N9
       Subsystem 3 - Part No SW: 4H1 919 600 C    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0062
       Serial number: 00000000010167
       Component: CD-Database  1886
                000 -  -  - Intermittent
                        Fault Frequency: 33
                        Reset counter: 178
                        Mileage: 65954 km
                        Date: 2019.04.28
                        Time: 11:38:12
                        Bin. Bits: 00000000 00100000
                        Bin. Bits: 00001000 00000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000106196381
       Coding: 010F0E20420062C202080007
       VCID: 394110D4B05EB382DA-806C
    Address 69: Trailer (J345)       Labels: Redir Fail!
       Part No SW: 4H0 907 383 C    HW: 4H0 907 383 C
       Component: Anhaenger     H07 0072
       Revision: 5H001002    Serial number: 00000128177315
       Coding: 0104010000000000
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H03---    Serial number: 525 PA8J06D02T
       Coding: 1030002
       VCID: 65F98CA4AC66E7624E-8030
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 176000076
       Coding: 0210044001
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B4D0ADCB2628192C8-806E
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000007460
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63FD92BC6A529952A0-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000106196970
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731     HW: 4H1 927 731
       Component: GSM-LL        H04 0081
       Revision: 0L0D4011    Serial number: SN100705  0154
       ASAM Dataset: EV_GSM2x3Mono 001014
       ROD: EV_GSM2x3Mono.rod
       VCID: 6AE3FF988D78C81A63-803E
    Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
       Part No SW: 4H0 907 547 E    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H09 0026
       Serial number: 0K84AE40006047
       Coding: 1101
       ASAM Dataset: EV_NightVisioGen1 001002
       ROD: EV_NightVisioGen1.rod
       Night vision system camera:
       Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
       Component: NV-CAM-Gen1  H07 0006
       Serial number: 00000000001013419394
       Part No SW: 4H0 907 217 B    HW: 4H0 907 217 A
       Component: DPC-SG        H22 0023
       Coding: ED060000
       ROD: EV_OnBoardCamerDPC.rod
       Part No SW: 4H0 907 182 E    HW: 4H0 907 182 E
       Component: IVB           H03 0027
       Serial number: 00453108106701
       Coding: 660FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2C6F3980470C162A51-8078
       Serial number: 00453108103301
       Coding: 260FF2
    Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
       Part No SW: 4H0 907 182 D    HW: 4H0 907 182 D
       Serial number: 00453108076801
       Coding: 200F00
       ASAM Dataset: EV_IVBDriveSideRear 001003
       Part No SW: 4H0 907 541 A    HW: 4H0 907 541
       Coding: 3704010201
       ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
       ROD: EV_AdaptCruisContr2AU64X_001.rod
              U1113 00 [024] - -
                        Reset counter: 179
                        Mileage: 58867 km
                        Date: 2019.02.22
                        Time: 15:09:13
                        Control Module temperature: 4 °C
                        Voltage terminal 15: 14.292 V
                        Velocity_vehicle_reference: 19.15 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.03 m/s²
    Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
       Serial number: 00453108087301
       Coding: 200F00
       ASAM Dataset: EV_IVBPasseSideRear 001003
    Address 8E: Image Processing (J851)       Labels:* None
       Part No SW: 4G0 907 107     HW: 4H0 907 107
       Component: BV-SG         H28 0026
       Serial number: 000040070607107
       Coding: 01A0BA061111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H04 0070
       Coding: 0066F609031F037E070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H04 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70D7EDF0ABA432CA2D-8024
    End-------------------------(Elapsed Time: 06:57)--------------------------
    A8 4H 4.2tdi without trailer hitch
    Wednesday,20,February,2019,09:23:01:01825
    VIN: WAUZZZ4H0AN003239   License Plate:
    Mileage: 282272km-175395mi   Repair Order:
    Scan: 01 02 03 05 06 08 09 10 11 31 13 15 16 17 18 19 22 28 34 36
              3B 3C 42 46 47 48 52 53 55 56 57 5B 5F 62 6D 6F 72 81 84 85
    VIN: WAUZZZ4H0AN003239   Mileage: 282272km-175395miles
    48-Seat, Rear, DS -- Status: OK 0000
       Component: 4.2TDI EDC17  H02 0010
       Revision: 34H02---
       Coding: 0106002C291F0268
       Shop #: WSC 11400 205 63513
    5619 - Engine Off Timer Performance
              P150A 00 [096] - -
       Part No SW: 4H1 927 158 Q    HW: 0BL 927 156 E
       Component: 0BL 42 TDIRdW H05 1008
       Revision: --H05---
       Coding: 001111
       VCID: 3E4B03C8A17094BAEF-806A
       Coding: E4EAA20027574500E300
       Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 L
       Component: BCM2 2.0      H13 0510
       Coding: 01071001000000000000
       Shop #: WSC 55882 001 1048576
       Subsystem 1 - Part No SW: 4H0 905 852 A    HW: 4H0 905 852 A
       Serial number: 0210000032118009
       Part No SW: 4H0 959 760     HW: 4H0 959 760
       Component: MEM-BFS       H07 0114
       Revision: AA000000    Serial number: 00001010107087
       VCID: 70D7EDF0A3A432CA2D-8024
       Component: Klima 4 Zonen H12 0040
       Coding: 389100BE04
       ASAM Dataset: EV_AirCondiFront 001048
       Component: BCM1 2.0      H09 0083
       Revision: 15009001    Serial number: 00000000495116
       Coding: 0200E01050B49FE1EB810007A0001908009CC3080A000101800008402100
       Component: WWS641 100309  H32 0040
       Serial number:         100325142854
       Coding: 0045F7
       Serial number: 10836482
       Coding: 025523
       Serial number: 16 03 2010  00000066
       Serial number: WA091313000000026337
       Coding: 020300
       Component: AQ_Hum_Sensor  H01 0001
       Serial number: 2218CE05000000000001
       Part No SW: 4H0 919 475 C    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H05 0011
       Revision: 11001001    Serial number: 44831006705533
       Coding: 100902
       ASAM Dataset: EV_AU64XParkiAssis2 005003
       ROD: EV_AU64XParkiAssis2.rod
       Revision: 34H02---
    8882 - Torque Intervention to Protect Turbocharger
              P100E 00 [032] - -
       Coding: 3604010201
                        Reset counter: 119
                        Mileage: 280328 km
                        Date: 2019.01.11
                        Time: 20:54:36
                        Control Module temperature: 10 °C
                        Voltage terminal 15: 13.894 V
                        Velocity_vehicle_reference: 10.34 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.12 m/s²
    145408 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Fault Frequency: 184
                        Reset counter: 119
                        Mileage: 282169 km
                        Date: 2019.02.18
                        Time: 19:56:12
                        Control Module temperature: 7 °C
                        Voltage terminal 15: 10.405 V
                        Velocity_vehicle_reference: -0.01 m/s
       Component: Airbag10.43   H22 0026
       Revision: --------    Serial number: 003G100114N6
       Serial number: 3575HRB405T6O2OU8899
       Serial number: 3585HRB40616O2OUCGM8
       Serial number: 3515JRB405R6CSQ8MGCM
       Serial number: 3525JRB40576094I31KK
       Serial number: 3554VRB405D6B1V4DGU5
       Serial number: 3564VRB405D6B1V4A9GP
       Revision: --------    Serial number: 90815JCA00019
       Coding: 00043C
       Subsystem 1 - Part No SW: 4H0 951 528 H    HW: 4H0 951 528 H
       Serial number: 15 02 2010  33004891
       Part No SW: 4H0 920 830 F    HW: 4H0 920 830 F
       Component: TDieRDWACCNV- H29 0185
       Revision: 19409111    Serial number: 658300310593094
       Coding: 130608009F000008010000
       ROD: EV_RBD4K.rod
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 F    HW: 4H0 919 204 F
       Serial number: 1100312021660
       Component: Standheizung  H20 0250
       Revision: 34003004    Serial number: 20100317023047
       Coding: 5D1300
       Shop #: WSC 13844 002 1048576
    01225 - Radio Receiver for Aux Heat (R64)
                        Reset counter: 145
                        Mileage: 276248 km
                        Date: 2018.11.02
                        Time: 17:08:22
                        Temperature: 13.0°C
                        Temperature: 24.0°C
                        Voltage: 13.50 V
                        Temperature: 12.0°C
                        RPM: 713 /min
                            No
    00664 - Fuel gauge
                        Reset counter: 107
                        Mileage: 281940 km
                        Date: 2019.02.15
                        Time: 20:31:45
                        Temperature: 79.0°C
                        Temperature: 77.0°C
                        Voltage: 14.50 V
                            Part Throttle
                        Count: 180
                        Temperature: 4.0°C
                        RPM: 690 /min
                            No
       Part No SW: 4H0 907 468 C    HW: 4H0 907 468 C
       Component: J533--Gateway H07 0175
       Revision: --------    Serial number: 00000000011600
       Coding: 00C1037D00
       ASAM Dataset: EV_GatewUDS 001021
       Component: J367-BDM  H07 0130
       Serial number: 00000000005640100058
       Part No SW: 4H0 907 163     HW: 4H0 907 163
       Component: 4 Wheel Drive H11 0005
       Serial number: 000503100001030
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003017
       VCID: 66FB8BA89960EC7A47-8032
       Component: Klima Fond    H11 0040
       Coding: 0100000000
       Coding: 008002
              C10C8 00 [008] -  -
                        Reset counter: 103
                        Mileage: 280941 km
                        Date: 2019.01.28
                        Time: 15:33:19
       Component: MEM-FS        H07 0114
       Revision: AA000000    Serial number: 00001010100461
       Component: SARA 6D red   H02 0011
       Revision: --------    Serial number: EJ1370002ZE9000
       Component: J769  SWA MasterH02 0050
       Coding: 0000101
       Subsystem 3 - Serial number: 5F29.03.1100H010003CH10602˙
       Subsystem 4 - Serial number: H10602˙
       Component: TSG FA        H02 0158
       Revision: --------    Serial number: 0000103227592
       Coding: 011F0E205E0062C202000007
       Revision: 00002001    Serial number: 0127470323
       Coding: 011A062000393581B32007B28C0000000000000000000000000000000000
       Component: Dachelektroni  H11 0070
       Serial number: A2010000000000059866
       Part No SW: 4H0 035 223     HW: 4H0 035 223
       Component: BOSE G3 D4    H07 0050
       Revision: CI007500    Serial number: 00000000000193
       VCID: 5B8DAA5C5A22A192E8-800E
       Revision: AA000000    Serial number: 00001001339828
       Component: TSG BF        H02 0158
       Revision: --------    Serial number: 0000103298786
       Revision: --------    Serial number: 00000000000996
       Component: ....AFS13.... H01 0055
       Serial number: 100330-0004-056
    H02 0003
       Coding: 1A0000
    H02 0003
       Coding: 1A0000
       Part No SW: 4E0 035 053 L    HW: 4E0 035 053
       Component: Radio U Basic H45 0085
       Revision: AB001007    Serial number: 010CL0A7503439
       VCID: 2579CCA42CE627628E-8070
       Part No SW: 4F0 919 129 G    HW: 4F0 919 129
       Component: HybridTV-DVB  H07 0550
       Revision: R0070000    Serial number: 76301300057201
       Coding: 01010000
       VCID: 30572DF0632472CA6D-8064
       Revision: AA000000    Serial number: 00001001339778
       Part No SW: 4H0 035 646 A    HW: 4H0 035 666 N
       Component: H-BN-EU       H47 1034
       Revision: --------    Serial number: 178GV0E7510212
       Coding: 020100000001FBEDF5148B1A00000003600001020100000002
       Shop #: WSC 36758 001 1048576
       Subsystem 1 - Part No: 8R0 060 884 FK
       Component: EUR 2018/2019  2702
       Subsystem 2 - Part No SW: 4H0 919 604 B    HW: 4H0 919 604 B
       Component: DU8 D4 SV NB  H44 0021
       Serial number: AUZ8ZDA11003ZHQ
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600 B
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000005970
       Component: CD-Database  5571
                        Reset counter: 50
                        Mileage: 281398 km
                        Date: 2019.02.05
                        Time: 18:05:55
                        Text: DU902A,Front,M,0,0,6
    00862 - Antenna for GPS Navigation (R50/R52)
                        Fault Status: 00101011
                        Fault Frequency: 15
                        Reset counter: 119
                        Mileage: 282169 km
                        Date: 2019.02.18
                        Time: 19:53:12
                        Voltage: 12.20 V
    03623 - Invalid Secruity/Release Code
                        Reset counter: 55
                        Mileage: 281521 km
                        Date: 2019.02.08
                        Time: 15:33:56
                        Hex Value: 0x0004
                        Hex Value: 0x0009
                        Count: 7
    03677 - Missing Secruity/Release Code
                        Reset counter: 55
                        Mileage: 281509 km
                        Date: 2019.02.07
                        Time: 22:26:27
                        Voltage: 12.40 V
       Component: TSG HL        H04 0158
       Revision: --------    Serial number: 0000103315039
       Coding: 010F0E20420062C202000007
       Part No SW: 4H0 959 107 F    HW: 4H0 959 107 F
       Component: HDSG-Modul    H11 0632
       Revision: 09145325    Serial number: 067000123
       Coding: 0200044000
       ASAM Dataset: EV_DeckLidContrUnit 001023
       Revision: --------    Serial number: 000000004410
       ROD: EV_Ambie.rod
       Component: TSG HR        H04 0158
       Revision: --------    Serial number: 0000103315016
       Component: GSM-LL        H07 0083
       Revision: 0L0D4011    Serial number: SN100302  0169
       Part No SW: 4H0 907 547 D    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H08 0022
       Serial number: 0K84AE40003392
       Coding: 1101
       Serial number: 00000000001005619843
       Part No SW: 4H0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H20 0014
       Coding: EC060000
       Part No SW: 4H0 907 182 A    HW: 4H0 907 182 A
       Serial number: 00448453014001
       Coding: 660FF2
       Serial number: 00448453092601
       Coding: 260FF2
       Part No SW: 4H0 907 182     HW: 4H0 907 182
       Serial number: 00448453044501
       Coding: 200F00
       VCID: 67E586AC9E6AF5727C-8032
       Coding: 3604010201
              U1113 00 [008] - -
                        Fault Frequency: 197
                        Reset counter: 119
                        Mileage: 282169 km
                        Date: 2019.02.18
                        Time: 19:56:12
                        Control Module temperature: 6 °C
                        Voltage terminal 15: 10.340 V
                        Velocity_vehicle_reference: -0.00 m/s
       Serial number: 00448453044901
       Coding: 200F00
    Address 8E: Image Processing (J851)       Labels:* Redir Fail!
       Part No SW: 4H0 907 107     HW: 4H0 907 107
       Component: BV-SG         H25 0008
       Serial number: 000040050603107
       Coding: 01A08200
       ASAM Dataset: EV_BVS 001007
       ROD: EV_BVS.rod
       VCID: 64FF91A06F5C9E6A59-8030
       Component: RGS-VL        H04 0060
       Coding: 0066F609031F037E070308014240C2000000
       ASAM Dataset: EV_RGS_L 002006
       ROD: EV_RGS_L.rod
       Component: RGS-VR        H04 0060
       ASAM Dataset: EV_RGS_R 002006
       ROD: EV_RGS_R.rod
    End-------------------------(Elapsed Time: 06:29)--------------------------
  2. Likes Uwe liked this post
  3. #2
    Hi and welcome.
    Please Get Verified so we can move this to the Retrofits section. I believe you are in Category 2 of that post.
    Mar 2019
    Thanks Uwe! I got myself verified, so this can be now moved to the retrofits.
    Here´s the known coding list for retrofitting original trailer hitch for A8 4H (prefacelift at least):
    Park/Steer Assist 10 -> Byte 0 Bit 0 : change to 1
    Auto dist. reg 13 -> Byte 0 bit 0 : change to 1
    CAN Gateway 19 -> Installation list -> turn on 69 - Trailer
    Level control 34 -> Byte 2 bit 0 : change to 1
    Adaptive cruise 8B -> Byte 0 bit 0 : change to 1
    Central Conv. 47 -> Byte 12 bit 5 : change to 1
    Back-up cam 6C -> Byte 8 but 9 : change to 1 (or 4th digit from right to +1)
    For Engine 01 the coding difference seems to be:
    0106002C291F0A68 <- trailer
    0106002C291F0268
    This actually to my understanding is only linked to the fan installed. The factory fitted trailer hitch is coupled with 600W fan instead of 400W. So probably just changes the control characteristics of cooling (or just fan control alone). So in case when keeping the fan unchanged, this is not valid code change. I´ll have to check what fan I have in place vs. my friends car with trailer.
    For ABS/ESP 03 the coding difference seems to be:
    E4EAA20027574500E700 <- trailer
    This to my understanding enables function for trailer towing ASB/ESP characteristics adjustment, when detected?
    I haven´t been fully verified the coding yet, since I don´t have the trailer control box issue solved yet. Any thoughts on the issue? I´m having hard times to understand what would be so different in the A8 4H gateway, that it won´t let communicate with the Q7 4L0 box.
    Apr 2018
    ITALY
    isn't it a shame to tow anything with an A8?
    Quote Originally Posted by jasso View Post
    Done!
    An A8 with a 4.2 TDI should be a pretty capable tow-vehicle, although I have to admit, I'd personally lean more toward a Touareg or a Q7 for that job.
    Mar 2019
    Depends on what you´re towing I mostly tow custom inline trailer holding 2 snowmobiles during winter. Pretty long drives to tracks, so quiet comfort is highly appreciated. + traction, torque and adjustable air suspension.
    Agree on the Q7. But when A8 AND Q7 is not an option, I rather cruise with top class sedan while I´m not towing anything.
  8. Likes Uwe, PetrolDave liked this post
