- May 20, 2019
- 25
- 5
- Milwaukee, USA
- C?ID=356886
Hi everyone. I have followed the instructions on the Audizine forum on how to retrofit the active TPMS. I believe that I have coded everything properly and have installed the wiring/hardware correctly. I can now see the display in the Virtual cockpit however I have a TPMS Malfunction error and I do not receive pressure or temperature information in the display. When I purchased the car, I bought a new set of HRE wheels and had the TPMS sensors installed hoping that someone would “crack” this retrofit which of course they have. The sensors installed in the wheels are HUF and coded for this application according to the installer. I believe our cars will automatically learn the sensors if they are the correct items and activated but I’m not 100% sure on that.
I’m posting here to see if someone could review my Auto-Scan file to see if there are other issues that I may need to address. There are a few errors but I'm not sure what they are indicating.
Thanks for your help,
Sunday,19,May,2019,16:50:03:62813
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WUACSAFV5J1903145 License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
65 6C
VIN: WUACSAFV5J1903145 Mileage: 2832km-1759miles
Address 01: Engine (------DAZA) Labels: None
Part No SW: 8S0 907 404 G HW: 07K 907 309 E
Component: R5 2.5l TFSI H22 0004
Revision: 53H22000
Coding: 1A250032242600053620
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM25TFS0118S0907404G 001004
ROD: EV_ECM25TFS0118S0907404G.rod
VCID: 3A2D306D1CD0CC07909-806E
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2111
Revision: 00H06V07
ROD: EV_TCMDQ500021.rod
VCID: 2E050C3DD09810A73C1-807A
Part No SW: 8S0 907 379 J HW: 8S0 907 379 J
Component: ESC H42 0050
Revision: 00000000 Serial number: 60828000000264
Coding: 99AAF08D6A9915AC009208680396900635990F56A80010C00960AC
ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
ROD: EV_Brake1UDSContiMK100IPB_061.rod
VCID: 48C95AA5523CAE9716D-801C
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0907
Revision: 00037000 Serial number: 0477034741
Coding: 030C0C1720
VCID: 3E253C7D00F8E027AC1-806A
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 8S0 820 043 HW: 8S0 820 043
Component: AC Automat H05 0040
Revision: 20010000 Serial number: 18140000009000
Coding: 400050100001041100
ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
ROD: EV_AirCondiVAPrehAU33x.rod
VCID: 6C81C6352604A2B7525-8038
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: DF02942900PAG0MUFU03
Operating and display unit 1 for air conditioning:
Subsystem 2 - Part No SW: 8S0 820 373 A HW: 8S0 820 373 A
Component: E774 BuA_1 H07 0020
Serial number: 00000000000000048934
Operating and display unit 2 for air conditioning:
Subsystem 3 - Part No SW: 8S0 820 359 A HW: 8S0 820 359 A
Component: E775 BuA_2 H07 0020
Operating and display unit 3 for air conditioning:
Subsystem 4 - Part No SW: 8S0 820 359 HW: 8S0 820 359
Component: E776 BuA_3 H07 0020
Operating and display unit 4 for air conditioning:
Subsystem 5 - Part No SW: 8S0 820 359 B HW: 8S0 820 359 B
Component: E777 BuA_4 H07 0020
Operating and display unit 5 for air conditioning:
Subsystem 6 - Part No SW: 8S0 820 373 B HW: 8S0 820 373 B
Component: E778 BuA_5 H07 0020
Part No SW: 5Q0 937 085 BP HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H36 0253
Serial number: 01001810200214
ROD: EV_BCMBOSCH_018.rod
VCID: 08499AA512BC6E97D6D-805C
Subsystem 1 - Part No SW: 8S1 955 119 B HW: 8K1 955 119 B Labels: 5QX-955-119-V1.CLB
Component: 43x LL 180312 038 0371
Serial number: 00000001803080302574
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 63301075
Coding: 00005D
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 25 01 2018 00001918
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z005502
Coding: 150000
Garage Door Opener Operating Unit:
Subsystem 5 - Part No SW: 8S0 959 719 HW: 8S0 959 719
Component: GTO BF H05 0010
Serial number: 20180302122806 00635
Subsystem 6 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099639407
Valve Block 1 In Driver Side Front Seat:
Subsystem 7 - Part No SW: 8S0 907 182 HW: 8S0 907 182
Component: N475 VB1 FSv H07 0021
Serial number: 7008173235E180200182
Coding: 810500
Valve Block 1 In Passenger Side Front Seat:
Subsystem 8 - Part No SW: 8S0 907 182 HW: 8S0 907 182
Component: N477 VB1 BFSv H07 0021
Serial number: 7008173235E180200201
Coding: 810500
526359 - Control Module Incorrectly Coded
U1014 00 [009] - -
[Steuergerät falsch codiert->Keine Anzeige]
Reset counter: 101
Mileage: 2816 km
Date: 2019.05.19
Time: 12:14:40
Revision: -------- Serial number: 39361808801303
Coding: 0070150011
VCID: 43D34D896B1A8DCFC3F-8016
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 H HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0083
Serial number: 070418041
ASAM Dataset: EV_AudiMagneRide 003007
ROD: EV_AudiMagneRide_003.rod
VCID: 46D5549D5828B8E7E41-8012
Part No SW: 5Q0 959 655 R HW: 5Q0 959 655 R
Serial number: 003M9R00947
Coding: BFCCF0C000800000A000001FC24800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4FFB71B9B75279AF577-801A
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000000000094TJJ/
Coding: 303333
Subsystem 2 - Part No SW: ----------- HW: 480 001 604 18
Serial number: 35700000000B34418D2I
Subsystem 3 - Part No SW: ----------- HW: 480 001 604 18
Serial number: 35800000000434418D2C
Subsystem 4 - Part No SW: ----------- HW: 480 012 203 18
Component: SideSensor_Dr 005 0108
Serial number: 351001A0D34181023E3T
Subsystem 5 - Part No SW: ----------- HW: 480 402 003 18
Serial number: 3550002B1252D864D14%
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 402 003 18
Serial number: 3560002B5252D860824$
Part No SW: 8S0 907 129 AS HW: 8S0 907 129 AS
Component: Lenks. Modul H07 0150
Revision: -------- Serial number: 91335RD302603
Coding: 2058
ASAM Dataset: EV_SMLSKLOMQB 050001
VCID: 0B43A5A903CA058FFBF-805E
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8S0 920 890 C HW: 8S0 920 890 C
Component: FBenUSA H42 0325
Coding: 086F10C1388AD7060322ECC49800801000000000
ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
ROD: EV_DashBoardBOSCHAU33X.rod
Part No SW: 8S0 907 468 G HW: 8S0 907 468 E
Component: GW MQB TT3 022 0323
Serial number: 05041810801350
Coding: 0301000424025D004B008028B80B00000000000000000000000000000001
ASAM Dataset: EV_GatewContiAU33X 013005
ROD: EV_GatewContiAU33X_013.rod
VCID: 44D14E956E148AF7FA5-8010
Subsystem 2 - Part No SW: 8S0 951 523 K HW: 8S0 951 523 K
Component: J453 MFL H01 0002
Serial number: 20180326170824 00591
Subsystem 3 - Part No SW: 8W0 915 181 HW: 8W0 915 181
Serial number: 8783516904
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00012.03.18
Coding: 0701
VCID: 4DC76BB1BD5E4BBF25B-8018
Part No SW: 8S0 907 566 HW: 4H0 907 566 F
Component: SWA Master H08 0060
Serial number: 0462809446
Coding: 030311
VCID: 7CA1F67556643237C25-8028
Subsystem 1 - Part No SW: 8S0 907 568 HW: 4H0 907 568 F
Component: SWA Slave H08 0060
Serial number: 0475385763
Coding: 030311
Component: TSG FS 020 0041
Serial number: 300318ECT11946
Coding: 001F53225C00040100000402
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 811E0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3B23356913EAF50F8BF-806E
16275 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 105
Mileage: 2805 km
Date: 2019.05.16
Time: 01:52:48
Motor status: 00
Supply voltage: 12.25 V
Temperature: 27.0 °C
KFC: 3F
KFA: 00 93
Environmental conditions: 21
uioUdNotFilt_xdu16: 12.17 V
uAdSensI_SwitchedKl30_xdu16: 12.14 V
NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
NoInitCause_RackPos_Rohwert: 01 80
RP_VALCNTSAV: activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_KMN_RACKPOS_SET: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_WHLSPDPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: activated
Part No SW: 8S0 035 466 A HW: 8S0 035 466
Component: MIB2_amp_P_TT H10 0440
Revision: 00000001 Serial number: AUZ8ZAJ5C00ATF3
Coding: 0133040000AA2A2AAA0000010000
ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
VCID: 34311E553EB43A774A5-8060
Component: TSG BFS 020 0041
Serial number: 310318ECU2950A
Coding: 001F53225E00040100000402
VCID: 42DD488D740084C7C89-8016
Address 55: Headlight Range (J745) Labels:* None
Part No SW: 4H4 907 357 G HW: 7P6 907 357 B
Component: MxB-ECU 001 0115
Coding: 0362001123200400
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
VCID: 3635245D28C82867741-8062
Coding: E01800
Coding: E01800
Subsystem 3 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H02 S002
Coding: E01800
Subsystem 4 - Part No SW: 8S0 941 329 HW: 8S0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 S002
Coding: E01800
13706005 - Databus
[Empfangener Fehlerwert im Signal BCM1_LDS_Stellung: CAN Message Gateway_72]
Reset counter: 141
Mileage: 2805 km
Date: 2019.05.16
Time: 01:52:54
Part No SW: 8S0 035 025 K HW: 8S0 035 025 B
Component: MU-H-LNS-US 054 1173
Serial number: A707D0JS003516
Coding: 013364020000000011220002041A00102F0000E1007000047E
VCID: 3537235135CE237F7DB-8060
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Multimedia Operating Unit:
Subsystem 2 - Part No SW: 8S0 919 614 M HW: 8S0 919 614 M
Component: ControlUnit_H H30 0206
Serial number: APVAK102031800010144
Component: Gracenote2 --- 3012
B11CF 53 [009] - Deactivated
Reset counter: 100
Mileage: 2805 km
Date: 2019.05.16
Time: 02:24:49
Voltage terminal 30: 12.2 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
U1111 00 [008] - -
Reset counter: 141
Mileage: 2805 km
Date: 2019.05.16
Time: 01:52:50
Voltage terminal 30: 12.3 V
BAP-BAP_Function_ID: 01
Address 65: Tire Pressure (J502) Labels: None
Part No SW: 8S0 907 273 HW: 4M0 907 273 B
Component: RDKHUFAU736 H04 0002
Serial number: 40000000006074
ROD: EV_RDKHUFAU736_AU37.rod
VCID: 77ABE9596F42116FAF7-8022
12652550 - invalid data record
B2005 00 [137] - -
[invalid_dataset]
Reset counter: 100
Mileage: 2805 km
Date: 2019.05.16
Time: 01:52:48
System information-System status: active
System information-Radio interference: not active
System information-Coding information: 00 00
System information-Terminal 15 on: Yes
System information-Unit: psi
System information-Vehicle speed is not zero: No
System information-Type of calibration: Menu
System information-Transport mode: not activated
8390147 - Tire Pressure Monitoring
C10DC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 101
Mileage: 2814 km
Date: 2019.05.19
Time: 10:03:04
Expanded ambient data 1-Left front tire pressure sensor: identification: Not available
Expanded ambient data 1-Right front tire pressure sensor: identification: Not available
Expanded ambient data 1-Left rear tire pressure sensor: identification: Not available
Expanded ambient data 1-Right rear tire pressure sensor: identification: Not available
Component: RVC Compact H12 0231
Coding: 0233640102002001000040
VCID: 392F2F6119D6C71F993-806C
End----------(Elapsed Time: 01:45, VBatt start/end: 1
