Results 1 to 3 of 3
Thread: G200 Coding Problem
    Jul 2018
    G200 Coding Problem
    Customer Replaced G200 Sensor, but saying Adjustment Not Possible when I try to get into basic settings.
    I am just trying to make sure its the replacement sensor or the wiring that is the problem and not my VCDS login that hasn't worked or anything.
    It never gave me the button for ON/OFF/NEXT, just said adjustment not possible in the boxes.
    The replacement sensor was a used one, so there is the possibility that the replacement sensor is also faulty.
    Any ideas or advice would be appreciated.
    Cheers
    Tuesday,21,May,2019,19:11:34:18208
    VCDS Version: 18.9.1.0 (x64)
    VIN: TRUZZZ8NZ11028678   License Plate: Y483NLC
    Mileage: 107347   Repair Order:
    Chassis Type: 8N (8N - Audi TT (1999 > 2007))
    Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
    Address 03: ABS Brakes        Labels: 8N0-907-379-MK20-E.clb
       Part No: 8N0 907 379 E
       Component: ESP     20    CAN  V005
       Coding: 18446
       Shop #: WSC 01423
       VCID: 3E7350933A3095BAEF-4B00
                57-00 - Electric Circuit Failure
    Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
       Part No: 8N0 820 043 A
       Component: TT-KLIMAVOLLAUTOMAT D03
       Coding: 00041
       Shop #: WSC 01236
       VCID: 285F96CBC8B43B0AB5-2586
    Address 15: Airbags        Labels: 8N8-909-601.lbl
       Part No: 8N8 909 601
       Component: Airbag Front+Seite 1008
       Coding: 10102
       Shop #: WSC 01236
       VCID: 77FD85B7558A64F2EC-5140
    Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
       Part No: 8N2 920 930 C
       Component: KOMBI+WEGFAHRS. M73 D55
       Coding: 05444
       Shop #: WSC 00847
       VCID: 326B74A3FE6841DA1B-4B00
       TRUZZZ8NZ11028678     AUZ5Z0A0023021
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 B
       Component: HALDEX LSC  ECC     0006
       VCID: 1F4D8D179DFAFCB2C4-4B00
    No Faults Found
    Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
       Part No: 8N8 962 267 B
       Component: Central Lock/Alarm  D04
       Coding: 06858
       Shop #: WSC 00468
       VCID: 408F2E6B40C4E34A9D-4ECE
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8N8 951 177
       Component: Innenraumueberw.    D09
       Coding: 00001
       VCID: 7CF79A9B6CAC47AA81-51D4
    Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
       Part No: 4B0 907 357
       Component: LEUCHTWEITEREGLER  D004
       Coding: 00010
       Shop #: WSC 01236
       VCID: 65C1DFFFFF26E6624E-517C
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 186
       Component:  Radio             0001
       Coding: 00205
       Shop #: WSC 06335
       VCID: 5DB1F71FD776AEA296-4B1A
    End-------------------------(Elapsed Time: 05:39)--------------------------
    Address 03: DTCs cleared
                    Address 03: ABS Brakes  (8N0 907 379 E)
    19:38:04 Group 063: Adjustment of Lateral Acceleration Sensor (G200)
      Adjustment  Adjustment
      Not Possible  Adjustment Status
      20.39 m/s^2  Lateral Accel.
      N/A  Lateral Acc. Sensor (G200)
    I'm not surprised that adjustment is not possible when you have a "Electric Circuit Failure" for that sensor.
    Verify wiring and connectors.
  3. Likes Jack@European_Parts, LHSLTD liked this post
    Jul 2018
    Thanks Uwe
    I did suggest this as the reason, and that it would change fault to 'not adapted' or similar or remove the fault once it was cleared once it was fixed, but he did say he had checked the wiring. As long as my conscience is clear that it wasn't me being more stupid than usual.
    Lennie
  5. Likes Jack@European_Parts liked this post
