Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: 2018 Audi TT RS (8S0) TPMS Retrofit - Receiving TPMS Malfunction
    Verified VCDS User Rapture's Avatar
    May 2019
    Milwaukee, USA
    Hi everyone. I have followed the instructions on the Audizine forum on how to retrofit the active TPMS. I believe that I have coded everything properly and have installed the wiring/hardware correctly. I can now see the display in the Virtual cockpit however I have a TPMS Malfunction error and I do not receive pressure or temperature information in the display. When I purchased the car, I bought a new set of HRE wheels and had the TPMS sensors installed hoping that someone would “crack” this retrofit which of course they have. The sensors installed in the wheels are HUF and coded for this application according to the installer. I believe our cars will automatically learn the sensors if they are the correct items and activated but I’m not 100% sure on that.
    I’m posting here to see if someone could review my Auto-Scan file to see if there are other issues that I may need to address. There are a few errors but I'm not sure what they are indicating.
    Thanks for your help,
    Sunday,19,May,2019,16:50:03:62813
    VIN: WUACSAFV5J1903145   License Plate:
    Chassis Type: FV-AU37 (8S0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 3C 42 44 47 52 55 5F
              65 6C
    VIN: WUACSAFV5J1903145   Mileage: 2832km-1759miles
    Address 01: Engine (------DAZA)       Labels: None
       Part No SW: 8S0 907 404 G    HW: 07K 907 309 E
       Component: R5 2.5l TFSI  H22 0004
       Revision: 53H22000
       Coding: 1A250032242600053620
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM25TFS0118S0907404G 001004
       ROD: EV_ECM25TFS0118S0907404G.rod
       VCID: 3A2D306D1CD0CC07909-806E
       Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2111
       Revision: 00H06V07
       ROD: EV_TCMDQ500021.rod
       VCID: 2E050C3DD09810A73C1-807A
       Part No SW: 8S0 907 379 J    HW: 8S0 907 379 J
       Component: ESC           H42 0050
       Revision: 00000000    Serial number: 60828000000264
       Coding: 99AAF08D6A9915AC009208680396900635990F56A80010C00960AC
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 061007
       ROD: EV_Brake1UDSContiMK100IPB_061.rod
       VCID: 48C95AA5523CAE9716D-801C
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0477034741
       Coding: 030C0C1720
       VCID: 3E253C7D00F8E027AC1-806A
       Part No SW: 8S0 820 043     HW: 8S0 820 043
       Component: AC Automat    H05 0040
       Revision: 20010000    Serial number: 18140000009000
       Coding: 400050100001041100
       ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
       ROD: EV_AirCondiVAPrehAU33x.rod
       VCID: 6C81C6352604A2B7525-8038
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: DF02942900PAG0MUFU03
       Operating and display unit 1 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
       Component: E774 BuA_1  H07 0020
       Serial number: 00000000000000048934
       Operating and display unit 2 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H07 0020
       Operating and display unit 3 for air conditioning:
       Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H07 0020
       Operating and display unit 4 for air conditioning:
       Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H07 0020
       Operating and display unit 5 for air conditioning:
       Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
       Component: E778 BuA_5  H07 0020
       Part No SW: 5Q0 937 085 BP    HW: 5Q0 937 085 BG
       Component: BCM MQBAB HNA H36 0253
       Serial number: 01001810200214
       ROD: EV_BCMBOSCH_018.rod
       VCID: 08499AA512BC6E97D6D-805C
       Subsystem 1 - Part No SW: 8S1 955 119 B    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
       Component: 43x LL 180312  038 0371
       Serial number: 00000001803080302574
       Coding: 1BC7F7
       Serial number: 63301075
       Coding: 00005D
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 25 01 2018  00001918
       Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H10 0100
       Serial number: 0000009600350Z005502
       Coding: 150000
       Subsystem 5 - Part No SW: 8S0 959 719     HW: 8S0 959 719
       Component: GTO BF  H05 0010
       Serial number: 20180302122806 00635
       Subsystem 6 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000099639407
       Subsystem 7 - Part No SW: 8S0 907 182     HW: 8S0 907 182
       Component: N475 VB1 FSv  H07 0021
       Serial number: 7008173235E180200182
       Coding: 810500
       Subsystem 8 - Part No SW: 8S0 907 182     HW: 8S0 907 182
       Component: N477 VB1 BFSv  H07 0021
       Serial number: 7008173235E180200201
       Coding: 810500
    526359 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [Steuergerät falsch codiert->Keine Anzeige]
                        Reset counter: 101
                        Mileage: 2816 km
                        Date: 2019.05.19
                        Time: 12:14:40
       Revision: --------    Serial number: 39361808801303
       Coding: 0070150011
       VCID: 43D34D896B1A8DCFC3F-8016
       Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
       Component: DAEMPFUNGS-SG H11 0083
       Serial number:       070418041
       ASAM Dataset: EV_AudiMagneRide 003007
       ROD: EV_AudiMagneRide_003.rod
       VCID: 46D5549D5828B8E7E41-8012
       Part No SW: 5Q0 959 655 R    HW: 5Q0 959 655 R
       Serial number: 003M9R00947
       Coding: BFCCF0C000800000A000001FC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4FFB71B9B75279AF577-801A
       Occupant Detection:
       Subsystem 1 - Part No SW: 4M0 959 339     HW: 4M0 959 339
       Component: BF-Gewichtss.  H11 0022
       Serial number: IBH0000000000094TJJ/
       Coding: 303333
       Subsystem 2 - Part No SW: -----------    HW: 480 001 604 18
       Serial number: 35700000000B34418D2I
       Subsystem 3 - Part No SW: -----------    HW: 480 001 604 18
       Serial number: 35800000000434418D2C
       Subsystem 4 - Part No SW: -----------    HW: 480 012 203 18
       Component: SideSensor_Dr  005 0108
       Serial number: 351001A0D34181023E3T
       Subsystem 5 - Part No SW: -----------    HW: 480 402 003 18
       Serial number: 3550002B1252D864D14%
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 003 18
       Serial number: 3560002B5252D860824$
       Part No SW: 8S0 907 129 AS    HW: 8S0 907 129 AS
       Component: Lenks. Modul  H07 0150
       Revision: --------    Serial number: 91335RD302603
       Coding: 2058
       ASAM Dataset: EV_SMLSKLOMQB 050001
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 0B43A5A903CA058FFBF-805E
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8S0 920 890 C    HW: 8S0 920 890 C
       Component: FBenUSA       H42 0325
       Coding: 086F10C1388AD7060322ECC49800801000000000
       ASAM Dataset: EV_DashBoardBOSCHAU33X 001027
       ROD: EV_DashBoardBOSCHAU33X.rod
       Part No SW: 8S0 907 468 G    HW: 8S0 907 468 E
       Component: GW MQB TT3    022 0323
       Serial number: 05041810801350
       Coding: 0301000424025D004B008028B80B00000000000000000000000000000001
       ASAM Dataset: EV_GatewContiAU33X 013005
       ROD: EV_GatewContiAU33X_013.rod
       VCID: 44D14E956E148AF7FA5-8010
       Subsystem 2 - Part No SW: 8S0 951 523 K    HW: 8S0 951 523 K
       Component: J453 MFL  H01 0002
       Serial number: 20180326170824 00591
       Subsystem 3 - Part No SW: 8W0 915 181     HW: 8W0 915 181
       Serial number: 8783516904
       Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7762
       Serial number: HA1-00012.03.18
       Coding: 0701
       VCID: 4DC76BB1BD5E4BBF25B-8018
       Part No SW: 8S0 907 566     HW: 4H0 907 566 F
       Component: SWA Master    H08 0060
       Serial number: 0462809446
       Coding: 030311
       ROD: EV_LaneChangAssis_VW51.rod
       VCID: 7CA1F67556643237C25-8028
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8S0 907 568     HW: 4H0 907 568 F
       Component: SWA Slave  H08 0060
       Serial number: 0475385763
       Coding: 030311
       Serial number: 300318ECT11946
       Coding: 001F53225C00040100000402
       Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 811E0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 3B23356913EAF50F8BF-806E
    16275 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 105
                        Mileage: 2805 km
                        Date: 2019.05.16
                        Time: 01:52:48
                        Motor status: 00
                        Supply voltage: 12.25 V
                        Temperature: 27.0 °C
                        KFC: 3F
                        KFA: 00 93
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 12.17 V
                        uAdSensI_SwitchedKl30_xdu16: 12.14 V
                        NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                        NoInitCause_RackPos_Rohwert: 01 80
                        RP_VALCNTSAV: activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: not activated
                        RP_CNTERR: activated
       Part No SW: 8S0 035 466 A    HW: 8S0 035 466
       Component: MIB2_amp_P_TT H10 0440
       Revision: 00000001    Serial number: AUZ8ZAJ5C00ATF3
       Coding: 0133040000AA2A2AAA0000010000
       ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
       ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
       VCID: 34311E553EB43A774A5-8060
       Serial number: 310318ECU2950A
       Coding: 001F53225E00040100000402
       VCID: 42DD488D740084C7C89-8016
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 0362001123200400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005012
       VCID: 3635245D28C82867741-8062
       Coding: E01800
       Coding: E01800
       Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 S002
       Coding: E01800
       Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 S002
       Coding: E01800
    13706005 - Databus
              [Empfangener Fehlerwert im Signal BCM1_LDS_Stellung: CAN Message Gateway_72]
                        Reset counter: 141
                        Mileage: 2805 km
                        Date: 2019.05.16
                        Time: 01:52:54
       Part No SW: 8S0 035 025 K    HW: 8S0 035 025 B
       Component: MU-H-LNS-US   054 1173
       Serial number: A707D0JS003516
       Coding: 013364020000000011220002041A00102F0000E1007000047E
       VCID: 3537235135CE237F7DB-8060
       Subsystem 1 - Part No SW: V03 959 801 GH    HW: -----------
       Component: NAR 2017/2018  --- 0060
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8S0 919 614 M    HW: 8S0 919 614 M
       Serial number: APVAK102031800010144
       Component: Gracenote2  --- 3012
              B11CF 53 [009] - Deactivated
                        Reset counter: 100
                        Mileage: 2805 km
                        Date: 2019.05.16
                        Time: 02:24:49
                        Voltage terminal 30: 12.2 V
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    7175 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 141
                        Mileage: 2805 km
                        Date: 2019.05.16
                        Time: 01:52:50
                        Voltage terminal 30: 12.3 V
                        BAP-BAP_Function_ID: 01
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 8S0 907 273     HW: 4M0 907 273 B
       Component: RDKHUFAU736   H04 0002
       Serial number: 40000000006074
       ASAM Dataset: EV_RDKHUFAU736 002007
       ROD: EV_RDKHUFAU736_AU37.rod
       VCID: 77ABE9596F42116FAF7-8022
    12652550 - invalid data record
              B2005 00 [137] -  -
              [invalid_dataset]
                        Reset counter: 100
                        Mileage: 2805 km
                        Date: 2019.05.16
                        Time: 01:52:48
                        System information-System status: active
                        System information-Radio interference: not active
                        System information-Coding information: 00 00
                        System information-Terminal 15 on: Yes
                        System information-Unit: psi
                        System information-Vehicle speed is not zero: No
                        System information-Type of calibration: Menu
                        System information-Transport mode: not activated
    8390147 - Tire Pressure Monitoring
              C10DC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 101
                        Mileage: 2814 km
                        Date: 2019.05.19
                        Time: 10:03:04
                        Expanded ambient data 1-Left front tire pressure sensor: identification: Not available
                        Expanded ambient data 1-Right front tire pressure sensor: identification: Not available
                        Expanded ambient data 1-Left rear tire pressure sensor: identification: Not available
                        Expanded ambient data 1-Right rear tire pressure sensor: identification: Not available
       Coding: 0233640102002001000040
       VCID: 392F2F6119D6C71F993-806C
    End----------(Elapsed Time: 01:45, VBatt start/end: 1
    Apr 2018
    ITALY
    did you buy module 65 new from a dealer? if so, it is not parameterized for your car, that's why it shows the INVALID DATA SET error.
    that need to be addressed first, and VCDS cannot fix it. then we'll see what other errors stay...
  3. Likes Dana liked this post
    May 2019
    Milwaukee, USA
    Thank you, I bought the part (receiver) online. What would I need to do to address the part, have a dealer do something or is there another way to correct this? I've not seen that this has been a problem for others that have done this retrofit.
    Apr 2018
    ITALY
    so is it new or used? if used and from a TT you don't have to worry about parameters and maybe there are just some basic settings that you can run with VCDS.
    May 2019
    Milwaukee, USA
    It is new. Interesting, I just moved the antenna below the foam tray in the boot and it is now reading the wheel sensors but still has the TPMS Malfunction and no reading. I'm really stumped as this has worked for others plug and play. Is it safe to say that the hardware is wired properly as it sees the controller?
    Tuesday,21,May,2019,14:44:11:62813
              65 6C
    VIN: WUACSAFV5J1903145   Mileage: 2860km-1777miles
       Revision: 53H22000
       Revision: 00H06V07
       Coding: 030C0C1720
       Coding: 1BC7F7
       Coding: 00005D
       Light switch:
       Coding: 150000
       Coding: 810500
       Coding: 810500
              U1014 00 [009] - -
                        Reset counter: 105
                        Mileage: 2860 km
                        Date: 2019.05.21
                        Time: 14:22:49
       Coding: 0070150011
       Occupant Detection:
       Coding: 303333
       Coding: 2058
       Coding: 0701
       Coding: 030311
       Coding: 030311
       Coding: 811E0000
       Coding: E01800
       Coding: E01800
       Coding: E01800
       Coding: E01800
    13706005 - Databus
                        Reset counter: 141
                        Mileage: 2805 km
                        Date: 2019.05.16
                        Time: 01:52:54
                        Reset counter: 105
                        Mileage: 2860 km
                        Date: 2019.05.21
                        Time: 14:38:53
                        Voltage terminal 30: 12.5 V
              B2005 00 [137] -  -
              [invalid_dataset]
                        Reset counter: 105
                        Mileage: 2860 km
                        Date: 2019.05.21
                        Time: 14:23:23
                        System information-Unit: kPa
                        Reset counter: 105
                        Mileage: 2860 km
                        Date: 2019.05.21
                        Time: 14:23:23
                        Expanded ambient data 1-Left front tire pressure sensor: identification: 626799051
                        Expanded ambient data 1-Right front tire pressure sensor: identification: 546928019
                        Expanded ambient data 1-Left rear tire pressure sensor: identification: 685539053
                        Expanded ambient data 1-Right rear tire pressure sensor: identification: 618400954
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.4V/12.4V)-----------
    Tuesday,21,May,2019,15:49:15:62813
              65 6C
    VIN: WUACSAFV5J1903145   Mileage: 2871km-1783miles
       Revision: 53H22000
    Readiness: 1110 0101
       Revision: 00H06V07
       Coding: 030C0C1720
       Coding: 1BC7F7
       Coding: 00005D
       Light switch:
       Coding: 150000
       Coding: 810500
       Coding: 810500
              U1014 00 [009] - -
                        Reset counter: 107
                        Mileage: 2871 km
                        Date: 2019.05.21
                        Time: 15:41:49
       Coding: 0070150011
       Occupant Detection:
       Coding: 303333
       Coding: 2058
       Coding: 0701
       Coding: 030311
       Coding: 030311
       Coding: 811E0000
       Coding: E01800
       Coding: E01800
       Coding: E01800
       Coding: E01800
              B2005 00 [137] -  -
              [invalid_dataset]
                        Reset counter: 107
                        Mileage: 2871 km
                        Date: 2019.05.21
                        Time: 15:41:50
                        Reset counter: 107
                        Mileage: 2871 km
                        Date: 2019.05.21
                        Time: 15:41:50
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.5V/12.4V)-----------
    Apr 2018
    ITALY
    yes it is wired correctly. the module needs to be outside the car in order to read the sensors.
    it has worked for other people because they bought a USED module.
    you won't be able to run basic setting until you load the data set. again VCDS cannot do it.
    you need the "other" tool or the dealer-level tool.
    beware, if you go to a dealer its online tool will refuse to load because the server will see that your car was bought without the feature.
    May 2019
    Milwaukee, USA
    Thanks darkchina,
    So it sounds like you are saying it may be easiest to just find another used antenna to make this work, or find a dealer that would be friendly to a retrofit? I realize the dealers tools probably read the VIN and as you state will recognize this option was not original to the build.
  9. #8
    Feb 2016
    my module was virgin too so it didnt work either at 1st. I paid to have the parameters loaded onto it by vagcarcoding. Im sure there must be VAG specialists near you that could do it cheaper than the dealer.
  10. #9
    May 2019
    Milwaukee, USA
    Quote Originally Posted by Ewan MacNee View Post
    Thanks Ewan, now that it appears we have honed in on why this is not working I will try to locate someone locally that may be able to assist with this. It really seemed like this should have been plug and play but that seems like wishful thinking to me now.
    Do you happen to have any information on what the parameters are that need to be loaded? That seems like it would be the next thing I would need to know.
  11. #10
    Jun 2017
    Could you quote the link to the How-To from Audizine?
  12. Likes Uwe liked this post
