can anyone give me the security code for steering assist.
Tuesday,21,May,2019,18:21:17:42570
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8P69A006716 License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56
VIN: WAUZZZ8P69A006716 Mileage: 229960km-142890miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3066
Revision: --H01--- Serial number: AUX7Z0H5FNI012
Coding: 0000072
Shop #: WSC 84224 932 461222
VCID: 75B4E89959CB520FBDB-8020
008198 - Intake Manifold Flap; Bank 1
P2006 - 000 - Stuck Closed - Intermittent
Mileage: 229961 km
Date: 2019.05.20
Time: 18:14:33
RPM: 782 /min
Load: 5.9 %
Lambda: 16.6 %
Mass Air / Rev.: 345.0 mg/str
Temperature: 57.6°C
008196 - Intake Manifold Flap; Bank 1
P2004 - 000 - Stuck Open
Mileage: 229961 km
Date: 2019.05.20
Time: 18:14:33
RPM: 782 /min
Load: 5.9 %
Lambda: 89.2 %
Mass Air / Rev.: 325.0 mg/str
Temperature: 57.6°C
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 1342401209220000C81202E5901F00823C0000
Shop #: WSC 06314 000 00000
VCID: 75B4E89955CB520FBDB-8020
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH08 0100
Revision: 000264 Serial number: 8P0820043BG
VCID: 72BED38528A54537989-8026
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008568940
Coding: F18A1F07A0141380EF00000A4F00000000084E0564060003002000000000
Shop #: WSC 06314 000 08192
VCID: 48CA516D7EB99FE716D-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030384A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 49CC5469693366EF093-801C
Serial number: 34928RB400003CCC184Y
Serial number: 35028RB400003D0E3A6N
Serial number: 35128RB400003CCC03DU
Serial number: 35228RB400003D0EAAC
Serial number: 35547RB400003CE961D
Serial number: 35647RB400003CE965C%
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 41DC4C495D83AEAFD13-8014
Component: E0221 H02 0030
01304 - Radio
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2245H004001151
Coding: 0004428
Shop #: WSC 00128 067 57207
VCID: 392C24A93553F66F993-806C
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K086050E43
Coding: E9811F061002020101
VCID: 35342899194B120F7DB-8060
Reset counter: 249
Mileage: 229961 km
Date: 2019.05.20
Time: 18:02:11
01304 - Radio
Reset counter: 249
Mileage: 229961 km
Date: 2019.05.20
Time: 18:02:15
Revision: D0H15004 Serial number: AUX7Z0H5FNI012
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 42DE43455885B5B7C89-8016
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
VCID: 36362F95044D1917741-8062
02546 - Steering Limit Stop
Mileage: 229950 km
Temperature: 26.0°C
Voltage: 13.90 V
Voltage: 13.70 V
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
VCID: 43D04641479FBCBFC3F-8016
Subsystem 1 - Component: Sounder No Answer
01134 - Alarm Horn (H12)
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659850185132
VCID: 3432159D12310B074A5-8060
Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
Coding: 0000564
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Coding: 0000013
Address 56: Radio
End----------(Elapsed Time: 01:03, VBatt start/end: 13.8V/13.7V)-----------
