Results 1 to 2 of 2
Thread: MK7 GTI 2014 JPN KEY FOB SUDDENLY NOT WORKING
    Feb 2018
    New Zealand
    So this car had an AFS fault so changed the bulb and fault gone but noticed a warning about changing the key battery so put a new one in.
    Now the remote unlock/lock doesnt work on the fob at all and when starting the car it only works if key is placed next to the ignition (keyless start car)
    Checked multiple batteries and even VW tried a battery and no luck.
    Nothing unusual in fault scans.
    Only coding changes that were recent were enabling DRL and radio region change but not sure of exact timing and if this correlates at all.
    Also how is it possible to obtain the original long coding for this cars modules?
    https://youtu.be/kJz_9dnEDDQ
    Tuesday,21,May,2019,15:27:51:30955
    VCDS Version: 18.9.1.0 (x64)
    Data version: 20190215 DS296.0
    VIN: WVWZZZAUZEW218504   License Plate:
    Mileage: 64781km-40253mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 57 5F
              A5 A9
    VIN: WVWZZZAUZEW218504   Mileage: 64781km-40253miles
    Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0007
       Revision: --H13---
       Coding: 091D00324464050B3000
       ASAM Dataset: EV_ECM20TFS0215G0906259 001011
       ROD: EV_ECM20TFS0215G0906259_VW37.rod
       VCID: 6BD5922E82FD1B1218-803E
    Readiness: 1000 0001
       Part No SW: 0D9 300 040 S    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H52 4307
       Revision: 05852204    Serial number: TFK01311110539
       ROD: EV_TCMDQ250021.rod
       VCID: 275DAE1E5E95FF72BC-8072
       Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
       Component: ESC           H31 0557
       Revision: 00000000    Serial number: 6314300000042A
       Coding: 01FA93A134212974037C060081C7A980C92C94C0608195F7F84250B8C209
       VCID: 7CF7A172F7938CAA81-8028
       Revision: 00021000    Serial number: 0194911728
       Coding: 030C0C
       VCID: 3A7B676ABD27729AD3-806E
       Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
       Component: Climatronic   H02 0805
       Revision: 00001K06
       Coding: 00120004100100001105000011101800
       VCID: 387F7D62832B608A25-806C
       Part No SW: 5Q0 937 085 T    HW: 5Q0 937 085 T
       Component: BCM MQBAB HNA H16 0124
       Serial number: 00011331900473
       Coding: 03011A42424522FB4BE44000000C07281800000000000000000000000000
       ROD: EV_BCMBOSCH_012.rod
       VCID: 4A9B37AAEDC7E21A43-801E
       Component: WWS    131111  042 0551
       Serial number:         131112171130
       Component: RLFS  024 0042
       Serial number: Y13M11D14H17M43S30S6
       Coding: 31E8DD
       Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H02 0033
       Revision: --------    Serial number: 94231333001339
       Coding: 0071051011
       ASAM Dataset: EV_EPHVA18AU3700000 002019
       VCID: 3B75626EB21D4B92C8-806E
       Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
       Component: ACC Bosch MQB H04 0150
       Serial number: 22111376510661
       Coding: 021C1700FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001013
       VCID: 3561745694399DE23E-8060
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H15 0115
       Serial number: 15111341354256
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 76E3B35AC9BFD6FAF7-8022
       Component: AirbagVW20    014 0386
       Serial number: 003MLR020841
       Coding: 98FCC0C0000000005C5400CF00C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F0D567EE68597B2A4-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169677B22111340078
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169676B20111372042
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 611 13
       Serial number: 357670000001AAFC2E06
       Subsystem 4 - Part No SW: -----------    HW: 480 001 811 13
       Serial number: 3586700000012ACC1E0
       Subsystem 5 - Part No SW: -----------    HW: 480 401 911 13
       Serial number: 3516502A51118A3362A$
       Subsystem 6 - Part No SW: -----------    HW: 480 401 911 13
       Serial number: 3526502AD1220762739%
       Subsystem 7 - Part No SW: -----------    HW: 480 401 511 13
       Serial number: 3556502AB1230BC312A6
       Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 19111304400277
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 7BF5A26EF29D8B9288-802E
       Part No SW: 5G6 920 870 C    HW: 5G6 920 870 C
       Component: KOMBI         320 2210
       Coding: 23AD09187F80000C02886A03040000
       VCID: 2F6D463E7665A73274-807A
       Revision: --------    Serial number: 0001261186
       Coding: 030100042B085900EF00027E9C0F00010001000000000000000000000000
       ROD: EV_GatewLear_010.rod
       VCID: 3F8D167EA60557B2E4-806A
       Component: E221__MFL-DC1  H06 0038
       Serial number: 27130001904010093457
       Coding: 2DFFFF
       Serial number: 0456231903
       Revision: 00000000    Serial number: 13000263142004
       Coding: DD00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 346749529F4384EA09-8060
       Serial number: 12111304080522
       Coding: 003F1320D001048000001000
       VCID: 408F1582DBFB284A9D-8014
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000003472301
       Coding: 0D0000
    65604 - Door Warning Lamp
              B1326 01 [009] - Electrical Failure
                        Reset counter: 61
                        Mileage: 64773 km
                        Date: 2019.05.21
                        Time: 13:50:44
       Coding: 9103
       ROD: EV_SteerAssisMQB_010.rod
       Serial number: 17111301100847
       Coding: 003F1120DE01048000801000
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000003408857
       Coding: 050000
                        Reset counter: 61
                        Mileage: 64773 km
                        Date: 2019.05.21
                        Time: 13:25:26
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Coding: 029603000B010200
       VCID: 3D716C76AC0945A2F6-8068
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
    Address 57: TV Tuner (R78)       Labels:* None
       Part No SW: 8V0 919 129 B    HW: 8V0 919 129
       Component: JP-DTV        H09 1360
       Coding: 02011C0000000100000000
       ASAM Dataset: EV_TVMELC 001033
       ROD: EV_TVMELC_VW37.rod
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 050 A    HW: 5G0 035 050
       Component: MU-H-N-JP     H41 0258
       Serial number: K5F AW74A00JNQ
       Coding: 02730006FF00000021111201001000001F0203260100010076
       ASAM Dataset: EV_MUHig4CAW7 001105
       ROD: EV_MUHig4CAW7_VW37.rod
       VCID: 1A3B87EA1DE7529A33-804E
       Component: ABT_High  H51 0022
       Serial number: VWZ8Z9NJ6004X3
       Subsystem 2 - Part No SW: V03 959 800 GH    HW: -----------
       Component: JPN 2013/2014  --- 7127
       Chip Card Reader Control Module:
       Subsystem 3 - Part No SW: 8V0 919 813     HW: 8V0 919 813
       Component: DSRC UNIT  H04 0001
       Serial number: 502070096701
       Traffic Data Aerial:
       Subsystem 4 - Part No SW: 8V0 035 504 A    HW: 8V0 035 504 A
       Component: VICS Antenna  H03 0001
       Serial number: 503070065004
       Subsystem 5 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote  --- 2006
    1543 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 60
                        Mileage: 64773 km
                        Date: 2019.05.21
                        Time: 13:14:13
                        Voltage terminal 30: 14.4 V
                        Byte_Coding_Condition-byte_0_condition: OK
                        Byte_Coding_Condition-byte_1_condition: OK
                        Byte_Coding_Condition-byte_10_condition: ERROR
                        Byte_Coding_Condition-byte_11_condition: ERROR
                        Byte_Coding_Condition-byte_12_condition: ERROR
                        Byte_Coding_Condition-byte_13_condition: ERROR
                        Byte_Coding_Condition-byte_14_condition: ERROR
                        Byte_Coding_Condition-byte_15_condition: ERROR
                        Byte_Coding_Condition-byte_16_condition: ERROR
                        Byte_Coding_Condition-byte_17_condition: ERROR
                        Byte_Coding_Condition-byte_18_condition: ERROR
                        Byte_Coding_Condition-byte_19_condition: ERROR
                        Byte_Coding_Condition-byte_2_condition: OK
                        Byte_Coding_Condition-byte_20_condition: ERROR
                        Byte_Coding_Condition-byte_21_condition: ERROR
                        Byte_Coding_Condition-byte_22_condition: ERROR
                        Byte_Coding_Condition-byte_23_condition: ERROR
                        Byte_Coding_Condition-byte_24_condition: ERROR
                        Byte_Coding_Condition-byte_25_condition: ERROR
                        Byte_Coding_Condition-byte_26_condition: ERROR
                        Byte_Coding_Condition-byte_27_condition: ERROR
                        Byte_Coding_Condition-byte_3_condition: OK
                        Byte_Coding_Condition-byte_4_condition: OK
                        Byte_Coding_Condition-byte_5_condition: OK
                        Byte_Coding_Condition-byte_6_condition: OK
                        Byte_Coding_Condition-byte_7_condition: OK
                        Byte_Coding_Condition-byte_8_condition: OK
                        Byte_Coding_Condition-byte_9_condition: ERROR
    0006 - Antenna Amplifier 2 for Radio
              B126E 13 [009] - Open Circuit
                        Reset counter: 60
                        Mileage: 64773 km
                        Date: 2019.05.21
                        Time: 13:14:13
                        Voltage terminal 30: 14.5 V
                        Status of antenna 2 for radio-Antenna current: 0 mA
                        Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                        Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                        Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
       Component: MQB_MFK       H05 0051
       Serial number: 10000012457
       Coding: 0100000000020303000400000101010100
       ROD: EV_MFKBoschAU370.rod
       Component: SAS-GEN 2     H06 0013
       Serial number: 131024201128
    End-------------------------(Elapsed Time: 04:42)--------------------------
    Quote Originally Posted by webup View Post
    Look in your Scans sub-folder to see if perhaps you have a scan from it in stock condition?
    If not, see here.
  3. Likes Fredrick Awuor liked this post
