Results 1 to 3 of 3
Thread: Steering assist
    Sep 2017
    Steering assist
    can anyone give me the security code for steering assist.
    Tuesday,21,May,2019,18:21:17:42570
    VIN: WAUZZZ8P69A006716   License Plate:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56
    VIN: WAUZZZ8P69A006716   Mileage: 229960km-142890miles
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 BQ    HW: 03L 906 022 BQ
       Component: R4 2,0L EDC 0000SG  3066
       Revision: --H01---    Serial number: AUX7Z0H5FNI012
       Coding: 0000072
       Shop #: WSC 84224 932 461222
       VCID: 75B4E89959CB520FBDB-8020
    008198 - Intake Manifold Flap; Bank 1
                   P2006 - 000 - Stuck Closed - Intermittent
                        Mileage: 229961 km
                        Date: 2019.05.20
                        Time: 18:14:33
                        RPM: 782 /min
                        Load: 0.0 %
                        Load: 5.9 %
                        Lambda: 16.6 %
                        Mass Air / Rev.: 345.0 mg/str
                        Temperature: 57.6C
    008196 - Intake Manifold Flap; Bank 1
                   P2004 - 000 - Stuck Open
                        Mileage: 229961 km
                        Date: 2019.05.20
                        Time: 18:14:33
                        RPM: 782 /min
                        Load: 0.0 %
                        Load: 5.9 %
                        Lambda: 89.2 %
                        Mass Air / Rev.: 325.0 mg/str
                        Temperature: 57.6C
       Part No SW: 1K0 907 379 BD    HW: 1K0 907 379 BD
       Revision: 00H31001
       Coding: 1342401209220000C81202E5901F00823C0000
       Shop #: WSC 06314 000 00000
       VCID: 75B4E89955CB520FBDB-8020
       Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
       Component: KlimavollautomatH08 0100
       Revision: 000264      Serial number: 8P0820043BG
       VCID: 72BED38528A54537989-8026
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
       Component: Bordnetz-SG     H54 2801
       Revision: 00H54000    Serial number: 00000008568940
       Coding: F18A1F07A0141380EF00000A4F00000000084E0564060003002000000000
       Shop #: WSC 06314 000 08192
       VCID: 48CA516D7EB99FE716D-801C
       Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H10 0040
       Coding: 00056595
       Shop #: WSC 06314
       Coding: 00150573
       Shop #: WSC 06314
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 J    HW: 8P0 959 655 J
       Component: Airbag AU1042 H06 0090
       Revision: --------    Serial number: 003000000000
       Coding: 303142413039303030384A55305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 49CC5469693366EF093-801C
       Serial number: 34928RB400003CCC184Y
       Serial number: 35028RB400003D0E3A6N
       Serial number: 35128RB400003CCC03DU
       Serial number: 35228RB400003D0EAAC
       Serial number: 35547RB400003CE961D
       Serial number: 35647RB400003CE965C%
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0002012
       VCID: 41DC4C495D83AEAFD13-8014
       Component: E0221           H02 0030
    01304 - Radio
       Part No SW: 8P0 920 982 C    HW: 8P0 920 982 C
       Component: KOMBIINSTR. VDO H15 0820
       Revision: D0H15004    Serial number: 2245H004001151
       Coding: 0004428
       Shop #: WSC 00128 067 57207
       VCID: 392C24A93553F66F993-806C
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K086050E43
       Coding: E9811F061002020101
       VCID: 35342899194B120F7DB-8060
                        Fault Status: 01101011
                        Reset counter: 249
                        Mileage: 229961 km
                        Date: 2019.05.20
                        Time: 18:02:11
    01304 - Radio
                        Reset counter: 249
                        Mileage: 229961 km
                        Date: 2019.05.20
                        Time: 18:02:15
       Revision: D0H15004    Serial number: AUX7Z0H5FNI012
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
       Component: Tuer-SG         H03 0060
       Coding: 0000564
       VCID: 42DE43455885B5B7C89-8016
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.079 H08 1901
       VCID: 36362F95044D1917741-8062
    02546 - Steering Limit Stop
                        Mileage: 229950 km
                        Temperature: 26.0C
                        Voltage: 13.90 V
                        Voltage: 13.70 V
    Address 46: Central Conv.        Labels: 8P0-959-433.lbl
       Part No: 8P0 959 433 J
       Component:    KSG          H11 0080
       Coding: 1980200002186D2D8505489AC637
       VCID: 43D04641479FBCBFC3F-8016
       Subsystem 1 - Component:   Sounder No Answer
       Subsystem 2 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Subsystem 3 - Part No: 8P0 951 177
       Component: Innenraumueberw.H04 0020
    01134 - Alarm Horn (H12)
       Part No SW: 8P3 035 382 D    HW: 8P3 035 382 D
       Component: AB2 SUBWOOFERBOXH30 0160
       Revision: 00006       Serial number: 30659850185132
       VCID: 3432159D12310B074A5-8060
       Part No SW: 8P0 959 802 J    HW: 8P0 959 802 J
       Coding: 0000564
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
       Part No: 8P0 907 357 J
       Component: Dynamische LWR  H01 0020
       Coding: 0000013
    Address 56: Radio
    End----------(Elapsed Time: 01:03, VBatt start/end: 13.8V/13.7V)-----------
    Sep 2017
    ignore all sorted
  3. Likes Uwe, Jack@European_Parts liked this post
    HQ
    Just in case this thread comes up in a Google search for DTC 02546:
    http://wiki.ross-tech.com/wiki/index.php/02546
    Jef
  5. Likes Uwe liked this post
