Results 1 to 10 of 17
Thread: Bentley Continental GT V8 2013 - is it safe to read ABS-Brakes Faults?
    Nov 2018
    Hi all, i have Hex net v2 professional
    this is my own car - everyday when i start it , it says "brake wear" on the screen, however all brake pads are fine LOADS left on them
    after a drive , stop and start car, the light does not come back on. only first start of every day it appears
    My question is, is VCDS safe to read this module on this car? Fault codes etc,
    I have plugged it in, it recognises everything, i used it to find a fault with a TPMS sensor earlier, was great help.
    thanks in advance, (plus any tips on why sensor light keeps coming on would be great)
    Hi and welcome.
    The best thing to do would be to post a complete Auto-Scan from your car.
  3. Likes DrPeter liked this post
    Nov 2018
    Thanks, i was just questioning if it was safe to read this module, as in the WIKI bentley 2012+ is greyed out meaning i have nothing to read.
    ive heard some specific modules should not be read with VCDS as they can leave error codes which are not clearable.
    16.4905 S, 151.7375 W
    Quote Originally Posted by ohwhatalad View Post
    We have had lots of Ross-Tech customer send us complete vehicle Auto-Scans of the Bentley Continental and the New Bentley Continental 2012+ without causing errors.
    Where have you seen that VCDS has left errors?
    Use the pull down menu on the Auto-Scan screen to select the [39-Bentley Continental (2012>), it will work fine.
    drpeter
  6. Likes Uwe liked this post
    Nov 2018
    hi all! i done a complete log today, however, when i go into 03-ABS BRAKES, it keeps timing out, over and over, i will try to attach a video, in the meantime here is my log
    Thursday,27,June,2019,17:22:05:51790
    VCDS Version: 19.6.0.6  HEX-V2 CB: 0.4505.4
    Chassis Type: 3W-BY62 (6N0)
    Scan: 01 02 03 05 06 07 08 09 15 16 17 19 2E 34 36 37 38 46 47 53
              56 65 68 6C 71 76 77
    VIN: SCBFJ63W9DC080562   Mileage: 64390km-40010miles
    68-Wiper Electr. -- Status: OK 0000
    71-Battery Charger -- Status: OK 0000
    Address 01: Engine (------CMMC)       Labels: None
       Part No SW: 3W0 906 560     HW: 3W0 907 560
       Component: 4.0l V8TFSI / H54 0002
       Revision: NFH54---    Serial number: VWX3Z0L3965688
       Coding: 1D2A00126527000A0001
       Shop #: WSC 11519 000 1048576
       ASAM Dataset: EV_ECM40TFS0113W0906560 001003
       ROD: EV_ECM40TFS0113W0906560.rod
       VCID: 74B1DFBF0E378B47DED-8020
    18062 - Coolant Pump 2
              P261A 00 [047] - Open circuit
                        Mileage: 62814 km
                        Date: 2019.04.16
                        Time: 11:21:54
                        Engine speed: 671.50 /min
                        Normed load value: 12.9 %
                        Coolant temperature: 99 C
                        Intake air temperature: 60 C
                        Voltage terminal 30: 13.900 V
                        AFS dm: 21.2 kg/h
                        Median injection timing: 1.952 ms
                        Engine operating condition-Channel 87: Idling
                        Relative load value: 20.39 %
                        Tumg: 20.3 C
                        Psr w: 358.52 hPa
                        Engine torque: 66.6 Nm
    Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
       Part No SW: 3W0 927 158     HW: 0CU 927 760 A
       Component: OBL 40TFSIRdW H08 0006
       Revision: --H08---    Serial number:
       Shop #: WSC 00083 790 00190
       ASAM Dataset: EV_TCMAL450211 002010
       ROD: EV_TCMAL450211_BY62.rod
       VCID: 7AADF1872C53FD37841-802E
       VCID: 55F7823BED4DF24FC93-8000
    No Faults Found
       Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
       Component: A0 Kessy            6850
       Revision: 00H24072    Serial number: VWX3Z0L3965688
       Coding: 0422125
       VCID: 2A0D01C790B38DB7B41-807E
    00184 - Control Circuit for Engine Start/Stop Switch
                008 - Implausible Signal
                        Fault Status: 01101000
                        Fault Frequency: 14
                        Reset counter: 67
                        Date: 2017.11.29
                        Time: 13:28:28
       Part No SW: 3W3 959 760     HW: 3W3 959 760
       Component: MEM-BFS       H03 0171
       Revision: AA000000    Serial number: 00000029584203
       Coding: C03A1B2495A70000090001010101010000212727000000
       Shop #: WSC 00083 790 00243
       VCID: 015F866B4145AEEFC5B-8054
    03945 - Air Cushion for Lumbar Massage
                        Fault Status: 00100011
                        Reset counter: 217
                        Mileage: 63812 km
                        Date: 2019.05.21
                        Time: 17:39:18
    Address 07: Control Head        Labels: 3D0-907-048.clb
       Part No SW: 3D0 907 048     HW: 3D0 907 048
       Component: J127 KBT vorn       0100
       Revision: ABH06001    Serial number: VWZ6Z7M0130003
       VCID: 6393ACE3B7191CFFB77-8036
    Address 08: Auto HVAC        Labels: 3W7-907-040.clb
       Part No: 3W0 907 040 H
       Component: Climatronic BY624   3016
       Coding: 0000111
       VCID: 363525B7540BD957209-8062
    Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
       Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
       Component: J519                7700
       Revision: -4006---    Serial number: --------------
       Coding: 40820000AB2A11800508030000000000
       VCID: 38292B8F5E1F2F27325-806C
    Address 15: Airbags        Labels: None
       Part No SW: 3W3 959 655     HW: 3W3 959 655
       Component: 11 Airbag 9.43  H04 0050
       Revision: 93H04005    Serial number: 003FV000715J
       Coding: 0012593
       VCID: 04518F7F5257BBC7EED-8050
       Subsystem 1 - Serial number: 6332DRB40E488796$
       Subsystem 2 - Serial number: 6342DRB40E498A12W
       Subsystem 3 - Serial number: 63528RB406B010299
       Subsystem 4 - Serial number: 63628RB406AE7200K
       Subsystem 5 - Serial number: 63747RB406B58C57.
       Subsystem 6 - Serial number: 63847RB406B58C9A2
    Address 16: Steering wheel        Labels: 7L6-953-549.lbl
       Part No: 7L6 953 549 K
       Component: J527                3601
       Coding: 0000032
       VCID: 47CB587323E150DF4BF-8012
    Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
       Part No SW: 3W0 920 851 D    HW: 3W0 920 851 D
       Component: J285 KOMBI-INST.    3519
       Revision: KPH10V02
       Coding: 0042414
       Shop #: WSC 12587 123 45725
       VCID: 372B28B35341205F3BF-8062
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 3W0 920 851 D
       Component: J533  GW-K-CAN TP20 3519
       Coding: 5FF2FFAEEB054701
       VCID: 70B9D3AF76AFB7673A5-8024
       Revision: A1001003    Serial number: 7662534922
       Coding: 030000
       Shop #: WSC 00083 790 00194
       VCID: 290FFECB99F586AFBDB-807C
    Address 34: Level Control        Labels: 3Wx-907-553-34.clb
       Part No: 3W0 907 553 H
       Component: LUFTFDR.-CDC- 3C3V0 7505
       Coding: 0005511
       Shop #: WSC 00083 790 00203
       VCID: 3FDB40937B31181FF3F-806A
       Component: MEM-FS        H03 0171
       Revision: AA000000    Serial number: 00000029586558
       Shop #: WSC 00083 790 00242
    Address 37: Navigation (J0506)       Labels: None
       Part No SW: 3W0 035 017 F    HW: 3W0 035 017 F
       Component: RNS-MID       H06 0160
       Revision: AB001001    Serial number: VWZ6Z7M0130003
       Coding: 060100020000002040
       VCID: 303913AFBA2FF7677A5-8064
                        Fault Status: 00100111
                        Reset counter: 244
                        Mileage: 64217 km
                        Date: 2019.06.18
                        Time: 15:45:14
    Address 38: Roof Electronics        Labels: None
       Part No: 3W0 907 135 G
       Component: Dachmodul           0803
       Coding: 0006589
       VCID: 3A2D318760133D37C41-806E
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 P
       Component: GS HSG              8135
       Coding: 0000040
       VCID: 3D273A9B716D0A0FE13-4B1E
       Subsystem 1 - Part No: 3W8 959 701 L
       Component: Tuersteuergeraet FS 1107
       Subsystem 2 - Part No: 3W8 959 702 L
       Component: Tuersteuergeraet BF 1107
       Subsystem 3 - Part No: 3W8 959 703 F
       Component: Tuersteuergeraet HL 0705
       Subsystem 4 - Part No: 3W8 959 704 F
       Component: Tuersteuergeraet HR 0705
       Subsystem 5 - Part No: 3W3 909 610 A
       Component: 24 HDSG             2012
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
    Address 47: Sound System        Labels: None
       Part No SW: 3W8 035 465 C    HW: 3W8 035 465 C
       Component: DSP 8 Channel       0030
       Revision: 00H07001    Serial number: 75870000390907
       VCID: 3C21379F6A670307D6D-8068
    Address 53: Parking Brake        Labels: 3W0-907-801.clb
       Part No SW: 3W0 907 801 G    HW: 3W0 907 801 G
       Component: EPB  BC7H0290   HC7 0290
       Coding: 0023513
       Shop #: WSC 00083 790 00211
       VCID: 3A2D318760433D37C41-5184
    Address 56: Radio
    Address 65: Tire Pressure        Labels: Redir Fail!
       Part No SW: 3W7 907 273 A    HW: 3W7 907 273 A
       Component: J0502 RDK           0004
       Revision: 0004 004    Serial number: 00000600007850
       Coding: 3501E04185C863B8FD439700439700
       Shop #: WSC 00083 790 00214
       VCID: 3E253D977C3B1117F89-806A
    Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
       Part No: 3W2 955 023 L
       Component: Wischermodul       0401
       Shop #: WSC 00000 725 65552
       VCID: 40D9436F06CF67E78A5-8014
       Part No SW: 3W3 907 441 C    HW: 3W3 907 441 C
       Component: J772__Rearview      0030
       Revision: 00H11000    Serial number: 525 PA8J250211
       Coding: 2022002
       VCID: 392F2E8B6555362FCDB-806C
    Address 71: Battery Charger (J367)       Labels:* None
       Part No SW: 3W3 915 181 A    HW: 3W3 915 181 A
       Component: EMM Batt Man  H04 0570
       Serial number: 0000000001
       Coding: 1E0100
       Shop #: WSC 37234 001 1048576
       ASAM Dataset: EV_BatteChargVaria1 002019
       ROD: EV_BatteChargVaria1_002.rod
       VCID: 372B28B35FC1205F3BF-8062
    Address 76: Park Assist        Labels: Redir Fail!
       Part No SW: 3W0 919 283 F    HW: 3W0 919 283 E
       Component: J446  ST Parkhilfe  0102
       Revision: 11H01001    Serial number: 66731211400084
       Coding: 0308036
    Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
       Part No SW: 3D0 035 730 A    HW: 3D0 035 730 A
       Component: Telefon       010 0422
       Revision: --------    Serial number: 35909603387598
       Coding: 020102010100010000000000
       ASAM Dataset: EV_UHVPremiPhaet A01002
       ROD: EV_UHVPremiPhaet.rod
       VCID: 1A6DD107CC131D37241-804E
    End----(Elapsed Time: 02:27, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
    Nov 2018
    Here is the video i took showing it cannot connect to ABS BRAKES module and therefore cannot read DTC
    any advice? i assume the BRAKE WEAR error i occasional get will be stored here
    https://drive.google.com/open?id=1t_...DORPxspvhJ327z
    Usually "Brake Wear" warnings originate from a simple circuit connected to the instrument cluster for the front pads, and from the EPB module for the back pads.
    But in this case, it looks like you might have a dodgy ABS controller.
  10. #8
    Uwe is correct, in the Bentley Continental GT, the 'brake pad wear sensors' are not sensors, they are simply wire loops in a plastic tab with a two terminal connector at the end.
    They are placed into each of the 4 wheel's brake (outer?) pads. In the wiring diagrams, they are called - G34, G35, G36 and G37.
    There is a 0.5mm red wire from the J285-Instrument Cluster on the G34-Left Front Pad wear sensor that should be grounded (from ground on the G37 through the G35, G36), when the sensors are NOT worn or damaged. If at anytime a pad wear senor loop is opened the Pad Wear light illuminates.
    So the circuit is from J285 to G34 to G35 to G36 to G37 to chassis ground.
    This information can be found in the "Dash panel insert" Bentley Factory wiring diagrams\Repair manuals.
    The ABS controller is not connected to these wear sensors.
    If the concern is not the brake pad wear sensor and this is actually an ABS concern, the light on the dash should be different. Maybe take a pic of the warning?
    Hope this helps,
    drpeter
  11. Likes Uwe liked this post
  12. #9
    Nov 2018
    Thanks your help is amazing!
    Firstly, its definitly brake wear sensor, it even says it on the dash in letters BRAKE WEAR
    Also, as its only on sometimes, others not, im sure not why, i think maybe a faulty brake pad wear sensor.
    So, id like to turn it OFF, if i go into instrument cluster, i can see the coding - it says +1 brake pad wear sensor active.
    See 2 photos here
    https://drive.google.com/file/d/1lfW...ew?usp=sharing
    https://drive.google.com/file/d/1-5N...ew?usp=sharing
    IF i change coding from 0042414 to 0041414 as VCDS shows, would that take away the error
    Can anyone confirm i am on the right path - dont wanna screw anything up!!
    Thanks again
  13. #10
    The problem is that those two digits of the coding are a binary bit-field, and 42 doesn't have a 1 in it.
    42 = +32 +8 +2
    So it would seem something in the coding specs for this cluster have changed since that file was written (last modification in 2009) and your 2013 car was made.
    Another approach is to pull the cluster and just jumper the appropriate wire behind it.
