Wednesday,22,May,2019,12:11:24:29066
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: WV1ZZZSYZK9         License Plate:
Mileage: 19435km-12076mi   Repair Order:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 03 08 09 10 15 16 17 18 19 42 44 52 5F 69 BB BC
VIN: WV1ZZZSYZK9         Mileage: 19435km-12076miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DAUA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 NB    HW: 04L 907 445 C
   Component: R4 2.0l TDI   H01 6116
   Revision: 23201001
   Coding: 0019403C6334050800000000000000000000000000000000
   Shop #: WSC 00069 790 00016
   ASAM Dataset: EV_ECM20TDI03004L906056NB 005005
   ROD: EV_ECM20TDI03004L906056NB.rod
   VCID: 7AADF0BE4C584177D09-802E
16395 - EGR Valve (N18)
          P0403 00 [096] - Malfunction
Readiness: N/A
   Part No SW: 2N0 907 379 C    HW: 2N0 907 379 C
   Component: ESC_base      H02 0850
   Serial number: 08503951180527
   Coding: 29A82477483DB687944E2464124B6D063C000078
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701028
   ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
   VCID: 3635248E38C06517741-8062
Address 08: Auto HVAC (J301)       Labels:* None
   Part No SW: 7C0 907 426 AF    HW: 7C0 907 426 AF
   Component: AC Manuell    H01 0401
   Coding: A03010000800200001000800500101000000000000001000200000000000
   Shop #: WSC 00069 790 00011
   ASAM Dataset: EV_AirCondiBHTCVN54X 003020
   ROD: EV_AirCondiBHTCVN54X_VN54.rod
   VCID: 6D87CBE20D16E6CF45B-8038
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001820400647
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW27.rod
   VCID: 7CA1F6A6466C7F47C25-8028
   Serial number: 000308418018184
   Coding: 0411050141
   ROD: EV_EPHVA18AU3700000_009_VN54.rod
   VCID: 4BC3657A534208FF3BF-801E
   Part No SW: 3Q0 959 655 BG    HW: 3Q0 959 655 BG
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W3PEYCCRX
   Coding: 800080000000000040000000000800000065
   ROD: EV_AirbaVW21TS6VW48X_VN54.rod
   VCID: 04518E463E9C0787BA5-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 802 205 18
   Component: FrontSensor_D  305 0109
   Serial number: 3550005119F140000006
   Front Sensor Passenger:
   Subsystem 2 - Part No SW: -----------    HW: 454 802 205 18
   Component: FrontSensor_P  305 0109
   Serial number: 35600842F9614000000K
   Part No SW: 5Q0 953 521 EL    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20180714500222
   Coding: 1204
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 005982562A841BA79ED-8054
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 7C0 920 741 B    HW: 7C0 920 741 B
   Component: KOMBI         211 2500
   Coding: 07A411002000000800082A000400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 2313EDDA9B52E0BFA3F-8076
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 7C0 963 271 B    HW: 7C0 963 271 B
   Component: STH-VN54x     008 0079
   Coding: 491100
   Shop #: WSC 00069 790 00031
   ASAM Dataset: EV_AuxilHeateWOSVN54X 001003
   ROD: EV_AuxilHeateWOSVN54X.rod
   VCID: 2809FAF6E27403E7F6D-807C
0036 - Fuel Level too Low
          P1250 00 [008] - -
                    Reset counter: 79
                    Mileage: 18003 km
                    Date: 2019.05.07
                    Time: 03:54:22
                    Operating condition of parking heater: OFF
                    71
                    Coolant temperature of parking heater: 50 C
                    Coolant temperature: 53 C
                    Engine running status: detected
                    Fuel level: 15 l
                    Heater output: 0 W
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0008206618
   Coding: 030000344F05730000000000000E00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW27.rod
   VCID: 3D273BA21DF6B64FB5B-8068
   Subsystem 2 - Part No SW: 2N0 915 181     HW: 2N0 915 181
   Serial number: 75884900001806120609
   Part No SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Component: TSG FS        006 0246
   Serial number: 0000331366345
   Coding: 00300B208000020100001000
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 46D5544E4820F597E41-8012
   Part No SW: 2N0 909 143 E    HW: 2N0 909 143 C
   Component: EPS_MQB_ZFLS  701 7021
   Coding: 0107
   ASAM Dataset: EV_SteerAssisMNB 002001
   ROD: EV_SteerAssisMNB.rod
   VCID: 2F3B11EAC79A54DF377-807A
   Part No SW: 5Q4 959 392 F    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0246
   Serial number: 0000329191300
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 45D753427526FE8FEDB-8010
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 2E0 035 130     HW: 2E0 035 130
   Component: MU-G--EU      611 0242
   Serial number: VWZGZ1V5605960
   Coding: 064500002800000000110001010002002F0000040000010000
   ASAM Dataset: EV_MUGlb4CHBAS 001001
   ROD: EV_MUGlb4CHBAS.rod
   VCID: 53F37D1A8B72503F73F-8006
   Part No SW: 6C0 907 383 G    HW: 6C0 907 383 G
   Component: Anhaenger     H27 0260
   Revision: 8D001004    Serial number: 0485964428
   Coding: 0100000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 2E050CEEC0905DD73C1-807A
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:00, VBatt start/end: 12.2V/12.2V)-----------
Engine +80c, engine off
;SW:04L-906-056-NB   HW:04L-907-445-C ---  Engine
;Component:R4 2.0l TDI   H01 6116, Coding:0019403C6334050800000000000000000000000000000000
;EV_ECM20TDI03004L906056NB,005005,EV_ECM20TDI03004L906056NB.rod
;Wednesday,22,May,2019,12:12:39:29066
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
;VCID: 7AADF0BE4C584177D09-802E
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WV1ZZZSYZK9,
IDE00018,Voltage terminal 15,11.859, V
IDE00019,Voltage terminal 30,12.321, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,77, C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),89.4, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator position,14, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00102,Control Module temperature,40.5, C
IDE00151,Oil fill level,72, mm
IDE00152,Oil warning threshold,57, mm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00178,Camshaft adjustment intake bank 1: specified value,0.0,
IDE00179,Camshaft adjustment intake bank 1: actual value,0.0,
IDE00182,Camshaft adaptation intake bank 1: phase position,1.0,
IDE00190,Charge air pressure specified value,0.005, bar
IDE00196,Engine oil temperature,71.4, C
IDE00198,Refrigerant pressure,0.000, bar
IDE00200,Median vehicle speed,0.00, km/h
IDE00304,Fuel level,76, l
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,1.03, g/s
IDE00348,Intake air temperature,38, C
IDE00349,Throttle valve position: normed,76, %
IDE00351,Main injection: start of activation,0.00,
IDE00352,Main injection: duration of activation,0, s
IDE00355,Cruise Control System (CCS): status,passive,
IDE00358,Limitation: torque,119.6, Nm
IDE00359,Limitation: smoke,0.0, Nm
IDE00363,Glow status,No preheat,
IDE00364,Preheat time,0.0, s
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.02, %
IDE00383,Pre-injection 1: activation start,0.00,
IDE00384,Pre-injection 1: activation duration,0, s
IDE00385,Pre-injection 2: activation start,0.00,
IDE00386,Pre-injection 2: activation duration,0, s
IDE00387,Post-injection 1: activation start,0.00,
IDE00388,Post-injection 1: activation duration,0, s
IDE00389,Post-injection 2: activation start,0.00,
IDE00390,Post-injection 2: activation duration,0, s
IDE00400,Intake manifold Runner Control (IMRC): activation,0.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,0.00, %
IDE00405,Crankshaft speed (RPM),0, /min
IDE00406,Camshaft speed (RPM),0, /min
IDE00407,Rail pressure regulation: status,Control operation: ignition on,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,not active,
IDE00416-MAS07386,Starter control: terminal 50 acknowledgment-Terminal 50 on CAN,not active,
IDE00416-MAS09390,Starter control: terminal 50 acknowledgment-Terminal 50 CAN valid,not active,
IDE00416-MAS09391,Starter control: terminal 50 acknowledgment-Terminal 50 via cable,not active,
IDE00416-MAS09392,Starter control: terminal 50 acknowledgment-Starter relay,not active,
IDE00416-MAS09394,Starter control: terminal 50 acknowledgment-Starter operation read back wire T50Ret,not active,
IDE00416,Starter control: terminal 50 acknowledgment,0,
IDE00417-MAS00077,Starter control: shut-off conditions 1-Immobilizer,not active,
IDE00417-MAS00357,Starter control: shut-off conditions 1-Starter shift malfunction,not active,
IDE00417-MAS01456,Starter control: shut-off conditions 1-Speed,not active,
IDE00417-MAS05133,Starter control: shut-off conditions 1-Drivetrain,not active,
IDE00417-MAS06857,Starter control: shut-off conditions 1-Speed,not active,
IDE00417-MAS09395,Starter control: shut-off conditions 1-RPM aborted starts,active,
IDE00417-MAS09396,Starter control: shut-off conditions 1-Engag. duration,not active,
IDE00417-MAS09397,Starter control: shut-off conditions 1-Engag. duration aborted starts,not active,
IDE00417-MAS09398,Starter control: shut-off conditions 1-Engag. duration panic start,not active,
IDE00417-MAS09399,Starter control: shut-off conditions 1-new errors,not active,
IDE00417-MAS09400,Starter control: shut-off conditions 1-manual start/error,not active,
IDE00417-MAS09401,Starter control: shut-off conditions 1-ignition,not active,
IDE00417-MAS09402,Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction,not active,
IDE00417-MAS09403,Starter control: shut-off conditions 1-Direct start function,not active,
IDE00417-MAS09404,Starter control: shut-off conditions 1-Engag. duration defrost.,not active,
IDE00417,Starter control: shut-off conditions 1,512,
IDE00420,Service regeneration: current duration,0, s
IDE00430,Particle filter: field regeneration request status,no request,
IDE00431,Particle filter: field regeneration lock status,8,
IDE00432,Particle filter: time since last regeneration,153, min
IDE00434,Particle filter: soot mass calculated,13.46, g
IDE00435,Particle filter: soot mass measured,1.76, g
IDE00436,Particle filter: kilometers since last regeneration,140.0,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,0, mg/stroke
IDE00474,Ambient air pressure,100, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,0.5, Nm
IDE00495,Calculated oil temperature,79.5, C
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,Open,
IDE00541,Acceleration,0.000, m/s
IDE00556,Outside air temperature,0, C
IDE00558,Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor),0.062 Lambda / 0.277 V,
IDE00583,Throttle valve specified value,100, %
IDE00584,Distance driven since erasing DTC memory,19423, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00589,Fuel pressure,300, kPa rel
IDE00590,Terminal 87 status,On,
IDE00594,Absolute intake pressure,100, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 ,
IDE00600,Conversion factors,,
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,255,
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Control Module 1,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00699,ESI: minimum oil level in service interval,0.0, mm
IDE00700,ESI: maximum oil level in service interval,0.0, mm
IDE00727,Test steps still to be performed,0,
IDE00784,Current test step,--no display--,
IDE00784-ENG124478,Current test step-Test_Program_Requested Action,0,
IDE00787,Cause for cancellation,0,
IDE01076-MAS00109,Time since ignition off-Hours,0, H
IDE01076-MAS00110,Time since ignition off-Minutes,12, min
IDE01076-MAS00111,Time since ignition off-Seconds,39, s
IDE01369,Intake manifold runner control (IMRC): offset closed,0.000, V
IDE01378,High fuel pressure: control deviation,197, bar
IDE01380,Pre-injection 3: activation start,0.00,
IDE01381,Pre-injection 3: activation duration,0, s
IDE01382,Post-injection 3: activation start,0.00,
IDE01383,Post-injection 3: activation duration,0, s
IDE01405-MAS05513,Status of starter activation-Bit 0,OK,
IDE01405-MAS05514,Status of starter activation-Bit 1,Before starter activation,
IDE01405-MAS05515,Status of starter activation-Bit 2,Before starter activation,
IDE01407,Particle filter: fuel consumption since last regeneration,10.46, l
IDE01410,Charge limit over-charge,50.00, g
IDE01671,Starter control: clutch switch,not pressed,
IDE01834,Battery voltage,12.304, V
IDE01880,Accelerator position 2,14, %
IDE01884,Camshaft adjustment intake bank 1: activation,0.00, %
IDE01922,Vehicle distance driven,19435, km
IDE02634,Lock time during deactivation,0, min
IDE02756,Number of manual engine starts,1168,
IDE02757,Number of automatic engine starts,223,
IDE03015,Compression test cylinder 1,0, /min
IDE03016,Compression test cylinder 2,0, /min
IDE03017,Compression test cylinder 3,0, /min
IDE03018,Compression test cylinder 4,0, /min
IDE03133,Heat circuit 1 for reduc. agent meter. system: act. curr.,0.000, A
IDE03134,Heat circuit 2 for reduc. agent meter. system: act. curr.,0.295, A
IDE03135,Sensor for reducing agent tank temperature: temperature,22.7, C
IDE03139,Reducing agent injector: resistance,0.000, Ohm
IDE03142,Remaining vehicle distance until reducing agent deficiency,6206.900, km
IDE03189-MAS04415,Number of prevented stop processes (statistics)-Ambient air pressure,1,
IDE03189-MAS04416,Number of prevented stop processes (statistics)-Sporadic function restriction,3,
IDE03189-MAS04417,Number of prevented stop processes (statistics)-Poor start detection,4,
IDE03189-MAS04590,Number of prevented stop processes (statistics)-Mixture adaptation,5,
IDE03189-MAS06089,Number of prevented stop processes (statistics)-Low brake pressure,2,
IDE03189-MAS06092,Number of prevented stop processes (statistics)-Regeneration,6,
IDE03189-ENG118032,Number of prevented stop processes (statistics)-brake_depression_day,0,
IDE03189-ENG118033,Number of prevented stop processes (statistics)-brake_depression_hour,0,
IDE03189-ENG118036,Number of prevented stop processes (statistics)-brake_depression_kilometer,0,
IDE03189-ENG118034,Number of prevented stop processes (statistics)-brake_depression_minute,0,
IDE03189-ENG118031,Number of prevented stop processes (statistics)-brake_depression_month,0,
IDE03189-ENG118029,Number of prevented stop processes (statistics)-brake_depression_prohibition_counter,0,
IDE03189-ENG118035,Number of prevented stop processes (statistics)-brake_depression_second,0,
IDE03189-ENG118030,Number of prevented stop processes (statistics)-brake_depression_year,0,
IDE03189-ENG118024,Number of prevented stop processes (statistics)-environment_air_density_day,0,
IDE03189-ENG118025,Number of prevented stop processes (statistics)-environment_air_density_hour,0,
IDE03189-ENG118028,Number of prevented stop processes (statistics)-environment_air_density_kilometer,0,
IDE03189-ENG118026,Number of prevented stop processes (statistics)-environment_air_density_minute,0,
IDE03189-ENG118023,Number of prevented stop processes (statistics)-environment_air_density_month,0,
IDE03189-ENG118021,Number of prevented stop processes (statistics)-environment_air_density_prohibition_counter,0,
IDE03189-ENG118027,Number of prevented stop processes (statistics)-environment_air_density_second,0,
IDE03189-ENG118022,Number of prevented stop processes (statistics)-environment_air_density_year,0,
IDE03189-ENG118056,Number of prevented stop processes (statistics)-mixture_adaption_day,0,
IDE03189-ENG118057,Number of prevented stop processes (statistics)-mixture_adaption_hour,0,
IDE03189-ENG118060,Number of prevented stop processes (statistics)-mixture_adaption_kilometer,0,
IDE03189-ENG118058,Number of prevented stop processes (statistics)-mixture_adaption_minute,0,
IDE03189-ENG118055,Number of prevented stop processes (statistics)-mixture_adaption_month,0,
IDE03189-ENG118053,Number of prevented stop processes (statistics)-mixture_adaption_prohibition_counter,0,
IDE03189-ENG118059,Number of prevented stop processes (statistics)-mixture_adaption_second,0,
IDE03189-ENG118054,Number of prevented stop processes (statistics)-mixture_adaption_year,0,
IDE03189-ENG118048,Number of prevented stop processes (statistics)-poor_crank_detection_day,0,
IDE03189-ENG118049,Number of prevented stop processes (statistics)-poor_crank_detection_hour,0,
IDE03189-ENG118052,Number of prevented stop processes (statistics)-poor_crank_detection_kilometer,0,
IDE03189-ENG118050,Number of prevented stop processes (statistics)-poor_crank_detection_minute,0,
IDE03189-ENG118047,Number of prevented stop processes (statistics)-poor_crank_detection_month,0,
IDE03189-ENG118045,Number of prevented stop processes (statistics)-poor_crank_detection_prohibition_counter,0,
IDE03189-ENG118051,Number of prevented stop processes (statistics)-poor_crank_detection_second,0,
IDE03189-ENG118046,Number of prevented stop processes (statistics)-poor_crank_detection_year,0,
IDE03189-ENG118064,Number of prevented stop processes (statistics)-regeneration_operation_day,10,
IDE03189-ENG118065,Number of prevented stop processes (statistics)-regeneration_operation_hour,20,
IDE03189-ENG118068,Number of prevented stop processes (statistics)-regeneration_operation_kilometer,18710,
IDE03189-ENG118066,Number of prevented stop processes (statistics)-regeneration_operation_minute,37,
IDE03189-ENG118063,Number of prevented stop processes (statistics)-regeneration_operation_month,5,
IDE03189-ENG118061,Number of prevented stop processes (statistics)-regeneration_operation_prohibition_counter,25,
IDE03189-ENG118067,Number of prevented stop processes (statistics)-regeneration_operation_second,26,
IDE03189-ENG118062,Number of prevented stop processes (statistics)-regeneration_operation_year,19,
IDE03189-ENG118040,Number of prevented stop processes (statistics)-sporadical_function_inhibition_day,0,
IDE03189-ENG118041,Number of prevented stop processes (statistics)-sporadical_function_inhibition_hour,0,
IDE03189-ENG118044,Number of prevented stop processes (statistics)-sporadical_function_inhibition_kilometer,0,
IDE03189-ENG118042,Number of prevented stop processes (statistics)-sporadical_function_inhibition_minute,0,
IDE03189-ENG118039,Number of prevented stop processes (statistics)-sporadical_function_inhibition_month,0,
IDE03189-ENG118037,Number of prevented stop processes (statistics)-sporadical_function_inhibition_prohibition_counter,0,
IDE03189-ENG118043,Number of prevented stop processes (statistics)-sporadical_function_inhibition_second,0,
IDE03189-ENG118038,Number of prevented stop processes (statistics)-sporadical_function_inhibition_year,0,
IDE03190-IDE04099,Number of requested start processes (statistics)-Reduction agent dosing,5,
IDE03190-MAS00077,Number of requested start processes (statistics)-Immobilizer,4,
IDE03190-MAS04369,Number of requested start processes (statistics)-Engine temperature too high,2,
IDE03190-MAS04370,Number of requested start processes (statistics)-Engine temperature too low,1,
IDE03190-MAS06089,Number of requested start processes (statistics)-Low brake pressure,3,
IDE03190-ENG118032,Number of requested start processes (statistics)-brake_depression_day,3,
IDE03190-ENG118033,Number of requested start processes (statistics)-brake_depression_hour,14,
IDE03190-ENG118036,Number of requested start processes (statistics)-brake_depression_kilometer,17467,
IDE03190-ENG118034,Number of requested start processes (statistics)-brake_depression_minute,41,
IDE03190-ENG118031,Number of requested start processes (statistics)-brake_depression_month,5,
IDE03190-ENG118029,Number of requested start processes (statistics)-brake_depression_prohibition_counter,1,
IDE03190-ENG118035,Number of requested start processes (statistics)-brake_depression_second,58,
IDE03190-ENG118030,Number of requested start processes (statistics)-brake_depression_year,19,
IDE03190-ENG118080,Number of requested start processes (statistics)-engine_temperature_too_high_day,0,
IDE03190-ENG118081,Number of requested start processes (statistics)-engine_temperature_too_high_hour,0,
IDE03190-ENG118084,Number of requested start processes (statistics)-engine_temperature_too_high_kilometer,0,
IDE03190-ENG118082,Number of requested start processes (statistics)-engine_temperature_too_high_minute,0,
IDE03190-ENG118079,Number of requested start processes (statistics)-engine_temperature_too_high_month,0,
IDE03190-ENG118077,Number of requested start processes (statistics)-engine_temperature_too_high_prohibition_counter,0,
IDE03190-ENG118083,Number of requested start processes (statistics)-engine_temperature_too_high_second,0,
IDE03190-ENG118078,Number of requested start processes (statistics)-engine_temperature_too_high_year,0,
IDE03190-ENG118072,Number of requested start processes (statistics)-engine_temperature_too_low_day,2,
IDE03190-ENG118073,Number of requested start processes (statistics)-engine_temperature_too_low_hour,19,
IDE03190-ENG118076,Number of requested start processes (statistics)-engine_temperature_too_low_kilometer,3998,
IDE03190-ENG118074,Number of requested start processes (statistics)-engine_temperature_too_low_minute,37,
IDE03190-ENG118071,Number of requested start processes (statistics)-engine_temperature_too_low_month,12,
IDE03190-ENG118069,Number of requested start processes (statistics)-engine_temperature_too_low_prohibition_counter,4,
IDE03190-ENG118075,Number of requested start processes (statistics)-engine_temperature_too_low_second,38,
IDE03190-ENG118070,Number of requested start processes (statistics)-engine_temperature_too_low_year,18,
IDE03190-ENG118088,Number of requested start processes (statistics)-immobiliser_day,0,
IDE03190-ENG118089,Number of requested start processes (statistics)-immobiliser_hour,0,
IDE03190-ENG118092,Number of requested start processes (statistics)-immobiliser_kilometer,0,
IDE03190-ENG118090,Number of requested start processes (statistics)-immobiliser_minute,0,
IDE03190-ENG118087,Number of requested start processes (statistics)-immobiliser_month,0,
IDE03190-ENG118085,Number of requested start processes (statistics)-immobiliser_prohibition_counter,0,
IDE03190-ENG118091,Number of requested start processes (statistics)-immobiliser_second,0,
IDE03190-ENG118086,Number of requested start processes (statistics)-immobiliser_year,0,
IDE03190-ENG122348,Number of requested start processes (statistics)-Nox_control_system_day,0,
IDE03190-ENG122349,Number of requested start processes (statistics)-Nox_control_system_hour,0,
IDE03190-ENG122352,Number of requested start processes (statistics)-Nox_control_system_kilometer,0,
IDE03190-ENG122350,Number of requested start processes (statistics)-Nox_control_system_minute,0,
IDE03190-ENG122347,Number of requested start processes (statistics)-Nox_control_system_month,0,
IDE03190-ENG122345,Number of requested start processes (statistics)-Nox_control_system_prohibition_counter,0,
IDE03190-ENG122351,Number of requested start processes (statistics)-Nox_control_system_second,0,
IDE03190-ENG122346,Number of requested start processes (statistics)-Nox_control_system_year,0,
IDE03235,Neutral position sensor: current transmission angle,0.00,
IDE03236,Neutral position sensor: adapted transmission angle,0.00,
IDE03242,Injector for reduction agent: current holding phase,0.000, A
IDE03243,Reducing agent injector: current saturation phase,0.000, A
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03248,Pressure control valve adaptation factor,0.025,
IDE03288,Heating circuit 1 for reducing agent metering: activation,not active,
IDE03289,Heating circuit 2 for reducing agent metering: activation,not active,
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03383,Exhaust mass flow of EGR,0.0, kg/h
IDE03387,Duration of overtemperature at the reduction agent injector,96, s
IDE03583-MAS04416,Engine shut-down overrides-Sporadic function restriction,OFF,
IDE03583-MAS04417,Engine shut-down overrides-Poor start detection,OFF,
IDE03583-MAS04590,Engine shut-down overrides-Mixture adaptation,OFF,
IDE03583-MAS06089,Engine shut-down overrides-Low brake pressure,OFF,
IDE03583-MAS06602,Engine shut-down overrides-Engine temperature,OFF,
IDE03583-MAS06603,Engine shut-down overrides-Ambient pressure,OFF,
IDE03583-MAS06604,Engine shut-down overrides-Start-stop sensor system,OFF,
IDE03583-MAS06605,Engine shut-down overrides-Regeneration operation,OFF,
IDE03584-MAS04369,Engine starting requirements-Engine temperature too high,OFF,
IDE03584-MAS04370,Engine starting requirements-Engine temperature too low,OFF,
IDE03584-MAS06606,Engine starting requirements-Brake under pressure too low,OFF,
IDE03584-MAS06607,Engine starting requirements-SCR System requires restart,OFF,
IDE03584,Engine starting requirements,OFF,
IDE03584-ENG23258,Engine starting requirements-Reserved_5,OFF,
IDE03584-ENG23116,Engine starting requirements-Reserved_6,OFF,
IDE03584-ENG23184,Engine starting requirements-Reserved_7,OFF,
IDE03585,System status for the start/stop function master,active: stop releases participant present,
IDE03586-ENG118093,Starting requirements for active participants-Active_Member_1,OFF,
IDE03586-ENG118102,Starting requirements for active participants-Active_Member_10,OFF,
IDE03586-ENG118103,Starting requirements for active participants-Active_Member_11,OFF,
IDE03586-ENG118104,Starting requirements for active participants-Active_Member_12,OFF,
IDE03586-ENG118105,Starting requirements for active participants-Active_Member_13,OFF,
IDE03586-ENG118106,Starting requirements for active participants-Active_Member_14,OFF,
IDE03586-ENG118107,Starting requirements for active participants-Active_Member_15,OFF,
IDE03586-ENG118108,Starting requirements for active participants-Active_Member_16,OFF,
IDE03586-ENG118094,Starting requirements for active participants-Active_Member_2,OFF,
IDE03586-ENG118095,Starting requirements for active participants-Active_Member_3,OFF,
IDE03586-ENG118096,Starting requirements for active participants-Active_Member_4,OFF,
IDE03586-ENG118097,Starting requirements for active participants-Active_Member_5,OFF,
IDE03586-ENG118098,Starting requirements for active participants-Active_Member_6,OFF,
IDE03586-ENG118099,Starting requirements for active participants-Active_Member_7,OFF,
IDE03586-ENG118100,Starting requirements for active participants-Active_Member_8,OFF,
IDE03586-ENG118101,Starting requirements for active participants-Active_Member_9,OFF,
IDE03587-ENG118093,Stop overrides for active participants-Active_Member_1,OFF,
IDE03587-ENG118102,Stop overrides for active participants-Active_Member_10,OFF,
IDE03587-ENG118103,Stop overrides for active participants-Active_Member_11,OFF,
IDE03587-ENG118104,Stop overrides for active participants-Active_Member_12,OFF,
IDE03587-ENG118105,Stop overrides for active participants-Active_Member_13,OFF,
IDE03587-ENG118106,Stop overrides for active participants-Active_Member_14,OFF,
IDE03587-ENG118107,Stop overrides for active participants-Active_Member_15,OFF,
IDE03587-ENG118108,Stop overrides for active participants-Active_Member_16,OFF,
IDE03587-ENG118094,Stop overrides for active participants-Active_Member_2,OFF,
IDE03587-ENG118095,Stop overrides for active participants-Active_Member_3,On,
IDE03587-ENG118096,Stop overrides for active participants-Active_Member_4,OFF,
IDE03587-ENG118097,Stop overrides for active participants-Active_Member_5,OFF,
IDE03587-ENG118098,Stop overrides for active participants-Active_Member_6,OFF,
IDE03587-ENG118099,Stop overrides for active participants-Active_Member_7,OFF,
IDE03587-ENG118100,Stop overrides for active participants-Active_Member_8,OFF,
IDE03587-ENG118101,Stop overrides for active participants-Active_Member_9,OFF,
IDE03588-ENG118093,System malfunctions for active participants start/stop-Active_Member_1,OFF,
IDE03588-ENG118102,System malfunctions for active participants start/stop-Active_Member_10,OFF,
IDE03588-ENG118103,System malfunctions for active participants start/stop-Active_Member_11,OFF,
IDE03588-ENG118104,System malfunctions for active participants start/stop-Active_Member_12,OFF,
IDE03588-ENG118105,System malfunctions for active participants start/stop-Active_Member_13,OFF,
IDE03588-ENG118106,System malfunctions for active participants start/stop-Active_Member_14,OFF,
IDE03588-ENG118107,System malfunctions for active participants start/stop-Active_Member_15,OFF,
IDE03588-ENG118108,System malfunctions for active participants start/stop-Active_Member_16,OFF,
IDE03588-ENG118094,System malfunctions for active participants start/stop-Active_Member_2,OFF,
IDE03588-ENG118095,System malfunctions for active participants start/stop-Active_Member_3,OFF,
IDE03588-ENG118096,System malfunctions for active participants start/stop-Active_Member_4,OFF,
IDE03588-ENG118097,System malfunctions for active participants start/stop-Active_Member_5,OFF,
IDE03588-ENG118098,System malfunctions for active participants start/stop-Active_Member_6,OFF,
IDE03588-ENG118099,System malfunctions for active participants start/stop-Active_Member_7,OFF,
IDE03588-ENG118100,System malfunctions for active participants start/stop-Active_Member_8,OFF,
IDE03588-ENG118101,System malfunctions for active participants start/stop-Active_Member_9,OFF,
IDE03589-ENG118109,Error status for start-stop related sensors-Sensor_1,OFF,
IDE03589-ENG118110,Error status for start-stop related sensors-Sensor_2,On,
IDE03589-ENG118111,Error status for start-stop related sensors-Sensor_3,On,
IDE03589-ENG118112,Error status for start-stop related sensors-Sensor_4,OFF,
IDE03589-ENG118113,Error status for start-stop related sensors-Sensor_5,OFF,
IDE03589-ENG118114,Error status for start-stop related sensors-Sensor_6,OFF,
IDE03589-ENG118115,Error status for start-stop related sensors-Sensor_7,OFF,
IDE03589-ENG118116,Error status for start-stop related sensors-Sensor_8,OFF,
IDE03712,Engine diagnostic status in curr driving cycle (end-of-line),4289686245,
IDE03767,Engine status,Stop,
IDE04003,Charge air temperature sensor,B1S1/B1S2:51/51 C /  C,
IDE04007,Start of injection,0.00,
IDE04008,Fuel consumption per hour,0.00, L/h
IDE04010,Engine torque: normalized,0, %
IDE04011,Nominal torque,0, Nm
IDE04015,exh.gas recirc.,EGR A:1/1/0 % / EGR B:---/---/--- %,
IDE04035,exh.gas recirc. temperature,EGRTemp 11/12:54/51 C / EGRTemp 21/22:---/--- C,
IDE04083,Coolant temperatures,ECT 1:77 C / ECT 2:45 C,
IDE04090,Exhaust temperature bank 1,S1/S2/S3/S4:  / 88/98/84/--- C,
IDE04098,NOX Sensor,NOx11:65535 ppm / NOx21:--- ,
IDE04099,Reduction agent dosing,ReAg Rate/Demand:0/0 L/h / Reag Tnk Lvl:75 %,
IDE04269,Intake manifold runner actuator: activation,5.00, %
IDE04270-IDE11376,Actuator for intake manifold runner control: status-Recognition of actuator closed or jammed open 2,not active,
IDE04270-MAS09413,Actuator for intake manifold runner control: status-open mech. stop approached,not active,
IDE04270-MAS09414,Actuator for intake manifold runner control: status-closed mech. stop approached,not active,
IDE04270-MAS09415,Actuator for intake manifold runner control: status-Adaptations met for offset on the mechan. stops,not active,
IDE04270-MAS09416,Actuator for intake manifold runner control: status-Adaptation active,not active,
IDE04270-MAS09417,Actuator for intake manifold runner control: status-open mech. stop adapted properly in current drive cycle,not active,
IDE04270-MAS09418,Actuator for intake manifold runner control: status-closed mech. stop adapted properly in current drive cycle,not active,
IDE04270-MAS09419,Actuator for intake manifold runner control: status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE04270-MAS09420,Actuator for intake manifold runner control: status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE04270-MAS09421,Actuator for intake manifold runner control: status-Ctrl. dev. detected after after breakaway function,not active,
IDE04270-MAS09422,Actuator for intake manifold runner control: status-Valve/actuator active: eng. running,not active,
IDE04270-MAS09423,Actuator for intake manifold runner control: status-Valve/actuator active: eng. off,not active,
IDE04270-MAS09424,Actuator for intake manifold runner control: status-Breakaway function active,not active,
IDE04270-MAS09425,Actuator for intake manifold runner control: status-Effective current limit. limited at controller output,active,
IDE04270-MAS09426,Actuator for intake manifold runner control: status-Actuator in shut-off position,active,
IDE04270-MAS09427,Actuator for intake manifold runner control: status-Breakaway function unsuccessful: actuator control deactivated,active,
IDE04270-MAS09428,Actuator for intake manifold runner control: status-Error in limit setter: position control is deactivated,not active,
IDE04270-MAS09429,Actuator for intake manifold runner control: status-Breakaway function is lowered,not active,
IDE04270-MAS09433,Actuator for intake manifold runner control: status-higher voltage should press valve closed when at mech. stop,not active,
IDE04270-MAS09434,Actuator for intake manifold runner control: status-Positioner detected as closed or jammed in open pos.,not active,
IDE04270-MAS09435,Actuator for intake manifold runner control: status-Reset adaptation values,not active,
IDE04270-MAS09436,Actuator for intake manifold runner control: status-Ambient air temperature permits adaptation,active,
IDE04270-MAS09437,Actuator for intake manifold runner control: status-Exh. gas temp. permits adaptation,active,
IDE04270-MAS09438,Actuator for intake manifold runner control: status-Engine temp. permits adaptation,active,
IDE04270-MAS09439,Actuator for intake manifold runner control: status-Battery voltage permits adaptation,active,
IDE04270-MAS09440,Actuator for intake manifold runner control: status-Ambient press. permits adaptation,not active,
IDE04270-MAS09441,Actuator for intake manifold runner control: status-Eng. run. time permits adaptation,not active,
IDE04270-MAS09442,Actuator for intake manifold runner control: status-Brake function active,not active,
IDE04270,Actuator for intake manifold runner control: status,251772928,
IDE04271,Intake manif runner actuator: uncond volt actual value,4.525, V
IDE04272,Counter for regeneration time of diesel particle filter,0, s
IDE04302-IDE11376,Bypass valve for high press turbocharger turbine inlet: status-Recognition of actuator closed or jammed open 2,not active,
IDE04302-MAS09413,Bypass valve for high press turbocharger turbine inlet: status-open mech. stop approached,not active,
IDE04302-MAS09414,Bypass valve for high press turbocharger turbine inlet: status-closed mech. stop approached,not active,
IDE04302-MAS09415,Bypass valve for high press turbocharger turbine inlet: status-Adaptations met for offset on the mechan. stops,not active,
IDE04302-MAS09416,Bypass valve for high press turbocharger turbine inlet: status-Adaptation active,not active,
IDE04302-MAS09417,Bypass valve for high press turbocharger turbine inlet: status-open mech. stop adapted properly in current drive cycle,not active,
IDE04302-MAS09418,Bypass valve for high press turbocharger turbine inlet: status-closed mech. stop adapted properly in current drive cycle,not active,
IDE04302-MAS09419,Bypass valve for high press turbocharger turbine inlet: status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE04302-MAS09420,Bypass valve for high press turbocharger turbine inlet: status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE04302-MAS09421,Bypass valve for high press turbocharger turbine inlet: status-Ctrl. dev. detected after after breakaway function,not active,
IDE04302-MAS09422,Bypass valve for high press turbocharger turbine inlet: status-Valve/actuator active: eng. running,not active,
IDE04302-MAS09423,Bypass valve for high press turbocharger turbine inlet: status-Valve/actuator active: eng. off,not active,
IDE04302-MAS09424,Bypass valve for high press turbocharger turbine inlet: status-Breakaway function active,not active,
IDE04302-MAS09425,Bypass valve for high press turbocharger turbine inlet: status-Effective current limit. limited at controller output,not active,
IDE04302-MAS09426,Bypass valve for high press turbocharger turbine inlet: status-Actuator in shut-off position,not active,
IDE04302-MAS09427,Bypass valve for high press turbocharger turbine inlet: status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE04302-MAS09428,Bypass valve for high press turbocharger turbine inlet: status-Error in limit setter: position control is deactivated,not active,
IDE04302-MAS09429,Bypass valve for high press turbocharger turbine inlet: status-Breakaway function is lowered,not active,
IDE04302-MAS09433,Bypass valve for high press turbocharger turbine inlet: status-higher voltage should press valve closed when at mech. stop,not active,
IDE04302-MAS09434,Bypass valve for high press turbocharger turbine inlet: status-Positioner detected as closed or jammed in open pos.,not active,
IDE04302-MAS09435,Bypass valve for high press turbocharger turbine inlet: status-Reset adaptation values,not active,
IDE04302-MAS09436,Bypass valve for high press turbocharger turbine inlet: status-Ambient air temperature permits adaptation,not active,
IDE04302-MAS09437,Bypass valve for high press turbocharger turbine inlet: status-Exh. gas temp. permits adaptation,not active,
IDE04302-MAS09438,Bypass valve for high press turbocharger turbine inlet: status-Engine temp. permits adaptation,not active,
IDE04302-MAS09439,Bypass valve for high press turbocharger turbine inlet: status-Battery voltage permits adaptation,not active,
IDE04302-MAS09440,Bypass valve for high press turbocharger turbine inlet: status-Ambient press. permits adaptation,not active,
IDE04302-MAS09441,Bypass valve for high press turbocharger turbine inlet: status-Eng. run. time permits adaptation,not active,
IDE04302-MAS09442,Bypass valve for high press turbocharger turbine inlet: status-Brake function active,not active,
IDE04302,Bypass valve for high press turbocharger turbine inlet: status,0,
IDE04468,Air mass at air mass meter 1,3.6, kg/h
IDE04623,Kick-down threshold,3.518, V
IDE04651,Torque request: A/C compressor,0.5, Nm
IDE04652,Exhaust gas jet volume in particle filter,3.8, m/h
IDE04653,Simulated particle filter surface temperature,104.2, C
IDE04654,CAN status - engine control module,0,
IDE04685,Setpoint generation interior torque,0.0, Nm
IDE04694,Engine diagnostic status 2 in curr driving cycle (end-of-line),4290733791,
IDE04713,Active brake system status,Not operated,
IDE04937,Sensor for engine block temperature: raw value,77.0, C
IDE05138,Shut-off timer: last engine shut-off time,760, s
IDE05139,Shut-off timer: last ECM after-run time,68, s
IDE05356,Calculated NOx concentration behind turbocharger,0, ppm
IDE05386,Exhaust model temperature 0,54.0, C
IDE05387,Exhaust model temperature 1,71.7, C
IDE05388,Exhaust model temperature 2,33.0, C
IDE05389,Exhaust model temperature 3,0.0, C
IDE05390,Exhaust model temperature 4,0.0, C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000000,
IDE05493,Air cleaner degree of soiling,0.00, %
IDE05494-MAS06902,Air cleaner full/empty detection-Full,No,
IDE05494,Air cleaner full/empty detection,0,
IDE05495-MAS05768,Suspicion of air cleaner icing-frosted,Yes,
IDE05495,Suspicion of air cleaner icing,1,
IDE05496-MAS03758,Air cleaner defrosted and cleared after suspicion of icing-Not Used,No,
IDE05496,Air cleaner defrosted and cleared after suspicion of icing,0,
IDE05625,Speed regulation requested torque,-3276.8, Nm
IDE05626,Calculated temperature at reduction agent injection valve,93.7, C
IDE05632,Fuel pressure regulator valve actual value,99.8, mA
IDE05633,Valve for fuel metering: feedback value measured,99.9, mA
IDE05694,Environmental pressure sensor gross voltage,4.046, V
IDE05861,DPF statistics: number of interrupted regenerations,0,
IDE05877,DPF statistics: regen time slice not poss in charge cycle,0.00000,
IDE05883,DPF statistics: regeneration time,0, s
IDE05901,DPF statistics: route in charge cycle,128000, m
IDE05903,DPF statistics: avg driv cycle time during charge cycle,0, s
IDE05908,DPF statistics: regeneration request,0,
IDE05910,DPF statistics: exhaust temperature regulation average value,0.00000,
IDE05918,DPF statistics: regeneration blocked status,0,
IDE05922,DPF statistics: error status,0,
IDE06059,Particulate filter: oil ash mass,7.70, g
IDE06060,Particulate filter ash load limit,110.00, g
IDE06216,DPF Statistics: average val.: exhaust temp. ctrl before DPF,-2.000,
IDE06386,Oil level: static measurement,72, mm
IDE06387,Oil level: last valid dynamic value,0, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition met,
IDE06389,Oil level: maximum value,0, mm
IDE06390,Oil level: minimum value,0, mm
IDE06567,Start-stop function deactivation frequency counter,1391,
IDE06568,Stop prevention by driver frequency counter,3477,
IDE06569,Vehicle stopped frequency counter,5577,
IDE06610,Vehicle standstill with stop frequency counter,285,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,No,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,CCS operating unit,
IDE06708-MAS00322,Cruise control switch actuation-Engaged OFF,No,
IDE06708-MAS00323,Cruise control switch actuation-Decelerate tap,No,
IDE06708-MAS00324,Cruise control switch actuation-Accelerate tap,No,
IDE06708-MAS00325,Cruise control switch actuation-Setting,No,
IDE06708-MAS00326,Cruise control switch actuation-Activation,No,
IDE06708-MAS14965,Cruise control switch actuation-Plausibility check of main switch,Yes,
IDE06708-MAS14966,Cruise control switch actuation-Tip acceleration/deceleration second level,No,
IDE06708-MAS14967,Cruise control switch actuation-Operating error,No,
IDE06708-MAS14972,Cruise control switch actuation-Hardware signal main switch,Yes,
IDE06708-MAS14973,Cruise control switch actuation-Operating lever: Implausible coding,No,
IDE06708-MAS14974,Cruise control switch actuation-Limiter button pressed,No,
IDE06708-MAS14975,Cruise control switch actuation-Main switch off via CAN,No,
IDE06708-MAS14976,Cruise control switch actuation-variance adapted successfully,Yes,
IDE06709,ACC variants (coding),CCS,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06866,Range limit cancellation due to red. agent metering sys. fault,0,
IDE07051,Engaged gear: raw signal,0,
IDE07084,Differential pressure ratio: low-pressure EGR,0.000,
IDE07086,Exhaust mass flow of low-pressure EGR: calculated,0.0, kg/h
IDE07233-MAS07412,Bit string for status of oil level-Oil level OK,not active,
IDE07233-MAS07413,Bit string for status of oil level-Check oil level,not active,
IDE07233-MAS07414,Bit string for status of oil level-Oil level monitoring,not active,
IDE07233-MAS07415,Bit string for status of oil level-Top up oil,not active,
IDE07233-MAS07416,Bit string for status of oil level-Top up oil immediately,not active,
IDE07233-MAS07417,Bit string for status of oil level-Reduce oil level,not active,
IDE07233-MAS07418,Bit string for status of oil level-Oil level not available,not active,
IDE07233-MAS07419,Bit string for status of oil level-Measmnt. not possible while engine running,not active,
IDE07233-MAS07420,Bit string for status of oil level-Engine not at oper. temp.,not active,
IDE07233-MAS07421,Bit string for status of oil level-Vehicle not in level position,not active,
IDE07233-MAS07422,Bit string for status of oil level-Oil level display,not active,
IDE07233-MAS07423,Bit string for status of oil level-Sensor faulty,not active,
IDE07234,Status bid for valid static oil level,Condition met,
IDE07235,Status bid for dynamic oil level,Condition not met,
IDE07374-MAS05852,Cylinder mass flow: act. value calculated-Mass flow,0.0, kg/h
IDE07375,Charge pressure before throttle valve: calculated actual value,1.005, bar
IDE07376,Intake manifold pressure: act. value calculated,1.005, bar
IDE07377,Exhaust recirculation valve 1 bank 1: mass flow - nominal value,0.0, kg/h
IDE07379,Cylinder charge: spec. value,521.0, mg/stroke
IDE07380,NOx catalyst accumulator: sulfur charge: act. value calculated,0.00, g
IDE07381,Cylinder charge: act. value calculated,0.0, mg/stroke
IDE07382,Exhaust recirculation valve 2 bank 1: mass flow - nominal value,0.0, kg/h
IDE07384,Throttle valv.adapter 1 bank 1: output pressure - nominal value,0.000, bar
IDE07385,Exhaust recircul.valve 1 bank 1: intake pressur.- actual value,1.006, bar
IDE07386,Total HFM air mass flow: calculated,3.6, kg/h
IDE07528-MAS12283,Coordinator releases for DPF regeneration-Components and systems fault-free,Condition met,
IDE07528-MAS12284,Coordinator releases for DPF regeneration-Tank level > Min. limit,Condition met,
IDE07528-MAS12285,Coordinator releases for DPF regeneration-Time after engine start: start driving > Min. the limit,Condition met,
IDE07528-MAS12286,Coordinator releases for DPF regeneration-Min. limit < driving speed < max. limit,Condition met,
IDE07528-MAS12287,Coordinator releases for DPF regeneration-Power connection,Condition met,
IDE07528-MAS12288,Coordinator releases for DPF regeneration-Lowest gear: no gear shifting,Condition met,
IDE07528-MAS12289,Coordinator releases for DPF regeneration-Oxygen sensor before NSC operational and fault-free,Condition met,
IDE07528-MAS12290,Coordinator releases for DPF regeneration-Oxygen sensor after NSC operational and fault-free,Condition met,
IDE07528-MAS12291,Coordinator releases for DPF regeneration-Ambient pressure > Min. limit,Condition met,
IDE07528-MAS12292,Coordinator releases for DPF regeneration-Min. limit < ambient temperature < max. limit,Condition met,
IDE07528-MAS12293,Coordinator releases for DPF regeneration-Control module temp. < Max. limit,Condition met,
IDE07528-MAS12294,Coordinator releases for DPF regeneration-Fuel temp. < Max. limit,Condition met,
IDE07528-MAS12295,Coordinator releases for DPF regeneration-DPF fault-free,Condition met,
IDE07528-MAS12296,Coordinator releases for DPF regeneration-Metering release for SCR,Condition met,
IDE07528-MAS12297,Coordinator releases for DPF regeneration-Smoke limit inactive,Condition met,
IDE07528-MAS12298,Coordinator releases for DPF regeneration-Soot mass < Max. limit_1,Condition met,
IDE07528-MAS12299,Coordinator releases for DPF regeneration-Soot mass < Max. limit_2,Condition met,
IDE07528-MAS12300,Coordinator releases for DPF regeneration-Min. limit < engine speed < max. limit,Condition not met,
IDE07528-MAS12301,Coordinator releases for DPF regeneration-Water quantity in charge air cooler < Max. limit,Condition met,
IDE07528-MAS12302,Coordinator releases for DPF regeneration-Internal torque < Max. limit,Condition met,
IDE07528-MAS12303,Coordinator releases for DPF regeneration-Internal torque > Min. limit,Condition met,
IDE07528-MAS12304,Coordinator releases for DPF regeneration-Min. limit < internal torque < max. limit,Condition met,
IDE07528-MAS12305,Coordinator releases for DPF regeneration-Dynamic internal torque < Max. limit,Condition met,
IDE07528-MAS12306,Coordinator releases for DPF regeneration-Positive control deviation motor filling < Max. limit,Condition met,
IDE07528-MAS12307,Coordinator releases for DPF regeneration-Negative control deviation motor filling > Min. limit,Condition met,
IDE07528-MAS12308,Coordinator releases for DPF regeneration-Min. limit < temperature after charge air cooler < max. limit,Condition met,
IDE07528-MAS12309,Coordinator releases for DPF regeneration-Min. limit < engine temperature < max. limit,Condition met,
IDE07528-MAS12310,Coordinator releases for DPF regeneration-Min. limit < combustion chamber temp. < max. limit,Condition met,
IDE07528-MAS12311,Coordinator releases for DPF regeneration-Combustion chamber temp. < Max. limit,Condition met,
IDE07528-MAS12312,Coordinator releases for DPF regeneration-Temperature before turbine < Max. limit,Condition met,
IDE07528-MAS12313,Coordinator releases for DPF regeneration-Temperature after DPF < Max. limit,Condition met,
IDE07528-MAS12314,Coordinator releases for DPF regeneration-Temperature after oxi cat. < Max. limit,Condition met,
IDE07528-MAS12315,Coordinator releases for DPF regeneration-Temperature after oxi cat. < Min. limit,Condition met,
IDE07528-MAS12316,Coordinator releases for DPF regeneration-NSC temperature < Max. limit,Condition met,
IDE07528-MAS12317,Coordinator releases for DPF regeneration-NSC temperature < Min. limit,Condition met,
IDE07528-MAS12318,Coordinator releases for DPF regeneration-Virtual temperature,Condition met,
IDE07528-MAS12611,Coordinator releases for DPF regeneration-Value,4294967295,
IDE07528,Coordinator releases for DPF regeneration,4294967287,
IDE07529-MAS12283,Coordinator releases: standard-Components and systems fault-free,Condition not met,
IDE07529-MAS12284,Coordinator releases: standard-Tank level > Min. limit,Condition not met,
IDE07529-MAS12285,Coordinator releases: standard-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07529-MAS12286,Coordinator releases: standard-Min. limit < driving speed < max. limit,Condition not met,
IDE07529-MAS12287,Coordinator releases: standard-Power connection,Condition not met,
IDE07529-MAS12288,Coordinator releases: standard-Lowest gear: no gear shifting,Condition not met,
IDE07529-MAS12289,Coordinator releases: standard-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07529-MAS12290,Coordinator releases: standard-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07529-MAS12291,Coordinator releases: standard-Ambient pressure > Min. limit,Condition not met,
IDE07529-MAS12292,Coordinator releases: standard-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07529-MAS12293,Coordinator releases: standard-Control module temp. < Max. limit,Condition not met,
IDE07529-MAS12294,Coordinator releases: standard-Fuel temp. < Max. limit,Condition not met,
IDE07529-MAS12295,Coordinator releases: standard-DPF fault-free,Condition not met,
IDE07529-MAS12296,Coordinator releases: standard-Metering release for SCR,Condition not met,
IDE07529-MAS12297,Coordinator releases: standard-Smoke limit inactive,Condition not met,
IDE07529-MAS12298,Coordinator releases: standard-Soot mass < Max. limit_1,Condition not met,
IDE07529-MAS12299,Coordinator releases: standard-Soot mass < Max. limit_2,Condition not met,
IDE07529-MAS12300,Coordinator releases: standard-Min. limit < engine speed < max. limit,Condition not met,
IDE07529-MAS12301,Coordinator releases: standard-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07529-MAS12302,Coordinator releases: standard-Internal torque < Max. limit,Condition not met,
IDE07529-MAS12303,Coordinator releases: standard-Internal torque > Min. limit,Condition not met,
IDE07529-MAS12304,Coordinator releases: standard-Min. limit < internal torque < max. limit,Condition not met,
IDE07529-MAS12305,Coordinator releases: standard-Dynamic internal torque < Max. limit,Condition not met,
IDE07529-MAS12306,Coordinator releases: standard-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07529-MAS12307,Coordinator releases: standard-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07529-MAS12308,Coordinator releases: standard-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07529-MAS12309,Coordinator releases: standard-Min. limit < engine temperature < max. limit,Condition not met,
IDE07529-MAS12310,Coordinator releases: standard-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07529-MAS12311,Coordinator releases: standard-Combustion chamber temp. < Max. limit,Condition not met,
IDE07529-MAS12312,Coordinator releases: standard-Temperature before turbine < Max. limit,Condition not met,
IDE07529-MAS12313,Coordinator releases: standard-Temperature after DPF < Max. limit,Condition not met,
IDE07529-MAS12314,Coordinator releases: standard-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07529-MAS12315,Coordinator releases: standard-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07529-MAS12316,Coordinator releases: standard-NSC temperature < Max. limit,Condition not met,
IDE07529-MAS12317,Coordinator releases: standard-NSC temperature < Min. limit,Condition not met,
IDE07529-MAS12318,Coordinator releases: standard-Virtual temperature,Condition not met,
IDE07529-MAS12611,Coordinator releases: standard-Value,0,
IDE07529,Coordinator releases: standard,0,
IDE07530-MAS12283,Coordinator releases for NOx reduction-Components and systems fault-free,Condition not met,
IDE07530-MAS12284,Coordinator releases for NOx reduction-Tank level > Min. limit,Condition not met,
IDE07530-MAS12285,Coordinator releases for NOx reduction-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07530-MAS12286,Coordinator releases for NOx reduction-Min. limit < driving speed < max. limit,Condition not met,
IDE07530-MAS12287,Coordinator releases for NOx reduction-Power connection,Condition not met,
IDE07530-MAS12288,Coordinator releases for NOx reduction-Lowest gear: no gear shifting,Condition not met,
IDE07530-MAS12289,Coordinator releases for NOx reduction-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07530-MAS12290,Coordinator releases for NOx reduction-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07530-MAS12291,Coordinator releases for NOx reduction-Ambient pressure > Min. limit,Condition not met,
IDE07530-MAS12292,Coordinator releases for NOx reduction-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07530-MAS12293,Coordinator releases for NOx reduction-Control module temp. < Max. limit,Condition not met,
IDE07530-MAS12294,Coordinator releases for NOx reduction-Fuel temp. < Max. limit,Condition not met,
IDE07530-MAS12295,Coordinator releases for NOx reduction-DPF fault-free,Condition not met,
IDE07530-MAS12296,Coordinator releases for NOx reduction-Metering release for SCR,Condition not met,
IDE07530-MAS12297,Coordinator releases for NOx reduction-Smoke limit inactive,Condition not met,
IDE07530-MAS12298,Coordinator releases for NOx reduction-Soot mass < Max. limit_1,Condition not met,
IDE07530-MAS12299,Coordinator releases for NOx reduction-Soot mass < Max. limit_2,Condition not met,
IDE07530-MAS12300,Coordinator releases for NOx reduction-Min. limit < engine speed < max. limit,Condition not met,
IDE07530-MAS12301,Coordinator releases for NOx reduction-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07530-MAS12302,Coordinator releases for NOx reduction-Internal torque < Max. limit,Condition not met,
IDE07530-MAS12303,Coordinator releases for NOx reduction-Internal torque > Min. limit,Condition not met,
IDE07530-MAS12304,Coordinator releases for NOx reduction-Min. limit < internal torque < max. limit,Condition not met,
IDE07530-MAS12305,Coordinator releases for NOx reduction-Dynamic internal torque < Max. limit,Condition not met,
IDE07530-MAS12306,Coordinator releases for NOx reduction-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07530-MAS12307,Coordinator releases for NOx reduction-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07530-MAS12308,Coordinator releases for NOx reduction-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07530-MAS12309,Coordinator releases for NOx reduction-Min. limit < engine temperature < max. limit,Condition not met,
IDE07530-MAS12310,Coordinator releases for NOx reduction-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07530-MAS12311,Coordinator releases for NOx reduction-Combustion chamber temp. < Max. limit,Condition not met,
IDE07530-MAS12312,Coordinator releases for NOx reduction-Temperature before turbine < Max. limit,Condition not met,
IDE07530-MAS12313,Coordinator releases for NOx reduction-Temperature after DPF < Max. limit,Condition not met,
IDE07530-MAS12314,Coordinator releases for NOx reduction-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07530-MAS12315,Coordinator releases for NOx reduction-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07530-MAS12316,Coordinator releases for NOx reduction-NSC temperature < Max. limit,Condition not met,
IDE07530-MAS12317,Coordinator releases for NOx reduction-NSC temperature < Min. limit,Condition not met,
IDE07530-MAS12318,Coordinator releases for NOx reduction-Virtual temperature,Condition not met,
IDE07530-MAS12611,Coordinator releases for NOx reduction-Value,0,
IDE07530,Coordinator releases for NOx reduction,0,
IDE07531-MAS12283,Coordinator releases: sulfur removal-Components and systems fault-free,Condition not met,
IDE07531-MAS12284,Coordinator releases: sulfur removal-Tank level > Min. limit,Condition not met,
IDE07531-MAS12285,Coordinator releases: sulfur removal-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07531-MAS12286,Coordinator releases: sulfur removal-Min. limit < driving speed < max. limit,Condition not met,
IDE07531-MAS12287,Coordinator releases: sulfur removal-Power connection,Condition not met,
IDE07531-MAS12288,Coordinator releases: sulfur removal-Lowest gear: no gear shifting,Condition not met,
IDE07531-MAS12289,Coordinator releases: sulfur removal-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07531-MAS12290,Coordinator releases: sulfur removal-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07531-MAS12291,Coordinator releases: sulfur removal-Ambient pressure > Min. limit,Condition not met,
IDE07531-MAS12292,Coordinator releases: sulfur removal-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07531-MAS12293,Coordinator releases: sulfur removal-Control module temp. < Max. limit,Condition not met,
IDE07531-MAS12294,Coordinator releases: sulfur removal-Fuel temp. < Max. limit,Condition not met,
IDE07531-MAS12295,Coordinator releases: sulfur removal-DPF fault-free,Condition not met,
IDE07531-MAS12296,Coordinator releases: sulfur removal-Metering release for SCR,Condition not met,
IDE07531-MAS12297,Coordinator releases: sulfur removal-Smoke limit inactive,Condition not met,
IDE07531-MAS12298,Coordinator releases: sulfur removal-Soot mass < Max. limit_1,Condition not met,
IDE07531-MAS12299,Coordinator releases: sulfur removal-Soot mass < Max. limit_2,Condition not met,
IDE07531-MAS12300,Coordinator releases: sulfur removal-Min. limit < engine speed < max. limit,Condition not met,
IDE07531-MAS12301,Coordinator releases: sulfur removal-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07531-MAS12302,Coordinator releases: sulfur removal-Internal torque < Max. limit,Condition not met,
IDE07531-MAS12303,Coordinator releases: sulfur removal-Internal torque > Min. limit,Condition not met,
IDE07531-MAS12304,Coordinator releases: sulfur removal-Min. limit < internal torque < max. limit,Condition not met,
IDE07531-MAS12305,Coordinator releases: sulfur removal-Dynamic internal torque < Max. limit,Condition not met,
IDE07531-MAS12306,Coordinator releases: sulfur removal-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07531-MAS12307,Coordinator releases: sulfur removal-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07531-MAS12308,Coordinator releases: sulfur removal-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07531-MAS12309,Coordinator releases: sulfur removal-Min. limit < engine temperature < max. limit,Condition not met,
IDE07531-MAS12310,Coordinator releases: sulfur removal-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07531-MAS12311,Coordinator releases: sulfur removal-Combustion chamber temp. < Max. limit,Condition not met,
IDE07531-MAS12312,Coordinator releases: sulfur removal-Temperature before turbine < Max. limit,Condition not met,
IDE07531-MAS12313,Coordinator releases: sulfur removal-Temperature after DPF < Max. limit,Condition not met,
IDE07531-MAS12314,Coordinator releases: sulfur removal-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07531-MAS12315,Coordinator releases: sulfur removal-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07531-MAS12316,Coordinator releases: sulfur removal-NSC temperature < Max. limit,Condition not met,
IDE07531-MAS12317,Coordinator releases: sulfur removal-NSC temperature < Min. limit,Condition not met,
IDE07531-MAS12318,Coordinator releases: sulfur removal-Virtual temperature,Condition not met,
IDE07531-MAS12611,Coordinator releases: sulfur removal-Value,0,
IDE07531,Coordinator releases: sulfur removal,0,
IDE07532-MAS12283,Coordinator releases for short trip-Components and systems fault-free,Condition not met,
IDE07532-MAS12284,Coordinator releases for short trip-Tank level > Min. limit,Condition not met,
IDE07532-MAS12285,Coordinator releases for short trip-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07532-MAS12286,Coordinator releases for short trip-Min. limit < driving speed < max. limit,Condition not met,
IDE07532-MAS12287,Coordinator releases for short trip-Power connection,Condition not met,
IDE07532-MAS12288,Coordinator releases for short trip-Lowest gear: no gear shifting,Condition not met,
IDE07532-MAS12289,Coordinator releases for short trip-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07532-MAS12290,Coordinator releases for short trip-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07532-MAS12291,Coordinator releases for short trip-Ambient pressure > Min. limit,Condition not met,
IDE07532-MAS12292,Coordinator releases for short trip-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07532-MAS12293,Coordinator releases for short trip-Control module temp. < Max. limit,Condition not met,
IDE07532-MAS12294,Coordinator releases for short trip-Fuel temp. < Max. limit,Condition not met,
IDE07532-MAS12295,Coordinator releases for short trip-DPF fault-free,Condition not met,
IDE07532-MAS12296,Coordinator releases for short trip-Metering release for SCR,Condition not met,
IDE07532-MAS12297,Coordinator releases for short trip-Smoke limit inactive,Condition not met,
IDE07532-MAS12298,Coordinator releases for short trip-Soot mass < Max. limit_1,Condition not met,
IDE07532-MAS12299,Coordinator releases for short trip-Soot mass < Max. limit_2,Condition not met,
IDE07532-MAS12300,Coordinator releases for short trip-Min. limit < engine speed < max. limit,Condition not met,
IDE07532-MAS12301,Coordinator releases for short trip-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07532-MAS12302,Coordinator releases for short trip-Internal torque < Max. limit,Condition not met,
IDE07532-MAS12303,Coordinator releases for short trip-Internal torque > Min. limit,Condition not met,
IDE07532-MAS12304,Coordinator releases for short trip-Min. limit < internal torque < max. limit,Condition not met,
IDE07532-MAS12305,Coordinator releases for short trip-Dynamic internal torque < Max. limit,Condition not met,
IDE07532-MAS12306,Coordinator releases for short trip-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07532-MAS12307,Coordinator releases for short trip-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07532-MAS12308,Coordinator releases for short trip-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07532-MAS12309,Coordinator releases for short trip-Min. limit < engine temperature < max. limit,Condition not met,
IDE07532-MAS12310,Coordinator releases for short trip-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07532-MAS12311,Coordinator releases for short trip-Combustion chamber temp. < Max. limit,Condition not met,
IDE07532-MAS12312,Coordinator releases for short trip-Temperature before turbine < Max. limit,Condition not met,
IDE07532-MAS12313,Coordinator releases for short trip-Temperature after DPF < Max. limit,Condition not met,
IDE07532-MAS12314,Coordinator releases for short trip-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07532-MAS12315,Coordinator releases for short trip-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07532-MAS12316,Coordinator releases for short trip-NSC temperature < Max. limit,Condition not met,
IDE07532-MAS12317,Coordinator releases for short trip-NSC temperature < Min. limit,Condition not met,
IDE07532-MAS12318,Coordinator releases for short trip-Virtual temperature,Condition not met,
IDE07532-MAS12611,Coordinator releases for short trip-Value,0,
IDE07532,Coordinator releases for short trip,0,
IDE07534,Target operating mode for engine,184619201,
IDE07535,Current operating mode of engine,184619201,
IDE07536,Next requested operating mode for engine,184619201,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,Yes,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,No,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,Yes,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,No,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,No,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07608,Standard test of current section,0,
IDE07706,Extern.temp.sens.1 bank 1: raw value,27.0, C
IDE07708,Turbocharg. 1 compressor outlet:temp.sensor 1 bank 1: raw value,51.7, C
IDE07709,Turboc.1 compres.outlet: temp.sensor 1 bank 1: uncnd.voltage,3.673, V
IDE07710,Charge air cool.output temp.sens.1 bank 1: raw value,51.0, C
IDE07711,Charge air cooler output temp.sens.1 bank 1: uncnd. voltage,3.694, V
IDE07712,Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value,83.2, C
IDE07713,Turbocharg.1 turbin.inlet: temp.sensor 1 bank 1:uncnd voltage,4.990, V
IDE07714,Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value,97.2, C
IDE07715,Turbochar.1 turbin.outlet: temp.sensor 1 bank 1: uncnd voltage,1.078, V
IDE07716,Particle filt.inlet temp.sens.1 bank 1: raw value,83.5, C
IDE07717,Particle filt.inlet temp.sens.1 bank 1: uncnd. voltage,1.043, V
IDE07718,Particle filter outlet temp.sens.1 bank 1: raw value,-40.0, C
IDE07719,Particulate filter output: temp. sensor 1: bank 1: raw voltage,0.002, V
IDE07724,Coolant temperature at engine outlet: calculated,76.7, C
IDE07725,Coolant temp.sens.1 bank 1 at cylinder head: raw value,76.7, C
IDE07726,Coolant temp.sens.1 bank 1 at cylinder head: uncnd. voltage,1.329, V
IDE07727,Coolant temp. sensor 1 bank 1 at cylinder head: raw value,45.5, C
IDE07728,Coolant temp. sensor 1 bank 1 at cylinder head: uncnd. voltage,2.482, V
IDE07729,Exh. gas recirc.temp. sens. 1 bank 1: raw value,51.5, C
IDE07730,Exhaust recirculation temp. sensor 1 bank 1: uncnd. voltage,0.965, V
IDE07733,Ambient air pressure sensor 1 bank 1: raw value,1.006, bar
IDE07734,Air filter outlet: pressure sensor 1 bank 1: raw value,1000, mbar
IDE07735,Air filter outlet: pressure sensor 1 bank 1: uncnd. voltage,0.000, V
IDE07736,Turbocharg.2 compress.outlet: press.sensor 1 bank 1: raw value,0, mbar
IDE07737-ENG49292,Turboc.2 compress.outlet: press.sensor 1 bank 1: uncnd. voltage-Voltage_16_usigned_1000,0.000, V
IDE07738,Charge air cooler inlet: pressure sensor 1 bank 1: raw value,1006, mbar
IDE07739,Charge air cooler inlet: press.sensor 1 bank 1: uncnd. voltage,1.080, V
IDE07742,Cylinder head: pressure sensor 3 bank 1: raw value,0.0, bar
IDE07744,Particle filter: air pressure sensor 1 bank 1: raw value,1.7, mbar
IDE07745,Particl.filt.: different.press.sensor 1 bank 1: adaptat. value,0.0, mbar
IDE07746,Particl.filt.: differential press.sens.1 bank 1: uncnd.voltage,0.000, V
IDE07747,Par.fil: diff.pr.sens.1 bank 1: offset,0.0, mbar
IDE07748,Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset,1.7, mbar
IDE07754,Exhaust recirculation valve 1 bank 1: activation,0.00, %
IDE07755,Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt,2.499, V
IDE07756,Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value,-1.14, %
IDE07757,Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value,-1.06, %
IDE07758,Exhaust recirc.valve 1 bank 1: posit.feedback -Offset closed.,0.00, %
IDE07759,Exh.recircul.valve 1 bank 1:posit.feedback - mech. stops,0,
IDE07760,Exh.recircul.valve 1 bank 1:posit.feedback - Breakaway attempts,0,
IDE07766,Exh.recircul.valve 2 bank 1:posit.feedback - mech. stops,0,
IDE07768,Throttle valve adapter 1 bank 1: activation,0.00, %
IDE07769,Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt,4.486, V
IDE07770,Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value,-0.01, %
IDE07771,Throttl.valve adapt. 1 bank 1: posit feedback - Act.value,0.00, %
IDE07772,Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed,0.55, %
IDE07773,Throttl.valve adapt. 1 bank 1: posit feedback - mech. stops,0,
IDE07774,Throttl.valve adapt.1 bank 1:pos.feedback - Breakaway attempts,0,
IDE07775,Exhaust recirculation valve 1 bank 1: activation,0.00, %
IDE07780,Exh.recircul.valve 1 bank 1: pos.feedback - mech. stops,0,
IDE07783,Turbine actuator 1 bank 1: posit.feedback - Uncnd vlt,3.694, V
IDE07784,Turbine actuator 1 bank 1: posit.feedback - Spec.value,0.00, %
IDE07785,Turbine actuator 1 bank 1: posit.feedback - Act.value,16.59, %
IDE07786,Turbine actuator 1 bank 1: posit.feedback - Offset closed,3.31, %
IDE07787,Turbine actuator 1 bank 1: posit.feedback - mech. stops,0,
IDE07788,Turbine actuator 1 bank 1: posit.feedback - Breakaway attempts,0,
IDE07789,Turbine actuator 1 bank 1: activation,5.00, %
IDE07790,Bypass valve for turboch 1 turbine inlet: activation,0.00, %
IDE07791-ENG49292,Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Uncnd vlt-Voltage_16_usigned_1000,0.000, V
IDE07792-ENG49291,Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Spec.value-Percent_16_usigned_100,0.00, %
IDE07793,Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Act.value,0.00, %
IDE07794,Turboch. 1 turb.byp.valve 1 B. 1:posit.feedback -Offset closed.,0.00, %
IDE07796-ENG114825,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Ident_32,0,
IDE07797-ENG49291,Injector 1 bank 1 for reducing agent before SCR cat: activation-Percent_16_usigned_100,0.00, %
IDE07798,Heater support pump 1 bank 1 second.circuit: activat.,10.00, %
IDE07799,Heater support pump 1 bank 1 primary circuit: activation,0.00, %
IDE07800,Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.,10.00, %
IDE07801,Mass airflow sensor 1 bank 1 airflow: raw value,0.0, mg/stroke
IDE07807,Fuel temp. sensor 1 bank 1: raw value,41.2, C
IDE07808,Fuel temp. sensor 1 bank 1 before CR pump: uncnd. voltage,2.184, V
IDE07812,Transmission neutral position sensor 1: raw value,0.00, %
IDE07815-MAS09445,Transmission neutral position sensor: adaptation status-Release of neutral gear output stage,not active,
IDE07815-MAS09446,Transmission neutral position sensor: adaptation status-Neutral gear detected,not active,
IDE07815-MAS09447,Transmission neutral position sensor: adaptation status-Neutral gear sensor - stop override,not active,
IDE07815-MAS09448,Transmission neutral position sensor: adaptation status-Neutral gear sensor adaptation completed for neutral gear,not active,
IDE07815-MAS09449,Transmission neutral position sensor: adaptation status-Neutral gear sensor adaption,not active,
IDE07815,Transmission neutral position sensor: adaptation status,0,
IDE07818,Fuel high pressure sensor: actual value,3.0, bar
IDE07819,Fuel high pressure sensor: unconditioned voltage,0.508, V
IDE07820,Fuel high pressure sensor: nominal value,200.0, bar
IDE07821,Fuel metering valve: activation,9.11, %
IDE07822,Fuel pressure regulator valve: activation,6.22, %
IDE07824,Tank-internal presupply pump 1 bank 1: activation,0.00, %
IDE07826,Accelerator pedal travel: raw value,0.00, %
IDE07827,Accelerator pedal: sensor voltage 1,0.723, V
IDE07828,Accelerator pedal: sensor voltage 2,0.361, V
IDE07832,Coolant fan 1: activation,10.00, %
IDE07833,Coolant fan 2: activation,0.00, %
IDE07834-MAS09443,Status of starter activation relay-Relay 1 activated,not active,
IDE07834-MAS09444,Status of starter activation relay-Relay 2 activated,not active,
IDE07904-ENG118117,Brake test switch status-actuated__activated,not activated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,not activated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,not activated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07916,Oxygen sensor bank 1 after oxi cat: exhaust temperat.calculated,99.2, C
IDE07928,Oxygen sensor bank 1 before oxi cat: exhaust temper. calculated,97.0, C
IDE07936,Oxyg.sens.bank 1 before oxi cat:act.-integr.pump curr.adapt.,0.000, A
IDE07984,Particle sensor: cleaning deviation reaction time,0.000,
IDE07987,Particle sensor: exhaust temperature,0.0, C
IDE07990,Particle sensor: surface temperature,138.8, C
IDE08064,Mass airflow sensor 1 bank 1 temperature sensor: raw value,38.7, C
IDE08065,Mass airflow sensor 1 bank 1 temperature sensor: raw value,0.000, V
IDE08067,Exhaust recirculat.2: different.press.sens.1 bank 1: offset,0.0, mbar
IDE08069-MAS05769,Fuel filter: water level sensor 1-Water,No,
IDE08069,Fuel filter: water level sensor 1,0,
IDE08132-ENG122793,SCR error notification reset status-SCR Inducement Group,0,
IDE08132-ENG122794,SCR error notification reset status-SCR Inducement State DFCC,0,
IDE08132-ENG45524,SCR error notification reset status-SCR Inducement Tester DFCC Five,0,
IDE08132-ENG45523,SCR error notification reset status-SCR Inducement Tester DFCC Four,0,
IDE08132-ENG45520,SCR error notification reset status-SCR Inducement Tester DFCC One,0,
IDE08132-ENG45522,SCR error notification reset status-SCR Inducement Tester DFCC Three,0,
IDE08132-ENG45521,SCR error notification reset status-SCR Inducement Tester DFCC Two,0,
IDE08138,Bypass valve for turboch 2 turbine inlet: activation,0.00, %
IDE08212,Standardised airflow ratio,1.000, counts
IDE08213,Standardised airflow ratio plausibility,invalid,
IDE08340,Particle sensor: measuring current calculated,0.0, A
IDE08721,Particle sensor: time in op. mode measurement,0.0, s
IDE09007,NOx sensor before SCR catalytic converter: supply voltage,0.000, V
IDE09009,NOx sensor after SCR catalytic converter: supply voltage,0.000, V
IDE09013,NOx sensor after SCR cat conv: O2 concen.,0.0000,
IDE09014,NOx sensor after SCR cat conv: offset correction factor,0, ppm
IDE09017,NOx sens.dwnstrm.SCR cat conv: NOx conc.,0, ppm
IDE09020,NOx sensor before SCR cat conv: O2 concen.,0.0000,
IDE09022,NOx sensor before SCR cat conv: offset correction factor,0, ppm
IDE09023-MAS14022,NOx sensor before SCR cat conv: status-Heater sensor release status,No,
IDE09023-MAS14023,NOx sensor before SCR cat conv: status-Status of binary Lambda signal,No,
IDE09023-MAS14024,NOx sensor before SCR cat conv: status-Status of linear Lambda signal,No,
IDE09023-MAS14025,NOx sensor before SCR cat conv: status-Com-Signal NOx-Sensor,No,
IDE09023-MAS14026,NOx sensor before SCR cat conv: status-Nox sensor ready for measurement,No,
IDE09023,NOx sensor before SCR cat conv: status,0,
IDE09024-MAS14022,NOx sensor after SCR cat conv: status-Heater sensor release status,No,
IDE09024-MAS14023,NOx sensor after SCR cat conv: status-Status of binary Lambda signal,No,
IDE09024-MAS14024,NOx sensor after SCR cat conv: status-Status of linear Lambda signal,No,
IDE09024-MAS14025,NOx sensor after SCR cat conv: status-Com-Signal NOx-Sensor,No,
IDE09024-MAS14026,NOx sensor after SCR cat conv: status-Nox sensor ready for measurement,No,
IDE09024,NOx sensor after SCR cat conv: status,0,
IDE09025,NOx sensor before SCR cat conv: NOx concentration,0, ppm
IDE09163,Exhaust recircul.2: different.press.sens.1 bank 1: dyn. offset,0.0, mbar
IDE09327,Cylinder 1 bank 1 internal moment,0.0, Nm
IDE09328,Cylinder 2 bank 1 internal moment,0.0, Nm
IDE09329,Cylinder 3 bank 1 internal moment,0.0, Nm
IDE09330,Cylinder 4 bank 1 internal moment,0.0, Nm
IDE09337,Intake manif.runner 1 bank1:pos. feedbck - Breakaway attempts,0,
IDE09338,Intake manif.runner 1 bank1:pos. feedbck - mech. stops,0,
IDE09339,Charge limit for service regeneration while driving,40.00, g
IDE09340,Primary injection: quantity setpoint,0.00, mg/stroke
IDE09420,Heat quantity for dewpoint end: particle sensor,0.00, %
IDE09648,EGR travel diagnosis: slightly increased NOx emission,0.00, kg/h
IDE09649,EGR travel diagnosis: strongly increased NOx emission,0.00, kg/h
IDE09650,AGR travel diag.: increased NOx emission effect. throttle valve,0.00, kg/h
IDE09651,EGR travel diagnosis: marginally increased NOx emission,-3.70, kg/h
IDE09683-MAS13144,Cylinder head: controller internal moment 1 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value,No,
IDE09683-MAS13145,Cylinder head: controller internal moment 1 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value,No,
IDE09683-MAS13146,Cylinder head: controller internal moment 1 bank 1: limit stat.-Offset combustion focus position < min. threshold,No,
IDE09683-MAS13147,Cylinder head: controller internal moment 1 bank 1: limit stat.-Offset combustion focus position >max. threshold,No,
IDE09683,Cylinder head: controller internal moment 1 bank 1: limit stat.,0,
IDE09684-MAS13144,Cylinder head: controller internal moment 2 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value,No,
IDE09684-MAS13145,Cylinder head: controller internal moment 2 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value,No,
IDE09684-MAS13146,Cylinder head: controller internal moment 2 bank 1: limit stat.-Offset combustion focus position < min. threshold,No,
IDE09684-MAS13147,Cylinder head: controller internal moment 2 bank 1: limit stat.-Offset combustion focus position >max. threshold,No,
IDE09684,Cylinder head: controller internal moment 2 bank 1: limit stat.,0,
IDE09685-MAS13144,Cylinder head: controller internal moment 3 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value,No,
IDE09685-MAS13145,Cylinder head: controller internal moment 3 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value,No,
IDE09685-MAS13146,Cylinder head: controller internal moment 3 bank 1: limit stat.-Offset combustion focus position < min. threshold,No,
IDE09685-MAS13147,Cylinder head: controller internal moment 3 bank 1: limit stat.-Offset combustion focus position >max. threshold,No,
IDE09685,Cylinder head: controller internal moment 3 bank 1: limit stat.,0,
IDE09686-MAS13144,Cylinder head: controller internal moment 4 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value,No,
IDE09686-MAS13145,Cylinder head: controller internal moment 4 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value,No,
IDE09686-MAS13146,Cylinder head: controller internal moment 4 bank 1: limit stat.-Offset combustion focus position < min. threshold,No,
IDE09686-MAS13147,Cylinder head: controller internal moment 4 bank 1: limit stat.-Offset combustion focus position >max. threshold,No,
IDE09686,Cylinder head: controller internal moment 4 bank 1: limit stat.,0,
IDE09842,Delete engine diagnostic stat. since error memory (end-of-line),4294967295,
IDE09843,Delete engine diagn. stat. 2 since error memory (end-of-line),4294967295,
IDE09877,O2 sensor 1 bank 1 dwnstrm cat.: raw value,10.000, counts
IDE09879,O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current,0.000, A
IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,1.000, counts
IDE09881,O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value,4.964, V
IDE09886,Exhaust gas recirc. valve 2 bank 1: mass flow - calculated,0.0, kg/h
IDE10032,Reducing agent quality sensor: urea concentration,0.00, %
IDE10039,Reducing agent quality sensor: validity,invalid,
IDE10223-MAS09705,Install. list for actuators bank 1-High press. turbocharger actuator,supported,
IDE10223-MAS09706,Install. list for actuators bank 1-Low press. turbocharger actuator,Not supported,
IDE10223-MAS09707,Install. list for actuators bank 1-High press. turbocharger bypass valve,Not supported,
IDE10223-MAS09708,Install. list for actuators bank 1-Throttle valve,supported,
IDE10223-MAS09709,Install. list for actuators bank 1-High press. exh. gas recirc. actuator,supported,
IDE10223-MAS09710,Install. list for actuators bank 1-Low press. exh. gas recirc. actuator,Not supported,
IDE10223-MAS09711,Install. list for actuators bank 1-Exhaust flap,Not supported,
IDE10223-MAS09712,Install. list for actuators bank 1-Coolant pump,Not supported,
IDE10223-MAS09713,Install. list for actuators bank 1-Coolant pump load charge cooler,supported,
IDE10223-MAS09714,Install. list for actuators bank 1-Swirl flap,supported,
IDE10223-MAS09715,Install. list for actuators bank 1-Variable valve operation actuator,Not supported,
IDE10223-MAS09716,Install. list for actuators bank 1-Radiator shutter,Not supported,
IDE10223-MAS09717,Install. list for actuators bank 1-Coolant pump: short circuit,supported,
IDE10223-MAS09718,Install. list for actuators bank 1-Valve for exh. gas recirc. cooler HP,Not supported,
IDE10223,Install. list for actuators bank 1,0,
IDE10223,Install. list for actuators bank 1,529050,
IDE10223,Install. list for actuators bank 1,1,
IDE10224-MAS09678,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm of air filter,Not supported,
IDE10224-MAS09679,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm. of turbocharger LP,Not supported,
IDE10224-MAS09680,Install. list for pressure and O2 sensors bank 1-Press. sens. upstrm. of charg. air cool.,supported,
IDE10224-MAS09681,Install. list for pressure and O2 sensors bank 1-Press. sens. above diesel part. filter,Not supported,
IDE10224-MAS09682,Install. list for pressure and O2 sensors bank 1-Press. sensor above exh. gas recirc. LP,Not supported,
IDE10224-MAS09684,Install. list for pressure and O2 sensors bank 1-Oxygen sensor upstrm. of oxidation cat.,supported,
IDE10224-MAS09685,Install. list for pressure and O2 sensors bank 1-Oxygen sensor dwnstrm. of oxidation cat.,Not supported,
IDE10224-MAS09686,Install. list for pressure and O2 sensors bank 1-Knox sensor upstrm. of SCAR cat.,Not supported,
IDE10224-MAS09687,Install. list for pressure and O2 sensors bank 1-NOx sensor dwnstrm. of SCR cat.,supported,
IDE10224-MAS09688,Install. list for pressure and O2 sensors bank 1-Cylinder press. sensor,supported,
IDE10224-MAS09689,Install. list for pressure and O2 sensors bank 1-Particulate sensor,supported,
IDE10224-MAS09690,Install. list for pressure and O2 sensors bank 1-Knock sensor,supported,
IDE10224-MAS09691,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm of air filter (SENT),Not supported,
IDE10224-MAS09692,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm. of turbocharger LP (SENT),Not supported,
IDE10224-MAS09693,Install. list for pressure and O2 sensors bank 1-Press. sens. upstrm. of charg. air cool. (SENT),Not supported,
IDE10224-MAS09694,Install. list for pressure and O2 sensors bank 1-Press. sens. above diesel part. filter (SENT),supported,
IDE10224-MAS09695,Install. list for pressure and O2 sensors bank 1-Press. sensor above exh. gas recirc. LP (SENT),Not supported,
IDE10224-MAS09697,Install. list for pressure and O2 sensors bank 1-Oxygen sensor upstrm. of oxidation cat. (SENT),Not supported,
IDE10224-MAS09698,Install. list for pressure and O2 sensors bank 1-Oxygen sensor dwnstrm. of oxidation cat. (SENT),Not supported,
IDE10224-MAS09699,Install. list for pressure and O2 sensors bank 1-NOx sensor upstrm. of SCAR cat. (SENT),Not supported,
IDE10224-MAS09700,Install. list for pressure and O2 sensors bank 1-NOx sensor dwnstrm. of SCAR cat. (SENT),Not supported,
IDE10224-MAS09701,Install. list for pressure and O2 sensors bank 1-Cylinder press. sensor (SENT),Not supported,
IDE10224-MAS09702,Install. list for pressure and O2 sensors bank 1-Particle sensor (SENT),Not supported,
IDE10224-MAS09703,Install. list for pressure and O2 sensors bank 1-Knock sensor (SENT),Not supported,
IDE10224,Install. list for pressure and O2 sensors bank 1,0,
IDE10224,Install. list for pressure and O2 sensors bank 1,1,
IDE10224,Install. list for pressure and O2 sensors bank 1,583876,
IDE10225-MAS08988,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. upstrm of turbocharger,supported,
IDE10225-MAS08989,Install. list for temperature sensors bank 1-Exh. gas temperature sensor upstrm. of oxidation cat.,supported,
IDE10225-MAS08990,Install. list for temperature sensors bank 1-Exh. gas temperature sensor dwnstrm. of oxidation cat.,supported,
IDE10225-MAS09653,Install. list for temperature sensors bank 1-Exh. gas temp. sens. upstrm. of diesel particle filter,Not supported,
IDE10225-MAS09654,Install. list for temperature sensors bank 1-Exh. gas temp. sens. dwnstrm. of diesel particle filter,Not supported,
IDE10225-MAS09655,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. LP,Not supported,
IDE10225-MAS09656,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. HP,supported,
IDE10225-MAS09657,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of radiator,supported,
IDE10225-MAS09658,Install. list for temperature sensors bank 1-Coolant temp. sensor dwnstrm. of radiator,supported,
IDE10225-MAS09659,Install. list for temperature sensors bank 1-Coolant temp. sensor in cylinder head,Not supported,
IDE10225-MAS09660,Install. list for temperature sensors bank 1-Intake air temperature sensor in mass airflow sensor,Not supported,
IDE10225-MAS09661,Install. list for temperature sensors bank 1-Intake air temp. sensor upstrm. of charge air cooler,supported,
IDE10225-MAS09662,Install. list for temperature sensors bank 1-Intake air temp. sensor dwnstrm. of charge air cooler,supported,
IDE10225-MAS09663,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of exh.gas recirc. cooler HP,supported,
IDE10225-MAS09664,Install. list for temperature sensors bank 1-Exh. gas temp. sens. upstrm. of turbocharger (SENT),Not supported,
IDE10225-MAS09665,Install. list for temperature sensors bank 1-Exhaust gas temp. sensor upstrm. of oxidation cat. (SENT),Not supported,
IDE10225-MAS09666,Install. list for temperature sensors bank 1-Exhaust gas temp. sensor dwnstrm. of oxidation cat. (SENT),Not supported,
IDE10225-MAS09667,Install. list for temperature sensors bank 1-Exh. gas temp. sensor upstrm. of diesel particle filter (SENT),Not supported,
IDE10225-MAS09668,Install. list for temperature sensors bank 1-Exh. gas temp. sensor dwnstrm. of diesel particle filter (SENT),Not supported,
IDE10225-MAS09669,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. LP (SENT),Not supported,
IDE10225-MAS09670,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. HP (SENT),Not supported,
IDE10225-MAS09671,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of radiator (SENT),Not supported,
IDE10225-MAS09672,Install. list for temperature sensors bank 1-Coolant temp. sensor dwnstrm. of radiator (SENT),Not supported,
IDE10225-MAS09673,Install. list for temperature sensors bank 1-Coolant temp. sensor in cylinder head (SENT),Not supported,
IDE10225-MAS09674,Install. list for temperature sensors bank 1-Intake air temperature sensor in mass airflow sensor (SENT),Not supported,
IDE10225-MAS09675,Install. list for temperature sensors bank 1-Intake air temp. sensor upstrm. of charge air cooler (SENT),Not supported,
IDE10225-MAS09676,Install. list for temperature sensors bank 1-Intake air temp. sensor dwnstrm. of charge air cooler (SENT),Not supported,
IDE10225-MAS09677,Install. list for temperature sensors bank 1-Coolant tem.sens.upstrm. of radiator exh.gas recirc. HP (SENT),Not supported,
IDE10225,Install. list for temperature sensors bank 1,0,
IDE10225,Install. list for temperature sensors bank 1,14791,
IDE10241,Reducing agent pump module relative press.: calculated,0, mbar
IDE10247,Reducing agent tank volume: act. value calculated,15.192, l
IDE10248,Reducing agent supply pump: offset factor calculated,1.006,
IDE10249,Reducing agent fill level sensor: act. value,81, mm
IDE10250,Reducing agent return pump: adapted displacement,0.038, ml
IDE10251,Reducing agent supply pump: measured resistance,4.315, Ohm
IDE10252,Operatingn hour reducing agent system: flawless,255, counts
IDE10257,Turbocharger 1 turbine byp.valve 1 bank 1 pos.contr.spec.val.,0.00, %
IDE10312,Exh. gas recirc. 1 bank 1: act.temp. of water upst. of radiator,46.5, C
IDE10313-IDE11376,Exhaust recirculation valve 1 bank 1: monitoring - status-Recognition of actuator closed or jammed open 2,not active,
IDE10313-MAS09413,Exhaust recirculation valve 1 bank 1: monitoring - status-open mech. stop approached,not active,
IDE10313-MAS09414,Exhaust recirculation valve 1 bank 1: monitoring - status-closed mech. stop approached,not active,
IDE10313-MAS09415,Exhaust recirculation valve 1 bank 1: monitoring - status-Adaptations met for offset on the mechan. stops,not active,
IDE10313-MAS09416,Exhaust recirculation valve 1 bank 1: monitoring - status-Adaptation active,not active,
IDE10313-MAS09417,Exhaust recirculation valve 1 bank 1: monitoring - status-open mech. stop adapted properly in current drive cycle,not active,
IDE10313-MAS09418,Exhaust recirculation valve 1 bank 1: monitoring - status-closed mech. stop adapted properly in current drive cycle,not active,
IDE10313-MAS09419,Exhaust recirculation valve 1 bank 1: monitoring - status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE10313-MAS09420,Exhaust recirculation valve 1 bank 1: monitoring - status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE10313-MAS09421,Exhaust recirculation valve 1 bank 1: monitoring - status-Ctrl. dev. detected after after breakaway function,not active,
IDE10313-MAS09422,Exhaust recirculation valve 1 bank 1: monitoring - status-Valve/actuator active: eng. running,not active,
IDE10313-MAS09423,Exhaust recirculation valve 1 bank 1: monitoring - status-Valve/actuator active: eng. off,not active,
IDE10313-MAS09424,Exhaust recirculation valve 1 bank 1: monitoring - status-Breakaway function active,not active,
IDE10313-MAS09425,Exhaust recirculation valve 1 bank 1: monitoring - status-Effective current limit. limited at controller output,active,
IDE10313-MAS09426,Exhaust recirculation valve 1 bank 1: monitoring - status-Actuator in shut-off position,active,
IDE10313-MAS09427,Exhaust recirculation valve 1 bank 1: monitoring - status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE10313-MAS09428,Exhaust recirculation valve 1 bank 1: monitoring - status-Error in limit setter: position control is deactivated,not active,
IDE10313-MAS09429,Exhaust recirculation valve 1 bank 1: monitoring - status-Breakaway function is lowered,not active,
IDE10313-MAS09433,Exhaust recirculation valve 1 bank 1: monitoring - status-higher voltage should press valve closed when at mech. stop,not active,
IDE10313-MAS09434,Exhaust recirculation valve 1 bank 1: monitoring - status-Positioner detected as closed or jammed in open pos.,not active,
IDE10313-MAS09435,Exhaust recirculation valve 1 bank 1: monitoring - status-Reset adaptation values,not active,
IDE10313-MAS09436,Exhaust recirculation valve 1 bank 1: monitoring - status-Ambient air temperature permits adaptation,active,
IDE10313-MAS09437,Exhaust recirculation valve 1 bank 1: monitoring - status-Exh. gas temp. permits adaptation,active,
IDE10313-MAS09438,Exhaust recirculation valve 1 bank 1: monitoring - status-Engine temp. permits adaptation,active,
IDE10313-MAS09439,Exhaust recirculation valve 1 bank 1: monitoring - status-Battery voltage permits adaptation,active,
IDE10313-MAS09440,Exhaust recirculation valve 1 bank 1: monitoring - status-Ambient press. permits adaptation,active,
IDE10313-MAS09441,Exhaust recirculation valve 1 bank 1: monitoring - status-Eng. run. time permits adaptation,not active,
IDE10313-MAS09442,Exhaust recirculation valve 1 bank 1: monitoring - status-Brake function active,not active,
IDE10313,Exhaust recirculation valve 1 bank 1: monitoring - status,520142848,
IDE10316-IDE11376,Turbine actuator 1 bank 1: monitoring - status-Recognition of actuator closed or jammed open 2,not active,
IDE10316-MAS09413,Turbine actuator 1 bank 1: monitoring - status-open mech. stop approached,not active,
IDE10316-MAS09414,Turbine actuator 1 bank 1: monitoring - status-closed mech. stop approached,not active,
IDE10316-MAS09415,Turbine actuator 1 bank 1: monitoring - status-Adaptations met for offset on the mechan. stops,not active,
IDE10316-MAS09416,Turbine actuator 1 bank 1: monitoring - status-Adaptation active,not active,
IDE10316-MAS09417,Turbine actuator 1 bank 1: monitoring - status-open mech. stop adapted properly in current drive cycle,not active,
IDE10316-MAS09418,Turbine actuator 1 bank 1: monitoring - status-closed mech. stop adapted properly in current drive cycle,not active,
IDE10316-MAS09419,Turbine actuator 1 bank 1: monitoring - status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE10316-MAS09420,Turbine actuator 1 bank 1: monitoring - status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE10316-MAS09421,Turbine actuator 1 bank 1: monitoring - status-Ctrl. dev. detected after after breakaway function,not active,
IDE10316-MAS09422,Turbine actuator 1 bank 1: monitoring - status-Valve/actuator active: eng. running,not active,
IDE10316-MAS09423,Turbine actuator 1 bank 1: monitoring - status-Valve/actuator active: eng. off,not active,
IDE10316-MAS09424,Turbine actuator 1 bank 1: monitoring - status-Breakaway function active,not active,
IDE10316-MAS09425,Turbine actuator 1 bank 1: monitoring - status-Effective current limit. limited at controller output,active,
IDE10316-MAS09426,Turbine actuator 1 bank 1: monitoring - status-Actuator in shut-off position,active,
IDE10316-MAS09427,Turbine actuator 1 bank 1: monitoring - status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE10316-MAS09428,Turbine actuator 1 bank 1: monitoring - status-Error in limit setter: position control is deactivated,not active,
IDE10316-MAS09429,Turbine actuator 1 bank 1: monitoring - status-Breakaway function is lowered,not active,
IDE10316-MAS09433,Turbine actuator 1 bank 1: monitoring - status-higher voltage should press valve closed when at mech. stop,not active,
IDE10316-MAS09434,Turbine actuator 1 bank 1: monitoring - status-Positioner detected as closed or jammed in open pos.,not active,
IDE10316-MAS09435,Turbine actuator 1 bank 1: monitoring - status-Reset adaptation values,not active,
IDE10316-MAS09436,Turbine actuator 1 bank 1: monitoring - status-Ambient air temperature permits adaptation,active,
IDE10316-MAS09437,Turbine actuator 1 bank 1: monitoring - status-Exh. gas temp. permits adaptation,active,
IDE10316-MAS09438,Turbine actuator 1 bank 1: monitoring - status-Engine temp. permits adaptation,active,
IDE10316-MAS09439,Turbine actuator 1 bank 1: monitoring - status-Battery voltage permits adaptation,active,
IDE10316-MAS09440,Turbine actuator 1 bank 1: monitoring - status-Ambient press. permits adaptation,not active,
IDE10316-MAS09441,Turbine actuator 1 bank 1: monitoring - status-Eng. run. time permits adaptation,not active,
IDE10316-MAS09442,Turbine actuator 1 bank 1: monitoring - status-Brake function active,not active,
IDE10316,Turbine actuator 1 bank 1: monitoring - status,251707392,
IDE10402-IDE11376,Throttle valve adapter 1 bank 1: monitoring - status-Recognition of actuator closed or jammed open 2,not active,
IDE10402-MAS09413,Throttle valve adapter 1 bank 1: monitoring - status-open mech. stop approached,not active,
IDE10402-MAS09414,Throttle valve adapter 1 bank 1: monitoring - status-closed mech. stop approached,not active,
IDE10402-MAS09415,Throttle valve adapter 1 bank 1: monitoring - status-Adaptations met for offset on the mechan. stops,active,
IDE10402-MAS09416,Throttle valve adapter 1 bank 1: monitoring - status-Adaptation active,not active,
IDE10402-MAS09417,Throttle valve adapter 1 bank 1: monitoring - status-open mech. stop adapted properly in current drive cycle,not active,
IDE10402-MAS09418,Throttle valve adapter 1 bank 1: monitoring - status-closed mech. stop adapted properly in current drive cycle,not active,
IDE10402-MAS09419,Throttle valve adapter 1 bank 1: monitoring - status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE10402-MAS09420,Throttle valve adapter 1 bank 1: monitoring - status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE10402-MAS09421,Throttle valve adapter 1 bank 1: monitoring - status-Ctrl. dev. detected after after breakaway function,not active,
IDE10402-MAS09422,Throttle valve adapter 1 bank 1: monitoring - status-Valve/actuator active: eng. running,not active,
IDE10402-MAS09423,Throttle valve adapter 1 bank 1: monitoring - status-Valve/actuator active: eng. off,not active,
IDE10402-MAS09424,Throttle valve adapter 1 bank 1: monitoring - status-Breakaway function active,not active,
IDE10402-MAS09425,Throttle valve adapter 1 bank 1: monitoring - status-Effective current limit. limited at controller output,active,
IDE10402-MAS09426,Throttle valve adapter 1 bank 1: monitoring - status-Actuator in shut-off position,active,
IDE10402-MAS09427,Throttle valve adapter 1 bank 1: monitoring - status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE10402-MAS09428,Throttle valve adapter 1 bank 1: monitoring - status-Error in limit setter: position control is deactivated,not active,
IDE10402-MAS09429,Throttle valve adapter 1 bank 1: monitoring - status-Breakaway function is lowered,not active,
IDE10402-MAS09433,Throttle valve adapter 1 bank 1: monitoring - status-higher voltage should press valve closed when at mech. stop,not active,
IDE10402-MAS09434,Throttle valve adapter 1 bank 1: monitoring - status-Positioner detected as closed or jammed in open pos.,not active,
IDE10402-MAS09435,Throttle valve adapter 1 bank 1: monitoring - status-Reset adaptation values,not active,
IDE10402-MAS09436,Throttle valve adapter 1 bank 1: monitoring - status-Ambient air temperature permits adaptation,active,
IDE10402-MAS09437,Throttle valve adapter 1 bank 1: monitoring - status-Exh. gas temp. permits adaptation,active,
IDE10402-MAS09438,Throttle valve adapter 1 bank 1: monitoring - status-Engine temp. permits adaptation,active,
IDE10402-MAS09439,Throttle valve adapter 1 bank 1: monitoring - status-Battery voltage permits adaptation,active,
IDE10402-MAS09440,Throttle valve adapter 1 bank 1: monitoring - status-Ambient press. permits adaptation,active,
IDE10402-MAS09441,Throttle valve adapter 1 bank 1: monitoring - status-Eng. run. time permits adaptation,active,
IDE10402-MAS09442,Throttle valve adapter 1 bank 1: monitoring - status-Brake function active,not active,
IDE10402,Throttle valve adapter 1 bank 1: monitoring - status,1057013764,
IDE10565,Reducing agent dosing quantity check: release conditions,0,
IDE10566,NOx sensor upstrm. of SCR cat.: activ. condit. offset diagnosis,not active,
IDE10567,NOx sensor dwnstrm. of SCR cat.: activ. condit. offset diagnos.,not active,
IDE10569,Turbo charger 1 Turbine inp.: Temp. sensor 1 Bank 1: raw data,0,
IDE10570,Turbo charger.1 turbine inp.: temp.sensor 1 bank 1: comp. temp.,0.0, C
IDE10571,Turbo charger.1 turbine inp.: temp.sens. 1 bank 1: ins.resist.,0, kOhm
IDE10572,Exh. gas temp. sens. upstrm. of turbo chgr.: intern. error code,0,
IDE10573,Exh. gas temp. sens. upstrm. of turbo chgr.: sens. type,0,
IDE10574,Exh. gas temp. sens. upstrm. of turbo chgr.: sens. mod.,0,
IDE10575,Exh. gas temp. sens. upstrm. of turbo chgr.: manf. ID,0,
IDE10579-MAS01493,Reducing agent system pressurization release conditions-Engine running,Condition not met,
IDE10579-MAS10830,Reducing agent system pressurization release conditions-Press. enabled,Condition met,
IDE10579-MAS10831,Reducing agent system pressurization release conditions-Heat. strategy: enable,Condition met,
IDE10579-MAS10832,Reducing agent system pressurization release conditions-Depressurized min. time below limit,Condition met,
IDE10579-MAS10833,Reducing agent system pressurization release conditions-Catalyst temp.reached,Condition not met,
IDE10579-MAS10834,Reducing agent system pressurization release conditions-Release due to jammed valve needle,Condition not met,
IDE10579-MAS10835,Reducing agent system pressurization release conditions-Rinse function finished,Condition met,
IDE10579-MAS10836,Reducing agent system pressurization release conditions-Initial filling completed,Condition met,
IDE10579-MAS13646,Reducing agent system pressurization release conditions-Release via inducement,Condition not met,
IDE10579,Reducing agent system pressurization release conditions,711,
IDE10633,Clutch protection function: reduced torque,0.0, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0, /min
IDE10811,Release requirement for DPF regeneration,0,
IDE10812,Diesel particulate filter regeneration: status,0,
IDE10815,Post injection 2: quantity spec. value,0.00, mg/stroke
IDE10816,Diesel particulate filter regen. level: current,0,
IDE10817,Lambda value at inlet of particulate filter,10.000,
IDE10818,Temp. spec. value for exhaust gas temp.con.dwnstrm. of oxi-cat,0.0, C
IDE10819,Exh. gas temp.control dwnstrm. of oxi-cat: filtered model error,0.0, C
IDE10820,Exh. gas temp. ctrl. upstrm. of turbine: spec. value,0.0, C
IDE10826,Exh. gas temp. controller upstrm. of turbine: I-part,0.000,
IDE10827,Exh.gas temp.contr. dwnstrm.of oxi-cat:post inject.qty.spec.val,0.00, mg/stroke
IDE10828,Exh. gas temp.contr. upstrm. of turbine: post inject.qty.corr.,0.00, mg/stroke
IDE10829,Post injection 1: quantity spec. value,0.00, mg/stroke
IDE10830,Post injection 3: quantity spec. value,0.00, mg/stroke
IDE10916,Reducing agent system debounce distance,0, km
IDE10917,Reducing agent delivery pump: coil temperature,298.3, C
IDE10918,Reducing agent: dosing qty. test calculated: actual volume,655.35, g
IDE10919,Reducing agent: dosing qty. test: calculated specified volume,0.00, g
IDE10920,Temp. upstrm. of reducing agent cat.: calculated,99.2, C
IDE10921,Reducing agent delivery pump: number of strokes,0,
IDE10968,Activation radiator shutter result,0.00, %
IDE10994,Poor start counter at start-stop,0,
IDE11067,Index of next requested engine mode,11,
IDE11068,Index of current engine mode,11,
IDE11069,Index of engine target mode,11,
IDE11074,Fuel pres.sen. 1 bank 1 upstream from HD pump: press. dev.,0, mbar
IDE11114,Fuel press. sensor 1 bank 1 upstr. from HD pump: adapt. value,0, mbar
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,22,
IDE11117-ENG127253,Charge press. ctrl deviation after throttle valve bank 1-Pressure_16_signed_10_mbar,-1000.9, mbar
IDE11118,Pressure after throttle valve: calculated,1.0, bar
IDE11119-ENG127253,Pressure corr. value after low pressure EGR valve: calculated-Pressure_16_signed_10_mbar,0.0, mbar
IDE11219,Reducing agent inj. quantity: spec. value,0, mg/s
IDE11220,Reducing agent system: current status,COSCR_no pressure control,
IDE11220,Reducing agent system: current status,2,
IDE11221,Reducing agent system: last status,COSCR_STANDBY,
IDE11221,Reducing agent system: last status,1,
IDE11222,Reducing agent system: current substatus,COSCR_INVALID,
IDE11222,Reducing agent system: current substatus,255,
IDE11223,Reducing agent system: last substatus,Unknown (0),
IDE11223,Reducing agent system: last substatus,0,
IDE11250,Reducing agent quality sensor: raw temperature value,0.0, C
IDE11311,Exh. recirc.cooler 1 bank 1: wat. temp. from cool.:uncond volt.,2.433, V
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11392,Activation of radiator shutter 2,0.00, %
IDE11448,Reducing agent over-pressure: diagnosis progress,0, %
IDE11449,Reducing agent under-pressure: diagnosis progress,0, %
IDE11574,Status max. oil level dynamically exceeded,No,
IDE11575,Status max. oil level permanently exceeded,No,
IDE11576,Oil level: last valid dynamic value overfilling,0.0, mm
IDE11621,Minimum deviation quantity: number of adapted points,0,
IDE11635,Radiator shutter 1: status referencing,completed successfully,
IDE11636,Radiator shutter 2: status referencing,completed successfully,
IDE11870,Heater supp.pump 1 bank 1 exh.gas recir.cool.circ.: activation,100.00, %
IDE11871,Exh.gas temp.sen upstr. of HD exh.gas recir.valv.:raw voltage,0.969, V
IDE11872,Exh.gas temp.sen upstream of HD exh.gas recir.valve:raw val.,53.5, C
IDE11895,Particle filter: differential press. sens.1 bank 1: raw data 1,662,
IDE11896,Particle filter: differential press. sens.1 bank 1: raw value 1,1, mbar
IDE11897,Particle filter: differential press. sens.1 bank 1: raw value 2,0, mbar
IDE11898,Particle filter: differential press. sens.1 bank 1: raw data 2,657,
IDE11900,Par.fil: diff.pr.sens.1 bank 1: data quality,120.39, %
IDE11901,Par.fil: diff.pr.sens.1 bank 1: sensor configuration,1,
IDE11902,Par.fil: diff.pr.sens.1 bank 1: manufacturer ID,5,
IDE11904,Par.fil: diff.pr.sens.1 bank 1: sensor type,9,
IDE12085,Fuel injection time deviation: cylinder 1,0, s
IDE12086,Fuel injection time deviation: cylinder 2,0, s
IDE12087,Fuel injection time deviation: cylinder 3,0, s
IDE12088,Fuel injection time deviation: cylinder 4,0, s
IDE12123,EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop,2.354, V
IDE12124,EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop,2.685, V
IDE12125,Particulate sensor: status condition automation,0,
IDE12125,Particulate sensor: status condition automation,Standby,
IDE12456,Turbocharger 1 positioner 1 bank 1: position feedback Adaption value,0.625, V
IDE12457,Turbocharger 1 bypass valve 1 bank 1: position feedback - Adaption value,0.747, V
IDE12458,Turbocharger 1 bypass valve 1 bank 1: position feedback - first learning,0, counts
IDE12459,Turbocharger 1 positioner 1 bank 1: position feedback First learning,1, counts
ENG130449-ENG130482,A flag to indicate the voltage vailidity-Bool type,Yes,
ENG127344,Acceleration demand state for VLC,6,
ENG08190,ACM Operating Mode Higher Bytes,00000000 00000000 ,
ENG08191,ACM Operating Mode Lower Bytes,00000000 00001011 ,
ENG125964,Alternator mechanically absorbed power,0.000, kW
ENG08221-ENG08230,APS Crank state-Delphi APS Crank State,P_L_APS_CRANK_WAITING,
ENG130440-ENG130480,Atmospheric pressure used by the brake vacuum model-Pressure 0 500 BIN6 kPa,100.64, kPa
ENG125969,Boost pressure demand,100, kPa
ENG101413,Calibration Identification,04L056NB6116BEBD,
ENG99697,Calibration Verification Number,7E 49 CE F2,
ENG105535,Code Checksum,BF 16 98 BD,
ENG105751,Data Checksum,72 10 AF 54,
ENG130456-ENG130482,Dew point passed at the wraf location-Bool type,No,
ENG130436-ENG115021,Diagnostic data acquired from VSEP over SPI-Delphi PWM DG A,P_L_PWM_DG_A_NO_ERROR,
ENG105980,Duration of the FAN dutycycle gap,0, s
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG130458-ENG130482,Electrical WRAF fault detected-Bool type,No,
ENG98582-ENG130485,Engine running time-Pressure BIN10 bar,0, s
ENG08216-ENG130482,ESM background pfc fail fault-Bool type,No,
ENG08217-ENG130482,ESM level2 pfc fail fault-Bool type,No,
ENG08219-ENG08229,ESM memory l2 test status-Delphi ESM Memory L2 Test Status,ESM_L2_TESTING_CODE,
ENG08218-ENG08228,ESM memory test status-Delphi ESM Memory Test Status,ESM_TESTING_STOPPED,
ENG113730-ENG113667,ESM_0_dmnd_idle_ext_active-Counter_in_seconds,0, s
ENG113731,ESM_0_dmnd_idle_ext_limit,0.00, /min
ENG113734,ESM_0_trq_mode_word,00000000 00000000 ,
ENG113704-ENG113658,ESM_Amon_ctrl_acc_error-Control_deviation,1.667, m/s
ENG113705-ENG113658,ESM_Amon_ctrl_n_error-Control_deviation,8000.0, /min
ENG113710-ENG113659,ESM_Amon_pedal_position-Pedal_position,0, %
ENG113711-ENG113658,ESM_Amon_set_veh_acc-Control_deviation,1.667, m/s
ENG113712-ENG113658,ESM_Amon_veh_acc_raw-Control_deviation,0.000, m/s
ENG113713-ENG100973,ESM_Amon_veh_spd_raw-Vehicle_speed,0.00, km/h
ENG113714-ENG99033,ESM_Battery_voltage-Voltage,12.30, V
ENG113735,ESM_Can_mode_word,00000000 00000000 ,
ENG125974,ESM_Crankless_active,OFF,
ENG113709-ENG98933,ESM_Electric_test_state-Status,Unknown (7),
ENG113715,ESM_Eng_spd_l1l2_diff,0.00, /min
ENG113716,ESM_Eng_spd_unchecked,0.00, /min
ENG113717,ESM_Eng_spd_unchecked_cam,0.00, /min
ENG113718,ESM_Eng_spd_unchecked_crk,0.00, /min
ENG113719,ESM_Engine_speed,0.00, /min
ENG113732-ENG113662,ESM_L2_a_ext_int_ofs-MSR_correction,0.000, m/s
ENG113720,ESM_L3_stop_comms,OFF,
ENG113736,ESM_L3_trqmngr_mode_word,00000000 00000000 ,
ENG130466-ENG130486,ESM_Last_reset_nvv-Delphi Status ESM last reset NVV,ESM_NO_FAULT,
ENG113721,ESM_Memory_rst_dmnd,OFF,
ENG113722-ENG113659,ESM_Pedal_nominal_value-Pedal_position,0, %
ENG113723,ESM_Pedal_test_allowed,OFF,
ENG113724,ESM_Plausibility_fault_detected,OFF,
ENG113725,ESM_Stop_coms,OFF,
ENG113726,ESM_Synchronization_lost,On,
ENG113727-ENG113660,ESM_Vext_raw-ESM_sensor_voltage,3.2813, V
ENG113729-ENG113666,ESM_Zpls_trq_relevant_pulses_nbr-Torque_relevant_pulses_in_buffer,0.000,
ENG125971,Exhaust gas recirculation actuator bit field status 2,00000000 00000000 10000000 01100000 ,
ENG130435-ENG130482,Fan PWM driver diagnostics inhibit request-Bool type,No,
ENG130432-ENG130482,Faults combined to provide interlocks for the throttle close request-Bool type,Yes,
ENG125968-ENG126086,Filtered value of IN_Dpf_dp_raw-CDPF Delta Pressure in hPa,1.500, hPa
ENG106571,Flag to det.if dur.of FAN dutycyc.gap is above min.thresh.,OFF,
ENG106572,Flag to det.if dur.of FAN dutycyc.pulse is above min.thresh.,On,
ENG106573,Flag to det.if dur.of FAN dutycyc.pulse is below max.thresh.,OFF,
ENG130457-ENG130482,Fuel cut-off at the Wraf sensor location: taking into account the exhaust mass flow-Bool type,No,
ENG130438-ENG130482,Generic lamp output-Bool type,No,
ENG106787,Global Checksum,7E 49 CE F2,
ENG08222,Hard reset count,0,
ENG125965,HPV current demand coming from the HPV control,100, mA
ENG125966,HPV current demand coming from the IMV control,100, mA
ENG126050,HWI_Aps_cam_index,1,
ENG126011,HWI_Aps_crank_events_betwen_cams,00 78,
ENG125999,HWI_Aps_crank_rotat_direc_enable,OFF,
ENG126037-ENG126090,HWI_Aps_crank_rotation_direction-APS crank rotation,HWI_APS_CRANK_ROTATION_FORWARD,
ENG125996,HWI_Aps_gap_event_misplaced,OFF,
ENG125995,HWI_Aps_gap_event_missed,OFF,
ENG125997,HWI_Aps_gap_period_detected,OFF,
ENG126036-ENG126090,HWI_Aps_hw_crank_direction-APS crank rotation,HWI_APS_CRANK_ROTATION_FORWARD,
ENG126038,HWI_Aps_hw_crank_pulse_width,2D,
ENG113737-ENG99000,I_C_Acc_decode_std_0-Value,0,
ENG113738-ENG99000,I_C_Acc_decode_std_1-Value,0,
ENG113739-ENG99000,I_C_Acc_decode_std_2-Value,0,
ENG128779-ENG99000,I_C_Acc_decode_std_3-Value,0,
ENG130452,ID of the last object which HWI_Nvm_Read return an error,0,
ENG130454,ID of the last object which HWI_Nvm_Write return an error,0,
ENG106932,Immobilizer Snapshot 001 Byte 1,00,
ENG106933,Immobilizer Snapshot 001 Byte 2,00,
ENG106934,Immobilizer Snapshot 001 Byte 3,00,
ENG106935,Immobilizer Snapshot 001 Byte 4,00,
ENG106936,Immobilizer Snapshot 001 Byte 5,00,
ENG106937,Immobilizer Snapshot 001 Byte 6,00,
ENG106938,Immobilizer Snapshot 002 Byte 1,00,
ENG106939,Immobilizer Snapshot 002 Byte 2,00,
ENG106940,Immobilizer Snapshot 002 Byte 3,00,
ENG106941,Immobilizer Snapshot 002 Byte 4,00,
ENG106942,Immobilizer Snapshot 002 Byte 5,00,
ENG106943,Immobilizer Snapshot 002 Byte 6,00,
ENG106944,Immobilizer Snapshot 004 Byte 1,00,
ENG106945,Immobilizer Snapshot 004 Byte 2,00,
ENG106946,Immobilizer Snapshot 004 Byte 3,00,
ENG106947,Immobilizer Snapshot 004 Byte 4,00,
ENG106948,Immobilizer Snapshot 004 Byte 5,00,
ENG106949,Immobilizer Snapshot 004 Byte 6,00,
ENG106950,Immobilizer Snapshot 005 Byte 1,00,
ENG106951,Immobilizer Snapshot 005 Byte 2,00,
ENG106952,Immobilizer Snapshot 005 Byte 3,00,
ENG106953,Immobilizer Snapshot 005 Byte 4,00,
ENG106954,Immobilizer Snapshot 005 Byte 5,00,
ENG106955,Immobilizer Snapshot 005 Byte 6,00,
ENG126000,IN_Injection_speed,0.00, /min
ENG126008,IN_Injection_speed_injector[0],0.00, /min
ENG126009,IN_Injection_speed_injector[1],0.00, /min
ENG126010,IN_Injection_speed_injector[2],0.00, /min
ENG128778,IN_Injection_speed_injector[3],0.00, /min
ENG126004,IN_Latest_inj_spd_table[0],0.00, /min
ENG126005,IN_Latest_inj_spd_table[1],0.00, /min
ENG126006,IN_Latest_inj_spd_table[2],0.00, /min
ENG126007,IN_Latest_inj_spd_table[3],0.00, /min
ENG103875-ENG99452,In-use perform. track.: 16 counters-Boost Pressure Monitor Completion Condition Counts,552, counts
ENG103875-ENG103994,In-use perform. track.: 16 counters-Boost Pressure Monitor Conditions Encountered Counts,346, counts
ENG103875-ENG100817,In-use perform. track.: 16 counters-EGR and/or VVT Monitor Completion Condition Counts,790, counts
ENG103875-ENG101113,In-use perform. track.: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts,346, counts
ENG103875-ENG104133,In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts,176, counts
ENG103875-ENG104165,In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts,228, counts
ENG103875-ENG28750,In-use perform. track.: 16 counters-Fuel Monitor Completion Condition Counts,0, counts
ENG103875-ENG28751,In-use perform. track.: 16 counters-Fuel Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG102823,In-use perform. track.: 16 counters-Ignition Cycle Counter,1105, counts
ENG103875-ENG99234,In-use perform. track.: 16 counters-NMHC Catalyst Monitor Completion Condition Counts,56, counts
ENG103875-ENG99167,In-use perform. track.: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts,20, counts
ENG103875-ENG101363,In-use perform. track.: 16 counters-NOx Adsorber Monitor Completion Condition Counts,0, counts
ENG103875-ENG103522,In-use perform. track.: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG125933,In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts,138, counts
ENG103875-ENG125934,In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts,346, counts
ENG103875-ENG99988,In-use perform. track.: 16 counters-OBD Monitoring Conditions Encountered Counts,346, counts
ENG103875-ENG100240,In-use perform. track.: 16 counters-PM Filter Monitor Completion Condition Counts,101, counts
ENG103875-ENG103730,In-use perform. track.: 16 counters-PM Filter Monitor Conditions Encountered Counts,20, counts
ENG130451,Last error returned by HWI_Nvm_Read for P_L_Nvm_write_obj_index object,0,
ENG130453,Last error returned by HWI_Nvm_Write for P_L_Nvm_write_obj_index object,0,
ENG130445-ENG130480,Linearised atmospheric pressure sensor data-Pressure 0 500 BIN6 kPa,100.64, kPa
ENG130465-ENG130482,Low battery mode active-Bool type,No,
ENG103817,Main Timing demand,0.000,
ENG130450-ENG130483,Manifold pressure offset-P_L Manifold abs pres offset nvv,0.000, kPa
ENG127343,Maximum allowed vehicle velocity,165.0, km/h
ENG107850,number of NEF refresh that have been performed,1525, counts
ENG107873,OBD Driver demand indicated torque,0.0, %
ENG107874-ENG98842,OBD EGR position control-Position,1.2, %
ENG107876-ENG127366,OBD maximum indicated torque-Torque 0 65535 BIN0 Nm,0, Nm
ENG130437,Oil pump PWM signal duty cycle,0.000, %
ENG127345-ENG127354,Operation mode cruise control and speed limiter-Cruise control 10km/h steps allowed,No,
ENG127345-ENG127353,Operation mode cruise control and speed limiter-Cruise control break intervention allowed,No,
ENG127345-ENG127355,Operation mode cruise control and speed limiter-Cruise control with display velocity setpoint,Yes,
ENG127345-ENG98891,Operation mode cruise control and speed limiter-Reserved,No,
ENG127345-ENG101416,Operation mode cruise control and speed limiter-Reserved_1,Yes,
ENG127345-ENG99458,Operation mode cruise control and speed limiter-Reserved_2,No,
ENG127345-ENG99668,Operation mode cruise control and speed limiter-Reserved_3,Yes,
ENG127345-ENG23189,Operation mode cruise control and speed limiter-Reserved_4,No,
ENG126002,P_L_Aps_cam_edge_learn_done,00,
ENG125998,P_L_Aps_cam_edge_window_end,OFF,
ENG125994,P_L_Aps_cam_index_confirmed,OFF,
ENG126035-ENG126089,P_L_Aps_cam_state-APS cam state,P_L_APS_CAM_WAITING,
ENG113760,P_L_Aps_camless_active,OFF,
ENG126043-ENG126092,P_L_Aps_camshaft_drift_angle-Camshaft target wheel drift angle,0.00,
ENG126003,P_L_Aps_crank_event_num,00,
ENG113759,P_L_Aps_crankless_active,OFF,
ENG126001,P_L_Aps_crankshaft_speed,0.00, /min
ENG113758,P_L_Aps_injection_speed,0.00, /min
ENG125993,P_L_Aps_learning_done_nvv,On,
ENG126034-ENG126088,P_L_Aps_mode-APS working mode,P_L_APS_NORMAL,
ENG113755,P_L_Aps_no_sync_speed,0.00, /min
ENG113749-ENG99000,P_L_Aps_sync_cnt_total-Value,0,
ENG113750,P_L_Aps_sync_lost,OFF,
ENG113751-ENG113669,P_L_Aps_sync_lost_origin-Sync_lost_status,P_L_APS_SYNC_LOST_NONE,
ENG113752,P_L_Aps_sync_tasks_enabled,OFF,
ENG113753,P_L_Aps_synchronised,OFF,
ENG113754-ENG113670,P_L_Aps_synchronised_origin-Sync_origin,P_L_APS_SYNC_NONE,
ENG113756-ENG113661,P_L_Aps_tdc_to_tooth_1_angle-Engine_timing_value,353.991,
ENG113757,P_L_Aps_timeout_detected,OFF,
ENG126012-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[0]-Mean of the learned camshaft edges position angles,0.000,
ENG126013-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[1]-Mean of the learned camshaft edges position angles,0.000,
ENG126014-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[2]-Mean of the learned camshaft edges position angles,0.000,
ENG126015-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[3]-Mean of the learned camshaft edges position angles,0.000,
ENG126016-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[4]-Mean of the learned camshaft edges position angles,0.000,
ENG126017-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[5]-Mean of the learned camshaft edges position angles,0.000,
ENG27003,P_L_Cds_Inlet_air_veh_dst_ff_hi,0,
ENG27004,P_L_Cds_Inlet_air_veh_dst_ff_lo,0,
ENG125978,P_L_Cds_p_class_selected,02,
ENG125976,P_L_Cds_vc_bit3_wr_valid_nvv,OFF,
ENG125977,P_L_Cds_vc_bit6_wr_valid_nvv,OFF,
ENG08376-ENG126091,P_L_Hpb_pos_ctrl_test-Valve Position,0.0, %
ENG27005,P_L_Inlet_air_atm_pres_ff_data,0,
ENG27006,P_L_Inlet_air_batt_volt_ff_data,0,
ENG27007,P_L_Inlet_air_cds_amf_ff_data,0,
ENG27008,P_L_Inlet_air_cool_temp_ff_data,0,
ENG27009,P_L_Inlet_air_doc_in_tmp_ff_data,0,
ENG27010,P_L_Inlet_air_egr_cool_t_ff_data,0,
ENG27011,P_L_Inlet_air_eng_spd_ff_data,0,
ENG27012,P_L_Inlet_air_ext_temp_ff_data,0,
ENG27013,P_L_Inlet_air_fan1_ff_data,0,
ENG27014,P_L_Inlet_air_fan2_ff_data,0,
ENG27015,P_L_Inlet_air_in_air_tmp_ff_data,0,
ENG27016,P_L_Inlet_air_t21_temp_ff_data,0,
ENG27017,P_L_Inlet_air_t22_temp_ff_data,0,
ENG27018,P_L_Inlet_air_veh_spd_ff_data,0,
ENG130582,P_L_Pedal_switch_case,USE_MIN,
ENG113740-ENG98489,P_L_Rail_pres_sample_cnts-counts,104.899, counts
ENG113762-ENG113664,P_L_Wraf_back_pressure_estimate-Back_pressure_estimate,1.006, bar
ENG113761-ENG113663,P_L_Wraf_ip_temp_compensation-Compensation_value,0.0456, mA
ENG108255,Power Latch counter,4291, counts
ENG08224-ENG130482,PT dfco 0 torque request-Bool type,Yes,
ENG130446-ENG130481,Raw battery voltage reading-Voltage BIN7 V,12.2344, V
ENG130441-ENG130481,Raw value for 3.3V on ADC0 from EQADC A-Voltage BIN7 V,3.2813, V
ENG130443-ENG130481,Raw value for 3.3V on ADC0 from EQADC B-Voltage BIN7 V,3.2813, V
ENG130442-ENG130481,Raw value for 3.3V on ADC1 from EQADC A-Voltage BIN7 V,0.0000, V
ENG130444-ENG130481,Raw value for 3.3V on ADC1 from EQADC B-Voltage BIN7 V,0.0000, V
ENG130434-ENG130482,Request throttle close based on inlet pressure-Bool type,No,
ENG08220,Reset detection pattern,23130,
ENG113745-ENG113668,RPC_Hp_control_state-HPV_Status,RPC_HP_DUMPING,
ENG113746-ENG113655,RPC_Hp_crt_trim-Current_trim,-314.141, mA
ENG113747-ENG98933,RPC_Im_control_state-Status,RPC_IM_ENERGY_SAVING,
ENG113748-ENG113655,RPC_Im_crt_trim-Current_trim,-9.531, mA
ENG130447-ENG130481,Scaled sensor value before validation for pbatt-Voltage BIN7 V,12.2578, V
ENG130448-ENG130481,Scaled sensor value before validation for vinj-Voltage BIN7 V,12.3047, V
ENG110382-ENG20519,SCR inducem system status-deviation of reagent consumption,Unknown (0),
ENG110382-ENG20512,SCR inducem system status-Distance traveled in current 10K block,8940, km
ENG110382-ENG20513,SCR inducem system status-Distance traveled while inducement system active in 20K block,0, km
ENG110382-ENG20514,SCR inducem system status-Distance traveled while inducement system active in 30K block,0, km
ENG110382-ENG20515,SCR inducem system status-Distance traveled while inducement system active in 40K block,0, km
ENG110382-ENG20511,SCR inducem system status-Distance traveled while inducement system active in current 10K block,0, km
ENG110382-ENG20518,SCR inducem system status-incorrect reagent,Unknown (0),
ENG110382-ENG20516,SCR inducem system status-inducement system active,not_active,
ENG110382-ENG20520,SCR inducem system status-NOx emissions too high,Unknown (0),
ENG110382-ENG20517,SCR inducem system status-reagent level too low,Unknown (0),
ENG27113-ENG130482,SCR system failure-Bool type,No,
ENG26352-ENG30059,SMC_Power_state-Param Delphi SMC Power State,SMC_SYSTEM_RUNNING,
ENG08223,Soft reset count,0,
ENG127342-ENG127352,State ACC Cruise Control Variant Correct Code-ACC Cruise variant code,CCS,
ENG127339-ENG127350,Status cruise control and speed limiter-Status velocity destination,Stand-by,
ENG127341-ENG98933,Status irriversible shutoff condition cruise control and limiter-Status,0,
ENG127348-ENG127363,Status powertrain VLC and VehFRstn-Automatic transmission reduced torque intervention,No,
ENG127348-ENG127362,Status powertrain VLC and VehFRstn-Automatic transmission shift,No,
ENG127348-ENG127359,Status powertrain VLC and VehFRstn-Clutch long open,No,
ENG127348-ENG112437,Status powertrain VLC and VehFRstn-Clutch open,Yes,
ENG127348-ENG127360,Status powertrain VLC and VehFRstn-Extended neutral gear detection manual switch v/n drift,No,
ENG127348-ENG127361,Status powertrain VLC and VehFRstn-Exteneded neutral gear detection only at Torque demand manual switch,No,
ENG127348-ENG127358,Status powertrain VLC and VehFRstn-Gear level position N/Intermediate position or Manual switch neutral gear,No,
ENG127348-ENG127357,Status powertrain VLC and VehFRstn-Gear lever position P,No,
ENG127348-ENG127356,Status powertrain VLC and VehFRstn-Manual switch first gear,No,
ENG127348-ENG127364,Status powertrain VLC and VehFRstn-Maximum engine speed not debounced regulation,No,
ENG127348-ENG101416,Status powertrain VLC and VehFRstn-Reserved_1,No,
ENG127348-ENG99458,Status powertrain VLC and VehFRstn-Reserved_2,No,
ENG127348-ENG99668,Status powertrain VLC and VehFRstn-Reserved_3,Yes,
ENG127348-ENG23189,Status powertrain VLC and VehFRstn-Reserved_4,Yes,
ENG127348-ENG98894,Status powertrain VLC and VehFRstn-Reverse gear,No,
ENG127348-ENG127365,Status powertrain VLC and VehFRstn-Vehical speed dependent engine speed limit only for automatic transmission,Yes,
ENG127340-ENG127351,Status reversible shutoff condition cruise control and limiter-Stau,17302592,
ENG130439-ENG130482,Switch the crank case heater on/off-Bool type,No,
ENG127347-ENG119265,Target velocity LMVCtl function-Velocity,0.0, km/h
ENG125961,The global air climate fluid pressure.,0.00, bar
ENG125972,Throttle valve actuator bit field status 2,00000000 00000000 00000000 01000100 ,
ENG125973,Turbocharger actuator HP bit field status 2,00000000 00000000 00000000 01000000 ,
ENG130433-ENG130482,Under pressure interlocks for the throttle-Bool type,No,
ENG109815,Value of temperature sensor 1 (set 1) at record result time,0, C
ENG109816,Value of temperature sensor 1 (set 2) at record result time,0, C
ENG109817,Value of temperature sensor 2 (set 1) at record result time,0, C
ENG109818,Value of temperature sensor 2 (set 2) at record result time,0, C
ENG109819,Value of temperature sensor 3 (set 1) at record result time,0, C
ENG109820,Value of temperature sensor 3 (set 2) at record result time,0, C
ENG109821,Value of temperature sensor 4 (set 1) at record result time,0, C
ENG109822,Value of temperature sensor 4 (set 2) at record result time,0, C
ENG109823,Value of temperature sensor 5 (set 1) at record result time,0, C
ENG109824,Value of temperature sensor 5 (set 2) at record result time,0, C
ENG109825,Value of temperature sensor 6 (set 1) at record result time,0, C
ENG109826,Value of temperature sensor 6 (set 2) at record result time,0, C
ENG127346-ENG127349,Velocity limitation requested by driver-Velocity driver requested speed limit,500.0, km/h
ENG125967-ENG98842,Vgt valve position for OBD Mode $02-Position,73.7, %
ENG08212-ENG08227,Wraf open circuit heater-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG08192-ENG08225,Wraf Origin State-Delphi Wraf Origin State,Unknown (14),
ENG130459-ENG130484,Wraf pump cell offset-Wraf pump cell offset current,0.00000, mA
ENG08193,Wraf pump current raw,0.00000, mA
ENG130455,Wraf pure air deviation correction factor,1.0043,
ENG08194,Wraf reference cell impedence,2000.00000, Ohm
ENG08213-ENG08227,Wraf sc2gnd heater-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG08206-ENG08227,Wraf sc2vbat reference cell-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG08207-ENG08227,Wraf sc2vbat sense resist-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG08208-ENG08227,Wraf sc2vbat sensor return-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG130464-ENG130484,Wraf second sensor pump cell offset-Wraf pump cell offset current,0.00000, mA
ENG08196,Wraf sensor ipk raw,0.00000, mA
ENG08197-ENG08196,Wraf sensor ipk raw old-Wraf sensor ipk raw,0.00000, mA
ENG08195,Wraf sensor learning count,2104,
ENG08198-ENG08226,Wraf state-Delphi Wraf State,WRAF_REF_CELL_STG_TEST,
Elapsed Time: 01:08
Engine +80c (cluster temperature gauge at 90c), engine at idle.
;SW:04L-906-056-NB   HW:04L-907-445-C ---  Engine
;Component:R4 2.0l TDI   H01 6116, Coding:0019403C6334050800000000000000000000000000000000
;EV_ECM20TDI03004L906056NB,005005,EV_ECM20TDI03004L906056NB.rod
;Wednesday,22,May,2019,12:14:49:29066
;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
;VCID: 7AADF0BE4C584177D09-802E
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WV1ZZZSYZK9,
IDE00018,Voltage terminal 15,12.735, V
IDE00019,Voltage terminal 30,13.142, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,831, /min
IDE00025,Coolant temperature,69, C
IDE00030,Status of actuator test,not active,
IDE00075,Vehicle speed,0, km/h
IDE00076,Status of initial fuel filling,was not yet started,
IDE00078,Time since engine start,8, s
IDE00083,Throttle valve position (absolute),27.5, %
IDE00085,Normed load value,38.0, %
IDE00086,Accelerator position,14, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00102,Control Module temperature,41.2, C
IDE00151,Oil fill level,65, mm
IDE00152,Oil warning threshold,58, mm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00178,Camshaft adjustment intake bank 1: specified value,0.0,
IDE00179,Camshaft adjustment intake bank 1: actual value,0.0,
IDE00182,Camshaft adaptation intake bank 1: phase position,1.0,
IDE00190,Charge air pressure specified value,1.382, bar
IDE00196,Engine oil temperature,70.1, C
IDE00198,Refrigerant pressure,0.000, bar
IDE00200,Median vehicle speed,0.00, km/h
IDE00304,Fuel level,76, l
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00347,Air mass: actual value:,10.53, g/s
IDE00348,Intake air temperature,49, C
IDE00349,Throttle valve position: normed,14, %
IDE00351,Main injection: start of activation,-5.98,
IDE00352,Main injection: duration of activation,632, s
IDE00355,Cruise Control System (CCS): status,passive,
IDE00358,Limitation: torque,186.6, Nm
IDE00359,Limitation: smoke,134.7, Nm
IDE00363,Glow status,No heat,
IDE00364,Preheat time,0.0, s
IDE00371,Fuel consumption,1.10, l/h
IDE00375,Generator: load signal,58.07, %
IDE00383,Pre-injection 1: activation start,0.00,
IDE00384,Pre-injection 1: activation duration,0, s
IDE00385,Pre-injection 2: activation start,11.39,
IDE00386,Pre-injection 2: activation duration,395, s
IDE00387,Post-injection 1: activation start,0.00,
IDE00388,Post-injection 1: activation duration,0, s
IDE00389,Post-injection 2: activation start,0.00,
IDE00390,Post-injection 2: activation duration,0, s
IDE00400,Intake manifold Runner Control (IMRC): activation,0.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,0.00, %
IDE00405,Crankshaft speed (RPM),827, /min
IDE00406,Camshaft speed (RPM),826, /min
IDE00407,Rail pressure regulation: status,Regulated oper. via press. ctrl valve and quant. ctrl valve,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,not active,
IDE00416-MAS07386,Starter control: terminal 50 acknowledgment-Terminal 50 on CAN,not active,
IDE00416-MAS09390,Starter control: terminal 50 acknowledgment-Terminal 50 CAN valid,not active,
IDE00416-MAS09391,Starter control: terminal 50 acknowledgment-Terminal 50 via cable,not active,
IDE00416-MAS09392,Starter control: terminal 50 acknowledgment-Starter relay,not active,
IDE00416-MAS09394,Starter control: terminal 50 acknowledgment-Starter operation read back wire T50Ret,not active,
IDE00416,Starter control: terminal 50 acknowledgment,0,
IDE00417-MAS00077,Starter control: shut-off conditions 1-Immobilizer,not active,
IDE00417-MAS00357,Starter control: shut-off conditions 1-Starter shift malfunction,not active,
IDE00417-MAS01456,Starter control: shut-off conditions 1-Speed,not active,
IDE00417-MAS05133,Starter control: shut-off conditions 1-Drivetrain,not active,
IDE00417-MAS06857,Starter control: shut-off conditions 1-Speed,not active,
IDE00417-MAS09395,Starter control: shut-off conditions 1-RPM aborted starts,active,
IDE00417-MAS09396,Starter control: shut-off conditions 1-Engag. duration,not active,
IDE00417-MAS09397,Starter control: shut-off conditions 1-Engag. duration aborted starts,not active,
IDE00417-MAS09398,Starter control: shut-off conditions 1-Engag. duration panic start,not active,
IDE00417-MAS09399,Starter control: shut-off conditions 1-new errors,not active,
IDE00417-MAS09400,Starter control: shut-off conditions 1-manual start/error,active,
IDE00417-MAS09401,Starter control: shut-off conditions 1-ignition,not active,
IDE00417-MAS09402,Starter control: shut-off conditions 1-Clutch error/terminal 50 malfunction,not active,
IDE00417-MAS09403,Starter control: shut-off conditions 1-Direct start function,not active,
IDE00417-MAS09404,Starter control: shut-off conditions 1-Engag. duration defrost.,not active,
IDE00417,Starter control: shut-off conditions 1,513,
IDE00420,Service regeneration: current duration,0, s
IDE00430,Particle filter: field regeneration request status,no request,
IDE00431,Particle filter: field regeneration lock status,8,
IDE00432,Particle filter: time since last regeneration,153, min
IDE00434,Particle filter: soot mass calculated,13.47, g
IDE00435,Particle filter: soot mass measured,1.76, g
IDE00436,Particle filter: kilometers since last regeneration,140.0,
IDE00445,Unlearning counter according OBD,255,
IDE00450,Operating Instructions,--no display--,
IDE00451,Currently running routine,Unknown (0),
IDE00472,Mean injection quantity,8, mg/stroke
IDE00474,Ambient air pressure,100, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,28.8, Nm
IDE00495,Calculated oil temperature,79.2, C
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00541,Acceleration,0.000, m/s
IDE00556,Outside air temperature,0, C
IDE00558,Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor),0.062 Lambda / 0.277 V,
IDE00583,Throttle valve specified value,20, %
IDE00584,Distance driven since erasing DTC memory,19423, km
IDE00585,Dist. driven with exh. Malfunction Indicator Lamp activated,0, km
IDE00589,Fuel pressure,34100, kPa rel
IDE00590,Terminal 87 status,On,
IDE00594,Absolute intake pressure,99, kPa abs
IDE00595,Allocation of oxygen sensors,B1S1 ,
IDE00600,Conversion factors,,
IDE00601,Monitoring status since erasing DTC memory,,
IDE00602,Monitoring status in current driving cycle,,
IDE00603,Number of driving cycles since erasing DTC memory,255,
IDE00609-MAS01155,Communication status of data bus 1-Control module,Engine Control Module 1,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,active,
IDE00699,ESI: minimum oil level in service interval,0.0, mm
IDE00700,ESI: maximum oil level in service interval,0.0, mm
IDE00727,Test steps still to be performed,0,
IDE00784,Current test step,--no display--,
IDE00784-ENG124478,Current test step-Test_Program_Requested Action,0,
IDE00787,Cause for cancellation,0,
IDE01076-MAS00109,Time since ignition off-Hours,0, H
IDE01076-MAS00110,Time since ignition off-Minutes,14, min
IDE01076-MAS00111,Time since ignition off-Seconds,36, s
IDE01369,Intake manifold runner control (IMRC): offset closed,0.000, V
IDE01378,High fuel pressure: control deviation,0, bar
IDE01380,Pre-injection 3: activation start,2.39,
IDE01381,Pre-injection 3: activation duration,363, s
IDE01382,Post-injection 3: activation start,0.00,
IDE01383,Post-injection 3: activation duration,0, s
IDE01405-MAS05513,Status of starter activation-Bit 0,OK,
IDE01405-MAS05514,Status of starter activation-Bit 1,Before starter activation,
IDE01405-MAS05515,Status of starter activation-Bit 2,Before starter activation,
IDE01407,Particle filter: fuel consumption since last regeneration,10.46, l
IDE01410,Charge limit over-charge,50.00, g
IDE01671,Starter control: clutch switch,not pressed,
IDE01834,Battery voltage,13.156, V
IDE01880,Accelerator position 2,15, %
IDE01884,Camshaft adjustment intake bank 1: activation,0.00, %
IDE01922,Vehicle distance driven,19435, km
IDE02634,Lock time during deactivation,0, min
IDE02756,Number of manual engine starts,1169,
IDE02757,Number of automatic engine starts,223,
IDE03015,Compression test cylinder 1,0, /min
IDE03016,Compression test cylinder 2,0, /min
IDE03017,Compression test cylinder 3,0, /min
IDE03018,Compression test cylinder 4,0, /min
IDE03133,Heat circuit 1 for reduc. agent meter. system: act. curr.,0.000, A
IDE03134,Heat circuit 2 for reduc. agent meter. system: act. curr.,0.311, A
IDE03135,Sensor for reducing agent tank temperature: temperature,23.0, C
IDE03139,Reducing agent injector: resistance,13.952, Ohm
IDE03142,Remaining vehicle distance until reducing agent deficiency,6206.900, km
IDE03189-MAS04415,Number of prevented stop processes (statistics)-Ambient air pressure,1,
IDE03189-MAS04416,Number of prevented stop processes (statistics)-Sporadic function restriction,3,
IDE03189-MAS04417,Number of prevented stop processes (statistics)-Poor start detection,4,
IDE03189-MAS04590,Number of prevented stop processes (statistics)-Mixture adaptation,5,
IDE03189-MAS06089,Number of prevented stop processes (statistics)-Low brake pressure,2,
IDE03189-MAS06092,Number of prevented stop processes (statistics)-Regeneration,6,
IDE03189-ENG118032,Number of prevented stop processes (statistics)-brake_depression_day,0,
IDE03189-ENG118033,Number of prevented stop processes (statistics)-brake_depression_hour,0,
IDE03189-ENG118036,Number of prevented stop processes (statistics)-brake_depression_kilometer,0,
IDE03189-ENG118034,Number of prevented stop processes (statistics)-brake_depression_minute,0,
IDE03189-ENG118031,Number of prevented stop processes (statistics)-brake_depression_month,0,
IDE03189-ENG118029,Number of prevented stop processes (statistics)-brake_depression_prohibition_counter,0,
IDE03189-ENG118035,Number of prevented stop processes (statistics)-brake_depression_second,0,
IDE03189-ENG118030,Number of prevented stop processes (statistics)-brake_depression_year,0,
IDE03189-ENG118024,Number of prevented stop processes (statistics)-environment_air_density_day,0,
IDE03189-ENG118025,Number of prevented stop processes (statistics)-environment_air_density_hour,0,
IDE03189-ENG118028,Number of prevented stop processes (statistics)-environment_air_density_kilometer,0,
IDE03189-ENG118026,Number of prevented stop processes (statistics)-environment_air_density_minute,0,
IDE03189-ENG118023,Number of prevented stop processes (statistics)-environment_air_density_month,0,
IDE03189-ENG118021,Number of prevented stop processes (statistics)-environment_air_density_prohibition_counter,0,
IDE03189-ENG118027,Number of prevented stop processes (statistics)-environment_air_density_second,0,
IDE03189-ENG118022,Number of prevented stop processes (statistics)-environment_air_density_year,0,
IDE03189-ENG118056,Number of prevented stop processes (statistics)-mixture_adaption_day,0,
IDE03189-ENG118057,Number of prevented stop processes (statistics)-mixture_adaption_hour,0,
IDE03189-ENG118060,Number of prevented stop processes (statistics)-mixture_adaption_kilometer,0,
IDE03189-ENG118058,Number of prevented stop processes (statistics)-mixture_adaption_minute,0,
IDE03189-ENG118055,Number of prevented stop processes (statistics)-mixture_adaption_month,0,
IDE03189-ENG118053,Number of prevented stop processes (statistics)-mixture_adaption_prohibition_counter,0,
IDE03189-ENG118059,Number of prevented stop processes (statistics)-mixture_adaption_second,0,
IDE03189-ENG118054,Number of prevented stop processes (statistics)-mixture_adaption_year,0,
IDE03189-ENG118048,Number of prevented stop processes (statistics)-poor_crank_detection_day,0,
IDE03189-ENG118049,Number of prevented stop processes (statistics)-poor_crank_detection_hour,0,
IDE03189-ENG118052,Number of prevented stop processes (statistics)-poor_crank_detection_kilometer,0,
IDE03189-ENG118050,Number of prevented stop processes (statistics)-poor_crank_detection_minute,0,
IDE03189-ENG118047,Number of prevented stop processes (statistics)-poor_crank_detection_month,0,
IDE03189-ENG118045,Number of prevented stop processes (statistics)-poor_crank_detection_prohibition_counter,0,
IDE03189-ENG118051,Number of prevented stop processes (statistics)-poor_crank_detection_second,0,
IDE03189-ENG118046,Number of prevented stop processes (statistics)-poor_crank_detection_year,0,
IDE03189-ENG118064,Number of prevented stop processes (statistics)-regeneration_operation_day,10,
IDE03189-ENG118065,Number of prevented stop processes (statistics)-regeneration_operation_hour,20,
IDE03189-ENG118068,Number of prevented stop processes (statistics)-regeneration_operation_kilometer,18710,
IDE03189-ENG118066,Number of prevented stop processes (statistics)-regeneration_operation_minute,37,
IDE03189-ENG118063,Number of prevented stop processes (statistics)-regeneration_operation_month,5,
IDE03189-ENG118061,Number of prevented stop processes (statistics)-regeneration_operation_prohibition_counter,25,
IDE03189-ENG118067,Number of prevented stop processes (statistics)-regeneration_operation_second,26,
IDE03189-ENG118062,Number of prevented stop processes (statistics)-regeneration_operation_year,19,
IDE03189-ENG118040,Number of prevented stop processes (statistics)-sporadical_function_inhibition_day,0,
IDE03189-ENG118041,Number of prevented stop processes (statistics)-sporadical_function_inhibition_hour,0,
IDE03189-ENG118044,Number of prevented stop processes (statistics)-sporadical_function_inhibition_kilometer,0,
IDE03189-ENG118042,Number of prevented stop processes (statistics)-sporadical_function_inhibition_minute,0,
IDE03189-ENG118039,Number of prevented stop processes (statistics)-sporadical_function_inhibition_month,0,
IDE03189-ENG118037,Number of prevented stop processes (statistics)-sporadical_function_inhibition_prohibition_counter,0,
IDE03189-ENG118043,Number of prevented stop processes (statistics)-sporadical_function_inhibition_second,0,
IDE03189-ENG118038,Number of prevented stop processes (statistics)-sporadical_function_inhibition_year,0,
IDE03190-IDE04099,Number of requested start processes (statistics)-Reduction agent dosing,5,
IDE03190-MAS00077,Number of requested start processes (statistics)-Immobilizer,4,
IDE03190-MAS04369,Number of requested start processes (statistics)-Engine temperature too high,2,
IDE03190-MAS04370,Number of requested start processes (statistics)-Engine temperature too low,1,
IDE03190-MAS06089,Number of requested start processes (statistics)-Low brake pressure,3,
IDE03190-ENG118032,Number of requested start processes (statistics)-brake_depression_day,3,
IDE03190-ENG118033,Number of requested start processes (statistics)-brake_depression_hour,14,
IDE03190-ENG118036,Number of requested start processes (statistics)-brake_depression_kilometer,17467,
IDE03190-ENG118034,Number of requested start processes (statistics)-brake_depression_minute,41,
IDE03190-ENG118031,Number of requested start processes (statistics)-brake_depression_month,5,
IDE03190-ENG118029,Number of requested start processes (statistics)-brake_depression_prohibition_counter,1,
IDE03190-ENG118035,Number of requested start processes (statistics)-brake_depression_second,58,
IDE03190-ENG118030,Number of requested start processes (statistics)-brake_depression_year,19,
IDE03190-ENG118080,Number of requested start processes (statistics)-engine_temperature_too_high_day,0,
IDE03190-ENG118081,Number of requested start processes (statistics)-engine_temperature_too_high_hour,0,
IDE03190-ENG118084,Number of requested start processes (statistics)-engine_temperature_too_high_kilometer,0,
IDE03190-ENG118082,Number of requested start processes (statistics)-engine_temperature_too_high_minute,0,
IDE03190-ENG118079,Number of requested start processes (statistics)-engine_temperature_too_high_month,0,
IDE03190-ENG118077,Number of requested start processes (statistics)-engine_temperature_too_high_prohibition_counter,0,
IDE03190-ENG118083,Number of requested start processes (statistics)-engine_temperature_too_high_second,0,
IDE03190-ENG118078,Number of requested start processes (statistics)-engine_temperature_too_high_year,0,
IDE03190-ENG118072,Number of requested start processes (statistics)-engine_temperature_too_low_day,2,
IDE03190-ENG118073,Number of requested start processes (statistics)-engine_temperature_too_low_hour,19,
IDE03190-ENG118076,Number of requested start processes (statistics)-engine_temperature_too_low_kilometer,3998,
IDE03190-ENG118074,Number of requested start processes (statistics)-engine_temperature_too_low_minute,37,
IDE03190-ENG118071,Number of requested start processes (statistics)-engine_temperature_too_low_month,12,
IDE03190-ENG118069,Number of requested start processes (statistics)-engine_temperature_too_low_prohibition_counter,4,
IDE03190-ENG118075,Number of requested start processes (statistics)-engine_temperature_too_low_second,38,
IDE03190-ENG118070,Number of requested start processes (statistics)-engine_temperature_too_low_year,18,
IDE03190-ENG118088,Number of requested start processes (statistics)-immobiliser_day,0,
IDE03190-ENG118089,Number of requested start processes (statistics)-immobiliser_hour,0,
IDE03190-ENG118092,Number of requested start processes (statistics)-immobiliser_kilometer,0,
IDE03190-ENG118090,Number of requested start processes (statistics)-immobiliser_minute,0,
IDE03190-ENG118087,Number of requested start processes (statistics)-immobiliser_month,0,
IDE03190-ENG118085,Number of requested start processes (statistics)-immobiliser_prohibition_counter,0,
IDE03190-ENG118091,Number of requested start processes (statistics)-immobiliser_second,0,
IDE03190-ENG118086,Number of requested start processes (statistics)-immobiliser_year,0,
IDE03190-ENG122348,Number of requested start processes (statistics)-Nox_control_system_day,0,
IDE03190-ENG122349,Number of requested start processes (statistics)-Nox_control_system_hour,0,
IDE03190-ENG122352,Number of requested start processes (statistics)-Nox_control_system_kilometer,0,
IDE03190-ENG122350,Number of requested start processes (statistics)-Nox_control_system_minute,0,
IDE03190-ENG122347,Number of requested start processes (statistics)-Nox_control_system_month,0,
IDE03190-ENG122345,Number of requested start processes (statistics)-Nox_control_system_prohibition_counter,0,
IDE03190-ENG122351,Number of requested start processes (statistics)-Nox_control_system_second,0,
IDE03190-ENG122346,Number of requested start processes (statistics)-Nox_control_system_year,0,
IDE03235,Neutral position sensor: current transmission angle,0.00,
IDE03236,Neutral position sensor: adapted transmission angle,0.00,
IDE03242,Injector for reduction agent: current holding phase,0.758, A
IDE03243,Reducing agent injector: current saturation phase,0.822, A
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03248,Pressure control valve adaptation factor,0.025,
IDE03288,Heating circuit 1 for reducing agent metering: activation,not active,
IDE03289,Heating circuit 2 for reducing agent metering: activation,not active,
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03383,Exhaust mass flow of EGR,0.0, kg/h
IDE03387,Duration of overtemperature at the reduction agent injector,96, s
IDE03583-MAS04416,Engine shut-down overrides-Sporadic function restriction,OFF,
IDE03583-MAS04417,Engine shut-down overrides-Poor start detection,OFF,
IDE03583-MAS04590,Engine shut-down overrides-Mixture adaptation,OFF,
IDE03583-MAS06089,Engine shut-down overrides-Low brake pressure,OFF,
IDE03583-MAS06602,Engine shut-down overrides-Engine temperature,OFF,
IDE03583-MAS06603,Engine shut-down overrides-Ambient pressure,OFF,
IDE03583-MAS06604,Engine shut-down overrides-Start-stop sensor system,On,
IDE03583-MAS06605,Engine shut-down overrides-Regeneration operation,OFF,
IDE03584-MAS04369,Engine starting requirements-Engine temperature too high,OFF,
IDE03584-MAS04370,Engine starting requirements-Engine temperature too low,OFF,
IDE03584-MAS06606,Engine starting requirements-Brake under pressure too low,OFF,
IDE03584-MAS06607,Engine starting requirements-SCR System requires restart,OFF,
IDE03584,Engine starting requirements,OFF,
IDE03584-ENG23258,Engine starting requirements-Reserved_5,OFF,
IDE03584-ENG23116,Engine starting requirements-Reserved_6,OFF,
IDE03584-ENG23184,Engine starting requirements-Reserved_7,OFF,
IDE03585,System status for the start/stop function master,active: no release by coordinator,
IDE03586-ENG118093,Starting requirements for active participants-Active_Member_1,OFF,
IDE03586-ENG118102,Starting requirements for active participants-Active_Member_10,OFF,
IDE03586-ENG118103,Starting requirements for active participants-Active_Member_11,OFF,
IDE03586-ENG118104,Starting requirements for active participants-Active_Member_12,OFF,
IDE03586-ENG118105,Starting requirements for active participants-Active_Member_13,OFF,
IDE03586-ENG118106,Starting requirements for active participants-Active_Member_14,OFF,
IDE03586-ENG118107,Starting requirements for active participants-Active_Member_15,OFF,
IDE03586-ENG118108,Starting requirements for active participants-Active_Member_16,OFF,
IDE03586-ENG118094,Starting requirements for active participants-Active_Member_2,OFF,
IDE03586-ENG118095,Starting requirements for active participants-Active_Member_3,OFF,
IDE03586-ENG118096,Starting requirements for active participants-Active_Member_4,OFF,
IDE03586-ENG118097,Starting requirements for active participants-Active_Member_5,OFF,
IDE03586-ENG118098,Starting requirements for active participants-Active_Member_6,OFF,
IDE03586-ENG118099,Starting requirements for active participants-Active_Member_7,OFF,
IDE03586-ENG118100,Starting requirements for active participants-Active_Member_8,OFF,
IDE03586-ENG118101,Starting requirements for active participants-Active_Member_9,OFF,
IDE03587-ENG118093,Stop overrides for active participants-Active_Member_1,OFF,
IDE03587-ENG118102,Stop overrides for active participants-Active_Member_10,OFF,
IDE03587-ENG118103,Stop overrides for active participants-Active_Member_11,OFF,
IDE03587-ENG118104,Stop overrides for active participants-Active_Member_12,OFF,
IDE03587-ENG118105,Stop overrides for active participants-Active_Member_13,OFF,
IDE03587-ENG118106,Stop overrides for active participants-Active_Member_14,OFF,
IDE03587-ENG118107,Stop overrides for active participants-Active_Member_15,OFF,
IDE03587-ENG118108,Stop overrides for active participants-Active_Member_16,OFF,
IDE03587-ENG118094,Stop overrides for active participants-Active_Member_2,OFF,
IDE03587-ENG118095,Stop overrides for active participants-Active_Member_3,OFF,
IDE03587-ENG118096,Stop overrides for active participants-Active_Member_4,OFF,
IDE03587-ENG118097,Stop overrides for active participants-Active_Member_5,OFF,
IDE03587-ENG118098,Stop overrides for active participants-Active_Member_6,OFF,
IDE03587-ENG118099,Stop overrides for active participants-Active_Member_7,OFF,
IDE03587-ENG118100,Stop overrides for active participants-Active_Member_8,OFF,
IDE03587-ENG118101,Stop overrides for active participants-Active_Member_9,OFF,
IDE03588-ENG118093,System malfunctions for active participants start/stop-Active_Member_1,OFF,
IDE03588-ENG118102,System malfunctions for active participants start/stop-Active_Member_10,OFF,
IDE03588-ENG118103,System malfunctions for active participants start/stop-Active_Member_11,OFF,
IDE03588-ENG118104,System malfunctions for active participants start/stop-Active_Member_12,OFF,
IDE03588-ENG118105,System malfunctions for active participants start/stop-Active_Member_13,OFF,
IDE03588-ENG118106,System malfunctions for active participants start/stop-Active_Member_14,OFF,
IDE03588-ENG118107,System malfunctions for active participants start/stop-Active_Member_15,OFF,
IDE03588-ENG118108,System malfunctions for active participants start/stop-Active_Member_16,OFF,
IDE03588-ENG118094,System malfunctions for active participants start/stop-Active_Member_2,OFF,
IDE03588-ENG118095,System malfunctions for active participants start/stop-Active_Member_3,OFF,
IDE03588-ENG118096,System malfunctions for active participants start/stop-Active_Member_4,OFF,
IDE03588-ENG118097,System malfunctions for active participants start/stop-Active_Member_5,OFF,
IDE03588-ENG118098,System malfunctions for active participants start/stop-Active_Member_6,OFF,
IDE03588-ENG118099,System malfunctions for active participants start/stop-Active_Member_7,OFF,
IDE03588-ENG118100,System malfunctions for active participants start/stop-Active_Member_8,OFF,
IDE03588-ENG118101,System malfunctions for active participants start/stop-Active_Member_9,OFF,
IDE03589-ENG118109,Error status for start-stop related sensors-Sensor_1,OFF,
IDE03589-ENG118110,Error status for start-stop related sensors-Sensor_2,On,
IDE03589-ENG118111,Error status for start-stop related sensors-Sensor_3,On,
IDE03589-ENG118112,Error status for start-stop related sensors-Sensor_4,OFF,
IDE03589-ENG118113,Error status for start-stop related sensors-Sensor_5,OFF,
IDE03589-ENG118114,Error status for start-stop related sensors-Sensor_6,OFF,
IDE03589-ENG118115,Error status for start-stop related sensors-Sensor_7,OFF,
IDE03589-ENG118116,Error status for start-stop related sensors-Sensor_8,OFF,
IDE03712,Engine diagnostic status in curr driving cycle (end-of-line),4289686245,
IDE03767,Engine status,Idling,
IDE04003,Charge air temperature sensor,B1S1/B1S2:56/45 C /  C,
IDE04007,Start of injection,-6.14,
IDE04008,Fuel consumption per hour,0.95, L/h
IDE04010,Engine torque: normalized,11, %
IDE04011,Nominal torque,500, Nm
IDE04015,exh.gas recirc.,EGR A:24/24/0 % / EGR B:---/---/--- %,
IDE04035,exh.gas recirc. temperature,EGRTemp 11/12:123/68 C / EGRTemp 21/22:---/--- C,
IDE04083,Coolant temperatures,ECT 1:70 C / ECT 2:48 C,
IDE04090,Exhaust temperature bank 1,S1/S2/S3/S4:  / 155/116/105/--- C,
IDE04098,NOX Sensor,NOx11:65535 ppm / NOx21:--- ,
IDE04099,Reduction agent dosing,ReAg Rate/Demand:0/0 L/h / Reag Tnk Lvl:75 %,
IDE04269,Intake manifold runner actuator: activation,34.97, %
IDE04270-IDE11376,Actuator for intake manifold runner control: status-Recognition of actuator closed or jammed open 2,not active,
IDE04270-MAS09413,Actuator for intake manifold runner control: status-open mech. stop approached,not active,
IDE04270-MAS09414,Actuator for intake manifold runner control: status-closed mech. stop approached,not active,
IDE04270-MAS09415,Actuator for intake manifold runner control: status-Adaptations met for offset on the mechan. stops,not active,
IDE04270-MAS09416,Actuator for intake manifold runner control: status-Adaptation active,not active,
IDE04270-MAS09417,Actuator for intake manifold runner control: status-open mech. stop adapted properly in current drive cycle,not active,
IDE04270-MAS09418,Actuator for intake manifold runner control: status-closed mech. stop adapted properly in current drive cycle,not active,
IDE04270-MAS09419,Actuator for intake manifold runner control: status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE04270-MAS09420,Actuator for intake manifold runner control: status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE04270-MAS09421,Actuator for intake manifold runner control: status-Ctrl. dev. detected after after breakaway function,not active,
IDE04270-MAS09422,Actuator for intake manifold runner control: status-Valve/actuator active: eng. running,active,
IDE04270-MAS09423,Actuator for intake manifold runner control: status-Valve/actuator active: eng. off,not active,
IDE04270-MAS09424,Actuator for intake manifold runner control: status-Breakaway function active,not active,
IDE04270-MAS09425,Actuator for intake manifold runner control: status-Effective current limit. limited at controller output,not active,
IDE04270-MAS09426,Actuator for intake manifold runner control: status-Actuator in shut-off position,not active,
IDE04270-MAS09427,Actuator for intake manifold runner control: status-Breakaway function unsuccessful: actuator control deactivated,active,
IDE04270-MAS09428,Actuator for intake manifold runner control: status-Error in limit setter: position control is deactivated,not active,
IDE04270-MAS09429,Actuator for intake manifold runner control: status-Breakaway function is lowered,not active,
IDE04270-MAS09433,Actuator for intake manifold runner control: status-higher voltage should press valve closed when at mech. stop,not active,
IDE04270-MAS09434,Actuator for intake manifold runner control: status-Positioner detected as closed or jammed in open pos.,not active,
IDE04270-MAS09435,Actuator for intake manifold runner control: status-Reset adaptation values,not active,
IDE04270-MAS09436,Actuator for intake manifold runner control: status-Ambient air temperature permits adaptation,active,
IDE04270-MAS09437,Actuator for intake manifold runner control: status-Exh. gas temp. permits adaptation,active,
IDE04270-MAS09438,Actuator for intake manifold runner control: status-Engine temp. permits adaptation,active,
IDE04270-MAS09439,Actuator for intake manifold runner control: status-Battery voltage permits adaptation,active,
IDE04270-MAS09440,Actuator for intake manifold runner control: status-Ambient press. permits adaptation,active,
IDE04270-MAS09441,Actuator for intake manifold runner control: status-Eng. run. time permits adaptation,not active,
IDE04270-MAS09442,Actuator for intake manifold runner control: status-Brake function active,not active,
IDE04270,Actuator for intake manifold runner control: status,520161280,
IDE04271,Intake manif runner actuator: uncond volt actual value,4.486, V
IDE04272,Counter for regeneration time of diesel particle filter,0, s
IDE04302-IDE11376,Bypass valve for high press turbocharger turbine inlet: status-Recognition of actuator closed or jammed open 2,not active,
IDE04302-MAS09413,Bypass valve for high press turbocharger turbine inlet: status-open mech. stop approached,not active,
IDE04302-MAS09414,Bypass valve for high press turbocharger turbine inlet: status-closed mech. stop approached,not active,
IDE04302-MAS09415,Bypass valve for high press turbocharger turbine inlet: status-Adaptations met for offset on the mechan. stops,not active,
IDE04302-MAS09416,Bypass valve for high press turbocharger turbine inlet: status-Adaptation active,not active,
IDE04302-MAS09417,Bypass valve for high press turbocharger turbine inlet: status-open mech. stop adapted properly in current drive cycle,not active,
IDE04302-MAS09418,Bypass valve for high press turbocharger turbine inlet: status-closed mech. stop adapted properly in current drive cycle,not active,
IDE04302-MAS09419,Bypass valve for high press turbocharger turbine inlet: status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE04302-MAS09420,Bypass valve for high press turbocharger turbine inlet: status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE04302-MAS09421,Bypass valve for high press turbocharger turbine inlet: status-Ctrl. dev. detected after after breakaway function,not active,
IDE04302-MAS09422,Bypass valve for high press turbocharger turbine inlet: status-Valve/actuator active: eng. running,not active,
IDE04302-MAS09423,Bypass valve for high press turbocharger turbine inlet: status-Valve/actuator active: eng. off,not active,
IDE04302-MAS09424,Bypass valve for high press turbocharger turbine inlet: status-Breakaway function active,not active,
IDE04302-MAS09425,Bypass valve for high press turbocharger turbine inlet: status-Effective current limit. limited at controller output,not active,
IDE04302-MAS09426,Bypass valve for high press turbocharger turbine inlet: status-Actuator in shut-off position,not active,
IDE04302-MAS09427,Bypass valve for high press turbocharger turbine inlet: status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE04302-MAS09428,Bypass valve for high press turbocharger turbine inlet: status-Error in limit setter: position control is deactivated,not active,
IDE04302-MAS09429,Bypass valve for high press turbocharger turbine inlet: status-Breakaway function is lowered,not active,
IDE04302-MAS09433,Bypass valve for high press turbocharger turbine inlet: status-higher voltage should press valve closed when at mech. stop,not active,
IDE04302-MAS09434,Bypass valve for high press turbocharger turbine inlet: status-Positioner detected as closed or jammed in open pos.,not active,
IDE04302-MAS09435,Bypass valve for high press turbocharger turbine inlet: status-Reset adaptation values,not active,
IDE04302-MAS09436,Bypass valve for high press turbocharger turbine inlet: status-Ambient air temperature permits adaptation,not active,
IDE04302-MAS09437,Bypass valve for high press turbocharger turbine inlet: status-Exh. gas temp. permits adaptation,not active,
IDE04302-MAS09438,Bypass valve for high press turbocharger turbine inlet: status-Engine temp. permits adaptation,not active,
IDE04302-MAS09439,Bypass valve for high press turbocharger turbine inlet: status-Battery voltage permits adaptation,not active,
IDE04302-MAS09440,Bypass valve for high press turbocharger turbine inlet: status-Ambient press. permits adaptation,not active,
IDE04302-MAS09441,Bypass valve for high press turbocharger turbine inlet: status-Eng. run. time permits adaptation,not active,
IDE04302-MAS09442,Bypass valve for high press turbocharger turbine inlet: status-Brake function active,not active,
IDE04302,Bypass valve for high press turbocharger turbine inlet: status,0,
IDE04468,Air mass at air mass meter 1,36.0, kg/h
IDE04623,Kick-down threshold,3.518, V
IDE04651,Torque request: A/C compressor,14.5, Nm
IDE04652,Exhaust gas jet volume in particle filter,40.9, m/h
IDE04653,Simulated particle filter surface temperature,99.0, C
IDE04654,CAN status - engine control module,0,
IDE04685,Setpoint generation interior torque,53.1, Nm
IDE04694,Engine diagnostic status 2 in curr driving cycle (end-of-line),4290733791,
IDE04713,Active brake system status,Not operated,
IDE04937,Sensor for engine block temperature: raw value,71.0, C
IDE05138,Shut-off timer: last engine shut-off time,0, s
IDE05139,Shut-off timer: last ECM after-run time,68, s
IDE05356,Calculated NOx concentration behind turbocharger,0, ppm
IDE05386,Exhaust model temperature 0,319.7, C
IDE05387,Exhaust model temperature 1,113.0, C
IDE05388,Exhaust model temperature 2,83.5, C
IDE05389,Exhaust model temperature 3,0.0, C
IDE05390,Exhaust model temperature 4,0.0, C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000198,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000014,
IDE05493,Air cleaner degree of soiling,0.00, %
IDE05494-MAS06902,Air cleaner full/empty detection-Full,No,
IDE05494,Air cleaner full/empty detection,0,
IDE05495-MAS05768,Suspicion of air cleaner icing-frosted,Yes,
IDE05495,Suspicion of air cleaner icing,1,
IDE05496-MAS03758,Air cleaner defrosted and cleared after suspicion of icing-Not Used,No,
IDE05496,Air cleaner defrosted and cleared after suspicion of icing,0,
IDE05625,Speed regulation requested torque,-3276.8, Nm
IDE05626,Calculated temperature at reduction agent injection valve,48.2, C
IDE05632,Fuel pressure regulator valve actual value,660.2, mA
IDE05633,Valve for fuel metering: feedback value measured,811.0, mA
IDE05694,Environmental pressure sensor gross voltage,4.046, V
IDE05861,DPF statistics: number of interrupted regenerations,0,
IDE05877,DPF statistics: regen time slice not poss in charge cycle,0.00000,
IDE05883,DPF statistics: regeneration time,0, s
IDE05901,DPF statistics: route in charge cycle,128000, m
IDE05903,DPF statistics: avg driv cycle time during charge cycle,0, s
IDE05908,DPF statistics: regeneration request,0,
IDE05910,DPF statistics: exhaust temperature regulation average value,0.00000,
IDE05918,DPF statistics: regeneration blocked status,0,
IDE05922,DPF statistics: error status,0,
IDE06059,Particulate filter: oil ash mass,7.70, g
IDE06060,Particulate filter ash load limit,110.00, g
IDE06216,DPF Statistics: average val.: exhaust temp. ctrl before DPF,-2.000,
IDE06386,Oil level: static measurement,72, mm
IDE06387,Oil level: last valid dynamic value,0, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,0, mm
IDE06390,Oil level: minimum value,0, mm
IDE06567,Start-stop function deactivation frequency counter,1391,
IDE06568,Stop prevention by driver frequency counter,3477,
IDE06569,Vehicle stopped frequency counter,5577,
IDE06610,Vehicle standstill with stop frequency counter,285,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,No,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,CCS operating unit,
IDE06708-MAS00322,Cruise control switch actuation-Engaged OFF,No,
IDE06708-MAS00323,Cruise control switch actuation-Decelerate tap,No,
IDE06708-MAS00324,Cruise control switch actuation-Accelerate tap,No,
IDE06708-MAS00325,Cruise control switch actuation-Setting,No,
IDE06708-MAS00326,Cruise control switch actuation-Activation,No,
IDE06708-MAS14965,Cruise control switch actuation-Plausibility check of main switch,Yes,
IDE06708-MAS14966,Cruise control switch actuation-Tip acceleration/deceleration second level,No,
IDE06708-MAS14967,Cruise control switch actuation-Operating error,No,
IDE06708-MAS14972,Cruise control switch actuation-Hardware signal main switch,Yes,
IDE06708-MAS14973,Cruise control switch actuation-Operating lever: Implausible coding,No,
IDE06708-MAS14974,Cruise control switch actuation-Limiter button pressed,No,
IDE06708-MAS14975,Cruise control switch actuation-Main switch off via CAN,No,
IDE06708-MAS14976,Cruise control switch actuation-variance adapted successfully,Yes,
IDE06709,ACC variants (coding),CCS,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06866,Range limit cancellation due to red. agent metering sys. fault,0,
IDE07051,Engaged gear: raw signal,0,
IDE07084,Differential pressure ratio: low-pressure EGR,0.000,
IDE07086,Exhaust mass flow of low-pressure EGR: calculated,0.0, kg/h
IDE07233-MAS07412,Bit string for status of oil level-Oil level OK,not active,
IDE07233-MAS07413,Bit string for status of oil level-Check oil level,not active,
IDE07233-MAS07414,Bit string for status of oil level-Oil level monitoring,not active,
IDE07233-MAS07415,Bit string for status of oil level-Top up oil,not active,
IDE07233-MAS07416,Bit string for status of oil level-Top up oil immediately,not active,
IDE07233-MAS07417,Bit string for status of oil level-Reduce oil level,not active,
IDE07233-MAS07418,Bit string for status of oil level-Oil level not available,not active,
IDE07233-MAS07419,Bit string for status of oil level-Measmnt. not possible while engine running,not active,
IDE07233-MAS07420,Bit string for status of oil level-Engine not at oper. temp.,not active,
IDE07233-MAS07421,Bit string for status of oil level-Vehicle not in level position,not active,
IDE07233-MAS07422,Bit string for status of oil level-Oil level display,not active,
IDE07233-MAS07423,Bit string for status of oil level-Sensor faulty,not active,
IDE07234,Status bid for valid static oil level,Condition met,
IDE07235,Status bid for dynamic oil level,Condition not met,
IDE07374-MAS05852,Cylinder mass flow: act. value calculated-Mass flow,46.8, kg/h
IDE07375,Charge pressure before throttle valve: calculated actual value,1.047, bar
IDE07376,Intake manifold pressure: act. value calculated,0.997, bar
IDE07377,Exhaust recirculation valve 1 bank 1: mass flow - nominal value,7.2, kg/h
IDE07379,Cylinder charge: spec. value,472.3, mg/stroke
IDE07380,NOx catalyst accumulator: sulfur charge: act. value calculated,0.00, g
IDE07381,Cylinder charge: act. value calculated,476.0, mg/stroke
IDE07382,Exhaust recirculation valve 2 bank 1: mass flow - nominal value,0.0, kg/h
IDE07384,Throttle valv.adapter 1 bank 1: output pressure - nominal value,0.988, bar
IDE07385,Exhaust recircul.valve 1 bank 1: intake pressur.- actual value,1.015, bar
IDE07386,Total HFM air mass flow: calculated,36.0, kg/h
IDE07528-MAS12283,Coordinator releases for DPF regeneration-Components and systems fault-free,Condition met,
IDE07528-MAS12284,Coordinator releases for DPF regeneration-Tank level > Min. limit,Condition met,
IDE07528-MAS12285,Coordinator releases for DPF regeneration-Time after engine start: start driving > Min. the limit,Condition met,
IDE07528-MAS12286,Coordinator releases for DPF regeneration-Min. limit < driving speed < max. limit,Condition met,
IDE07528-MAS12287,Coordinator releases for DPF regeneration-Power connection,Condition met,
IDE07528-MAS12288,Coordinator releases for DPF regeneration-Lowest gear: no gear shifting,Condition met,
IDE07528-MAS12289,Coordinator releases for DPF regeneration-Oxygen sensor before NSC operational and fault-free,Condition met,
IDE07528-MAS12290,Coordinator releases for DPF regeneration-Oxygen sensor after NSC operational and fault-free,Condition met,
IDE07528-MAS12291,Coordinator releases for DPF regeneration-Ambient pressure > Min. limit,Condition met,
IDE07528-MAS12292,Coordinator releases for DPF regeneration-Min. limit < ambient temperature < max. limit,Condition met,
IDE07528-MAS12293,Coordinator releases for DPF regeneration-Control module temp. < Max. limit,Condition met,
IDE07528-MAS12294,Coordinator releases for DPF regeneration-Fuel temp. < Max. limit,Condition met,
IDE07528-MAS12295,Coordinator releases for DPF regeneration-DPF fault-free,Condition met,
IDE07528-MAS12296,Coordinator releases for DPF regeneration-Metering release for SCR,Condition met,
IDE07528-MAS12297,Coordinator releases for DPF regeneration-Smoke limit inactive,Condition met,
IDE07528-MAS12298,Coordinator releases for DPF regeneration-Soot mass < Max. limit_1,Condition met,
IDE07528-MAS12299,Coordinator releases for DPF regeneration-Soot mass < Max. limit_2,Condition met,
IDE07528-MAS12300,Coordinator releases for DPF regeneration-Min. limit < engine speed < max. limit,Condition met,
IDE07528-MAS12301,Coordinator releases for DPF regeneration-Water quantity in charge air cooler < Max. limit,Condition met,
IDE07528-MAS12302,Coordinator releases for DPF regeneration-Internal torque < Max. limit,Condition met,
IDE07528-MAS12303,Coordinator releases for DPF regeneration-Internal torque > Min. limit,Condition met,
IDE07528-MAS12304,Coordinator releases for DPF regeneration-Min. limit < internal torque < max. limit,Condition met,
IDE07528-MAS12305,Coordinator releases for DPF regeneration-Dynamic internal torque < Max. limit,Condition met,
IDE07528-MAS12306,Coordinator releases for DPF regeneration-Positive control deviation motor filling < Max. limit,Condition met,
IDE07528-MAS12307,Coordinator releases for DPF regeneration-Negative control deviation motor filling > Min. limit,Condition met,
IDE07528-MAS12308,Coordinator releases for DPF regeneration-Min. limit < temperature after charge air cooler < max. limit,Condition met,
IDE07528-MAS12309,Coordinator releases for DPF regeneration-Min. limit < engine temperature < max. limit,Condition met,
IDE07528-MAS12310,Coordinator releases for DPF regeneration-Min. limit < combustion chamber temp. < max. limit,Condition met,
IDE07528-MAS12311,Coordinator releases for DPF regeneration-Combustion chamber temp. < Max. limit,Condition met,
IDE07528-MAS12312,Coordinator releases for DPF regeneration-Temperature before turbine < Max. limit,Condition met,
IDE07528-MAS12313,Coordinator releases for DPF regeneration-Temperature after DPF < Max. limit,Condition met,
IDE07528-MAS12314,Coordinator releases for DPF regeneration-Temperature after oxi cat. < Max. limit,Condition met,
IDE07528-MAS12315,Coordinator releases for DPF regeneration-Temperature after oxi cat. < Min. limit,Condition met,
IDE07528-MAS12316,Coordinator releases for DPF regeneration-NSC temperature < Max. limit,Condition met,
IDE07528-MAS12317,Coordinator releases for DPF regeneration-NSC temperature < Min. limit,Condition met,
IDE07528-MAS12318,Coordinator releases for DPF regeneration-Virtual temperature,Condition met,
IDE07528-MAS12611,Coordinator releases for DPF regeneration-Value,4294967295,
IDE07528,Coordinator releases for DPF regeneration,4294967295,
IDE07529-MAS12283,Coordinator releases: standard-Components and systems fault-free,Condition not met,
IDE07529-MAS12284,Coordinator releases: standard-Tank level > Min. limit,Condition not met,
IDE07529-MAS12285,Coordinator releases: standard-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07529-MAS12286,Coordinator releases: standard-Min. limit < driving speed < max. limit,Condition not met,
IDE07529-MAS12287,Coordinator releases: standard-Power connection,Condition not met,
IDE07529-MAS12288,Coordinator releases: standard-Lowest gear: no gear shifting,Condition not met,
IDE07529-MAS12289,Coordinator releases: standard-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07529-MAS12290,Coordinator releases: standard-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07529-MAS12291,Coordinator releases: standard-Ambient pressure > Min. limit,Condition not met,
IDE07529-MAS12292,Coordinator releases: standard-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07529-MAS12293,Coordinator releases: standard-Control module temp. < Max. limit,Condition not met,
IDE07529-MAS12294,Coordinator releases: standard-Fuel temp. < Max. limit,Condition not met,
IDE07529-MAS12295,Coordinator releases: standard-DPF fault-free,Condition not met,
IDE07529-MAS12296,Coordinator releases: standard-Metering release for SCR,Condition not met,
IDE07529-MAS12297,Coordinator releases: standard-Smoke limit inactive,Condition not met,
IDE07529-MAS12298,Coordinator releases: standard-Soot mass < Max. limit_1,Condition not met,
IDE07529-MAS12299,Coordinator releases: standard-Soot mass < Max. limit_2,Condition not met,
IDE07529-MAS12300,Coordinator releases: standard-Min. limit < engine speed < max. limit,Condition not met,
IDE07529-MAS12301,Coordinator releases: standard-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07529-MAS12302,Coordinator releases: standard-Internal torque < Max. limit,Condition not met,
IDE07529-MAS12303,Coordinator releases: standard-Internal torque > Min. limit,Condition not met,
IDE07529-MAS12304,Coordinator releases: standard-Min. limit < internal torque < max. limit,Condition not met,
IDE07529-MAS12305,Coordinator releases: standard-Dynamic internal torque < Max. limit,Condition not met,
IDE07529-MAS12306,Coordinator releases: standard-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07529-MAS12307,Coordinator releases: standard-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07529-MAS12308,Coordinator releases: standard-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07529-MAS12309,Coordinator releases: standard-Min. limit < engine temperature < max. limit,Condition not met,
IDE07529-MAS12310,Coordinator releases: standard-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07529-MAS12311,Coordinator releases: standard-Combustion chamber temp. < Max. limit,Condition not met,
IDE07529-MAS12312,Coordinator releases: standard-Temperature before turbine < Max. limit,Condition not met,
IDE07529-MAS12313,Coordinator releases: standard-Temperature after DPF < Max. limit,Condition not met,
IDE07529-MAS12314,Coordinator releases: standard-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07529-MAS12315,Coordinator releases: standard-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07529-MAS12316,Coordinator releases: standard-NSC temperature < Max. limit,Condition not met,
IDE07529-MAS12317,Coordinator releases: standard-NSC temperature < Min. limit,Condition not met,
IDE07529-MAS12318,Coordinator releases: standard-Virtual temperature,Condition not met,
IDE07529-MAS12611,Coordinator releases: standard-Value,0,
IDE07529,Coordinator releases: standard,0,
IDE07530-MAS12283,Coordinator releases for NOx reduction-Components and systems fault-free,Condition not met,
IDE07530-MAS12284,Coordinator releases for NOx reduction-Tank level > Min. limit,Condition not met,
IDE07530-MAS12285,Coordinator releases for NOx reduction-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07530-MAS12286,Coordinator releases for NOx reduction-Min. limit < driving speed < max. limit,Condition not met,
IDE07530-MAS12287,Coordinator releases for NOx reduction-Power connection,Condition not met,
IDE07530-MAS12288,Coordinator releases for NOx reduction-Lowest gear: no gear shifting,Condition not met,
IDE07530-MAS12289,Coordinator releases for NOx reduction-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07530-MAS12290,Coordinator releases for NOx reduction-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07530-MAS12291,Coordinator releases for NOx reduction-Ambient pressure > Min. limit,Condition not met,
IDE07530-MAS12292,Coordinator releases for NOx reduction-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07530-MAS12293,Coordinator releases for NOx reduction-Control module temp. < Max. limit,Condition not met,
IDE07530-MAS12294,Coordinator releases for NOx reduction-Fuel temp. < Max. limit,Condition not met,
IDE07530-MAS12295,Coordinator releases for NOx reduction-DPF fault-free,Condition not met,
IDE07530-MAS12296,Coordinator releases for NOx reduction-Metering release for SCR,Condition not met,
IDE07530-MAS12297,Coordinator releases for NOx reduction-Smoke limit inactive,Condition not met,
IDE07530-MAS12298,Coordinator releases for NOx reduction-Soot mass < Max. limit_1,Condition not met,
IDE07530-MAS12299,Coordinator releases for NOx reduction-Soot mass < Max. limit_2,Condition not met,
IDE07530-MAS12300,Coordinator releases for NOx reduction-Min. limit < engine speed < max. limit,Condition not met,
IDE07530-MAS12301,Coordinator releases for NOx reduction-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07530-MAS12302,Coordinator releases for NOx reduction-Internal torque < Max. limit,Condition not met,
IDE07530-MAS12303,Coordinator releases for NOx reduction-Internal torque > Min. limit,Condition not met,
IDE07530-MAS12304,Coordinator releases for NOx reduction-Min. limit < internal torque < max. limit,Condition not met,
IDE07530-MAS12305,Coordinator releases for NOx reduction-Dynamic internal torque < Max. limit,Condition not met,
IDE07530-MAS12306,Coordinator releases for NOx reduction-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07530-MAS12307,Coordinator releases for NOx reduction-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07530-MAS12308,Coordinator releases for NOx reduction-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07530-MAS12309,Coordinator releases for NOx reduction-Min. limit < engine temperature < max. limit,Condition not met,
IDE07530-MAS12310,Coordinator releases for NOx reduction-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07530-MAS12311,Coordinator releases for NOx reduction-Combustion chamber temp. < Max. limit,Condition not met,
IDE07530-MAS12312,Coordinator releases for NOx reduction-Temperature before turbine < Max. limit,Condition not met,
IDE07530-MAS12313,Coordinator releases for NOx reduction-Temperature after DPF < Max. limit,Condition not met,
IDE07530-MAS12314,Coordinator releases for NOx reduction-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07530-MAS12315,Coordinator releases for NOx reduction-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07530-MAS12316,Coordinator releases for NOx reduction-NSC temperature < Max. limit,Condition not met,
IDE07530-MAS12317,Coordinator releases for NOx reduction-NSC temperature < Min. limit,Condition not met,
IDE07530-MAS12318,Coordinator releases for NOx reduction-Virtual temperature,Condition not met,
IDE07530-MAS12611,Coordinator releases for NOx reduction-Value,0,
IDE07530,Coordinator releases for NOx reduction,0,
IDE07531-MAS12283,Coordinator releases: sulfur removal-Components and systems fault-free,Condition not met,
IDE07531-MAS12284,Coordinator releases: sulfur removal-Tank level > Min. limit,Condition not met,
IDE07531-MAS12285,Coordinator releases: sulfur removal-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07531-MAS12286,Coordinator releases: sulfur removal-Min. limit < driving speed < max. limit,Condition not met,
IDE07531-MAS12287,Coordinator releases: sulfur removal-Power connection,Condition not met,
IDE07531-MAS12288,Coordinator releases: sulfur removal-Lowest gear: no gear shifting,Condition not met,
IDE07531-MAS12289,Coordinator releases: sulfur removal-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07531-MAS12290,Coordinator releases: sulfur removal-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07531-MAS12291,Coordinator releases: sulfur removal-Ambient pressure > Min. limit,Condition not met,
IDE07531-MAS12292,Coordinator releases: sulfur removal-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07531-MAS12293,Coordinator releases: sulfur removal-Control module temp. < Max. limit,Condition not met,
IDE07531-MAS12294,Coordinator releases: sulfur removal-Fuel temp. < Max. limit,Condition not met,
IDE07531-MAS12295,Coordinator releases: sulfur removal-DPF fault-free,Condition not met,
IDE07531-MAS12296,Coordinator releases: sulfur removal-Metering release for SCR,Condition not met,
IDE07531-MAS12297,Coordinator releases: sulfur removal-Smoke limit inactive,Condition not met,
IDE07531-MAS12298,Coordinator releases: sulfur removal-Soot mass < Max. limit_1,Condition not met,
IDE07531-MAS12299,Coordinator releases: sulfur removal-Soot mass < Max. limit_2,Condition not met,
IDE07531-MAS12300,Coordinator releases: sulfur removal-Min. limit < engine speed < max. limit,Condition not met,
IDE07531-MAS12301,Coordinator releases: sulfur removal-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07531-MAS12302,Coordinator releases: sulfur removal-Internal torque < Max. limit,Condition not met,
IDE07531-MAS12303,Coordinator releases: sulfur removal-Internal torque > Min. limit,Condition not met,
IDE07531-MAS12304,Coordinator releases: sulfur removal-Min. limit < internal torque < max. limit,Condition not met,
IDE07531-MAS12305,Coordinator releases: sulfur removal-Dynamic internal torque < Max. limit,Condition not met,
IDE07531-MAS12306,Coordinator releases: sulfur removal-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07531-MAS12307,Coordinator releases: sulfur removal-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07531-MAS12308,Coordinator releases: sulfur removal-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07531-MAS12309,Coordinator releases: sulfur removal-Min. limit < engine temperature < max. limit,Condition not met,
IDE07531-MAS12310,Coordinator releases: sulfur removal-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07531-MAS12311,Coordinator releases: sulfur removal-Combustion chamber temp. < Max. limit,Condition not met,
IDE07531-MAS12312,Coordinator releases: sulfur removal-Temperature before turbine < Max. limit,Condition not met,
IDE07531-MAS12313,Coordinator releases: sulfur removal-Temperature after DPF < Max. limit,Condition not met,
IDE07531-MAS12314,Coordinator releases: sulfur removal-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07531-MAS12315,Coordinator releases: sulfur removal-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07531-MAS12316,Coordinator releases: sulfur removal-NSC temperature < Max. limit,Condition not met,
IDE07531-MAS12317,Coordinator releases: sulfur removal-NSC temperature < Min. limit,Condition not met,
IDE07531-MAS12318,Coordinator releases: sulfur removal-Virtual temperature,Condition not met,
IDE07531-MAS12611,Coordinator releases: sulfur removal-Value,0,
IDE07531,Coordinator releases: sulfur removal,0,
IDE07532-MAS12283,Coordinator releases for short trip-Components and systems fault-free,Condition not met,
IDE07532-MAS12284,Coordinator releases for short trip-Tank level > Min. limit,Condition not met,
IDE07532-MAS12285,Coordinator releases for short trip-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07532-MAS12286,Coordinator releases for short trip-Min. limit < driving speed < max. limit,Condition not met,
IDE07532-MAS12287,Coordinator releases for short trip-Power connection,Condition not met,
IDE07532-MAS12288,Coordinator releases for short trip-Lowest gear: no gear shifting,Condition not met,
IDE07532-MAS12289,Coordinator releases for short trip-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07532-MAS12290,Coordinator releases for short trip-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07532-MAS12291,Coordinator releases for short trip-Ambient pressure > Min. limit,Condition not met,
IDE07532-MAS12292,Coordinator releases for short trip-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07532-MAS12293,Coordinator releases for short trip-Control module temp. < Max. limit,Condition not met,
IDE07532-MAS12294,Coordinator releases for short trip-Fuel temp. < Max. limit,Condition not met,
IDE07532-MAS12295,Coordinator releases for short trip-DPF fault-free,Condition not met,
IDE07532-MAS12296,Coordinator releases for short trip-Metering release for SCR,Condition not met,
IDE07532-MAS12297,Coordinator releases for short trip-Smoke limit inactive,Condition not met,
IDE07532-MAS12298,Coordinator releases for short trip-Soot mass < Max. limit_1,Condition not met,
IDE07532-MAS12299,Coordinator releases for short trip-Soot mass < Max. limit_2,Condition not met,
IDE07532-MAS12300,Coordinator releases for short trip-Min. limit < engine speed < max. limit,Condition not met,
IDE07532-MAS12301,Coordinator releases for short trip-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07532-MAS12302,Coordinator releases for short trip-Internal torque < Max. limit,Condition not met,
IDE07532-MAS12303,Coordinator releases for short trip-Internal torque > Min. limit,Condition not met,
IDE07532-MAS12304,Coordinator releases for short trip-Min. limit < internal torque < max. limit,Condition not met,
IDE07532-MAS12305,Coordinator releases for short trip-Dynamic internal torque < Max. limit,Condition not met,
IDE07532-MAS12306,Coordinator releases for short trip-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07532-MAS12307,Coordinator releases for short trip-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07532-MAS12308,Coordinator releases for short trip-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07532-MAS12309,Coordinator releases for short trip-Min. limit < engine temperature < max. limit,Condition not met,
IDE07532-MAS12310,Coordinator releases for short trip-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07532-MAS12311,Coordinator releases for short trip-Combustion chamber temp. < Max. limit,Condition not met,
IDE07532-MAS12312,Coordinator releases for short trip-Temperature before turbine < Max. limit,Condition not met,
IDE07532-MAS12313,Coordinator releases for short trip-Temperature after DPF < Max. limit,Condition not met,
IDE07532-MAS12314,Coordinator releases for short trip-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07532-MAS12315,Coordinator releases for short trip-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07532-MAS12316,Coordinator releases for short trip-NSC temperature < Max. limit,Condition not met,
IDE07532-MAS12317,Coordinator releases for short trip-NSC temperature < Min. limit,Condition not met,
IDE07532-MAS12318,Coordinator releases for short trip-Virtual temperature,Condition not met,
IDE07532-MAS12611,Coordinator releases for short trip-Value,0,
IDE07532,Coordinator releases for short trip,0,
IDE07534,Target operating mode for engine,184619201,
IDE07535,Current operating mode of engine,184619201,
IDE07536,Next requested operating mode for engine,184619201,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,No,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,No,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,Yes,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,No,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,No,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC error,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07608,Standard test of current section,0,
IDE07706,Extern.temp.sens.1 bank 1: raw value,27.0, C
IDE07708,Turbocharg. 1 compressor outlet:temp.sensor 1 bank 1: raw value,56.5, C
IDE07709,Turboc.1 compres.outlet: temp.sensor 1 bank 1: uncnd.voltage,3.528, V
IDE07710,Charge air cool.output temp.sens.1 bank 1: raw value,45.0, C
IDE07711,Charge air cooler output temp.sens.1 bank 1: uncnd. voltage,3.885, V
IDE07712,Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value,158.5, C
IDE07713,Turbocharg.1 turbin.inlet: temp.sensor 1 bank 1:uncnd voltage,4.930, V
IDE07714,Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value,122.7, C
IDE07715,Turbochar.1 turbin.outlet: temp.sensor 1 bank 1: uncnd voltage,1.135, V
IDE07716,Particle filt.inlet temp.sens.1 bank 1: raw value,114.2, C
IDE07717,Particle filt.inlet temp.sens.1 bank 1: uncnd. voltage,1.115, V
IDE07718,Particle filter outlet temp.sens.1 bank 1: raw value,-40.0, C
IDE07719,Particulate filter output: temp. sensor 1: bank 1: raw voltage,0.003, V
IDE07724,Coolant temperature at engine outlet: calculated,72.0, C
IDE07725,Coolant temp.sens.1 bank 1 at cylinder head: raw value,72.0, C
IDE07726,Coolant temp.sens.1 bank 1 at cylinder head: uncnd. voltage,1.475, V
IDE07727,Coolant temp. sensor 1 bank 1 at cylinder head: raw value,48.5, C
IDE07728,Coolant temp. sensor 1 bank 1 at cylinder head: uncnd. voltage,2.350, V
IDE07729,Exh. gas recirc.temp. sens. 1 bank 1: raw value,74.5, C
IDE07730,Exhaust recirculation temp. sensor 1 bank 1: uncnd. voltage,1.024, V
IDE07733,Ambient air pressure sensor 1 bank 1: raw value,1.006, bar
IDE07734,Air filter outlet: pressure sensor 1 bank 1: raw value,1000, mbar
IDE07735,Air filter outlet: pressure sensor 1 bank 1: uncnd. voltage,0.000, V
IDE07736,Turbocharg.2 compress.outlet: press.sensor 1 bank 1: raw value,0, mbar
IDE07737-ENG49292,Turboc.2 compress.outlet: press.sensor 1 bank 1: uncnd. voltage-Voltage_16_usigned_1000,0.000, V
IDE07738,Charge air cooler inlet: pressure sensor 1 bank 1: raw value,999, mbar
IDE07739,Charge air cooler inlet: press.sensor 1 bank 1: uncnd. voltage,1.099, V
IDE07742,Cylinder head: pressure sensor 3 bank 1: raw value,41.5, bar
IDE07744,Particle filter: air pressure sensor 1 bank 1: raw value,9.0, mbar
IDE07745,Particl.filt.: different.press.sensor 1 bank 1: adaptat. value,7.3, mbar
IDE07746,Particl.filt.: differential press.sens.1 bank 1: uncnd.voltage,0.000, V
IDE07747,Par.fil: diff.pr.sens.1 bank 1: offset,0.0, mbar
IDE07748,Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset,1.7, mbar
IDE07754,Exhaust recirculation valve 1 bank 1: activation,20.64, %
IDE07755,Exhaust recirc.valve 1 bank 1: posit.feedback - Uncnd vlt,2.816, V
IDE07756,Exhaust recirc.valve 1 bank 1: posit.feedback - Spec.value,24.08, %
IDE07757,Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value,24.04, %
IDE07758,Exhaust recirc.valve 1 bank 1: posit.feedback -Offset closed.,0.00, %
IDE07759,Exh.recircul.valve 1 bank 1:posit.feedback - mech. stops,0,
IDE07760,Exh.recircul.valve 1 bank 1:posit.feedback - Breakaway attempts,0,
IDE07766,Exh.recircul.valve 2 bank 1:posit.feedback - mech. stops,0,
IDE07768,Throttle valve adapter 1 bank 1: activation,-12.43, %
IDE07769,Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt,1.378, V
IDE07770,Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value,79.99, %
IDE07771,Throttl.valve adapt. 1 bank 1: posit feedback - Act.value,79.91, %
IDE07772,Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed,0.55, %
IDE07773,Throttl.valve adapt. 1 bank 1: posit feedback - mech. stops,0,
IDE07774,Throttl.valve adapt.1 bank 1:pos.feedback - Breakaway attempts,0,
IDE07775,Exhaust recirculation valve 1 bank 1: activation,0.00, %
IDE07780,Exh.recircul.valve 1 bank 1: pos.feedback - mech. stops,0,
IDE07783,Turbine actuator 1 bank 1: posit.feedback - Uncnd vlt,0.630, V
IDE07784,Turbine actuator 1 bank 1: posit.feedback - Spec.value,100.00, %
IDE07785,Turbine actuator 1 bank 1: posit.feedback - Act.value,99.86, %
IDE07786,Turbine actuator 1 bank 1: posit.feedback - Offset closed,3.31, %
IDE07787,Turbine actuator 1 bank 1: posit.feedback - mech. stops,0,
IDE07788,Turbine actuator 1 bank 1: posit.feedback - Breakaway attempts,0,
IDE07789,Turbine actuator 1 bank 1: activation,95.00, %
IDE07790,Bypass valve for turboch 1 turbine inlet: activation,0.00, %
IDE07791-ENG49292,Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Uncnd vlt-Voltage_16_usigned_1000,0.000, V
IDE07792-ENG49291,Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Spec.value-Percent_16_usigned_100,0.00, %
IDE07793,Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Act.value,0.00, %
IDE07794,Turboch. 1 turb.byp.valve 1 B. 1:posit.feedback -Offset closed.,0.00, %
IDE07796-ENG114825,Turboch. 1 turb.byp.v. 1 bank 1: pos.feedback -Breakaw.attempts-Ident_32,0,
IDE07797-ENG49291,Injector 1 bank 1 for reducing agent before SCR cat: activation-Percent_16_usigned_100,0.00, %
IDE07798,Heater support pump 1 bank 1 second.circuit: activat.,95.00, %
IDE07799,Heater support pump 1 bank 1 primary circuit: activation,0.00, %
IDE07800,Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.,93.83, %
IDE07801,Mass airflow sensor 1 bank 1 airflow: raw value,382.6, mg/stroke
IDE07807,Fuel temp. sensor 1 bank 1: raw value,31.7, C
IDE07808,Fuel temp. sensor 1 bank 1 before CR pump: uncnd. voltage,2.604, V
IDE07812,Transmission neutral position sensor 1: raw value,0.00, %
IDE07815-MAS09445,Transmission neutral position sensor: adaptation status-Release of neutral gear output stage,not active,
IDE07815-MAS09446,Transmission neutral position sensor: adaptation status-Neutral gear detected,not active,
IDE07815-MAS09447,Transmission neutral position sensor: adaptation status-Neutral gear sensor - stop override,not active,
IDE07815-MAS09448,Transmission neutral position sensor: adaptation status-Neutral gear sensor adaptation completed for neutral gear,not active,
IDE07815-MAS09449,Transmission neutral position sensor: adaptation status-Neutral gear sensor adaption,not active,
IDE07815,Transmission neutral position sensor: adaptation status,0,
IDE07818,Fuel high pressure sensor: actual value,343.0, bar
IDE07819,Fuel high pressure sensor: unconditioned voltage,1.133, V
IDE07820,Fuel high pressure sensor: nominal value,341.0, bar
IDE07821,Fuel metering valve: activation,41.77, %
IDE07822,Fuel pressure regulator valve: activation,18.00, %
IDE07824,Tank-internal presupply pump 1 bank 1: activation,100.00, %
IDE07826,Accelerator pedal travel: raw value,0.00, %
IDE07827,Accelerator pedal: sensor voltage 1,0.718, V
IDE07828,Accelerator pedal: sensor voltage 2,0.366, V
IDE07832,Coolant fan 1: activation,44.00, %
IDE07833,Coolant fan 2: activation,0.00, %
IDE07834-MAS09443,Status of starter activation relay-Relay 1 activated,not active,
IDE07834-MAS09444,Status of starter activation relay-Relay 2 activated,not active,
IDE07904-ENG118117,Brake test switch status-actuated__activated,not activated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,not activated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,not activated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07916,Oxygen sensor bank 1 after oxi cat: exhaust temperat.calculated,140.5, C
IDE07928,Oxygen sensor bank 1 before oxi cat: exhaust temper. calculated,124.0, C
IDE07936,Oxyg.sens.bank 1 before oxi cat:act.-integr.pump curr.adapt.,0.000, A
IDE07984,Particle sensor: cleaning deviation reaction time,0.000,
IDE07987,Particle sensor: exhaust temperature,10.2, C
IDE07990,Particle sensor: surface temperature,198.8, C
IDE08064,Mass airflow sensor 1 bank 1 temperature sensor: raw value,42.5, C
IDE08065,Mass airflow sensor 1 bank 1 temperature sensor: raw value,0.000, V
IDE08067,Exhaust recirculat.2: different.press.sens.1 bank 1: offset,0.0, mbar
IDE08069-MAS05769,Fuel filter: water level sensor 1-Water,No,
IDE08069,Fuel filter: water level sensor 1,0,
IDE08132-ENG122793,SCR error notification reset status-SCR Inducement Group,0,
IDE08132-ENG122794,SCR error notification reset status-SCR Inducement State DFCC,0,
IDE08132-ENG45524,SCR error notification reset status-SCR Inducement Tester DFCC Five,0,
IDE08132-ENG45523,SCR error notification reset status-SCR Inducement Tester DFCC Four,0,
IDE08132-ENG45520,SCR error notification reset status-SCR Inducement Tester DFCC One,0,
IDE08132-ENG45522,SCR error notification reset status-SCR Inducement Tester DFCC Three,0,
IDE08132-ENG45521,SCR error notification reset status-SCR Inducement Tester DFCC Two,0,
IDE08138,Bypass valve for turboch 2 turbine inlet: activation,0.00, %
IDE08212,Standardised airflow ratio,1.233, counts
IDE08213,Standardised airflow ratio plausibility,invalid,
IDE08340,Particle sensor: measuring current calculated,0.0, A
IDE08721,Particle sensor: time in op. mode measurement,0.0, s
IDE09007,NOx sensor before SCR catalytic converter: supply voltage,0.000, V
IDE09009,NOx sensor after SCR catalytic converter: supply voltage,0.000, V
IDE09013,NOx sensor after SCR cat conv: O2 concen.,0.0000,
IDE09014,NOx sensor after SCR cat conv: offset correction factor,0, ppm
IDE09017,NOx sens.dwnstrm.SCR cat conv: NOx conc.,0, ppm
IDE09020,NOx sensor before SCR cat conv: O2 concen.,0.0000,
IDE09022,NOx sensor before SCR cat conv: offset correction factor,0, ppm
IDE09023-MAS14022,NOx sensor before SCR cat conv: status-Heater sensor release status,No,
IDE09023-MAS14023,NOx sensor before SCR cat conv: status-Status of binary Lambda signal,No,
IDE09023-MAS14024,NOx sensor before SCR cat conv: status-Status of linear Lambda signal,No,
IDE09023-MAS14025,NOx sensor before SCR cat conv: status-Com-Signal NOx-Sensor,No,
IDE09023-MAS14026,NOx sensor before SCR cat conv: status-Nox sensor ready for measurement,No,
IDE09023,NOx sensor before SCR cat conv: status,0,
IDE09024-MAS14022,NOx sensor after SCR cat conv: status-Heater sensor release status,No,
IDE09024-MAS14023,NOx sensor after SCR cat conv: status-Status of binary Lambda signal,Yes,
IDE09024-MAS14024,NOx sensor after SCR cat conv: status-Status of linear Lambda signal,Yes,
IDE09024-MAS14025,NOx sensor after SCR cat conv: status-Com-Signal NOx-Sensor,No,
IDE09024-MAS14026,NOx sensor after SCR cat conv: status-Nox sensor ready for measurement,No,
IDE09024,NOx sensor after SCR cat conv: status,6,
IDE09025,NOx sensor before SCR cat conv: NOx concentration,0, ppm
IDE09163,Exhaust recircul.2: different.press.sens.1 bank 1: dyn. offset,0.0, mbar
IDE09327,Cylinder 1 bank 1 internal moment,475.0, Nm
IDE09328,Cylinder 2 bank 1 internal moment,479.3, Nm
IDE09329,Cylinder 3 bank 1 internal moment,451.8, Nm
IDE09330,Cylinder 4 bank 1 internal moment,458.1, Nm
IDE09337,Intake manif.runner 1 bank1:pos. feedbck - Breakaway attempts,0,
IDE09338,Intake manif.runner 1 bank1:pos. feedbck - mech. stops,0,
IDE09339,Charge limit for service regeneration while driving,40.00, g
IDE09340,Primary injection: quantity setpoint,5.56, mg/stroke
IDE09420,Heat quantity for dewpoint end: particle sensor,0.00, %
IDE09648,EGR travel diagnosis: slightly increased NOx emission,47.30, kg/h
IDE09649,EGR travel diagnosis: strongly increased NOx emission,0.00, kg/h
IDE09650,AGR travel diag.: increased NOx emission effect. throttle valve,47.20, kg/h
IDE09651,EGR travel diagnosis: marginally increased NOx emission,-0.20, kg/h
IDE09683-MAS13144,Cylinder head: controller internal moment 1 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value,No,
IDE09683-MAS13145,Cylinder head: controller internal moment 1 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value,No,
IDE09683-MAS13146,Cylinder head: controller internal moment 1 bank 1: limit stat.-Offset combustion focus position < min. threshold,No,
IDE09683-MAS13147,Cylinder head: controller internal moment 1 bank 1: limit stat.-Offset combustion focus position >max. threshold,No,
IDE09683,Cylinder head: controller internal moment 1 bank 1: limit stat.,0,
IDE09684-MAS13144,Cylinder head: controller internal moment 2 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value,No,
IDE09684-MAS13145,Cylinder head: controller internal moment 2 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value,No,
IDE09684-MAS13146,Cylinder head: controller internal moment 2 bank 1: limit stat.-Offset combustion focus position < min. threshold,No,
IDE09684-MAS13147,Cylinder head: controller internal moment 2 bank 1: limit stat.-Offset combustion focus position >max. threshold,No,
IDE09684,Cylinder head: controller internal moment 2 bank 1: limit stat.,0,
IDE09685-MAS13144,Cylinder head: controller internal moment 3 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value,No,
IDE09685-MAS13145,Cylinder head: controller internal moment 3 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value,No,
IDE09685-MAS13146,Cylinder head: controller internal moment 3 bank 1: limit stat.-Offset combustion focus position < min. threshold,No,
IDE09685-MAS13147,Cylinder head: controller internal moment 3 bank 1: limit stat.-Offset combustion focus position >max. threshold,No,
IDE09685,Cylinder head: controller internal moment 3 bank 1: limit stat.,0,
IDE09686-MAS13144,Cylinder head: controller internal moment 4 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to min.value,No,
IDE09686-MAS13145,Cylinder head: controller internal moment 4 bank 1: limit stat.-Controller output of the foc.posit.contr. limited to max.value,No,
IDE09686-MAS13146,Cylinder head: controller internal moment 4 bank 1: limit stat.-Offset combustion focus position < min. threshold,No,
IDE09686-MAS13147,Cylinder head: controller internal moment 4 bank 1: limit stat.-Offset combustion focus position >max. threshold,No,
IDE09686,Cylinder head: controller internal moment 4 bank 1: limit stat.,0,
IDE09842,Delete engine diagnostic stat. since error memory (end-of-line),4294967295,
IDE09843,Delete engine diagn. stat. 2 since error memory (end-of-line),4294967295,
IDE09877,O2 sensor 1 bank 1 dwnstrm cat.: raw value,10.000, counts
IDE09879,O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current,0.000, A
IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,1.000, counts
IDE09881,O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value,4.964, V
IDE09886,Exhaust gas recirc. valve 2 bank 1: mass flow - calculated,0.0, kg/h
IDE10032,Reducing agent quality sensor: urea concentration,0.00, %
IDE10039,Reducing agent quality sensor: validity,invalid,
IDE10223-MAS09705,Install. list for actuators bank 1-High press. turbocharger actuator,supported,
IDE10223-MAS09706,Install. list for actuators bank 1-Low press. turbocharger actuator,Not supported,
IDE10223-MAS09707,Install. list for actuators bank 1-High press. turbocharger bypass valve,Not supported,
IDE10223-MAS09708,Install. list for actuators bank 1-Throttle valve,supported,
IDE10223-MAS09709,Install. list for actuators bank 1-High press. exh. gas recirc. actuator,supported,
IDE10223-MAS09710,Install. list for actuators bank 1-Low press. exh. gas recirc. actuator,Not supported,
IDE10223-MAS09711,Install. list for actuators bank 1-Exhaust flap,Not supported,
IDE10223-MAS09712,Install. list for actuators bank 1-Coolant pump,Not supported,
IDE10223-MAS09713,Install. list for actuators bank 1-Coolant pump load charge cooler,supported,
IDE10223-MAS09714,Install. list for actuators bank 1-Swirl flap,supported,
IDE10223-MAS09715,Install. list for actuators bank 1-Variable valve operation actuator,Not supported,
IDE10223-MAS09716,Install. list for actuators bank 1-Radiator shutter,Not supported,
IDE10223-MAS09717,Install. list for actuators bank 1-Coolant pump: short circuit,supported,
IDE10223-MAS09718,Install. list for actuators bank 1-Valve for exh. gas recirc. cooler HP,Not supported,
IDE10223,Install. list for actuators bank 1,0,
IDE10223,Install. list for actuators bank 1,529050,
IDE10223,Install. list for actuators bank 1,1,
IDE10224-MAS09678,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm of air filter,Not supported,
IDE10224-MAS09679,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm. of turbocharger LP,Not supported,
IDE10224-MAS09680,Install. list for pressure and O2 sensors bank 1-Press. sens. upstrm. of charg. air cool.,supported,
IDE10224-MAS09681,Install. list for pressure and O2 sensors bank 1-Press. sens. above diesel part. filter,Not supported,
IDE10224-MAS09682,Install. list for pressure and O2 sensors bank 1-Press. sensor above exh. gas recirc. LP,Not supported,
IDE10224-MAS09684,Install. list for pressure and O2 sensors bank 1-Oxygen sensor upstrm. of oxidation cat.,supported,
IDE10224-MAS09685,Install. list for pressure and O2 sensors bank 1-Oxygen sensor dwnstrm. of oxidation cat.,Not supported,
IDE10224-MAS09686,Install. list for pressure and O2 sensors bank 1-Knox sensor upstrm. of SCAR cat.,Not supported,
IDE10224-MAS09687,Install. list for pressure and O2 sensors bank 1-NOx sensor dwnstrm. of SCR cat.,supported,
IDE10224-MAS09688,Install. list for pressure and O2 sensors bank 1-Cylinder press. sensor,supported,
IDE10224-MAS09689,Install. list for pressure and O2 sensors bank 1-Particulate sensor,supported,
IDE10224-MAS09690,Install. list for pressure and O2 sensors bank 1-Knock sensor,supported,
IDE10224-MAS09691,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm of air filter (SENT),Not supported,
IDE10224-MAS09692,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm. of turbocharger LP (SENT),Not supported,
IDE10224-MAS09693,Install. list for pressure and O2 sensors bank 1-Press. sens. upstrm. of charg. air cool. (SENT),Not supported,
IDE10224-MAS09694,Install. list for pressure and O2 sensors bank 1-Press. sens. above diesel part. filter (SENT),supported,
IDE10224-MAS09695,Install. list for pressure and O2 sensors bank 1-Press. sensor above exh. gas recirc. LP (SENT),Not supported,
IDE10224-MAS09697,Install. list for pressure and O2 sensors bank 1-Oxygen sensor upstrm. of oxidation cat. (SENT),Not supported,
IDE10224-MAS09698,Install. list for pressure and O2 sensors bank 1-Oxygen sensor dwnstrm. of oxidation cat. (SENT),Not supported,
IDE10224-MAS09699,Install. list for pressure and O2 sensors bank 1-NOx sensor upstrm. of SCAR cat. (SENT),Not supported,
IDE10224-MAS09700,Install. list for pressure and O2 sensors bank 1-NOx sensor dwnstrm. of SCAR cat. (SENT),Not supported,
IDE10224-MAS09701,Install. list for pressure and O2 sensors bank 1-Cylinder press. sensor (SENT),Not supported,
IDE10224-MAS09702,Install. list for pressure and O2 sensors bank 1-Particle sensor (SENT),Not supported,
IDE10224-MAS09703,Install. list for pressure and O2 sensors bank 1-Knock sensor (SENT),Not supported,
IDE10224,Install. list for pressure and O2 sensors bank 1,0,
IDE10224,Install. list for pressure and O2 sensors bank 1,1,
IDE10224,Install. list for pressure and O2 sensors bank 1,583876,
IDE10225-MAS08988,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. upstrm of turbocharger,supported,
IDE10225-MAS08989,Install. list for temperature sensors bank 1-Exh. gas temperature sensor upstrm. of oxidation cat.,supported,
IDE10225-MAS08990,Install. list for temperature sensors bank 1-Exh. gas temperature sensor dwnstrm. of oxidation cat.,supported,
IDE10225-MAS09653,Install. list for temperature sensors bank 1-Exh. gas temp. sens. upstrm. of diesel particle filter,Not supported,
IDE10225-MAS09654,Install. list for temperature sensors bank 1-Exh. gas temp. sens. dwnstrm. of diesel particle filter,Not supported,
IDE10225-MAS09655,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. LP,Not supported,
IDE10225-MAS09656,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. HP,supported,
IDE10225-MAS09657,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of radiator,supported,
IDE10225-MAS09658,Install. list for temperature sensors bank 1-Coolant temp. sensor dwnstrm. of radiator,supported,
IDE10225-MAS09659,Install. list for temperature sensors bank 1-Coolant temp. sensor in cylinder head,Not supported,
IDE10225-MAS09660,Install. list for temperature sensors bank 1-Intake air temperature sensor in mass airflow sensor,Not supported,
IDE10225-MAS09661,Install. list for temperature sensors bank 1-Intake air temp. sensor upstrm. of charge air cooler,supported,
IDE10225-MAS09662,Install. list for temperature sensors bank 1-Intake air temp. sensor dwnstrm. of charge air cooler,supported,
IDE10225-MAS09663,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of exh.gas recirc. cooler HP,supported,
IDE10225-MAS09664,Install. list for temperature sensors bank 1-Exh. gas temp. sens. upstrm. of turbocharger (SENT),Not supported,
IDE10225-MAS09665,Install. list for temperature sensors bank 1-Exhaust gas temp. sensor upstrm. of oxidation cat. (SENT),Not supported,
IDE10225-MAS09666,Install. list for temperature sensors bank 1-Exhaust gas temp. sensor dwnstrm. of oxidation cat. (SENT),Not supported,
IDE10225-MAS09667,Install. list for temperature sensors bank 1-Exh. gas temp. sensor upstrm. of diesel particle filter (SENT),Not supported,
IDE10225-MAS09668,Install. list for temperature sensors bank 1-Exh. gas temp. sensor dwnstrm. of diesel particle filter (SENT),Not supported,
IDE10225-MAS09669,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. LP (SENT),Not supported,
IDE10225-MAS09670,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. HP (SENT),Not supported,
IDE10225-MAS09671,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of radiator (SENT),Not supported,
IDE10225-MAS09672,Install. list for temperature sensors bank 1-Coolant temp. sensor dwnstrm. of radiator (SENT),Not supported,
IDE10225-MAS09673,Install. list for temperature sensors bank 1-Coolant temp. sensor in cylinder head (SENT),Not supported,
IDE10225-MAS09674,Install. list for temperature sensors bank 1-Intake air temperature sensor in mass airflow sensor (SENT),Not supported,
IDE10225-MAS09675,Install. list for temperature sensors bank 1-Intake air temp. sensor upstrm. of charge air cooler (SENT),Not supported,
IDE10225-MAS09676,Install. list for temperature sensors bank 1-Intake air temp. sensor dwnstrm. of charge air cooler (SENT),Not supported,
IDE10225-MAS09677,Install. list for temperature sensors bank 1-Coolant tem.sens.upstrm. of radiator exh.gas recirc. HP (SENT),Not supported,
IDE10225,Install. list for temperature sensors bank 1,0,
IDE10225,Install. list for temperature sensors bank 1,14791,
IDE10241,Reducing agent pump module relative press.: calculated,0, mbar
IDE10247,Reducing agent tank volume: act. value calculated,15.192, l
IDE10248,Reducing agent supply pump: offset factor calculated,1.006,
IDE10249,Reducing agent fill level sensor: act. value,81, mm
IDE10250,Reducing agent return pump: adapted displacement,0.038, ml
IDE10251,Reducing agent supply pump: measured resistance,4.315, Ohm
IDE10252,Operatingn hour reducing agent system: flawless,255, counts
IDE10257,Turbocharger 1 turbine byp.valve 1 bank 1 pos.contr.spec.val.,0.00, %
IDE10312,Exh. gas recirc. 1 bank 1: act.temp. of water upst. of radiator,48.2, C
IDE10313-IDE11376,Exhaust recirculation valve 1 bank 1: monitoring - status-Recognition of actuator closed or jammed open 2,not active,
IDE10313-MAS09413,Exhaust recirculation valve 1 bank 1: monitoring - status-open mech. stop approached,not active,
IDE10313-MAS09414,Exhaust recirculation valve 1 bank 1: monitoring - status-closed mech. stop approached,not active,
IDE10313-MAS09415,Exhaust recirculation valve 1 bank 1: monitoring - status-Adaptations met for offset on the mechan. stops,active,
IDE10313-MAS09416,Exhaust recirculation valve 1 bank 1: monitoring - status-Adaptation active,not active,
IDE10313-MAS09417,Exhaust recirculation valve 1 bank 1: monitoring - status-open mech. stop adapted properly in current drive cycle,not active,
IDE10313-MAS09418,Exhaust recirculation valve 1 bank 1: monitoring - status-closed mech. stop adapted properly in current drive cycle,not active,
IDE10313-MAS09419,Exhaust recirculation valve 1 bank 1: monitoring - status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE10313-MAS09420,Exhaust recirculation valve 1 bank 1: monitoring - status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE10313-MAS09421,Exhaust recirculation valve 1 bank 1: monitoring - status-Ctrl. dev. detected after after breakaway function,not active,
IDE10313-MAS09422,Exhaust recirculation valve 1 bank 1: monitoring - status-Valve/actuator active: eng. running,active,
IDE10313-MAS09423,Exhaust recirculation valve 1 bank 1: monitoring - status-Valve/actuator active: eng. off,not active,
IDE10313-MAS09424,Exhaust recirculation valve 1 bank 1: monitoring - status-Breakaway function active,not active,
IDE10313-MAS09425,Exhaust recirculation valve 1 bank 1: monitoring - status-Effective current limit. limited at controller output,not active,
IDE10313-MAS09426,Exhaust recirculation valve 1 bank 1: monitoring - status-Actuator in shut-off position,not active,
IDE10313-MAS09427,Exhaust recirculation valve 1 bank 1: monitoring - status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE10313-MAS09428,Exhaust recirculation valve 1 bank 1: monitoring - status-Error in limit setter: position control is deactivated,not active,
IDE10313-MAS09429,Exhaust recirculation valve 1 bank 1: monitoring - status-Breakaway function is lowered,not active,
IDE10313-MAS09433,Exhaust recirculation valve 1 bank 1: monitoring - status-higher voltage should press valve closed when at mech. stop,not active,
IDE10313-MAS09434,Exhaust recirculation valve 1 bank 1: monitoring - status-Positioner detected as closed or jammed in open pos.,not active,
IDE10313-MAS09435,Exhaust recirculation valve 1 bank 1: monitoring - status-Reset adaptation values,not active,
IDE10313-MAS09436,Exhaust recirculation valve 1 bank 1: monitoring - status-Ambient air temperature permits adaptation,active,
IDE10313-MAS09437,Exhaust recirculation valve 1 bank 1: monitoring - status-Exh. gas temp. permits adaptation,active,
IDE10313-MAS09438,Exhaust recirculation valve 1 bank 1: monitoring - status-Engine temp. permits adaptation,active,
IDE10313-MAS09439,Exhaust recirculation valve 1 bank 1: monitoring - status-Battery voltage permits adaptation,active,
IDE10313-MAS09440,Exhaust recirculation valve 1 bank 1: monitoring - status-Ambient press. permits adaptation,active,
IDE10313-MAS09441,Exhaust recirculation valve 1 bank 1: monitoring - status-Eng. run. time permits adaptation,active,
IDE10313-MAS09442,Exhaust recirculation valve 1 bank 1: monitoring - status-Brake function active,not active,
IDE10313,Exhaust recirculation valve 1 bank 1: monitoring - status,1056966660,
IDE10316-IDE11376,Turbine actuator 1 bank 1: monitoring - status-Recognition of actuator closed or jammed open 2,not active,
IDE10316-MAS09413,Turbine actuator 1 bank 1: monitoring - status-open mech. stop approached,not active,
IDE10316-MAS09414,Turbine actuator 1 bank 1: monitoring - status-closed mech. stop approached,active,
IDE10316-MAS09415,Turbine actuator 1 bank 1: monitoring - status-Adaptations met for offset on the mechan. stops,active,
IDE10316-MAS09416,Turbine actuator 1 bank 1: monitoring - status-Adaptation active,not active,
IDE10316-MAS09417,Turbine actuator 1 bank 1: monitoring - status-open mech. stop adapted properly in current drive cycle,not active,
IDE10316-MAS09418,Turbine actuator 1 bank 1: monitoring - status-closed mech. stop adapted properly in current drive cycle,not active,
IDE10316-MAS09419,Turbine actuator 1 bank 1: monitoring - status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE10316-MAS09420,Turbine actuator 1 bank 1: monitoring - status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE10316-MAS09421,Turbine actuator 1 bank 1: monitoring - status-Ctrl. dev. detected after after breakaway function,not active,
IDE10316-MAS09422,Turbine actuator 1 bank 1: monitoring - status-Valve/actuator active: eng. running,active,
IDE10316-MAS09423,Turbine actuator 1 bank 1: monitoring - status-Valve/actuator active: eng. off,not active,
IDE10316-MAS09424,Turbine actuator 1 bank 1: monitoring - status-Breakaway function active,not active,
IDE10316-MAS09425,Turbine actuator 1 bank 1: monitoring - status-Effective current limit. limited at controller output,not active,
IDE10316-MAS09426,Turbine actuator 1 bank 1: monitoring - status-Actuator in shut-off position,not active,
IDE10316-MAS09427,Turbine actuator 1 bank 1: monitoring - status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE10316-MAS09428,Turbine actuator 1 bank 1: monitoring - status-Error in limit setter: position control is deactivated,not active,
IDE10316-MAS09429,Turbine actuator 1 bank 1: monitoring - status-Breakaway function is lowered,not active,
IDE10316-MAS09433,Turbine actuator 1 bank 1: monitoring - status-higher voltage should press valve closed when at mech. stop,not active,
IDE10316-MAS09434,Turbine actuator 1 bank 1: monitoring - status-Positioner detected as closed or jammed in open pos.,not active,
IDE10316-MAS09435,Turbine actuator 1 bank 1: monitoring - status-Reset adaptation values,not active,
IDE10316-MAS09436,Turbine actuator 1 bank 1: monitoring - status-Ambient air temperature permits adaptation,active,
IDE10316-MAS09437,Turbine actuator 1 bank 1: monitoring - status-Exh. gas temp. permits adaptation,active,
IDE10316-MAS09438,Turbine actuator 1 bank 1: monitoring - status-Engine temp. permits adaptation,active,
IDE10316-MAS09439,Turbine actuator 1 bank 1: monitoring - status-Battery voltage permits adaptation,active,
IDE10316-MAS09440,Turbine actuator 1 bank 1: monitoring - status-Ambient press. permits adaptation,active,
IDE10316-MAS09441,Turbine actuator 1 bank 1: monitoring - status-Eng. run. time permits adaptation,active,
IDE10316-MAS09442,Turbine actuator 1 bank 1: monitoring - status-Brake function active,not active,
IDE10316,Turbine actuator 1 bank 1: monitoring - status,1056966662,
IDE10402-IDE11376,Throttle valve adapter 1 bank 1: monitoring - status-Recognition of actuator closed or jammed open 2,not active,
IDE10402-MAS09413,Throttle valve adapter 1 bank 1: monitoring - status-open mech. stop approached,not active,
IDE10402-MAS09414,Throttle valve adapter 1 bank 1: monitoring - status-closed mech. stop approached,not active,
IDE10402-MAS09415,Throttle valve adapter 1 bank 1: monitoring - status-Adaptations met for offset on the mechan. stops,active,
IDE10402-MAS09416,Throttle valve adapter 1 bank 1: monitoring - status-Adaptation active,not active,
IDE10402-MAS09417,Throttle valve adapter 1 bank 1: monitoring - status-open mech. stop adapted properly in current drive cycle,not active,
IDE10402-MAS09418,Throttle valve adapter 1 bank 1: monitoring - status-closed mech. stop adapted properly in current drive cycle,not active,
IDE10402-MAS09419,Throttle valve adapter 1 bank 1: monitoring - status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE10402-MAS09420,Throttle valve adapter 1 bank 1: monitoring - status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE10402-MAS09421,Throttle valve adapter 1 bank 1: monitoring - status-Ctrl. dev. detected after after breakaway function,not active,
IDE10402-MAS09422,Throttle valve adapter 1 bank 1: monitoring - status-Valve/actuator active: eng. running,active,
IDE10402-MAS09423,Throttle valve adapter 1 bank 1: monitoring - status-Valve/actuator active: eng. off,not active,
IDE10402-MAS09424,Throttle valve adapter 1 bank 1: monitoring - status-Breakaway function active,not active,
IDE10402-MAS09425,Throttle valve adapter 1 bank 1: monitoring - status-Effective current limit. limited at controller output,not active,
IDE10402-MAS09426,Throttle valve adapter 1 bank 1: monitoring - status-Actuator in shut-off position,not active,
IDE10402-MAS09427,Throttle valve adapter 1 bank 1: monitoring - status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE10402-MAS09428,Throttle valve adapter 1 bank 1: monitoring - status-Error in limit setter: position control is deactivated,not active,
IDE10402-MAS09429,Throttle valve adapter 1 bank 1: monitoring - status-Breakaway function is lowered,not active,
IDE10402-MAS09433,Throttle valve adapter 1 bank 1: monitoring - status-higher voltage should press valve closed when at mech. stop,not active,
IDE10402-MAS09434,Throttle valve adapter 1 bank 1: monitoring - status-Positioner detected as closed or jammed in open pos.,not active,
IDE10402-MAS09435,Throttle valve adapter 1 bank 1: monitoring - status-Reset adaptation values,not active,
IDE10402-MAS09436,Throttle valve adapter 1 bank 1: monitoring - status-Ambient air temperature permits adaptation,active,
IDE10402-MAS09437,Throttle valve adapter 1 bank 1: monitoring - status-Exh. gas temp. permits adaptation,active,
IDE10402-MAS09438,Throttle valve adapter 1 bank 1: monitoring - status-Engine temp. permits adaptation,active,
IDE10402-MAS09439,Throttle valve adapter 1 bank 1: monitoring - status-Battery voltage permits adaptation,active,
IDE10402-MAS09440,Throttle valve adapter 1 bank 1: monitoring - status-Ambient press. permits adaptation,active,
IDE10402-MAS09441,Throttle valve adapter 1 bank 1: monitoring - status-Eng. run. time permits adaptation,active,
IDE10402-MAS09442,Throttle valve adapter 1 bank 1: monitoring - status-Brake function active,not active,
IDE10402,Throttle valve adapter 1 bank 1: monitoring - status,1056966660,
IDE10565,Reducing agent dosing quantity check: release conditions,0,
IDE10566,NOx sensor upstrm. of SCR cat.: activ. condit. offset diagnosis,not active,
IDE10567,NOx sensor dwnstrm. of SCR cat.: activ. condit. offset diagnos.,not active,
IDE10569,Turbo charger 1 Turbine inp.: Temp. sensor 1 Bank 1: raw data,0,
IDE10570,Turbo charger.1 turbine inp.: temp.sensor 1 bank 1: comp. temp.,0.0, C
IDE10571,Turbo charger.1 turbine inp.: temp.sens. 1 bank 1: ins.resist.,0, kOhm
IDE10572,Exh. gas temp. sens. upstrm. of turbo chgr.: intern. error code,0,
IDE10573,Exh. gas temp. sens. upstrm. of turbo chgr.: sens. type,0,
IDE10574,Exh. gas temp. sens. upstrm. of turbo chgr.: sens. mod.,0,
IDE10575,Exh. gas temp. sens. upstrm. of turbo chgr.: manf. ID,0,
IDE10579-MAS01493,Reducing agent system pressurization release conditions-Engine running,Condition met,
IDE10579-MAS10830,Reducing agent system pressurization release conditions-Press. enabled,Condition met,
IDE10579-MAS10831,Reducing agent system pressurization release conditions-Heat. strategy: enable,Condition met,
IDE10579-MAS10832,Reducing agent system pressurization release conditions-Depressurized min. time below limit,Condition met,
IDE10579-MAS10833,Reducing agent system pressurization release conditions-Catalyst temp.reached,Condition not met,
IDE10579-MAS10834,Reducing agent system pressurization release conditions-Release due to jammed valve needle,Condition met,
IDE10579-MAS10835,Reducing agent system pressurization release conditions-Rinse function finished,Condition met,
IDE10579-MAS10836,Reducing agent system pressurization release conditions-Initial filling completed,Condition met,
IDE10579-MAS13646,Reducing agent system pressurization release conditions-Release via inducement,Condition not met,
IDE10579,Reducing agent system pressurization release conditions,751,
IDE10633,Clutch protection function: reduced torque,0.0, Nm
IDE10634,Clutch protection function: slip speed of the clutch,0, /min
IDE10811,Release requirement for DPF regeneration,0,
IDE10812,Diesel particulate filter regeneration: status,0,
IDE10815,Post injection 2: quantity spec. value,0.00, mg/stroke
IDE10816,Diesel particulate filter regen. level: current,0,
IDE10817,Lambda value at inlet of particulate filter,3.507,
IDE10818,Temp. spec. value for exhaust gas temp.con.dwnstrm. of oxi-cat,0.0, C
IDE10819,Exh. gas temp.control dwnstrm. of oxi-cat: filtered model error,32.5, C
IDE10820,Exh. gas temp. ctrl. upstrm. of turbine: spec. value,650.0, C
IDE10826,Exh. gas temp. controller upstrm. of turbine: I-part,0.000,
IDE10827,Exh.gas temp.contr. dwnstrm.of oxi-cat:post inject.qty.spec.val,0.00, mg/stroke
IDE10828,Exh. gas temp.contr. upstrm. of turbine: post inject.qty.corr.,0.00, mg/stroke
IDE10829,Post injection 1: quantity spec. value,0.00, mg/stroke
IDE10830,Post injection 3: quantity spec. value,0.00, mg/stroke
IDE10916,Reducing agent system debounce distance,0, km
IDE10917,Reducing agent delivery pump: coil temperature,298.3, C
IDE10918,Reducing agent: dosing qty. test calculated: actual volume,655.35, g
IDE10919,Reducing agent: dosing qty. test: calculated specified volume,0.00, g
IDE10920,Temp. upstrm. of reducing agent cat.: calculated,143.2, C
IDE10921,Reducing agent delivery pump: number of strokes,0,
IDE10968,Activation radiator shutter result,0.00, %
IDE10994,Poor start counter at start-stop,0,
IDE11067,Index of next requested engine mode,11,
IDE11068,Index of current engine mode,11,
IDE11069,Index of engine target mode,11,
IDE11074,Fuel pres.sen. 1 bank 1 upstream from HD pump: press. dev.,0, mbar
IDE11114,Fuel press. sensor 1 bank 1 upstr. from HD pump: adapt. value,0, mbar
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,22,
IDE11117-ENG127253,Charge press. ctrl deviation after throttle valve bank 1-Pressure_16_signed_10_mbar,342.9, mbar
IDE11118,Pressure after throttle valve: calculated,0.9, bar
IDE11119-ENG127253,Pressure corr. value after low pressure EGR valve: calculated-Pressure_16_signed_10_mbar,0.0, mbar
IDE11219,Reducing agent inj. quantity: spec. value,0, mg/s
IDE11220,Reducing agent system: current status,COSCR_no pressure control,
IDE11220,Reducing agent system: current status,2,
IDE11221,Reducing agent system: last status,COSCR_STANDBY,
IDE11221,Reducing agent system: last status,1,
IDE11222,Reducing agent system: current substatus,COSCR_INVALID,
IDE11222,Reducing agent system: current substatus,255,
IDE11223,Reducing agent system: last substatus,Unknown (0),
IDE11223,Reducing agent system: last substatus,0,
IDE11250,Reducing agent quality sensor: raw temperature value,0.0, C
IDE11311,Exh. recirc.cooler 1 bank 1: wat. temp. from cool.:uncond volt.,2.350, V
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometers,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometers,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometers,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometers,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometers,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometers,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometers,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometers,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometers,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometers,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11392,Activation of radiator shutter 2,0.00, %
IDE11448,Reducing agent over-pressure: diagnosis progress,0, %
IDE11449,Reducing agent under-pressure: diagnosis progress,0, %
IDE11574,Status max. oil level dynamically exceeded,No,
IDE11575,Status max. oil level permanently exceeded,No,
IDE11576,Oil level: last valid dynamic value overfilling,0.0, mm
IDE11621,Minimum deviation quantity: number of adapted points,0,
IDE11635,Radiator shutter 1: status referencing,completed successfully,
IDE11636,Radiator shutter 2: status referencing,completed successfully,
IDE11870,Heater supp.pump 1 bank 1 exh.gas recir.cool.circ.: activation,100.00, %
IDE11871,Exh.gas temp.sen upstr. of HD exh.gas recir.valv.:raw voltage,1.169, V
IDE11872,Exh.gas temp.sen upstream of HD exh.gas recir.valve:raw val.,140.5, C
IDE11895,Particle filter: differential press. sens.1 bank 1: raw data 1,686,
IDE11896,Particle filter: differential press. sens.1 bank 1: raw value 1,9, mbar
IDE11897,Particle filter: differential press. sens.1 bank 1: raw value 2,1, mbar
IDE11898,Particle filter: differential press. sens.1 bank 1: raw data 2,659,
IDE11900,Par.fil: diff.pr.sens.1 bank 1: data quality,119.73, %
IDE11901,Par.fil: diff.pr.sens.1 bank 1: sensor configuration,1,
IDE11902,Par.fil: diff.pr.sens.1 bank 1: manufacturer ID,5,
IDE11904,Par.fil: diff.pr.sens.1 bank 1: sensor type,9,
IDE12085,Fuel injection time deviation: cylinder 1,9, s
IDE12086,Fuel injection time deviation: cylinder 2,5, s
IDE12087,Fuel injection time deviation: cylinder 3,-7, s
IDE12088,Fuel injection time deviation: cylinder 4,-7, s
IDE12123,EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop,2.354, V
IDE12124,EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop,2.685, V
IDE12125,Particulate sensor: status condition automation,0,
IDE12125,Particulate sensor: status condition automation,Standby,
IDE12456,Turbocharger 1 positioner 1 bank 1: position feedback Adaption value,0.630, V
IDE12457,Turbocharger 1 bypass valve 1 bank 1: position feedback - Adaption value,0.747, V
IDE12458,Turbocharger 1 bypass valve 1 bank 1: position feedback - first learning,0, counts
IDE12459,Turbocharger 1 positioner 1 bank 1: position feedback First learning,1, counts
ENG130449-ENG130482,A flag to indicate the voltage vailidity-Bool type,Yes,
ENG127344,Acceleration demand state for VLC,6,
ENG08190,ACM Operating Mode Higher Bytes,00000000 00000000 ,
ENG08191,ACM Operating Mode Lower Bytes,00000000 00001011 ,
ENG125964,Alternator mechanically absorbed power,0.714, kW
ENG08221-ENG08230,APS Crank state-Delphi APS Crank State,P_L_APS_GAP_CONFIRMED,
ENG130440-ENG130480,Atmospheric pressure used by the brake vacuum model-Pressure 0 500 BIN6 kPa,100.64, kPa
ENG125969,Boost pressure demand,98, kPa
ENG101413,Calibration Identification,04L056NB6116BEBD,
ENG99697,Calibration Verification Number,7E 49 CE F2,
ENG105535,Code Checksum,BF 16 98 BD,
ENG105751,Data Checksum,72 10 AF 54,
ENG130456-ENG130482,Dew point passed at the wraf location-Bool type,No,
ENG130436-ENG115021,Diagnostic data acquired from VSEP over SPI-Delphi PWM DG A,P_L_PWM_DG_A_NO_ERROR,
ENG105980,Duration of the FAN dutycycle gap,0, s
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG130458-ENG130482,Electrical WRAF fault detected-Bool type,No,
ENG98582-ENG130485,Engine running time-Pressure BIN10 bar,59, s
ENG08216-ENG130482,ESM background pfc fail fault-Bool type,No,
ENG08217-ENG130482,ESM level2 pfc fail fault-Bool type,No,
ENG08219-ENG08229,ESM memory l2 test status-Delphi ESM Memory L2 Test Status,ESM_L2_TESTING_CODE,
ENG08218-ENG08228,ESM memory test status-Delphi ESM Memory Test Status,ESM_TESTING_STOPPED,
ENG113730-ENG113667,ESM_0_dmnd_idle_ext_active-Counter_in_seconds,0, s
ENG113731,ESM_0_dmnd_idle_ext_limit,0.00, /min
ENG113734,ESM_0_trq_mode_word,00000000 00000000 ,
ENG113704-ENG113658,ESM_Amon_ctrl_acc_error-Control_deviation,1.667, m/s
ENG113705-ENG113658,ESM_Amon_ctrl_n_error-Control_deviation,7172.8, /min
ENG113710-ENG113659,ESM_Amon_pedal_position-Pedal_position,0, %
ENG113711-ENG113658,ESM_Amon_set_veh_acc-Control_deviation,1.667, m/s
ENG113712-ENG113658,ESM_Amon_veh_acc_raw-Control_deviation,0.000, m/s
ENG113713-ENG100973,ESM_Amon_veh_spd_raw-Vehicle_speed,0.00, km/h
ENG113714-ENG99033,ESM_Battery_voltage-Voltage,13.24, V
ENG113735,ESM_Can_mode_word,00000000 00000000 ,
ENG125974,ESM_Crankless_active,OFF,
ENG113709-ENG98933,ESM_Electric_test_state-Status,Unknown (7),
ENG113715,ESM_Eng_spd_l1l2_diff,0.00, /min
ENG113716,ESM_Eng_spd_unchecked,828.50, /min
ENG113717,ESM_Eng_spd_unchecked_cam,0.00, /min
ENG113718,ESM_Eng_spd_unchecked_crk,827.25, /min
ENG113719,ESM_Engine_speed,827.50, /min
ENG113732-ENG113662,ESM_L2_a_ext_int_ofs-MSR_correction,0.000, m/s
ENG113720,ESM_L3_stop_comms,OFF,
ENG113736,ESM_L3_trqmngr_mode_word,00000000 00000000 ,
ENG130466-ENG130486,ESM_Last_reset_nvv-Delphi Status ESM last reset NVV,ESM_NO_FAULT,
ENG113721,ESM_Memory_rst_dmnd,OFF,
ENG113722-ENG113659,ESM_Pedal_nominal_value-Pedal_position,0, %
ENG113723,ESM_Pedal_test_allowed,OFF,
ENG113724,ESM_Plausibility_fault_detected,OFF,
ENG113725,ESM_Stop_coms,OFF,
ENG113726,ESM_Synchronization_lost,OFF,
ENG113727-ENG113660,ESM_Vext_raw-ESM_sensor_voltage,3.2813, V
ENG113729-ENG113666,ESM_Zpls_trq_relevant_pulses_nbr-Torque_relevant_pulses_in_buffer,5.880,
ENG125971,Exhaust gas recirculation actuator bit field status 2,00000000 00000000 00000000 01100000 ,
ENG130435-ENG130482,Fan PWM driver diagnostics inhibit request-Bool type,No,
ENG130432-ENG130482,Faults combined to provide interlocks for the throttle close request-Bool type,Yes,
ENG125968-ENG126086,Filtered value of IN_Dpf_dp_raw-CDPF Delta Pressure in hPa,9.000, hPa
ENG106571,Flag to det.if dur.of FAN dutycyc.gap is above min.thresh.,OFF,
ENG106572,Flag to det.if dur.of FAN dutycyc.pulse is above min.thresh.,On,
ENG106573,Flag to det.if dur.of FAN dutycyc.pulse is below max.thresh.,OFF,
ENG130457-ENG130482,Fuel cut-off at the Wraf sensor location: taking into account the exhaust mass flow-Bool type,No,
ENG130438-ENG130482,Generic lamp output-Bool type,No,
ENG106787,Global Checksum,7E 49 CE F2,
ENG08222,Hard reset count,0,
ENG125965,HPV current demand coming from the HPV control,660, mA
ENG125966,HPV current demand coming from the IMV control,800, mA
ENG126050,HWI_Aps_cam_index,1,
ENG126011,HWI_Aps_crank_events_betwen_cams,00 09,
ENG125999,HWI_Aps_crank_rotat_direc_enable,OFF,
ENG126037-ENG126090,HWI_Aps_crank_rotation_direction-APS crank rotation,HWI_APS_CRANK_ROTATION_FORWARD,
ENG125996,HWI_Aps_gap_event_misplaced,OFF,
ENG125995,HWI_Aps_gap_event_missed,OFF,
ENG125997,HWI_Aps_gap_period_detected,OFF,
ENG126036-ENG126090,HWI_Aps_hw_crank_direction-APS crank rotation,HWI_APS_CRANK_ROTATION_FORWARD,
ENG126038,HWI_Aps_hw_crank_pulse_width,2D,
ENG113737-ENG99000,I_C_Acc_decode_std_0-Value,0,
ENG113738-ENG99000,I_C_Acc_decode_std_1-Value,0,
ENG113739-ENG99000,I_C_Acc_decode_std_2-Value,0,
ENG128779-ENG99000,I_C_Acc_decode_std_3-Value,0,
ENG130452,ID of the last object which HWI_Nvm_Read return an error,0,
ENG130454,ID of the last object which HWI_Nvm_Write return an error,0,
ENG106932,Immobilizer Snapshot 001 Byte 1,00,
ENG106933,Immobilizer Snapshot 001 Byte 2,00,
ENG106934,Immobilizer Snapshot 001 Byte 3,00,
ENG106935,Immobilizer Snapshot 001 Byte 4,00,
ENG106936,Immobilizer Snapshot 001 Byte 5,00,
ENG106937,Immobilizer Snapshot 001 Byte 6,00,
ENG106938,Immobilizer Snapshot 002 Byte 1,00,
ENG106939,Immobilizer Snapshot 002 Byte 2,00,
ENG106940,Immobilizer Snapshot 002 Byte 3,00,
ENG106941,Immobilizer Snapshot 002 Byte 4,00,
ENG106942,Immobilizer Snapshot 002 Byte 5,00,
ENG106943,Immobilizer Snapshot 002 Byte 6,00,
ENG106944,Immobilizer Snapshot 004 Byte 1,00,
ENG106945,Immobilizer Snapshot 004 Byte 2,00,
ENG106946,Immobilizer Snapshot 004 Byte 3,00,
ENG106947,Immobilizer Snapshot 004 Byte 4,00,
ENG106948,Immobilizer Snapshot 004 Byte 5,00,
ENG106949,Immobilizer Snapshot 004 Byte 6,00,
ENG106950,Immobilizer Snapshot 005 Byte 1,00,
ENG106951,Immobilizer Snapshot 005 Byte 2,00,
ENG106952,Immobilizer Snapshot 005 Byte 3,00,
ENG106953,Immobilizer Snapshot 005 Byte 4,00,
ENG106954,Immobilizer Snapshot 005 Byte 5,00,
ENG106955,Immobilizer Snapshot 005 Byte 6,00,
ENG126000,IN_Injection_speed,826.00, /min
ENG126008,IN_Injection_speed_injector[0],827.75, /min
ENG126009,IN_Injection_speed_injector[1],830.00, /min
ENG126010,IN_Injection_speed_injector[2],830.25, /min
ENG128778,IN_Injection_speed_injector[3],828.50, /min
ENG126004,IN_Latest_inj_spd_table[0],829.25, /min
ENG126005,IN_Latest_inj_spd_table[1],829.75, /min
ENG126006,IN_Latest_inj_spd_table[2],828.75, /min
ENG126007,IN_Latest_inj_spd_table[3],827.00, /min
ENG103875-ENG99452,In-use perform. track.: 16 counters-Boost Pressure Monitor Completion Condition Counts,552, counts
ENG103875-ENG103994,In-use perform. track.: 16 counters-Boost Pressure Monitor Conditions Encountered Counts,346, counts
ENG103875-ENG100817,In-use perform. track.: 16 counters-EGR and/or VVT Monitor Completion Condition Counts,790, counts
ENG103875-ENG101113,In-use perform. track.: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts,346, counts
ENG103875-ENG104133,In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts,176, counts
ENG103875-ENG104165,In-use perform. track.: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts,228, counts
ENG103875-ENG28750,In-use perform. track.: 16 counters-Fuel Monitor Completion Condition Counts,0, counts
ENG103875-ENG28751,In-use perform. track.: 16 counters-Fuel Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG102823,In-use perform. track.: 16 counters-Ignition Cycle Counter,1106, counts
ENG103875-ENG99234,In-use perform. track.: 16 counters-NMHC Catalyst Monitor Completion Condition Counts,56, counts
ENG103875-ENG99167,In-use perform. track.: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts,20, counts
ENG103875-ENG101363,In-use perform. track.: 16 counters-NOx Adsorber Monitor Completion Condition Counts,0, counts
ENG103875-ENG103522,In-use perform. track.: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG125933,In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts,138, counts
ENG103875-ENG125934,In-use perform. track.: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts,346, counts
ENG103875-ENG99988,In-use perform. track.: 16 counters-OBD Monitoring Conditions Encountered Counts,346, counts
ENG103875-ENG100240,In-use perform. track.: 16 counters-PM Filter Monitor Completion Condition Counts,101, counts
ENG103875-ENG103730,In-use perform. track.: 16 counters-PM Filter Monitor Conditions Encountered Counts,20, counts
ENG130451,Last error returned by HWI_Nvm_Read for P_L_Nvm_write_obj_index object,0,
ENG130453,Last error returned by HWI_Nvm_Write for P_L_Nvm_write_obj_index object,0,
ENG130445-ENG130480,Linearised atmospheric pressure sensor data-Pressure 0 500 BIN6 kPa,100.64, kPa
ENG130465-ENG130482,Low battery mode active-Bool type,No,
ENG103817,Main Timing demand,-6.625,
ENG130450-ENG130483,Manifold pressure offset-P_L Manifold abs pres offset nvv,0.000, kPa
ENG127343,Maximum allowed vehicle velocity,165.0, km/h
ENG107850,number of NEF refresh that have been performed,1525, counts
ENG107873,OBD Driver demand indicated torque,9.0, %
ENG107874-ENG98842,OBD EGR position control-Position,24.3, %
ENG107876-ENG127366,OBD maximum indicated torque-Torque 0 65535 BIN0 Nm,500, Nm
ENG130437,Oil pump PWM signal duty cycle,100.000, %
ENG127345-ENG127354,Operation mode cruise control and speed limiter-Cruise control 10km/h steps allowed,No,
ENG127345-ENG127353,Operation mode cruise control and speed limiter-Cruise control break intervention allowed,No,
ENG127345-ENG127355,Operation mode cruise control and speed limiter-Cruise control with display velocity setpoint,Yes,
ENG127345-ENG98891,Operation mode cruise control and speed limiter-Reserved,No,
ENG127345-ENG101416,Operation mode cruise control and speed limiter-Reserved_1,Yes,
ENG127345-ENG99458,Operation mode cruise control and speed limiter-Reserved_2,No,
ENG127345-ENG99668,Operation mode cruise control and speed limiter-Reserved_3,Yes,
ENG127345-ENG23189,Operation mode cruise control and speed limiter-Reserved_4,No,
ENG126002,P_L_Aps_cam_edge_learn_done,00,
ENG125998,P_L_Aps_cam_edge_window_end,OFF,
ENG125994,P_L_Aps_cam_index_confirmed,On,
ENG126035-ENG126089,P_L_Aps_cam_state-APS cam state,P_L_APS_PATTERN_CONFIRMED,
ENG113760,P_L_Aps_camless_active,OFF,
ENG126043-ENG126092,P_L_Aps_camshaft_drift_angle-Camshaft target wheel drift angle,0.95,
ENG126003,P_L_Aps_crank_event_num,20,
ENG113759,P_L_Aps_crankless_active,OFF,
ENG126001,P_L_Aps_crankshaft_speed,826.75, /min
ENG113758,P_L_Aps_injection_speed,825.75, /min
ENG125993,P_L_Aps_learning_done_nvv,On,
ENG126034-ENG126088,P_L_Aps_mode-APS working mode,P_L_APS_NORMAL,
ENG113755,P_L_Aps_no_sync_speed,867.25, /min
ENG113749-ENG99000,P_L_Aps_sync_cnt_total-Value,1,
ENG113750,P_L_Aps_sync_lost,OFF,
ENG113751-ENG113669,P_L_Aps_sync_lost_origin-Sync_lost_status,Unknown (17),
ENG113752,P_L_Aps_sync_tasks_enabled,On,
ENG113753,P_L_Aps_synchronised,On,
ENG113754-ENG113670,P_L_Aps_synchronised_origin-Sync_origin,P_L_APS_SYNC_GAP_CAM,
ENG113756-ENG113661,P_L_Aps_tdc_to_tooth_1_angle-Engine_timing_value,353.991,
ENG113757,P_L_Aps_timeout_detected,OFF,
ENG126012-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[0]-Mean of the learned camshaft edges position angles,0.000,
ENG126013-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[1]-Mean of the learned camshaft edges position angles,0.156,
ENG126014-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[2]-Mean of the learned camshaft edges position angles,-0.031,
ENG126015-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[3]-Mean of the learned camshaft edges position angles,0.094,
ENG126016-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[4]-Mean of the learned camshaft edges position angles,0.000,
ENG126017-ENG126087,P_L_Cds_cam_edge_delta_ang_mean[5]-Mean of the learned camshaft edges position angles,0.000,
ENG27003,P_L_Cds_Inlet_air_veh_dst_ff_hi,0,
ENG27004,P_L_Cds_Inlet_air_veh_dst_ff_lo,0,
ENG125978,P_L_Cds_p_class_selected,02,
ENG125976,P_L_Cds_vc_bit3_wr_valid_nvv,OFF,
ENG125977,P_L_Cds_vc_bit6_wr_valid_nvv,OFF,
ENG08376-ENG126091,P_L_Hpb_pos_ctrl_test-Valve Position,0.0, %
ENG27005,P_L_Inlet_air_atm_pres_ff_data,0,
ENG27006,P_L_Inlet_air_batt_volt_ff_data,0,
ENG27007,P_L_Inlet_air_cds_amf_ff_data,0,
ENG27008,P_L_Inlet_air_cool_temp_ff_data,0,
ENG27009,P_L_Inlet_air_doc_in_tmp_ff_data,0,
ENG27010,P_L_Inlet_air_egr_cool_t_ff_data,0,
ENG27011,P_L_Inlet_air_eng_spd_ff_data,0,
ENG27012,P_L_Inlet_air_ext_temp_ff_data,0,
ENG27013,P_L_Inlet_air_fan1_ff_data,0,
ENG27014,P_L_Inlet_air_fan2_ff_data,0,
ENG27015,P_L_Inlet_air_in_air_tmp_ff_data,0,
ENG27016,P_L_Inlet_air_t21_temp_ff_data,0,
ENG27017,P_L_Inlet_air_t22_temp_ff_data,0,
ENG27018,P_L_Inlet_air_veh_spd_ff_data,0,
ENG130582,P_L_Pedal_switch_case,USE_MIN,
ENG113740-ENG98489,P_L_Rail_pres_sample_cnts-counts,230.778, counts
ENG113762-ENG113664,P_L_Wraf_back_pressure_estimate-Back_pressure_estimate,1.015, bar
ENG113761-ENG113663,P_L_Wraf_ip_temp_compensation-Compensation_value,0.0456, mA
ENG108255,Power Latch counter,4291, counts
ENG08224-ENG130482,PT dfco 0 torque request-Bool type,No,
ENG130446-ENG130481,Raw battery voltage reading-Voltage BIN7 V,13.2031, V
ENG130441-ENG130481,Raw value for 3.3V on ADC0 from EQADC A-Voltage BIN7 V,3.2813, V
ENG130443-ENG130481,Raw value for 3.3V on ADC0 from EQADC B-Voltage BIN7 V,3.2813, V
ENG130442-ENG130481,Raw value for 3.3V on ADC1 from EQADC A-Voltage BIN7 V,0.0000, V
ENG130444-ENG130481,Raw value for 3.3V on ADC1 from EQADC B-Voltage BIN7 V,0.0000, V
ENG130434-ENG130482,Request throttle close based on inlet pressure-Bool type,No,
ENG08220,Reset detection pattern,23130,
ENG113745-ENG113668,RPC_Hp_control_state-HPV_Status,RPC_HP_CLOSED,
ENG113746-ENG113655,RPC_Hp_crt_trim-Current_trim,217.813, mA
ENG113747-ENG98933,RPC_Im_control_state-Status,RPC_IM_CLOSED_LOOP,
ENG113748-ENG113655,RPC_Im_crt_trim-Current_trim,-3.906, mA
ENG130447-ENG130481,Scaled sensor value before validation for pbatt-Voltage BIN7 V,13.1563, V
ENG130448-ENG130481,Scaled sensor value before validation for vinj-Voltage BIN7 V,13.2344, V
ENG110382-ENG20519,SCR inducem system status-deviation of reagent consumption,Unknown (0),
ENG110382-ENG20512,SCR inducem system status-Distance traveled in current 10K block,8940, km
ENG110382-ENG20513,SCR inducem system status-Distance traveled while inducement system active in 20K block,0, km
ENG110382-ENG20514,SCR inducem system status-Distance traveled while inducement system active in 30K block,0, km
ENG110382-ENG20515,SCR inducem system status-Distance traveled while inducement system active in 40K block,0, km
ENG110382-ENG20511,SCR inducem system status-Distance traveled while inducement system active in current 10K block,0, km
ENG110382-ENG20518,SCR inducem system status-incorrect reagent,Unknown (0),
ENG110382-ENG20516,SCR inducem system status-inducement system active,not_active,
ENG110382-ENG20520,SCR inducem system status-NOx emissions too high,Unknown (0),
ENG110382-ENG20517,SCR inducem system status-reagent level too low,Unknown (0),
ENG27113-ENG130482,SCR system failure-Bool type,No,
ENG26352-ENG30059,SMC_Power_state-Param Delphi SMC Power State,SMC_SYSTEM_RUNNING,
ENG08223,Soft reset count,0,
ENG127342-ENG127352,State ACC Cruise Control Variant Correct Code-ACC Cruise variant code,CCS,
ENG127339-ENG127350,Status cruise control and speed limiter-Status velocity destination,Stand-by,
ENG127341-ENG98933,Status irriversible shutoff condition cruise control and limiter-Status,0,
ENG127348-ENG127363,Status powertrain VLC and VehFRstn-Automatic transmission reduced torque intervention,No,
ENG127348-ENG127362,Status powertrain VLC and VehFRstn-Automatic transmission shift,No,
ENG127348-ENG127359,Status powertrain VLC and VehFRstn-Clutch long open,No,
ENG127348-ENG112437,Status powertrain VLC and VehFRstn-Clutch open,Yes,
ENG127348-ENG127360,Status powertrain VLC and VehFRstn-Extended neutral gear detection manual switch v/n drift,No,
ENG127348-ENG127361,Status powertrain VLC and VehFRstn-Exteneded neutral gear detection only at Torque demand manual switch,No,
ENG127348-ENG127358,Status powertrain VLC and VehFRstn-Gear level position N/Intermediate position or Manual switch neutral gear,No,
ENG127348-ENG127357,Status powertrain VLC and VehFRstn-Gear lever position P,No,
ENG127348-ENG127356,Status powertrain VLC and VehFRstn-Manual switch first gear,No,
ENG127348-ENG127364,Status powertrain VLC and VehFRstn-Maximum engine speed not debounced regulation,No,
ENG127348-ENG101416,Status powertrain VLC and VehFRstn-Reserved_1,No,
ENG127348-ENG99458,Status powertrain VLC and VehFRstn-Reserved_2,No,
ENG127348-ENG99668,Status powertrain VLC and VehFRstn-Reserved_3,Yes,
ENG127348-ENG23189,Status powertrain VLC and VehFRstn-Reserved_4,Yes,
ENG127348-ENG98894,Status powertrain VLC and VehFRstn-Reverse gear,No,
ENG127348-ENG127365,Status powertrain VLC and VehFRstn-Vehical speed dependent engine speed limit only for automatic transmission,Yes,
ENG127340-ENG127351,Status reversible shutoff condition cruise control and limiter-Stau,17302592,
ENG130439-ENG130482,Switch the crank case heater on/off-Bool type,Yes,
ENG127347-ENG119265,Target velocity LMVCtl function-Velocity,0.0, km/h
ENG125961,The global air climate fluid pressure.,0.00, bar
ENG125972,Throttle valve actuator bit field status 2,00000000 00000000 00000000 11000000 ,
ENG125973,Turbocharger actuator HP bit field status 2,00000000 00000000 00000000 01000010 ,
ENG130433-ENG130482,Under pressure interlocks for the throttle-Bool type,No,
ENG109815,Value of temperature sensor 1 (set 1) at record result time,0, C
ENG109816,Value of temperature sensor 1 (set 2) at record result time,0, C
ENG109817,Value of temperature sensor 2 (set 1) at record result time,0, C
ENG109818,Value of temperature sensor 2 (set 2) at record result time,0, C
ENG109819,Value of temperature sensor 3 (set 1) at record result time,0, C
ENG109820,Value of temperature sensor 3 (set 2) at record result time,0, C
ENG109821,Value of temperature sensor 4 (set 1) at record result time,0, C
ENG109822,Value of temperature sensor 4 (set 2) at record result time,0, C
ENG109823,Value of temperature sensor 5 (set 1) at record result time,0, C
ENG109824,Value of temperature sensor 5 (set 2) at record result time,0, C
ENG109825,Value of temperature sensor 6 (set 1) at record result time,0, C
ENG109826,Value of temperature sensor 6 (set 2) at record result time,0, C
ENG127346-ENG127349,Velocity limitation requested by driver-Velocity driver requested speed limit,500.0, km/h
ENG125967-ENG98842,Vgt valve position for OBD Mode $02-Position,12.5, %
ENG08212-ENG08227,Wraf open circuit heater-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG08192-ENG08225,Wraf Origin State-Delphi Wraf Origin State,WRAF_REF_CELL_STB_TEST,
ENG130459-ENG130484,Wraf pump cell offset-Wraf pump cell offset current,0.00000, mA
ENG08193,Wraf pump current raw,0.00000, mA
ENG130455,Wraf pure air deviation correction factor,1.0043,
ENG08194,Wraf reference cell impedence,2000.00000, Ohm
ENG08213-ENG08227,Wraf sc2gnd heater-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG08206-ENG08227,Wraf sc2vbat reference cell-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG08207-ENG08227,Wraf sc2vbat sense resist-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG08208-ENG08227,Wraf sc2vbat sensor return-Delphi Wraf Sc2vbat Oc Sc2gnd,P_L_WRAF_NO_FAULT,
ENG130464-ENG130484,Wraf second sensor pump cell offset-Wraf pump cell offset current,0.00000, mA
ENG08196,Wraf sensor ipk raw,0.00000, mA
ENG08197-ENG08196,Wraf sensor ipk raw old-Wraf sensor ipk raw,0.00000, mA
ENG08195,Wraf sensor learning count,2104,
ENG08198-ENG08226,Wraf state-Delphi Wraf State,WRAF_DISCHARGE_INPUT_CAP,
Elapsed Time: 01:09
