Results 1 to 3 of 3
Thread: P2002 - Efficiency Below Threshold
    Sep 2018
    This might have been asked a lot of times but I need a little bit feedback if possible please.
    History: Skoda Octavia 1.6L CR TDI, new injectors and new EGR. After replacement of those parts engine light came on with the P2002 code after some driving. The first time I managed to clean it by service regeneration. The measured soot was 66g and it was close to the 70g limit. After regen it fell down to 6g and management light turned off. Decided just in case to use one of these DPF cleaners and fuel additive for DPF cleaninbg as well. After a few days the management light came on again after a long trip, so something is not right. I have looked into the values but the soot was a negative number. This does not seem right. Did pressure sensor got damaged or something? What do you think? The car does many frequent regenerations
    Planning to inspect the sensors around the DPF this weekend
    Thanks in advance for any tip
    Full scan and some data attached
    Tuesday,21,May,2019,21:08:35:26039
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: TMBJT21Z8A2026985   License Plate: WO10TXZ
    Mileage: 116220km-72215mi   Repair Order:
    Chassis Type: 1Z-SK35 (1K0)
    VIN: TMBJT21Z8A2026985   Mileage: 116220km-72215miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 AG    HW: 03L 906 023 AG
       Component: R4 1.6l TDI   H23 9979
       Revision: --H23---    Serial number:
       Coding: 00114014030500080000
       Shop #: WSC 73430 031 00999
       ASAM Dataset: EV_ECM16TDI02103L906023AG 003014
       ROD: EV_ECM16TDI02103L997557M.rod
       VCID: 6B8237825303AB2F5BF-803E
    11791 - Particulate Trap Bank 1
              P2002 00 [237] - Efficiency Below Threshold
                        Mileage: 115823 km
                        Date: 2019.05.12
                        Time: 01:23:48
                        Engine speed: 1605.00 /min
                        Normed load value: 52.5 %
                        Vehicle speed: 63 km/h
                        Coolant temperature: 94 C
                        Intake air temperature: 20 C
                        Voltage terminal 30: 14.344 V
                        Air mass: actual value:: 6.34 g/s
                        Particle filter: difference pressure-DIP_PF: 0.00 hPa
                        Particle filter: soot mass measured-MASS_SOOT_PHY_PF: 26.70 g
                        Particle filter: soot mass calculated-MASS_SOOT_SIM_PF: 61.66 g
                        Particle filter: offset for differential press.-DIP_PF_AD[0]: 0.00 hPa
                        Exh.gas temp.sen 3-TEG_MES[1]: 314.79 C
                        Exh.gas temp.sen 4-TEG_MES[2]: 299.98 C
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AQ    HW: 1K0 907 379 AQ
       Component: MABS MK70M          0105
       Revision: 00H32001
       Coding: 0016641
       Shop #: WSC 73430 790 00999
       VCID: 015E752A4D0F517F913-8054
       Part No SW: 3T0 820 047 H    HW: 3T0 820 047 H
       Component: Climatic      130 0203
       Revision: 00005001
       Coding: 0000000000
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_SK35.rod
       VCID: 3430ECFE4EBD34D74A5-8060
       Part No SW: 1K0 937 085 D    HW: 1K0 937 085 D
       Component: BCM PQ35  B+  103 0541
       Revision: 00103 AE
       Coding: 48180AB8B0050CB04010008011000024010000AE424D81605C4440000000
       VCID: 3038E0EEBA2508F72ED-8064
       Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 14070  22  0601
       Coding: 00D7B7
       Component: Q4 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD2EVLJ7
       Coding: 0020788
       VCID: 3D26C9DA7177F59FB5B-8068
       Subsystem 1 - Serial number: 6332MSME4964236AF
       Subsystem 2 - Serial number: 6342MSME485431085
       Part No SW: 1K0 953 549 DA    HW: 1K0 953 549 DA
       Component: J0527           053 0111
       VCID: 74B02CFE02BD74D78A5-8020
       Part No SW: 1Z0 920 903 D    HW: 1Z0 920 903 D
       Component: KOMBI         H21 0110
       Coding: 410300
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
       VCID: 3634D6F658C126C7741-8062
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H16 5223
       Revision:   H16       Serial number: 4120K0972709A1
       Coding: E9801F06000202002303
       VCID: 669446B644619647041-8032
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H21 0110
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2114
       Coding: 0000564
       VCID: 48C8A80E2EB5A03716D-801C
    01030 - Central Locking Key Switch; Driver Side; Lock
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 69     2901
       Revision: 00H17000
       VCID: 2F3AE392AB1B170F377-807A
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000564
       VCID: 47CAAB3223ABAF4F1F7-8012
       Part No SW: 1Z0 035 161 G    HW: 1Z0 035 161 G
       Component: Radio-SWING   008 0021
       Revision: -----09S    Serial number: SKZ4Z2J1112843
       Coding: 000002000001
       VCID: 323CEAE6B4293AE7589-8066
    End------(Elapsed Time: 00:41, VBatt start/end: 12.5V/12.5V, udsna)--------
  2. Likes Boki Ar, Uwe liked this post
  3. #2
    The sensor is faulty or pipe is plugged to sensor.
  4. Likes Uwe liked this post
  5. #3
    Sep 2018
    Great thanks, will check it out
