Results 1 to 10 of 10
Thread: VW Golf Sportswagen 2015, Dead Infotainment after jumpstart
    Oct 2016
    Hi there,
    Any help would be appreciated.
    I had to receive cold-weather related jump start from another car (not a charging device).
    I made the mistake to connect the negative cable directly to the negative terminal of the battery.
    Car started but the infotainment console went dark.
    I did check the fuses in banks F10 (MINI, Display, infotainment controls), F12 (ATO, Infotainment Services), F16 (MINI, Phone).
    These fuses are fine.
    Any ideas about other fuses that I could check?
    Many thanks for any replies!
    P.S. Correction year is 2015, not 2018
    I've fixed the thread title for you.
    It couldn't hurt to run an Auto-Scan and post the results. No guarantees, but there might be clues in there.
    Oct 2016
    Thank you Uwe!
    Will do this tomorrow.
    New Info:
    I let the car run and:
    - Checked all fuses in both fuse boxes (inside and engine) with a multimeter - all fuses are fine.
    - I also took out and plugged back in the fuses for the infotainment system (hoping for some sort of reboot)
    No cigar ...
    Oct 2016
    Here we go:
    Thursday,22,March,2018,20:23:36:17869
    VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
    VIN: 3VWC17AU7FM50####   License Plate:
    Mileage: 27675km-17196mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
    VIN: 3VWC17AU7FM50####   Mileage: 27675km-17196miles
    5F-Information Electr. -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5GM 906 264     HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 091A00122424002F0000
       Shop #: WSC 00066 790 00218
       ASAM Dataset: EV_ECM18TFS0205GM906264 001001
       ROD: EV_ECM18TFS0208V0906264F.rod
       VCID: 0444442E8F5ED2643C-8050
       Part No SW: 09G 927 749 D    HW: 09G 927 749 D
       Component: AISIN AG6 G3  129 2866
       ROD: EV_TCMAQ250031_002_VW25.rod
       VCID: 3A38FAD6BD1A549416-806E
    Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
       Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
       Component: ESC           H32 0385
       Revision: 00000000    Serial number: 50115000000088
       Coding: 04FA6AA12420096F007C020481CA292056249000408194B400430050C002
       Shop #: WSC 01383 790 50316
       VCID: 47DE9322FEE8397C99-8012
       Part No SW: 5GM 907 426     HW: 5GM 907 426
       Revision: 00001K01
       Coding: 02020004200100000000000000000000
       ROD: EV_ACManueBHBVW37X_003_VW37.rod
       VCID: 0542592A8464EB6C2B-8050
              B10CD 00 [008] -  -
                        Reset counter: 48
                        Mileage: 27163 km
                        Date: 2018.03.18
                        Time: 20:20:18
                        Voltage terminal 30: 10.9 V
                        CAN input signal(s) status-Back-up light: OFF
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
       Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
       Component: BCM PQ37BOSCH 028 0145
       Revision: --------    Serial number: 86581201151322
       Coding: 000018424041804169E44000000403001000000000000000000000000000
       Shop #: WSC 00066 790 00082
       ROD: EV_BCMBOSCH_014.rod
       VCID: 49DA951AE8FCCF0C8F-801C
       Component: WWS    140902  043 0581
       Serial number:         150225003202
    787212 - Windshield Washer Pump
              B1261 01 [008] - Electrical Failure
    132363 - Voltage Supply; Terminal 30; Left
              B140D 13 [008] - Open Circuit
                        Reset counter: 51
                        Mileage: 27675 km
                        Date: 2018.03.22
                        Time: 08:51:40
    329480 - Heated Passenger Seat
              B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
                        Fault Frequency: 33
                        Reset counter: 52
                        Mileage: 24838 km
                        Date: 2017.12.31
                        Time: 11:11:43
       Serial number: 003GCR0165G0
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J150002C9GK01
       Coding: 303138
       Subsystem 2 - Part No SW: -----------    HW: 480 001 912 14
       Serial number: 3570000000070D214212
       Subsystem 3 - Part No SW: -----------    HW: 480 001 912 14
       Serial number: 358000000005AAD0721L
       Subsystem 4 - Part No SW: -----------    HW: 480 401 411 14
       Serial number: 3510002B1188FC13C3DD
       Subsystem 5 - Part No SW: -----------    HW: 480 401 311 14
       Serial number: 35200029D188FC1582DL
       Subsystem 6 - Part No SW: -----------    HW: 480 401 612 14
       Serial number: 3550002A1196FF60320/
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 612 14
       Serial number: 3560002C9196FF622119
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
              [Bladder Mat: functional restriction because of low voltage]
                        Reset counter: 48
                        Mileage: 27163 km
                        Date: 2018.03.19
                        Time: 05:50:12
       Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150118400498
       Coding: 0410
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3FCE8BC2A63871BC21-806A
       Part No SW: 5G1 920 840     HW: 5G1 920 840
       Component: KOMBI         243 4270
       Coding: 0BB4110A2180CF0502086A001000000000000000
       VCID: 648464AE6F1E72649C-8030
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_Audio_0x31 keine Kommunikation]
                        Reset counter: 10
                        Mileage: 27595 km
                        Date: 2018.03.19
                        Time: 10:35:57
              U1110 00 [009] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 10
                        Mileage: 27595 km
                        Date: 2018.03.19
                        Time: 10:35:57
    16777022 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_NAV SD_0x32 keine Kommunikation]
                        Reset counter: 10
                        Mileage: 27595 km
                        Date: 2018.03.19
                        Time: 10:35:57
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2203
       Revision: --------    Serial number: 22011510001560
       Coding: 0101000820085900EF0000081C0F00000001050000000000000000000000
       Shop #: WSC 00066 790 07029
       VCID: 71AA1DFAA0ECD7CCE7-8024
       Component: E221__MFL-DC1  H16 0101
       Serial number: 27150000246550085071
       Coding: 29FFFF
    131699 - Control unit for information electronics 1
              U1054 00 [009] - No Communication
              [Timeout Knoten 0x73 / 5F - Steuergerät für Informationselektronik 1]
                        Reset counter: 12
                        Mileage: 27675 km
                        Date: 2018.03.22
                        Time: 08:56:42
                        Supply voltage: Terminal 30: 11.5 V
                        Terminal 15: On
    66052 - Infotainment CAN Bus (SAE Bus E)
              U0065 00 [008] - Performance
              [Globaler Timeout CAN-Infotainment]
                        Fault Frequency: 33
                        Reset counter: 51
                        Mileage: 27163 km
                        Date: 2018.03.19
                        Time: 05:44:10
                        Terminal 15: OFF
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 060215060507EO
       Coding: 003003200000040000000000
       VCID: 3E30F6C6A13278B42A-806A
       Serial number: 00000000000000422812
       Coding: 011000
    589829 - Window Regulator; Rear Driver side
              B131F F5 [008] - Supply Voltage too Low
                        Reset counter: 48
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0102
       VCID: 43C68732CAD0155C45-8016
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 060215060509NL
       VCID: 3D32F1CAAC3463AC33-8068
       Serial number: 00000000000000611718
       Coding: 091000
    589845 - Window Regulator; Front Passenger side
              B1320 F5 [008] - Supply Voltage too Low
                        Reset counter: 48
       Component: OCULowMQBUS   007 0564
       Coding: 02730202C2821A017F1E06000000
       Shop #: WSC 00066 790 00122
       ROD: EV_OCULowMQB.rod
    0022 - Databus
              [CAN TO radio]
                        Fault Frequency: 12
                        Reset counter: 12
                        Mileage: 27163 km
                        Date: 2018.03.19
                        Time: 05:43:26
    0036 - Databus
              [CAN TO GPS data]
                        Reset counter: 11
                        Mileage: 27163 km
                        Date: 2018.03.19
                        Time: 05:43:26
    13636864 - Mobile Online Services
              B149A F0 [008] - Vehicle Condition Report
                        Reset counter: 45
    End----------(Elapsed Time: 01:17, VBatt start/end: 13.9V/13.9V)-----------
    OK, the 5F module (your Infotainment) is definitely off-line.
    Does anyone know if those MIB1 units have a dedicated fuse on the back of them like so many older VW/Audi radios did?
    Moni, I suggest you to clear all fault codes the slow way; from the Auto-Scan screen, with 'Use CAN command' un-checked. Then cycle the ignition OFF and back ON again and re-scan. Reason: I think there are still spurious codes in various systems from your dead battery incident and I'd like to have them gone and to see what comes back.
  6. Likes Boki Ar liked this post
    Oct 2016
    Thank you Uwe.
    The how-to steps made it easy for me
    Saturday,24,March,2018,10:57:53:17869
    VIN: 3VWC17AU7FM50####   License Plate: CLEAN
       Revision: --H13---
    Readiness: 1010 1101
       Revision: 00001K01
       Occupant Detection:
       Coding: 303138
       Coding: 0410
              U1110 00 [009] - -
                        Reset counter: 14
                        Mileage: 27675 km
                        Date: 2018.03.24
                        Time: 22:49:17
              U1110 00 [009] - -
                        Reset counter: 14
                        Mileage: 27675 km
                        Date: 2018.03.24
                        Time: 22:49:16
              U1110 00 [009] - -
                        Reset counter: 14
                        Mileage: 27675 km
                        Date: 2018.03.24
                        Time: 22:49:17
       Coding: 29FFFF
                        Reset counter: 14
                        Mileage: 27675 km
                        Date: 2018.03.24
                        Time: 22:49:29
                        Supply voltage: Terminal 30: 13.8 V
                        Terminal 15: On
       Coding: 011000
       Coding: 0102
       Coding: 091000
    0022 - Databus
              [CAN TO radio]
                        Reset counter: 14
                        Mileage: 27675 km
                        Date: 2018.03.24
                        Time: 22:50:36
    0036 - Databus
              [CAN TO GPS data]
                        Reset counter: 14
                        Mileage: 27675 km
                        Date: 2018.03.24
                        Time: 22:50:36
    End----------(Elapsed Time: 01:13, VBatt start/end: 13.9V/13.9V)-----------
  8. Likes Uwe liked this post
    OK, now the only faults left are IMO attributable to the 5F-Infotainment module being off-line.
    One suggestion I received privately was: Try cold-booting it. You could do that by disconnecting the car's battery for a while, but if it were me, I'd do it by pulling the Infotainment unit, unplugging it from the car's harness and checking to see it it has its own fuse on the back of it, like so many other VW/Audi radios do. If it does, and that fuse is blown, well, you've found the culprit. If not, then while you have it out, you can use a meter to verify that the module is getting power as it should.
  10. #8
    Dec 2016
    Amsterdam
    My MIB2.5 unit does not have one on the back. There might be one inside the housing, but since mine works i’m not really feel like busting seals unfortunately. I have seen pictures of other MIB units that do have one, visible when you disconnect the quadlock connector. If it doesnt have one, triple check if the right fuse in the fuse box is really okay (DVM), check power to unit as Uwe said, and as a last resort you could check if it has an internal fuse. Although voltage spikes can FUBAR electronics instantly and without burning through any fuses...
    Current:
  11. Likes Uwe, Jack@European_Parts liked this post
  12. #9
    Mar 2019
    Hi everyone can anyone please help me what are the basic steps to code infotainment on to the car. in other words code into the car to make it work.
    On a vw polo 2014 model
    Do I need to go can gateway and click on installation list and tick 5F
    Let me know buddy
    The car is 100 miles away a request by Jack has been made to me so I couldn't post a scan at this stage
    "Hello Sam, it's Jack with the gti that time. Sorry it's a little late. Not sure if you can help but can you reprogram an infotainment system on a 64 plate polo? Thanks again"
    Kind Regards
  13. #10
    May 2014
    ^ ^^^Hi. Can you clarify your wants - please ?
    "can you reprogram an infotainment system on a 64 plate polo?" and "in other words code into the car to make it work. On a vw polo 2014 model" - are a tad confusing (to me, at least)
    And please post-up an autoscan for the car that is to receive the 5F unit
  14. Likes Uwe liked this post
