2018 Audi TT RS (8S0) TPMS Retrofit - Receiving TPMS Malfunction
Rapture
Milwaukee, USA
C?ID=356886
Hi everyone. I have followed the instructions on the Audizine forum on how to retrofit the active TPMS. I believe that I have coded everything properly and have installed the wiring/hardware correctly. I can now see the display in the Virtual cockpit however I have a TPMS Malfunction error and I do not receive pressure or temperature information in the display. When I purchased the car, I bought a new set of HRE wheels and had the TPMS sensors installed hoping that someone would “crack” this retrofit which of course they have. The sensors installed in the wheels are HUF and coded for this application according to the installer. I believe our cars will automatically learn the sensors if they are the correct items and activated but I’m not 100% sure on that.
I’m posting here to see if someone could review my Auto-Scan file to see if there are other issues that I may need to address. There are a few errors but I'm not sure what they are indicating.
Thanks for your help,
Sunday,19,May,2019,16:50:03:62813
VIN: WUACSAFV5J1903145   License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
          65 6C
VIN: WUACSAFV5J1903145   Mileage: 2832km-1759miles
Address 01: Engine (------DAZA)       Labels: None
   Part No SW: 8S0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  H22 0004
   Revision: 53H22000
   Coding: 1A250032242600053620
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM25TFS0118S0907404G 001004
   ROD: EV_ECM25TFS0118S0907404G.rod
   VCID: 3A2D306D1CD0CC07909-806E
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2111
   Revision: 00H06V07
   ROD: EV_TCMDQ500021.rod
   VCID: 2E050C3DD09810A73C1-807A
   Part No SW: 8S0 907 379 J    HW: 8S0 907 379 J
   Component: ESC           H42 0050
   Revision: 00000000    Serial number: 60828000000264
   Coding: 99AAF08D6A9915AC009208680396900635990F56A80010C00960AC
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 48C95AA5523CAE9716D-801C
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0477034741
   Coding: 030C0C1720
   VCID: 3E253C7D00F8E027AC1-806A
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0040
   Revision: 20010000    Serial number: 18140000009000
   Coding: 400050100001041100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C81C6352604A2B7525-8038
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: DF02942900PAG0MUFU03
   Operating and display unit 1 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H07 0020
   Serial number: 00000000000000048934
   Operating and display unit 2 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Operating and display unit 3 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Operating and display unit 4 for air conditioning:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Operating and display unit 5 for air conditioning:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H07 0020
   Part No SW: 5Q0 937 085 BP    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H36 0253
   Serial number: 01001810200214
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08499AA512BC6E97D6D-805C
   Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 180312  038 0371
   Serial number: 00000001803080302574
   Coding: 1BC7F7
   Serial number: 63301075
   Coding: 00005D
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 25 01 2018  00001918
   Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H10 0100
   Serial number: 0000009600350Z005502
   Coding: 150000
   Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
   Component: GTO BF  H05 0010
   Serial number: 20180302122806 00635
   Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099639407
   Subsystem 7 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N475 VB1 FSv  H07 0021
   Serial number: 7008173235E180200182
   Coding: 810500
   Subsystem 8 - Part No SW: 8S0 907 182     HW: 8S0 907 182
   Component: N477 VB1 BFSv  H07 0021
   Serial number: 7008173235E180200201
   Coding: 810500
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 101
                    Mileage: 2816 km
                    Date: 2019.05.19
                    Time: 12:14:40
   Revision: --------    Serial number: 39361808801303
   Coding: 0070150011
   VCID: 43D34D896B1A8DCFC3F-8016
   Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0083
   Serial number:       070418041
   ASAM Dataset: EV_AudiMagneRide 003007
   ROD: EV_AudiMagneRide_003.rod
   VCID: 46D5549D5828B8E7E41-8012
   Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
   Serial number: 003M9R00947
   Coding: BFCCF0C000800000A000001FC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4FFB71B9B75279AF577-801A
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000000000094TJJ/
   Coding: 303333
   Subsystem 2 - Part No SW: -----------    HW: 480 001 604 18
   Serial number: 35700000000B34418D2I
   Subsystem 3 - Part No SW: -----------    HW: 480 001 604 18
   Serial number: 35800000000434418D2C
   Subsystem 4 - Part No SW: -----------    HW: 480 012 203 18
   Component: SideSensor_Dr  005 0108
   Serial number: 351001A0D34181023E3T
   Subsystem 5 - Part No SW: -----------    HW: 480 402 003 18
   Serial number: 3550002B1252D864D14%
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 003 18
   Serial number: 3560002B5252D860824$
   Part No SW: 8S0 907 129 AS    HW: 8S0 907 129 AS
   Component: Lenks. Modul  H07 0150
   Revision: --------    Serial number: 91335RD302603
   Coding: 2058
   ASAM Dataset: EV_SMLSKLOMQB 050001
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 0B43A5A903CA058FFBF-805E
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8S0 920 890 C    HW: 8S0 920 890 C
   Component: FBenUSA       H42 0325
   Coding: 086F10C1388AD7060322ECC49800801000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
   ROD: EV_DashBoardBOSCHAU33X.rod
   Part No SW: 8S0 907 468 G    HW: 8S0 907 468 E
   Component: GW MQB TT3    022 0323
   Serial number: 05041810801350
   Coding: 0301000424025D004B008028B80B00000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 013005
   ROD: EV_GatewContiAU33X_013.rod
   VCID: 44D14E956E148AF7FA5-8010
   Subsystem 2 - Part No SW: 8S0 951 523 K    HW: 8S0 951 523 K
   Component: J453 MFL  H01 0002
   Serial number: 20180326170824 00591
   Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
   Serial number: 8783516904
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00012.03.18
   Coding: 0701
   VCID: 4DC76BB1BD5E4BBF25B-8018
   Part No SW: 8S0 907 566     HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0462809446
   Coding: 030311
   ROD: EV_LaneChangAssis_VW51.rod
   VCID: 7CA1F67556643237C25-8028
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
   Component: SWA Slave  H08 0060
   Serial number: 0475385763
   Coding: 030311
   Serial number: 300318ECT11946
   Coding: 001F53225C00040100000402
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 811E0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3B23356913EAF50F8BF-806E
16275 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 105
                    Mileage: 2805 km
                    Date: 2019.05.16
                    Time: 01:52:48
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 27.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.17 V
                    uAdSensI_SwitchedKl30_xdu16: 12.14 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: activated
   Part No SW: 8S0 035 466 A    HW: 8S0 035 466
   Component: MIB2_amp_P_TT H10 0440
   Revision: 00000001    Serial number: AUZ8ZAJ5C00ATF3
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 34311E553EB43A774A5-8060
   Serial number: 310318ECU2950A
   Coding: 001F53225E00040100000402
   VCID: 42DD488D740084C7C89-8016
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 0362001123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
   VCID: 3635245D28C82867741-8062
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
13706005 - Databus
          [Empfangener Fehlerwert im Signal BCM1_LDS_Stellung: CAN Message Gateway_72]
                    Reset counter: 141
                    Mileage: 2805 km
                    Date: 2019.05.16
                    Time: 01:52:54
   Part No SW: 8S0 035 025 K    HW: 8S0 035 025 B
   Component: MU-H-LNS-US   054 1173
   Serial number: A707D0JS003516
   Coding: 013364020000000011220002041A00102F0000E1007000047E
   VCID: 3537235135CE237F7DB-8060
   Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
   Component: NAR 2017/2018  --- 0060
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
   Serial number: APVAK102031800010144
   Component: Gracenote2  --- 3012
          B11CF 53 [009] - Deactivated
                    Reset counter: 100
                    Mileage: 2805 km
                    Date: 2019.05.16
                    Time: 02:24:49
                    Voltage terminal 30: 12.2 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
7175 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 141
                    Mileage: 2805 km
                    Date: 2019.05.16
                    Time: 01:52:50
                    Voltage terminal 30: 12.3 V
                    BAP-BAP_Function_ID: 01
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 8S0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0002
   Serial number: 40000000006074
   ASAM Dataset: EV_RDKHUFAU736 002007
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 77ABE9596F42116FAF7-8022
12652550 - invalid data record
          B2005 00 [137] -  -
          [invalid_dataset]
                    Reset counter: 100
                    Mileage: 2805 km
                    Date: 2019.05.16
                    Time: 01:52:48
                    System information-System status: active
                    System information-Radio interference: not active
                    System information-Coding information: 00 00
                    System information-Terminal 15 on: Yes
                    System information-Unit: psi
                    System information-Vehicle speed is not zero: No
                    System information-Type of calibration: Menu
                    System information-Transport mode: not activated
8390147 - Tire Pressure Monitoring
          C10DC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 101
                    Mileage: 2814 km
                    Date: 2019.05.19
                    Time: 10:03:04
                    Expanded ambient data 1-Left front tire pressure sensor: identification: Not available
                    Expanded ambient data 1-Right front tire pressure sensor: identification: Not available
                    Expanded ambient data 1-Left rear tire pressure sensor: identification: Not available
                    Expanded ambient data 1-Right rear tire pressure sensor: identification: Not available
   Coding: 0233640102002001000040
   VCID: 392F2F6119D6C71F993-806C
End----------(Elapsed Time: 01:45, VBatt start/end: 1
darkchina811
ITALY
C?ID=333184
did you buy module 65 new from a dealer? if so, it is not parameterized for your car, that's why it shows the INVALID DATA SET error.
that need to be addressed first, and VCDS cannot fix it. then we'll see what other errors stay...
Rapture
Milwaukee, USA
C?ID=356886
Thank you, I bought the part (receiver) online. What would I need to do to address the part, have a dealer do something or is there another way to correct this? I've not seen that this has been a problem for others that have done this retrofit.
darkchina811
ITALY
C?ID=333184
so is it new or used? if used and from a TT you don't have to worry about parameters and maybe there are just some basic settings that you can run with VCDS.
Rapture
Milwaukee, USA
C?ID=356886
It is new. Interesting, I just moved the antenna below the foam tray in the boot and it is now reading the wheel sensors but still has the TPMS Malfunction and no reading. I'm really stumped as this has worked for others plug and play. Is it safe to say that the hardware is wired properly as it sees the controller?
Tuesday,21,May,2019,14:44:11:62813
          65 6C
VIN: WUACSAFV5J1903145   Mileage: 2860km-1777miles
   Revision: 53H22000
   Revision: 00H06V07
   Coding: 030C0C1720
   Coding: 1BC7F7
   Coding: 00005D
   Light switch:
   Coding: 150000
   Coding: 810500
   Coding: 810500
          U1014 00 [009] - -
                    Reset counter: 105
                    Mileage: 2860 km
                    Date: 2019.05.21
                    Time: 14:22:49
   Coding: 0070150011
   Occupant Detection:
   Coding: 303333
   Coding: 2058
   Coding: 0701
   Coding: 030311
   Coding: 030311
   Coding: 811E0000
   Coding: E01800
   Coding: E01800
   Coding: E01800
   Coding: E01800
13706005 - Databus
                    Reset counter: 141
                    Mileage: 2805 km
                    Date: 2019.05.16
                    Time: 01:52:54
                    Reset counter: 105
                    Mileage: 2860 km
                    Date: 2019.05.21
                    Time: 14:38:53
                    Voltage terminal 30: 12.5 V
          B2005 00 [137] -  -
          [invalid_dataset]
                    Reset counter: 105
                    Mileage: 2860 km
                    Date: 2019.05.21
                    Time: 14:23:23
                    System information-Unit: kPa
                    Reset counter: 105
                    Mileage: 2860 km
                    Date: 2019.05.21
                    Time: 14:23:23
                    Expanded ambient data 1-Left front tire pressure sensor: identification: 626799051
                    Expanded ambient data 1-Right front tire pressure sensor: identification: 546928019
                    Expanded ambient data 1-Left rear tire pressure sensor: identification: 685539053
                    Expanded ambient data 1-Right rear tire pressure sensor: identification: 618400954
End----------(Elapsed Time: 01:36, VBatt start/end: 12.4V/12.4V)-----------
Tuesday,21,May,2019,15:49:15:62813
          65 6C
VIN: WUACSAFV5J1903145   Mileage: 2871km-1783miles
   Revision: 53H22000
Readiness: 1110 0101
   Revision: 00H06V07
   Coding: 030C0C1720
   Coding: 1BC7F7
   Coding: 00005D
   Light switch:
   Coding: 150000
   Coding: 810500
   Coding: 810500
          U1014 00 [009] - -
                    Reset counter: 107
                    Mileage: 2871 km
                    Date: 2019.05.21
                    Time: 15:41:49
   Coding: 0070150011
   Occupant Detection:
   Coding: 303333
   Coding: 2058
   Coding: 0701
   Coding: 030311
   Coding: 030311
   Coding: 811E0000
   Coding: E01800
   Coding: E01800
   Coding: E01800
   Coding: E01800
          B2005 00 [137] -  -
          [invalid_dataset]
                    Reset counter: 107
                    Mileage: 2871 km
                    Date: 2019.05.21
                    Time: 15:41:50
                    Reset counter: 107
                    Mileage: 2871 km
                    Date: 2019.05.21
                    Time: 15:41:50
End----------(Elapsed Time: 01:35, VBatt start/end: 12.5V/12.4V)-----------
darkchina811
ITALY
C?ID=333184
yes it is wired correctly. the module needs to be outside the car in order to read the sensors.
it has worked for other people because they bought a USED module.
you won't be able to run basic setting until you load the data set. again VCDS cannot do it.
you need the "other" tool or the dealer-level tool.
beware, if you go to a dealer its online tool will refuse to load because the server will see that your car was bought without the feature.
Rapture
Milwaukee, USA
C?ID=356886
Thanks darkchina,
So it sounds like you are saying it may be easiest to just find another used antenna to make this work, or find a dealer that would be friendly to a retrofit? I realize the dealers tools probably read the VIN and as you state will recognize this option was not original to the build.
Ewan MacNee
C?ID=88042
my module was virgin too so it didnt work either at 1st. I paid to have the parameters loaded onto it by vagcarcoding. Im sure there must be VAG specialists near you that could do it cheaper than the dealer.
Rapture
Milwaukee, USA
C?ID=356886
Thanks Ewan, now that it appears we have honed in on why this is not working I will try to locate someone locally that may be able to assist with this. It really seemed like this should have been plug and play but that seems like wishful thinking to me now.
Do you happen to have any information on what the parameters are that need to be loaded? That seems like it would be the next thing I would need to know.
hadez16
C?ID=289891
Could you quote the link to the How-To from Audizine?
hadez16
C?ID=289891
Rapture
Milwaukee, USA
C?ID=356886
One should be aware that this luckily applies to an TTRS ABS unit as the byte count seems to be still the same...
Other ABS units do have many more bytes where these instructions might not apply anymore...
hadez, are you saying to be careful about using these instructions for other Audi/VW models?
Rapture
Milwaukee, USA
C?ID=356886
I visited a local dealer yesterday who was willing to take a look at this next Thursday. Can anyone offer advice on what to tell them to do? I realize they should know something about this, but my car does not have the option and there isn't another one that does on their lot. My concern is that their software may not let them make an update to an option that is illogical based on my VIN.
They have several new 2019 RS5's on their lot, but I have not been able to confirm if that car uses the same system for TPMS. I doubt it does as it's quite a bit newer.
Rapture
Milwaukee, USA
C?ID=356886
I went to the dealer today and I think basically my part is defective. He said he could not load any parameters on it, and even called the Audi tech "hotline" to see if they had an override code to help, but that did not work. He pulled a similar but newer part off a 19 RS5 and everything worked fine. I guess that at least solves the mystery, and that I did install it correctly. $300 later and I have to find another part. At least I know the root cause now. I think I will purchase the newer part number just because. The Tech also said he has never had to load any parameters on this module prior to installation.
Rapture
Milwaukee, USA
C?ID=356886
Well, I tried another new part and still have the same error codes, same problem. Obviously this antenna needs some type of coding.
MasterTommy
Amsterdam
C?ID=295586
1: Mount module in the oem position with the original bracket. Do not DIY the TPMS module location or you will keep wasting time on this.
2: Load parameters using ‘that other tool’ if ODIS wont do it.
Module not in oem position and parameters not loaded will be the two things you will need to make absolutely sure are correct, otherwise there is no way to know if we’re chasing ghosts.
Rapture
Milwaukee, USA
C?ID=356886
Thanks for the input MT.
Here's the thing though, they plugged in another Antenna they pulled out of a 2019 RS5 and they said mine worked as soon as they drove a few hundred feet. It was in the same position in the trunk, which is literally 6 inches or so from where it mounts under the bumper cover, and the scan show it reads the wheel sensors I.D.'s. Is the other tool the Vag Can Professional?
I really appreciate the help here,
darkchina811
ITALY
C?ID=333184
I saw your private message. I don't have much more insight than what I already shared, in my opinion stop hitting your head on the wall and buy a USED part, possibly from same/similar car. it will work straight away.
+1 as well for installing the module in the OEM position, and OUTSIDE the car. for the record, Golf 7 does not exist with OEM TPMS, I retrofitted following a guide that made me position the module next to the exhaust, below the rear bumper on the left. works perfectly.
Ronaldo
Brazil
C?ID=357813
I did many testings with the antenna placed in the trunk or even on the backseat and it worked fine so I think the module positioning is not that critical. Sent you a pvt message on where to buy a parameterized module.
